I’ve done a bulk import, and I’m now getting a strange error whenever any user tries to like a post. It gives a popup saying “Sorry, an error has occurred”
In the error log, I see this but I don’t know what the issue is:
create_errors_json called with unrecognized type: #<PostActionCreator::CreateResult:0x00007fa749976830 @success=false, @errors=#<ActiveModel::Errors:0x00007fa73e7c46c8 @base=#<PostActionCreator::CreateResult:0x00007fa749976830 ...>, @messages={}, @details={}>>
/var/www/discourse/lib/json_error.rb:38:in `create_errors_array'
/var/www/discourse/lib/json_error.rb:8:in `create_errors_json'
/var/www/discourse/app/controllers/application_controller.rb:641:in `render_json_error'
/var/www/discourse/app/controllers/post_actions_controller.rb:25:in `create'
actionpack-6.0.3.5/lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
actionpack-6.0.3.5/lib/abstract_controller/base.rb:195:in `process_action'
actionpack-6.0.3.5/lib/action_controller/metal/rendering.rb:30:in `process_action'
actionpack-6.0.3.5/lib/abstract_controller/callbacks.rb:42:in `block in process_action'
activesupport-6.0.3.5/lib/active_support/callbacks.rb:112:in `block in run_callbacks'
/var/www/discourse/app/controllers/application_controller.rb:363:in `block in with_resolved_locale'
i18n-1.8.10/lib/i18n.rb:314:in `with_locale'
/var/www/discourse/app/controllers/application_controller.rb:363:in `with_resolved_locale'
activesupport-6.0.3.5/lib/active_support/callbacks.rb:121:in `block in run_callbacks'
activesupport-6.0.3.5/lib/active_support/callbacks.rb:139:in `run_callbacks'
actionpack-6.0.3.5/lib/abstract_controller/callbacks.rb:41:in `process_action'
actionpack-6.0.3.5/lib/action_controller/metal/rescue.rb:22:in `process_action'
actionpack-6.0.3.5/lib/action_controller/metal/instrumentation.rb:33:in `block in process_action'
activesupport-6.0.3.5/lib/active_support/notifications.rb:180:in `block in instrument'
activesupport-6.0.3.5/lib/active_support/notifications/instrumenter.rb:24:in `instrument'
activesupport-6.0.3.5/lib/active_support/notifications.rb:180:in `instrument'
actionpack-6.0.3.5/lib/action_controller/metal/instrumentation.rb:32:in `process_action'
actionpack-6.0.3.5/lib/action_controller/metal/params_wrapper.rb:245:in `process_action'
activerecord-6.0.3.5/lib/active_record/railties/controller_runtime.rb:27:in `process_action'
actionpack-6.0.3.5/lib/abstract_controller/base.rb:136:in `process'
actionview-6.0.3.5/lib/action_view/rendering.rb:39:in `process'
rack-mini-profiler-2.3.1/lib/mini_profiler/profiling_methods.rb:85:in `block in profile_method'
actionpack-6.0.3.5/lib/action_controller/metal.rb:190:in `dispatch'
actionpack-6.0.3.5/lib/action_controller/metal.rb:254:in `dispatch'
actionpack-6.0.3.5/lib/action_dispatch/routing/route_set.rb:50:in `dispatch'
actionpack-6.0.3.5/lib/action_dispatch/routing/route_set.rb:33:in `serve'
actionpack-6.0.3.5/lib/action_dispatch/journey/router.rb:49:in `block in serve'
actionpack-6.0.3.5/lib/action_dispatch/journey/router.rb:32:in `each'
actionpack-6.0.3.5/lib/action_dispatch/journey/router.rb:32:in `serve'
actionpack-6.0.3.5/lib/action_dispatch/routing/route_set.rb:834:in `call'
/var/www/discourse/lib/middleware/omniauth_bypass_middleware.rb:71:in `call'
rack-2.2.3/lib/rack/tempfile_reaper.rb:15:in `call'
rack-2.2.3/lib/rack/conditional_get.rb:40:in `call'
rack-2.2.3/lib/rack/head.rb:12:in `call'
