Error when running plugin specs
I’m getting this on two dev instances when trying to run plugin specs on latest.
(database has been rully migrated in the test environment):
e.g bin/rake plugin:spec\[discourse-locations]
An error occurred while loading rails_helper.
Failure/Error: default_scope { where(deleted_at: nil) }
ActiveRecord::StatementInvalid:
  PG::UndefinedTable: ERROR:  relation "chat_channels" does not exist
  LINE 9:  WHERE a.attrelid = '"chat_channels"'::regclass
< SNIP >
# --- Caused by: ---
# PG::UndefinedTable:
#   ERROR:  relation "chat_channels" does not exist
#   LINE 9:  WHERE a.attrelid = '"chat_channels"'::regclass
Looking at the test database, the chat migrations appear not to have run.
> psql discourse_test
# \d
Oh …!
I forgot to add the first environment variable to include plugins with this db migration (because chat is still a plugin):
LOAD_PLUGINS=1 RAILS_ENV=test rake db:migrate
