Encoding conversiefout van ASCII-8bit naar UTF-8 in logs
I’m seeing this warning in the logs, not sure where it’s coming from. Never seen it before, started after upgrading from 3.2.0 to 3.3.0.
It’s the sole warning around the timestamps, no other errors/warnings (initially thought it was email related, but not seeing any errors or bounced emails around the time).
Installed
3.3.0.beta2-dev
(777b8f6d51)
Message (4 copies reported)
RequestTracker.get_data failed : Encoding::UndefinedConversionError : "\xA1" from ASCII-8BIT to UTF-8
Backtrace
/var/www/discourse/lib/middleware/request_tracker.rb:190:in `encode'
/var/www/discourse/lib/middleware/request_tracker.rb:190:in `get_data'
/var/www/discourse/lib/middleware/request_tracker.rb:207:in `log_request_info'
/var/www/discourse/lib/middleware/request_tracker.rb:320:in `call'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.8.1/lib/rails/engine.rb:530:in `call'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.8.1/lib/rails/railtie.rb:226:in `public_send'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.8.1/lib/rails/railtie.rb:226:in `method_missing'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rack-2.2.9/lib/rack/urlmap.rb:74:in `block in call'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rack-2.2.9/lib/rack/urlmap.rb:58:in `each'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rack-2.2.9/lib/rack/urlmap.rb:58:in `call'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/unicorn-6.1.0/lib/unicorn/http_server.rb:634:in `process_client'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/unicorn-6.1.0/lib/unicorn/http_server.rb:739:in `worker_loop'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/unicorn-6.1.0/lib/unicorn/http_server.rb:547:in `spawn_missing_workers'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/unicorn-6.1.0/lib/unicorn/http_server.rb:143:in `start'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/unicorn-6.1.0/bin/unicorn:128:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/3.2.0/bin/unicorn:25:in `load'
/var/www/discourse/vendor/bundle/ruby/3.2.0/bin/unicorn:25:in `<main>'
There seems to be an issue with a specific web crawler; it should not affect you. :thinking:
Here, there is an issue with encoding the crawler user agent to UTF-8, as it contains an invalid byte.
scrub is supposed to do that. Maybe using :undef parameter can help here:
user_agent.encode("utf-8", :undef => :replace)
[51] pry(main)> string = "hello \xa1\x28world\x29".force_encoding("ASCII-8BIT")
=> "hello \xA1(world)"
[52] pry(main)> string.encode('utf-8')
Encoding::UndefinedConversionError: "\xA1" from ASCII-8BIT to UTF-8
from (pry):52:in `encode'
[53] pry(main)> string.encode('utf-8', :undef => :replace)
=> "hello �(world)"
Looks good, a PR ?
A fix has been merged. :+1:
https://github.com/discourse/discourse/pull/27181
Nice work! :clap: :smiley: :dragon:
This topic was automatically closed after 3 days. New replies are no longer allowed.
