marianord
(Mariano Rodriguez)
1
Discourse インスタンスのバックアップで問題が発生しています。インスタンスは Backblaze の B2 へのアップロード用に設定されています。
エラーログ:
Making sure archive does not already exist...
Creating empty archive...
Archiving data dump...
Archiving uploads...
Skipping uploads stored on S3.
Removing tmp '/var/www/discourse/tmp/backups/default/2026-01-16-151337' directory...
Gzipping archive, this may take a while...
Uploading archive...
EXCEPTION: failed to abort multipart upload: SSL_read: unexpected eof while reading. Multipart upload failed: Checksum Type mismatch occurred, expected checksum type: CRC32, actual checksum type: null; Checksum Type mismatch occurred, expected checksum type: CRC32, actual checksum type: null; Checksum Type mismatch occurred, expected checksum type: CRC32, actual checksum type: null; Checksum Type mismatch occurred, expected checksum type: CRC32, actual checksum type: null; Checksum Type mismatch occurred, expected checksum type: CRC32, actual checksum type: null; Checksum Type mismatch occurred, expected checksum type: CRC32, actual checksum type: null; Checksum Type mismatch occurred, expected checksum type: CRC32, actual checksum type: null; Checksum Type mismatch occurred, expected checksum type: CRC32, actual checksum type: null; Checksum Type mismatch occurred, expected checksum type: CRC32, actual checksum type: null; Checksum Type mismatch occurred, expected checksum type: CRC32, actual checksum type: null
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/aws-sdk-s3-1.182.0/lib/aws-sdk-s3/multipart_file_uploader.rb:103:in `rescue in abort_upload'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/aws-sdk-s3-1.182.0/lib/aws-sdk-s3/multipart_file_uploader.rb:90:in `abort_upload'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/aws-sdk-s3-1.182.0/lib/aws-sdk-s3/multipart_file_uploader.rb:86:in `upload_parts'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/aws-sdk-s3-1.182.0/lib/aws-sdk-s3/multipart_file_uploader.rb:59:in `upload'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/aws-sdk-s3-1.182.0/lib/aws-sdk-s3/file_uploader.rb:42:in `block in upload'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/aws-sdk-core-3.227.0/lib/aws-sdk-core/plugins/user_agent.rb:90:in `metric'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/aws-sdk-s3-1.182.0/lib/aws-sdk-s3/file_uploader.rb:40:in `upload'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/aws-sdk-s3-1.182.0/lib/aws-sdk-s3/customizations/object.rb:477:in `block in upload_file'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/aws-sdk-s3-1.182.0/lib/aws-sdk-s3/customizations/object.rb:476:in `upload_file'
/var/www/discourse/lib/backup_restore/s3_backup_store.rb:48:in `upload_file'
/var/www/discourse/lib/backup_restore/backuper.rb:351:in `upload_archive'
/var/www/discourse/lib/backup_restore/backuper.rb:41:in `run'
script/discourse:115:in `backup'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/thor-1.4.0/lib/thor/command.rb:28:in `run'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/thor-1.4.0/lib/thor/invocation.rb:127:in `invoke_command'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/thor-1.4.0/lib/thor.rb:538:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/thor-1.4.0/lib/thor/base.rb:584:in `start'
script/discourse:397:in `\u003ctop (required)\u003e'
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.6.4/lib/bundler/cli/exec.rb:59:in `load'
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.6.4/lib/bundler/cli/exec.rb:59:in `kernel_load'
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.6.4/lib/bundler/cli/exec.rb:23:in `run'
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.6.4/lib/bundler/cli.rb:452:in `exec'
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.6.4/lib/bundler/vendor/thor/lib/thor/command.rb:28:in `run'
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.6.4/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.6.4/lib/bundler/vendor/thor/lib/thor.rb:538:in `dispatch'
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.6.4/lib/bundler/cli.rb:35:in `dispatch'
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.6.4/lib/bundler/vendor/thor/lib/thor/base.rb:584:in `start'
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.6.4/lib/bundler/cli.rb:29:in `start'
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.6.4/exe/bundle:28:in `block in \u003ctop (required)\u003e'
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.6.4/lib/bundler/friendly_errors.rb:117:in `with_friendly_errors'
/usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.6.4/exe/bundle:20:in `\u003ctop (required)\u003e'
/usr/local/bin/bundle:25:in `\u003cmain\u003e'
Deleting old backups...
Cleaning stuff up...
Removing archive from local storage...
Removing '.tar' leftovers...
Marking backup as finished...
