3cz
(3cz)
Avril 14, 2019, 3:38
1
I got this information after my configuration completed.
“You are not connected to Discourse. If you are setting up the plugin, this notice should go away after completing the form on this page.”
I checked everything and didn’t find the solution, I can accessed the rest url via Curl command in the host server, both Wordpress and Discourse.
Any configuration is normal in my Wordpress except I changed the plugin path via wp-config.php like this:
if ( !defined(‘ABSPATH’) )
define(‘ABSPATH’, dirname(FILE ) . ‘/’);
define (‘WP_CONTENT_FOLDERNAME’, ‘func’);
define (‘WP_CONTENT_DIR’, ABSPATH . WP_CONTENT_FOLDERNAME);
define(‘WP_SITEURL’, ‘https://’ . $_SERVER[‘HTTP_HOST’] . ‘/’);
define(‘WP_CONTENT_URL’, WP_SITEURL . WP_CONTENT_FOLDERNAME);
I am not sure if this configuration caused the issue.
3cz
(3cz)
Avril 14, 2019, 5:51
I get this error for a testing which I post this link: https://www.Mysite.com/api/wp-discourse/v1/update-topic-content
And as you see, I rewrite the path from “wp-json” to “api”.
"code": "rest_no_route",
"message": "未找到匹配URL和请求方式的路由",
"data": {
"status": 404
simon
Avril 14, 2019, 6:47
3
That route requires an authenticated POST request. It is meant to be used by Discourse webhooks. It looks like you are getting the correct response.
This happens when a 200 response is not returned from a request made to Discourse with the Publishing Username and API Key that you have set. Are you using the All Users API key from Discourse?
3 « J'aime »
3cz
(3cz)
Avril 14, 2019, 2:11
4
Hi Simon,
I got an mail notification and find this “cURL error 60: SSL certificate problem: unable to get local issuer certificate”
so I changed my ssl configuration from DigiCert Global Root CA to let’s Encrpyt, now the connecting is fine.
Thx.
3 « J'aime »
system
(system)
A fermé ce sujet ()
Mai 14, 2019, 2:24
5
