I’m trying to migrate my server to a new host, so I downloaded a backup file, and uploaded it to the new host. Installed a fresh copy of discourse, and followed the instructions to do so from the command line:
Unfortunately, the discourse restore databasename fails with:
ALTER TABLE
ALTER TABLE
ALTER TABLE
ERROR: could not create unique index "posts_search_pkey"
DETAIL: Key (post_id)=(36946) is duplicated.
EXCEPTION: psql failed: DETAIL: Key (post_id)=(36946) is duplicated.
/var/www/discourse/lib/backup_restore/database_restorer.rb:92:in `restore_dump'
/var/www/discourse/lib/backup_restore/database_restorer.rb:26:in `restore'
/var/www/discourse/lib/backup_restore/restorer.rb:51:in `run'
script/discourse:149:in `restore'
Seems there’s something wrong with the database file? Can someone give me some direction on how I can fix this error? I still have access to the original server, which seems to be running fine.
Is there some sql command or something I can run that will analyze (and fix?) the database before I download a backup?
./launcher enter app
su - postges
psql discourse
select id from post_search_data were post_id>86918 and post_id<86921;
--- when you get the id ----
delete from post_search_data where id=ID_FROM_LAST_QUERY
There could be more.
Perhaps someone else can provide more help but that’s about all I think I can do without being logged in to your server. If you need much more help, you can post in #marketplace or contact me directly.
Or perhaps it’s safe to just wipe it away and have it get regenerated, but I’m not quite sure about that.
discourse=# reindex index concurrently "posts_search_pkey";
ERROR: could not create unique index "posts_search_pkey_ccnew2"
DETAIL: Key (post_id)=(116038) is duplicated.
discourse=# delete from post_search_data
where post_id = 116038;
DELETE 2
DELETE 0
ERROR: could not create unique index "posts_search_pkey_ccnew3"
DETAIL: Key (post_id)=(9336) is duplicated.
where post_id = 9336;
DELETE 1
REINDEX
Once everything seemed ok, I did a full backup and restored it on a new server with no issues.
I appreciate everyone’s time. I love discourse!
Lesson learned: check backups once in a while to be sure they’re good I keep daily backups, and then keep monthly “snapshots” too. The earliest backup I had that didn’t have a corrupted database was 4 months old
