Error on invitations page - "Cannot read properties of undefined (reading 'slice')"
On the latest stable version, I see a JavaScript error when I click the “Create invite link” button at /u/user_name/invited/pending.
The console shows:
Uncaught (in promise) TypeError: Cannot read properties of undefined (reading ‘slice’)
at h.shortKey (chunk.f105ceace2ad381ddb2f.d41d8cd9.js:241:61588)
If the invite object is rendered before invite_key is populated from the server, the invite_key is undefined and it crashes when using .slice() on nothing.
In invite.js, the shortKey function tries to shorten an invite key:
shortKey(key) {
return key.slice(0, 4) + “…”;
I can’t reproduce it on meta, so maybe I see it because my server or network isn’t as fast. But checking if the key exists before using it seems to resolve it:
return key ? key.slice(0, 4) + “…” : “”;
For a simple fix, is it better to post here or open a PR?
Invite key is not nullable though:
And this is iterating through model.invites:
I had a look at the code and I am not sure where partially populated code can come from, even when I added a 400ms delay on the network here I can not repro.
I think we need some sort of repro here prior to patching, that patch ends up letting people copy a broken invite link.
Thanks for looking into it and pointing that out.
Putting the delay in before_create should expose it.
I updated it to:
{{else}}
  {{icon "link"}}
+ {{#if invite.invite_key}}
    {{i18n
      "user.invited.invited_via_link"
      key=invite.shortKey
      count=invite.redemption_count
      max=invite.max_redemptions_allowed
+ {{else}}
+   <em>Generating link...</em>
+ {{/if}}
{{/if}}
I think this would be fine as a PR provided it is localized.
Still a bit confused about where we are populating Invite with a half full object, but it is better than failing and seems correct to me.
I wonder if it’s been fixed on latest. In that case, we just need to identify the commit which fixed it, and backport it to stable.
The invite is added to the list immediately after save() but before invite_key is populated from the server. It’s still present in latest, so I opened PR #35679
