Exclude staff from statistics
Hi everyone!
I’ve checked out another topic where this issue was discussed, but it seems there is no solution yet, right?
  • Maybe I’m missing something and there is a way to exclude staff from the statistics (topics created, posts created, etc.)?
  • Also, it seems Replies section includes not only replies themselves, but all the actions on the whole (‘made this topic public’, ‘assigned this topic’, hidden replies, etc.) - is there an option to track replies only?
You can use the data explorer plugin to generate such statistics, though I don’t see any built-in queries that do that.
Mostly, if your community is new enough that staff actions are a sizable amount of your total traffic, then you can count the number of user posts by hand. :slight_smile:
@pfaffman thank you for your suggestion!
Yes, I do count it manually now but as you guess it’s far from being convenient :slight_smile: It looks like a real basic feature, and it’s sad it’s not available yet.
Thank you anyways for looking into this!
