Error using {{didInsert}} in a connector component: “Class constructor DidInsertModifier cannot be invoked without 'new'”
A user is encountering a TypeError when using the {{didInsert}} modifier in a connector component for a custom theme. The error, Class constructor DidInsertModifier cannot be invoked without 'new', occurs when the modifier is used in the template. The user is trying to run DOM logic after render by attaching {{didInsert this.modifyElement}} to a component. A reply suggests that the template syntax might be incomplete, as the modifier should be applied to an element like <div {{didInsert this.modifyElement}}> rather than used standalone. jahan_gagan david
Hi team,
I’m working on a custom theme component and trying to use a connector component via the plugin outlet kanban-card-bottom. Inside that connector component, I want to run DOM logic after render using the {{didInsert}} modifier.
However, as soon as I add {{didInsert this.modifyElement}} in the template, I get the following error in the browser console:
Uncaught (in promise) TypeError: Class constructor DidInsertModifier cannot be invoked without 'new'
    at FunctionHelperManager.getValue (index.js:214:86)
My component setup:
// javascripts/discourse/connectors/kanban-card-bottom/replace-last-post-by.gjs
import Component from "@glimmer/component";
import { action } from "@ember/object";
import didInsert from "@ember/render-modifiers/modifiers/did-insert";
export default class ReplaceLastPostBy extends Component {
  @action
  modifyElement(element) {
    console.log("Element ====> ", element);
  <template>
  </template>
Goal:
I simply want to target a DOM element after render from this connector component (e.g., replace a username visually).
Any insights would be appreciated!
Error Screenshot
Thanks,
It looks like there’s some code missing from your example? I’d expect to see a <template> / </template>, and for the modifier to be attached to an element like
<template>
  </div>
</template>
