Everyone permissions + "See" permissions
סיכום מבוסס בינה מלאכותית
The discussion revolves around the limitations of Discourse’s permission system, particularly the inability to exclude a specific group from accessing a category. outofthebox wants to restrict a group of users from participating in a public category while allowing other registered members to participate. robmc explains that this is not possible with the current permission system, as it only allows for inclusion, not exclusion.
Stephen suggests that instead of trying to exclude a group, it might be more practical to identify and group the users who should have access and grant them explicit permissions. However, outofthebox finds this approach too complicated and decides to ask the restricted group to refrain from participating in the main categories.
hellekin provides additional context on group permissions and suggests that creating a complex group hierarchy could achieve the desired outcome, but this approach is considered too complicated.
D8vid shares a use case where the ability to exclude a group from access would be useful, specifically in a fan community where members want to opt-out of seeing topics that may contain spoilers.
Overall, the discussion highlights the limitations of Discourse’s permission system and the need for creative workarounds to achieve specific access control scenarios.
Hi,
Our Discourse community has a public area that any registered member can participate in. However, I would like to be able to add some members to a group that effectively Silences them from that particular category. However, they would be able to participate in other Categories. What permissions in the Security tab need to be enabled to make it possible to restrict members of one group from creating/replying in a Category while allowing every other registered member to participate?
It is not possible to use security to “Exclude” a group of users, only to “Include”, so to achieve this you would need to create a group that would include all users except for the group you do not want to have access.
See these previous topics:
Since @robmc mentioned this topic in Everyone permissions + "See" permissions - #2 by robmc, let me add a resource to this discussion from Caucus groups:
The standard access levels are:
Keyword Value Description
organizer 40 Full management powers for whatever the group is used in
instructor 30 (limited organizer powers)
include 20
readonly 10
exclude 0 No access
inherit -1 Inherit actual access level from subgroup
So that means you can actually put groups in groups, and exclude groups from certain things, creating a complex – or complicated – way to look at things. IMO this is a bit too fancy, and group exclusion should be enough: THIS permissions if IN GROUP X BUT NOT IN GROUP Y.
Discourse denies by default, with explicit permissions to see, reply and create. You can achieve pretty much any outcome if users are grouped by role or purpose.
Rather than talking about silencing users, tell us what differentiates the two groups:
  • How are they arriving on your system?
  • How are they identified?
  • Do you use SSO or any form of idm?
If you’re able to identify this group to silence, is it any less practical to have a ‘see’ by default and instead identify and group the users you want to create and respond?
I think the issue is that one or more users are in one or more groups that intersect.
Sure, so they aren’t the groups which grant that right. If there’s a need for a different security partition there’s a need for a different group.
Hi Robert,
Thanks for the quick answer. It looks like this is not supported, which is fine. All software has limits.
You did mention:
Is there a way, in the core functionality of Discourse, to do this? Or is this plugin territory?
There’s no native way to maintain a group with all users except for those in another group within Discourse, but as you didn’t answer the questions asked above you might end up baking something yourself, or have to do it the old-fashioned way.
Hi Stephen,
Interesting questions. It would be a pretty substantial change to limit our main forum to ‘see’ only, and then to identify and group the users who can create and respond. I think the simplest answer, given that this isn’t how Discourse works, is to simply ask this small group of users to refrain from participating in the main categories.
Without knowing more yes, it probably is.
Without knowing the criteria to be a member of either group, we can’t really help you with any technology-based solutions.
I’ve been reading many topics on this issue, and have a use case where the ability to exclude a group from access (e.g. to a category) would be most useful, in this fashion:
The use case is a Discourse instance dedicated to a fan community (for a multi-book & multi-season TV production) where ‘spoilers’ are an issue; members would like the ability to opt-out of seeing topics belonging to categories that are likely to contain spoilers.