Notifying 'system' of the end of the backup...
Finished!
[FAILED]
アップグレード後に動作しなくなったと仮定して、動作していたバージョン(最後に成功したバックアップのファイル名が分かると役立ちます)と現在のバージョンは分かりますか?
marianord
(Mariano Rodriguez)
5
古いファイルを探してみます。整理していて、確認する前に削除してしまいました
この v20251209012613 はすでに失敗していたことを知っています。いつから動作しなくなったかを確認するために、古いファイルを復元してみます。
バックラゼがクリーンインストールで動作するようになったばかりで、あなたの環境は古いバージョンのDiscourseのようです。スタックトレースのRubyのバージョンは3.3.0ですが、私の環境では3.4.0です。aws-sdk-coreとaws-sdk-s3 gemのバージョンは同じように見えるため、違いがあるかどうかはわかりませんが、指摘する価値はあると思いました。
marianord
(Mariano Rodriguez)
8
再試行しましたが、同じエラーが発生しました。
セットアップ:
AWS_REQUEST_CHECKSUM_CALCULATION: WHEN_REQUIRED
AWS_RESPONSE_CHECKSUM_VALIDATION: WHEN_REQUIRED
DISCOURSE_USE_S3: true
DISCOURSE_S3_REGION: "us-west-004"
DISCOURSE_S3_INSTALL_CORS_RULE: false
DISCOURSE_S3_CONFIGURE_TOMBSTONE_POLICY: false
DISCOURSE_S3_ENDPOINT: 'https://s3.us-west-004.backblazeb2.com'
DISCOURSE_S3_ACCESS_KEY_ID: '******'
DISCOURSE_S3_SECRET_ACCESS_KEY: '******'
DISCOURSE_S3_CDN_URL: 'https://******3.c******a.com'
DISCOURSE_S3_BUCKET: c******a
DISCOURSE_S3_BACKUP_BUCKET: 'c******a/backup'
DISCOURSE_S3_UPLOAD_BUCKET: 'c******a'
DISCOURSE_BACKUP_LOCATION: s3
スタックトレース:
アーカイブを Gzip 圧縮しています。しばらくかかる場合があります...
アーカイブをアップロードしています...
例外: マルチパートアップロードの中止に失敗しました: SSL_read: 読み取り中に予期しない eof。マルチパートアップロードに失敗しました: チェックサムタイプの不一致が発生しました。期待されるチェックサムタイプ: CRC32、実際のチェックサムタイプ: null; チェックサムタイプの不一致が発生しました。期待されるチェックサムタイプ: CRC32、実際のチェックサムタイプ: null; チェックサムタイプの不一致が発生しました。期待されるチェックサムタイプ: CRC32、実際のチェックサムタイプ: null; チェックサムタイプの不一致が発生しました。期待されるチェックサムタイプ: CRC32、実際のチェックサムタイプ: null; チェックサムタイプの不一致が発生しました。期待されるチェックサムタイプ: CRC32、実際のチェックサムタイプ: null; チェックサムタイプの不一致が発生しました。期待されるチェックサムタイプ: CRC32、実際のチェックサムタイプ: null; チェックサムタイプの不一致が発生しました。期待されるチェックサムタイプ: CRC32、実際のチェックサムタイプ: null; チェックサムタイプの不一致が発生しました。期待されるチェックサムタイプ: CRC32、実際のチェックサムタイプ: null; チェックサムタイプの不一致が発生しました。期待されるチェックサムタイプ: CRC32、実際のチェックサムタイプ: null; チェックサムタイプの不一致が発生しました。期待されるチェックサムタイプ: CRC32、実際のチェックサムタイプ: null
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/aws-sdk-s3-1.182.0/lib/aws-sdk-s3/multipart_file_uploader.rb:103:in 'Aws::S3::MultipartFileUploader#abort_upload'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/aws-sdk-s3-1.182.0/lib/aws-sdk-s3/multipart_file_uploader.rb:86:in 'Aws::S3::MultipartFileUploader#upload_parts'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/aws-sdk-s3-1.182.0/lib/aws-sdk-s3/multipart_file_uploader.rb:59:in 'Aws::S3::MultipartFileUploader#upload'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/aws-sdk-s3-1.182.0/lib/aws-sdk-s3/file_uploader.rb:42:in 'block in Aws::S3::FileUploader#upload'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/aws-sdk-core-3.227.0/lib/aws-sdk-core/plugins/user_agent.rb:90:in 'Aws::Plugins::UserAgent.metric'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/aws-sdk-s3-1.182.0/lib/aws-sdk-s3/file_uploader.rb:40:in 'Aws::S3::FileUploader#upload'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/aws-sdk-s3-1.182.0/lib/aws-sdk-s3/customizations/object.rb:477:in 'block in Aws::S3::Object#upload_file'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/aws-sdk-s3-1.182.0/lib/aws-sdk-s3/customizations/object.rb:476:in 'Aws::S3::Object#upload_file'
