Error following updates (S3 Backup Plugin)
A while ago I had an error during an update, so I tried to fix it with a git pull and rebuild etc.
The errors continue, and users have been reporting errors etc. This was the error in the latest attempt to update the Docker
Compressing: vendor.fc515a92f838bfb06405ac3186d67213-d190f217c498848c25a4048fe73ad56cbd28decf7b7eddf1b7ea34d79ee1ee6d.js
pnpm terser '/var/www/discourse/public/assets/_vendor.fc515a92f838bfb06405ac3186d67213-d190f217c498848c25a4048fe73ad56cbd28decf7b7eddf1b7ea34d79ee1ee6d.js' -m -c -o '/var/www/discourse/public/assets/vendor.fc515a92f838bfb06405ac3186d67213-d190f217c498848c25a4048fe73ad56cbd28decf7b7eddf1b7ea34d79ee1ee6d.js' --source-map "base='/var/www/discourse/public/assets',root='/assets',url='vendor.fc515a92f838bfb06405ac3186d67213-d190f217c498848c25a4048fe73ad56cbd28decf7b7eddf1b7ea34d79ee1ee6d.js.map',includeSources=true"
rake aborted!
Errno::ENOENT: No such file or directory @ rb_file_s_size - /var/www/discourse/public/assets/vendor.fc515a92f838bfb06405ac3186d67213-d190f217c498848c25a4048fe73ad56cbd28decf7b7eddf1b7ea34d79ee1ee6d.js (Errno::ENOENT)
/var/www/discourse/lib/tasks/assets.rake:297:in `size'
/var/www/discourse/lib/tasks/assets.rake:297:in `block (6 levels) in <main>'
/var/www/discourse/lib/tasks/assets.rake:250:in `log_task_duration'
/var/www/discourse/lib/tasks/assets.rake:289:in `block (5 levels) in <main>'
/var/www/discourse/lib/tasks/assets.rake:240:in `block in concurrent?'
/var/www/discourse/lib/tasks/assets.rake:288:in `block (4 levels) in <main>'
/var/www/discourse/lib/tasks/assets.rake:271:in `each'
/var/www/discourse/lib/tasks/assets.rake:271:in `block (3 levels) in <main>'
/var/www/discourse/lib/tasks/assets.rake:240:in `concurrent?'
/var/www/discourse/lib/tasks/assets.rake:267:in `block (2 levels) in <main>'
/var/www/discourse/lib/tasks/assets.rake:266:in `block in <main>'
/var/www/discourse/lib/tasks/assets.rake:332:in `block in <main>'
Tasks: TOP => assets:precompile:compress_js
Docker Manager: FAILED TO UPGRADE
#<RuntimeError: RuntimeError>
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:210:in `run'
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:111:in `upgrade'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:19:in `block in <main>'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:6:in `fork'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:6:in `<main>'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.1.4/lib/rails/commands/runner/runner_command.rb:41:in `load'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.1.4/lib/rails/commands/runner/runner_command.rb:41:in `block in perform'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.1.4/lib/active_support/execution_wrapper.rb:92:in `wrap'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.1.4/lib/rails/commands/runner/runner_command.rb:40:in `perform'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/thor-1.3.2/lib/thor/command.rb:28:in `run'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/thor-1.3.2/lib/thor/invocation.rb:127:in `invoke_command'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.1.4/lib/rails/command/base.rb:178:in `invoke_command'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/thor-1.3.2/lib/thor.rb:538:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.1.4/lib/rails/command/base.rb:73:in `perform'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.1.4/lib/rails/command.rb:71:in `block in invoke'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.1.4/lib/rails/command.rb:149:in `with_argv'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.1.4/lib/rails/command.rb:69:in `invoke'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.1.4/lib/rails/commands.rb:18:in `<main>'
/usr/local/lib/ruby/3.3.0/bundled_gems.rb:74:in `require'
/usr/local/lib/ruby/3.3.0/bundled_gems.rb:74:in `block (2 levels) in replace_require'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/bootsnap-1.18.4/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:30:in `require'
bin/rails:18:in `<main>'
The Error log also has entries referring to the same missing file etc
Any good way to fix this?
Do you have any custom plugins?
All plugins are credited to Discourse
Backup uploads to s3 is deprecated. It could be a problem.
Well it’s the only one that I can’t disable through the interface, and I can’t find it in the settings - do I need to delete it through the terminal?
Yes. You would comment it out in your yml file and then rebuild.
Have done so and another rebuild - error free.
Have asked the community to let me know if any issues come up but it looks like it is resolved.
Thank you!
