Hi!
I have installed discourse and rebuilt it after changing a setting in the app.yml. When i went to load onto the site to set it up via IP:Port I get ‘ERR_CONNECTION_REFUSED’. The docker container seems to be running fine portainer shows Port:80 so I know the system has bound my custom port to port 80 on the container. My custom port is allowed through UFW so im not sure what is up. Does anyone have any ideas on how to fix this? If i try to connect through my subdomain(using the reverse proxy) I get 502 bad gateway.
Kian
