ウェブインターフェース経由でのDiscourseのアップデートエラー
Cloudflareもプラグインも使っていません。何か原因がわかる方はいらっしゃいますか?
インストール済み:
2.6.0.beta5
メモリ 4GB
最後のエラーメッセージは以下の通りです:
メッセージ
ジョブ例外:タイムアウトが期限切れ
バックトレース
pg-1.2.3/lib/pg.rb:58:in `initialize’
pg-1.2.3/lib/pg.rb:58:in `new’
pg-1.2.3/lib/pg.rb:58:in `connect’
activerecord-6.0.3.3/lib/active_record/connection_adapters/postgresql_adapter.rb:46:in `postgresql_connection’
activerecord-6.0.3.3/lib/active_record/connection_adapters/abstract/connection_pool.rb:887:in `new_connection’
activerecord-6.0.3.3/lib/active_record/connection_adapters/abstract/connection_pool.rb:931:in `checkout_new_connection’
activerecord-6.0.3.3/lib/active_record/connection_adapters/abstract/connection_pool.rb:910:in `try_to_checkout_new_connection’
activerecord-6.0.3.3/lib/active_record/connection_adapters/abstract/connection_pool.rb:871:in `acquire_connection’
activerecord-6.0.3.3/lib/active_record/connection_adapters/abstract/connection_pool.rb:593:in `checkout’
activerecord-6.0.3.3/lib/active_record/connection_adapters/abstract/connection_pool.rb:437:in `connection’
activerecord-6.0.3.3/lib/active_record/connection_adapters/abstract/connection_pool.rb:1119:in `retrieve_connection’
activerecord-6.0.3.3/lib/active_record/connection_handling.rb:221:in `retrieve_connection’
activerecord-6.0.3.3/lib/active_record/connection_handling.rb:189:in `connection’
/var/www/discourse/lib/freedom_patches/fast_pluck.rb:61:in `pluck’
/var/www/discourse/lib/freedom_patches/pluck_first.rb:5:in `pluck_first’
/var/www/discourse/app/models/application_request.rb:75:in `req_id’
/var/www/discourse/app/models/application_request.rb:80:in `rescue in req_id’
/var/www/discourse/app/models/application_request.rb:70:in `req_id’
/var/www/discourse/app/models/application_request.rb:47:in `block in write_cache!’
/var/www/discourse/app/models/application_request.rb:42:in `each’
/var/www/discourse/app/models/application_request.rb:42:in `write_cache!’
/var/www/discourse/app/models/application_request.rb:33:in `write_cache!’
/var/www/discourse/app/models/concerns/cached_counting.rb:37:in `perform_increment!’
/var/www/discourse/app/models/application_request.rb:28:in `increment!’
/var/www/discourse/lib/middleware/request_tracker.rb:71:in `log_request’
/var/www/discourse/lib/middleware/request_tracker.rb:299:in `block in log_later’
/var/www/discourse/lib/scheduler/defer.rb:94:in `block in do_work’
rails_multisite-2.5.0/lib/rails_multisite/connection_management.rb:76:in `with_connection’
/var/www/discourse/lib/scheduler/defer.rb:89:in `do_work’
/var/www/discourse/lib/scheduler/defer.rb:79:in `block (2 levels) in start_thread’
この前のエラーメッセージが関連しているかどうかわかりません:
メッセージ
default: ホットリンクされた画像の取得に失敗しました (https://i.ytimg.com/vi/yPdIXXjM9z8/maxresdefault.jpg) post: 270 undefined method recompress_original_jpg_quality' for #<Class:0x00007f9235c81710> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3.3/lib/active_record/dynamic_matchers.rb:22:in method_missing’ /var/www/discourse/lib/upload_creator.rb:291:in should_alter_quality?' /var/www/discourse/lib/upload_creator.rb:59:in block in create_for’ /var/www/discourse/lib/distributed_mutex.rb:33:in block in synchronize' /var/www/discourse/lib/distributed_mutex.rb:29:in synchronize’ /var/www/discourse/lib/distributed_mutex.rb:29:in synchronize' /var/www/discourse/lib/distributed_mutex.rb:14:in synchronize’ /var/www/discourse/lib/upload_creator.rb:45:in create_for' /var/www/discourse/app/jobs/regular/pull_hotlinked_images.rb:132:in attempt_download’ /var/www/discourse/app/jobs/regular/pull_hotlinked_images.rb:42:in block in execute' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/nokogiri-1.10.10/lib/nokogiri/xml/node_set.rb:238:in