Hi!
On a new forum (50 topics atm), i see the similar topic box to be empty pretty often. I’m not sure what’s the algorithm for displaying that, but i think it should be hidden if there are no results, no?
Hi!
I noticed that earlier today on another instance of discourse. I agree - doesn’t seem like it should be displayed if there’s nothing there…
Not sure what’s happening but there is a check
The problem is easy to reproduce with these steps:
I can reproduce (almost) every time
edit: i even succeeded to reproduce on meta.discourse, but apparently it’s not every time, but only once in a while
Thanks, I have a repro. Will fix
I think this is fixed now? There used to be logic to prevent that from appearing until the number of topics was high enough to support it…
Not fixed yet. @eviltrout will have to have a look because I can’t figure out why it’s not hiding the popup when the code is right