/var/www/discourse/lib/content_security_policy/middleware.rb:12:in `call'
/var/www/discourse/lib/middleware/anonymous_cache.rb:355:in `call'
rack-2.2.3/lib/rack/session/abstract/id.rb:266:in `context'
rack-2.2.3/lib/rack/session/abstract/id.rb:260:in `call'
actionpack-6.0.3.5/lib/action_dispatch/middleware/cookies.rb:648:in `call'
actionpack-6.0.3.5/lib/action_dispatch/middleware/callbacks.rb:27:in `block in call'
activesupport-6.0.3.5/lib/active_support/callbacks.rb:101:in `run_callbacks'
actionpack-6.0.3.5/lib/action_dispatch/middleware/callbacks.rb:26:in `call'
actionpack-6.0.3.5/lib/action_dispatch/middleware/actionable_exceptions.rb:18:in `call'
actionpack-6.0.3.5/lib/action_dispatch/middleware/debug_exceptions.rb:32:in `call'
actionpack-6.0.3.5/lib/action_dispatch/middleware/show_exceptions.rb:33:in `call'
logster-2.9.6/lib/logster/middleware/reporter.rb:43:in `call'
railties-6.0.3.5/lib/rails/rack/logger.rb:37:in `call_app'
railties-6.0.3.5/lib/rails/rack/logger.rb:28:in `call'
/var/www/discourse/config/initializers/100-quiet_logger.rb:23:in `call'
/var/www/discourse/config/initializers/100-silence_logger.rb:31:in `call'
actionpack-6.0.3.5/lib/action_dispatch/middleware/remote_ip.rb:81:in `call'
actionpack-6.0.3.5/lib/action_dispatch/middleware/request_id.rb:27:in `call'
/var/www/discourse/lib/middleware/enforce_hostname.rb:23:in `call'
rack-2.2.3/lib/rack/method_override.rb:24:in `call'
actionpack-6.0.3.5/lib/action_dispatch/middleware/executor.rb:14:in `call'
rack-2.2.3/lib/rack/sendfile.rb:110:in `call'
actionpack-6.0.3.5/lib/action_dispatch/middleware/host_authorization.rb:76:in `call'
rack-mini-profiler-2.3.1/lib/mini_profiler/profiler.rb:248:in `call'
message_bus-3.3.4/lib/message_bus/rack/middleware.rb:61:in `call'
/var/www/discourse/lib/middleware/request_tracker.rb:177:in `call'
railties-6.0.3.5/lib/rails/engine.rb:527:in `call'
railties-6.0.3.5/lib/rails/railtie.rb:190:in `public_send'
railties-6.0.3.5/lib/rails/railtie.rb:190:in `method_missing'
rack-2.2.3/lib/rack/urlmap.rb:74:in `block in call'
rack-2.2.3/lib/rack/urlmap.rb:58:in `each'
rack-2.2.3/lib/rack/urlmap.rb:58:in `call'
unicorn-6.0.0/lib/unicorn/http_server.rb:634:in `process_client'
unicorn-6.0.0/lib/unicorn/http_server.rb:732:in `worker_loop'
unicorn-6.0.0/lib/unicorn/http_server.rb:547:in `spawn_missing_workers'
unicorn-6.0.0/lib/unicorn/http_server.rb:143:in `start'
unicorn-6.0.0/bin/unicorn:128:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/bin/unicorn:23:in `load'
/var/www/discourse/vendor/bundle/ruby/2.7.0/bin/unicorn:23:in `<main>'
This is what appears in production.log:
Started POST "/post_actions" for 172.70.38.225 at 2021-04-11 17:53:40 +0000
Processing by PostActionsController#create as */*
Parameters: {"id"=>"10827773", "post_action_type_id"=>"2", "flag_topic"=>"false"}
create_errors_json called with unrecognized type: #<PostActionCreator::CreateResult:0x00007f6c0d6872b8 @success=false, @errors=#<ActiveModel::Errors:0x00007f6c0e3a0a58 @base=#<PostActionCreator::CreateResult:0x00007f6c0d6872b8 ...>, @messages={}, @details={}>>
Completed 422 Unprocessable Entity in 41ms (Views: 0.1ms | ActiveRecord: 0.0ms | Allocations: 8930)
Here’s what I’ve done so far:
- Run import:ensure_consistency rake task
- VACUUM VERBOSE ANALYZE
- Rebuild the container
- Tested with multiple users and multiple topics
Any ideas what could be wrong here?
