Fout bij het bewerken van het 2e bericht van een evenementonderwerp gemaakt door discourse-events
Hi,
i’m going through the process of adding a post to each topic that the discourse-events plugin created, and on a random topic, i got an “Internal Server Error”
this is retrievanble in the log
the edit has applied and i will disable the discourse-events plugin shortly
de site ging daarna in een buffertoestand totdat de tweede herlading
Hi Paul,
Sorry, but following the advice of Discourse Devs, i commented out Angus’s discourse-events plugin, but i also commented out Robert’s discourse-locations (since i didn’t find use for the location functionality, there’s no University calendar to test with)
Therefore, i won’t be able to help you diagnose the issue easily, because the unofficial plugin(s) isn’t on my only VPS now.
I hope you understand, and if you do, i’m really hoping to collect more votes on bringing the import functionality into Discourse Calendar (and Event) or event plugin, Feature Topic below:
https://meta.discourse.org/t/support-ical-feed-sync-in-discourse-calendar-plugin-import-from-ics-urls/376245
