đź“… Event Location/Description
You can now add a location and a description to an event.
The location is a mono-line text field (supports auto-linking) which will be displayed with a location pin icon:
Screenshot 2025-06-25 at 10.23.21
The description is a multiline text field (supports auto-linking + line breaks) which will be displayed at the end of the event with no icon:
Info:
This is brilliant, and a much more flexible and high value use of the existing fields - it is also consistent with how most email calendars handle their events.
Would now be a good time to remove the Minimal Event option?
Is there any interest in extending “Location” to include pre-defined/centrally managed locations and, ultimately, room management? E.g. a “room” can only have 1 event occurring in it within a given period of time, so sort of room “reservation”, etc? This would be a huge feature for enabling conferences, but also potentially managing events for real-world communities with associated spaces.
While this is a real step forward, the Location field is not being passed through via the .ics or Google Calendar (i.e. a regression)
Location list would be great indeed. Maybe for the moment you may use the calendar feature and make a parent category for the location, then a sub category for each room. All the reservations would be topic created with an event in it and will appear on the category calendar of this category(room). One drawback is the event system does not take concurrent event into account however if you are in a community with a bit of receptivity you may ask to check if there is already a reservation at this time before and after the reservation is created.
Now that I know Discourse uses FullCalendar and that FullCalendar supports what I understand to be full Resource (e.g. “Room”/location) management this idea seems even more obvious to implement. It seems like it would just be a matter of hooking up to the existing Resource handling plugin (GPL compatible for redistribution) and adding some simple conflict checking on event creation.
Pour la gestion “Salle”/lieu, il faudra peut être penser à ajouter des filtres de recherche d évènement par lieu avec notion de places disponible ou complet a fin de faciliter le choix de l’évènement