/var/www/discourse/lib/backup_restore/s3_backup_store.rb:48:in 'BackupRestore::S3BackupStore#upload_file'
/var/www/discourse/lib/backup_restore/creator.rb:434:in 'BackupRestore::Creator#upload_archive'
/var/www/discourse/lib/backup_restore/creator.rb:41:in 'BackupRestore::Creator#run'
script/discourse:115:in 'DiscourseCLI#backup'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/thor-1.4.0/lib/thor/command.rb:28:in 'Thor::Command#run'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/thor-1.4.0/lib/thor/invocation.rb:127:in 'Thor::Invocation#invoke_command'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/thor-1.4.0/lib/thor.rb:538:in 'Thor.dispatch'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/thor-1.4.0/lib/thor/base.rb:584:in 'Thor::Base::ClassMethods#start'
script/discourse:397:in '<top (required)>'
/usr/local/lib/ruby/gems/3.4.0/gems/bundler-2.6.4/lib/bundler/cli/exec.rb:59:in 'Kernel.load'
/usr/local/lib/ruby/gems/3.4.0/gems/bundler-2.6.4/lib/bundler/cli/exec.rb:59:in 'Bundler::CLI::Exec#kernel_load'
/usr/local/lib/ruby/gems/3.4.0/gems/bundler-2.6.4/lib/bundler/cli/exec.rb:23:in 'Bundler::CLI::Exec#run'
/usr/local/lib/ruby/gems/3.4.0/gems/bundler-2.6.4/lib/bundler/cli.rb:452:in 'Bundler::CLI#exec'
/usr/local/lib/ruby/gems/3.4.0/gems/bundler-2.6.4/lib/bundler/vendor/thor/lib/thor/command.rb:28:in 'Bundler::Thor::Command#run'
/usr/local/lib/ruby/gems/3.4.0/gems/bundler-2.6.4/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in 'Bundler::Thor::Invocation#invoke_command'
/usr/local/lib/ruby/gems/3.4.0/gems/bundler-2.6.4/lib/bundler/vendor/thor/lib/thor.rb:538:in 'Bundler::Thor.dispatch'
/usr/local/lib/ruby/gems/3.4.0/gems/bundler-2.6.4/lib/bundler/cli.rb:35:in 'Bundler::CLI.dispatch'
/usr/local/lib/ruby/gems/3.4.0/gems/bundler-2.6.4/lib/bundler/vendor/thor/lib/thor/base.rb:584:in 'Bundler::Thor::Base::ClassMethods#start'
/usr/local/lib/ruby/gems/3.4.0/gems/bundler-2.6.4/lib/bundler/cli.rb:29:in 'Bundler::CLI.start'
/usr/local/lib/ruby/gems/3.4.0/gems/bundler-2.6.4/exe/bundle:28:in 'block in <top (required)>'
/usr/local/lib/ruby/gems/3.4.0/gems/bundler-2.6.4/lib/bundler/friendly_errors.rb:117:in 'Bundler.with_friendly_errors'
/usr/local/lib/ruby/gems/3.4.0/gems/bundler-2.6.4/exe/bundle:20:in '<top (required)>'
/usr/local/bin/bundle:25:in 'Kernel#load'
/usr/local/bin/bundle:25:in '<main>'
古いバックアップを削除しています...
後処理をしています...
ローカルストレージからアーカイブを削除しています...
'.tar' の残り物を削除しています...
バックアップが完了したことをマークしています...
バックアップ終了を 'system' に通知しています...
完了しました!
[失敗]
ええ、私のセットアップには AWS_*_CHECKSUM_CALCULATION の設定がなく、あなたのセットアップではここでエラーが発生しているようです。B2でその機能がサポートされていないというスレッドがありますが、最近実装されたようですが、実際に機能するかどうかはわかりません。
「いいね!」 1
marianord
(Mariano Rodriguez)
10
OK、これでうまくいきました。
完了しました!
[成功]
バックアップが完了しました。
出力ファイルはS3に保存されています
「いいね!」 2
system
(system)
クローズされました:
11
