Elipse (pontos suspensivos) no final de um título é removida
Hello,
Most people use ... (dot dot dot) instead of (the proper ellipsis mark), but dots are automatically removed at the end of a title.
Would that be possible to implement a specific case so that “dot dot dot” in titles are no longer removed (or even better: automatically replaced by ellipsis) ?
Cheers
2 curtidas
While not specifically for an ellipsis, we do have the title prettify setting, which when disabled would allow for ... (it would also enable other things in titles like all caps and !!!! or ???? so you’d want to keep an eye out for bad titles)
You’d likely need a plugin if you wanted to check for ... and replace it with
Are you running into titles that should have an ellipsis quite often? Our reasoning was that there isn’t much of a difference between
I'm not sure how to write a good title...
and
7 curtidas
Thank you for your answer.
I agree that a full stop makes no difference at the end of a title (and is not used, as a general rule, at the end of titles, headings or captions).
Conversely, ellipsis has several meanings and will definitely make a difference if present:
I sell a bike, a pair of skis, (slightly weird, is there something missing? And why merging these two items in a single topic?)
I sell a bike, a pair of skis, ... (ok, probably selling all my sports gear, there are plenty of things and I write a single message for everything, that makes sense).
I think there are quite a lot of examples, where ellipsis has an unfinished thought meaning, where a title would completely lost its meaning if ellipsis is absent:
This software is not the most user friendly one, but
This software is not the most user friendly one, but...
To my point of view, it would clearly be an improvement to the actual title prettify settings to allow this specific punctuation.
4 curtidas
This will not be happening. If you want that odd case, disable the rule.
3 curtidas
i will rather tune it so that it behaves exactly the way i want.
Thanks for your help
1 curtida
Se ao final do título de uma nova postagem, o usuário adicionar três pontos ASCII, eles serão removidos silenciosamente, alterando o significado do título do usuário.
Ele pode nunca notar o que aconteceu.
1 curtida
Preferimos que os títulos sejam descritivos, portanto, terminar em reticências geralmente não é preferível.
Isso vem de title prettify:
E, apenas para observação, você tem uma tendência a se referir a todos os usuários como ‘ele’. Se você pudesse ser menos genérico/talvez não usar a terceira pessoa com tanta frequência, seria muito apreciado. :pray:
5 curtidas
Bem, acho que isso significará que todos teremos que usar este caractere Unicode “…” .
Mas estou dizendo que três pontos são diferentes de um ponto final extra acidental ou mesmo de dois pontos.
Caso contrário, você pode muito bem remover “?”, “!” e outra pontuação significativa.
2 curtidas
Acabei de ver este outro nos Tópicos Semelhantes, então vou combiná-los. :+1:
Encontrei isto hoje ao postar no nosso fórum interno.
Eu estava tentando argumentar que nosso produto usa excessivamente reticências com um título como:
Uso excessivo de…
O que se transformou em
Uso excessivo de
Repetidamente e repetidamente. :angry:
O que finalmente funcionou foi
Uso excessivo de . . . .
(Tive que usar 4 porque a última foi cortada automaticamente :melting_face:)
3 curtidas
Acho que para um uso ocasional você pode usar a solução alternativa do Jidanni e copiar e colar o caractere:
Embora, quando uso meu celular para criar um tópico e o título com Over-use of… (digitando os 3 pontos finais separadamente), ele também o converte em uma reticências funcional/visível. Não sei se todos os celulares fazem essa conversão, mas pode ser outra maneira de contornar a restrição.
Com certeza, a elipse não é um erro de digitação e é parte integrante de uma linguagem. Eu gostaria que a configuração “title prettify” não corrigisse isso, porque não é um erro… :wink:
1 curtida
