Veel HTTP 502 en 429 na update naar 3.4.0.beta1-dev
User Crius reports experiencing frequent HTTP 502 (Bad Gateway) and 429 (Too Many Requests) errors after updating their Discourse instance from v3.2.1 to 3.4.0.beta1-dev. Despite following Cloudflare best practices and disabling minification, the issues persisted, including lagging real-time features like unread topic tracking. Server metrics showed no unusual load, but browser console logs confirmed client-side errors. Falco suspected PostgreSQL was overwhelmed despite idle RAM, prompting Crius to ask for tuning guidance. Sidekiq queues showed recurring failed jobs, but no clear root cause emerged. After no resolution, Crius downgraded to v3.2.5, which resolved all issues. This sparked debate with RGJ, who cautioned that downgrading from “tests-passed” to “stable” isn’t officially supported and warned of potential hidden configuration issues. Crius defended the downgrade, criticizing Discourse’s definition of “stable” and the community’s tone, arguing that users shouldn’t be blamed for relying on what’s labeled stable. Moin clarified that Discourse’s “stable” branch means known bugs, not necessarily fewer bugs than “tests-passed”. Crius confirmed v3.2.5 restored stability and advised future readers to consider downgrading if facing similar issues. The thread ended with RGJ reiterating that he offered help voluntarily and that the issue likely stemmed from configuration, not core Discourse bugs.
Discourse version: 3.4.0.beta1-dev (bf3d8a0a94)
Updated yesterday and had to disable minify from Cloudflare as suggested here:
However, since then, lots of users (me included) experimented several instances of 502 (Bad Gateway) and 529 (Too Many Requests).
In an attempt at trying to alleviate the problem, I followed this guide as well:
However, nothing seems to have changed in terms of frequency of those errors.
The update happened yesterday around 11AM. I performed a full rebuild because I wanted to disable a plugin as well.
I have a Prometheus+Grafana instance that monitor the server and discourse, but the server seems fine in terms of loading:
Discourse metrics (the drop in metrics around 11AM yesterday is the rebuild bringing down the container):
Again, I don’t see any strange pattern.
However, this is the browser console just a minute ago, after trying to send a PM to a user:
Anything else I might provide (logs of any kind) please ask away. Thank you.
Oh, if it helps, also lots of “background” real time operations are clearly lagging behind.
Topics already read are not registered as being read, for example.
Just to make sure, you did this step as well, then rebuilt, correct?
Yes, sorry, I forgot to add, I had already added the Cloudflare template to the app.yml file a long time ago. We have always been behind Cloudflare, since the very first day.
This is a partial of the app.yml, we have our own certificates independently renewed, which is why the letsencrypt one is commented out:
## this is the all-in-one, standalone Discourse Docker container template
## After making changes to this file, you MUST rebuild
## BE *VERY* CAREFUL WHEN EDITING!
## YAML FILES ARE SUPER SUPER SENSITIVE TO MISTAKES IN WHITESPACE OR ALIGNMENT!
## visit http://www.yamllint.com/ to validate this file as needed
templates:
  - "templates/web.ssl.template.yml"
#  - "templates/web.letsencrypt.ssl.template.yml"
  - "templates/cloudflare.template.yml"
## which TCP/IP ports should this container expose?
## If you want Discourse to share a port with another webserver like Apache or nginx,
## see https://meta.discourse.org/t/17247 for details
expose:
  - "80:80"   # http
  - "443:443" # https
Excerpt of the /logs
I see this moved to #installation, just to be clear, this is not a new installation.
This instance of discourse have been running since march 2023 and never had this specific problem.
There has been an issue in the past with some 529 but had been since resolved.
I think it still fits into
Looks like your PostgreSQL is overwhelmed. Looks like most of you RAM is idle, I´d try tweaking the DB to use it and see how things fare after that.
What does /sidekiq/queues look like?
What version where you updating from?
From the latest stable the 6th of May, v3.2.1 to the latest test-passed.
Sidekiq queues:
The Dead job section is this one but it’s the same job since the beginning of time it seems.
Oldest entries:
The ones in retry are the same job being retried over and over it seems.
But… why suddenly? After just an update of the application layer?
I am using the discourse prometheus exporter plugin.
If I added a postgresql exporter as another container on the VM, would it be possible to allow it to access the metrics on the discourse postgresql installation?
Any more precise direction about how to fine tune the db for discourse?
Not sure if related, but surely started happening after the update, clicking on the dismiss button in the unread tab always return a 503.
Well, as it seems like there isn’t a solution I’ll try to go back to the latest stable as it’s supposed to be… you know, stable.
Crossing finger that there isn’t a core dependency breaking the build process, like last time.
You can’t go back from tests-passed to stable, unless there is a higher stable version available. So the next opportunity for you is when 3.4.0 is out, I figure that’s around or after Christmas…
Besides, you’ll have to bite the bullet someday.
Well, I just did. Seems to be working. We don’t care anyway for any of the features in 3.3.0 anyway.
I’ll see if there are still issues. Worse it can get is that we still get a plethora of 429 and 502, not that big of a change.
I’d appreciate directions on how to configure the Postgres on discourse so it has more resources available, however.
Edit: Deployed version 3.2.5. System seems stable.
Please remind us that you did this when you’re posting your next issue :wink:
I always mention the version I am in when posting an issue.
I think it’s important to remember that exactly because this is presented as an open source software, critical issues should be considered instead of writing things like this:
This is yet another example of people going out of their way and switching to the “stable” version encountering some bugs that fall between the cracks because it’s a not the most popular version deployed.
When stable should mean “stable”, not “legacy”.
The fact that core dependencies like discourse docker are pushed without a tag system should be enough to be a bit more humble when responding to users that are reporting an issue.
I was talking about mentioning the fact that you downgraded when you technically couldn’t.
I think it’s important to remember… that I do not work for Discourse and I am helping you in my own time, so I do not appreciate your tone, nor am I able to do anything with your feedback.