block in each’ /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/nokogiri-1.10.10/lib/nokogiri/xml/node_set.rb:237:in upto' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/nokogiri-1.10.10/lib/nokogiri/xml/node_set.rb:237:in each’ /var/www/discourse/app/jobs/regular/pull_hotlinked_images.rb:32:in execute' /var/www/discourse/app/jobs/base.rb:232:in block (2 levels) in perform’ /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rails_multisite-2.5.0/lib/rails_multisite/connection_management.rb:76:in with_connection' /var/www/discourse/app/jobs/base.rb:221:in block in perform’ /var/www/discourse/app/jobs/base.rb:217:in each' /var/www/discourse/app/jobs/base.rb:217:in perform’ /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-6.1.2/lib/sidekiq/processor.rb:196:in execute_job' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sidekiq-6.1.2/lib/sidekiq/processor.rb:164:in block (2 levels) in process’ /var/www/discours…
バックトレース
/var/www/discourse/app/jobs/regular/pull_hotlinked_images.rb:232:in `public_send’
/var/www/discourse/app/jobs/regular/pull_hotlinked_images.rb:232:in `log’
/var/www/discourse/app/jobs/regular/pull_hotlinked_images.rb:56:in `rescue in block in execute’
/var/www/discourse/app/jobs/regular/pull_hotlinked_images.rb:33:in `block in execute’
nokogiri-1.10.10/lib/nokogiri/xml/node_set.rb:238:in `block in each’
nokogiri-1.10.10/lib/nokogiri/xml/node_set.rb:237:in `upto’
nokogiri-1.10.10/lib/nokogiri/xml/node_set.rb:237:in `each’
/var/www/discourse/app/jobs/regular/pull_hotlinked_images.rb:32:in `execute’
/var/www/discourse/app/jobs/base.rb:232:in `block (2 levels) in perform’
/var/www/discourse/app/jobs/base.rb:221:in `block in perform’
/var/www/discourse/app/jobs/base.rb:217:in `each’
/var/www/discourse/app/jobs/base.rb:217:in `perform’
sidekiq-6.1.2/lib/sidekiq/processor.rb:196:in `execute_job’
sidekiq-6.1.2/lib/sidekiq/processor.rb:164:in `block (2 levels) in process’
sidekiq-6.1.2/lib/sidekiq/middleware/chain.rb:138:in `block in invoke’
/var/www/discourse/lib/sidekiq/pausable.rb:138:in `call’
sidekiq-6.1.2/lib/sidekiq/middleware/chain.rb:140:in `block in invoke’
sidekiq-6.1.2/lib/sidekiq/middleware/chain.rb:143:in `invoke’
sidekiq-6.1.2/lib/sidekiq/processor.rb:163:in `block in process’
sidekiq-6.1.2/lib/sidekiq/processor.rb:136:in `block (6 levels) in dispatch’
sidekiq-6.1.2/lib/sidekiq/job_retry.rb:111:in `local’
sidekiq-6.1.2/lib/sidekiq/processor.rb:135:in `block (5 levels) in dispatch’
sidekiq-6.1.2/lib/sidekiq.rb:38:in `block in module:Sidekiq’
sidekiq-6.1.2/lib/sidekiq/processor.rb:131:in `block (4 levels) in dispatch’
sidekiq-6.1.2/lib/sidekiq/processor.rb:257:in `stats’
sidekiq-6.1.2/lib/sidekiq/processor.rb:126:in `block (3 levels) in dispatch’
sidekiq-6.1.2/lib/sidekiq/job_logger.rb:13:in `call’
sidekiq-6.1.2/lib/sidekiq/processor.rb:125:in `block (2 levels) in dispatch’
sidekiq-6.1.2/lib/sidekiq/job_retry.rb:78:in `global’
sidekiq-6.1.2/lib/sidekiq/processor.rb:124:in `block in dispatch’
sidekiq-6.1.2/lib/sidekiq/logger.rb:10:in `with’
sidekiq-6.1.2/lib/sidekiq/job_logger.rb:33:in `prepare’
sidekiq-6.1.2/lib/sidekiq/processor.rb:123:in `dispatch’
sidekiq-6.1.2/lib/sidekiq/processor.rb:162:in `process’
sidekiq-6.1.2/lib/sidekiq/processor.rb:78:in `process_one’
sidekiq-6.1.2/lib/sidekiq/processor.rb:68:in `run’
sidekiq-6.1.2/lib/sidekiq/util.rb:15:in `watchdog’
sidekiq-6.1.2/lib/sidekiq/util.rb:24:in `block in safe_thread’
コマンドラインからアップグレードしてみてください。
ありがとうございます、動作しました。Web インターフェースでは動作しなかった理由について、心当たりはありますか?
Webインターフェースではコンテナを停止できず、コンテナの更新も必要な場合があります。
わかりました。今後とも頭に入れておきます。
