Error connecting to Redis on localhost:6379 (Errno::EADDRNOTAVAIL)
So if you remove your reverse proxy it works? Then the problem is the reverse proxy configuration :wink:
Yes!
@Falco I’ve finally found my solution! Tryed reverse proxying in HTTP with HAPROXY, NGINX, APACHE and everytime site was working but delete problem was there waiting for me.
Last night I gave a last try because I’d really like Discourse, so I told myself: go on, try with HTTPS, it will make no difference but why don’t give it a try before giving up?
Well, with HTTPS all works perfectly. For me it’s perfect this way, I’ll throw HTTP in the garbage bin :joy:
This are the relevant parts of Apache config:
<VirtualHost *:443>
    ServerName discourse.apicolturaitalianafb.it
	SSLEngine on
	SSLCertificateFile "/usr/local/ssl/crt/certificate.crt"
	SSLCertificateKeyFile "/usr/local/ssl/crt/private.key"
	SSLCertificateChainFile "/usr/local/ssl/crt/ca_bundle.crt"
   <Location />
        ProxyPreserveHost On
        RequestHeader set Host "discourse.apicolturaitalianafb.it:8443"
        ProxyPass http://discourse.apicolturaitalianafb.it:8880/
   </Location>
</VirtualHost>
and Discourse’s app.yml:
templates:
#  - "templates/web.socketed.template.yml"
  #- "templates/web.ssl.template.yml"
  #- "templates/web.letsencrypt.ssl.template.yml"
## which TCP/IP ports should this container expose?
## If you want Discourse to share a port with another webserver like Apache or nginx,
## see https://meta.discourse.org/t/17247 for details
expose:
  - "8880:80"   # http
#  - "8443:443" # https
It’s long past time! :wink:
Glad you got it sorted.
