That absolutely worked! Thank you, you are a discourse god! Just need to check each category and re-apply as needed.
, but⊠far from it
Iâve quite recently discovered this very impressive work and like it very much (and also the work of the team of Pavilion - Building online communities. )
Just a note that the FA icon calendar needs to be updated to use calendar-alt and calendar-plus-o with far-calendar-plus
What does this setting do?
events event label no text
â No text on add event buttons.
I was testing adding an event to a topic and now I canât figure out how to manually remove the event date and time. Can someone tell me how to remove the date/time so this topic is no longer an event?
You have to edit the title of the topic then the event and you should find âdeleteâ at the bottom of the modal
I found it! Thank you good sir!
For some reason iâm getting a 500 error though
(Could it have something to do with the fact that I added an event time/date, when it was in a different category⊠and i moved it to the current category, where i just tried to delete it.)
Hereâs what just happened:
WellâŠ
âŠ
Looks like a small regression, it doesnât work here either âŠ
Weird
Hi @angus @fzngagan, I try to report it at Pavilion but iâm not sure if the wizard is working
it cycles here :
2.5.0.beta2 and latest commit of events, I have that in the log :
Message (2 copies reported)
NoMethodError (undefined method
[]' for nil:NilClass) /var/www/discourse/plugins/discourse-events/plugin.rb:274:inblock (2 levels) in activate!âBacktrace
block (2 levels) in activate!' /var/www/discourse/lib/post_revisor.rb:441:inblock (2 levels) in update_topicâ
/var/www/discourse/lib/post_revisor.rb:439:ineach' /var/www/discourse/lib/post_revisor.rb:439:inblock in update_topicâ
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/connection_adapters/abstract/database_statements.rb:279:intransaction' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/transactions.rb:212:intransactionâ
/var/www/discourse/lib/post_revisor.rb:438:inupdate_topic' /var/www/discourse/lib/post_revisor.rb:338:inreviseâ
/var/www/discourse/lib/post_revisor.rb:331:inrevise_and_create_new_version' /var/www/discourse/lib/post_revisor.rb:236:inrevise_postâ
@Benjamin_D Thanks for the report. That wizard will work again now. @jord8on Iâve also fixed the events issue.
cc @fzngagan see FIX: event removal · angusmcleod/discourse-events@a5340f6 · GitHub
All good on my end, now! Thanks for the quick fix!!
Hello!
Does this plugin automatically generate the json+ld tags (or other meta tags) that allow google and other search engines to parse the event data on each post?
Has anyone tried adding a Subscribe button to their agenda view?
Itâs strange, but this doesnât work for me.
I have events enabled in admin:
I created a new category and set âallow eventsâ there too:
I created a test post. Then I edited it and I do not see any âadd to calendarâ button (except for the default Discourse date icon)
It doesnât yet. But its a good suggestion. Can you add a feature request here?
https://thepavilion.io/w/feature-request/steps/step_1
Hi,
I am unable to edit an event once posted in the edit topic window.
Please help
Facing the same issue on sandbox as well here: test Topic event - Sandbox - Pavilion
Have you tried editing the thread title as opposed to the first post?
i.e. click on the pencil next to the title of the post.
It should give you access to the event plugin details.
You werenât the first, and you wonât be the last.
I find it counter-intuitive if Iâm honest but I can see the technical rationale behind it.
Is there an issue with the plugin at the moment? I have installed the plugin and made sure it was ticked in the plugin settings but it doesnât show up when I create a new topic.
All of my other plugins are issue free
In the same boat as this guy
