Esecuzione SQL non funziona in psql
Sto cercando di eseguire:
SELECT user_id, 0 post_id, current_timestamp granted_at
FROM badge_posts
WHERE (:backfill OR user_id IN (:user_ids) OR 0 NOT IN (:post_ids) )
GROUP BY user_id
HAVING count(*) > 1000
ma ricevo un errore su :backfill. Qualcuno può dirmi perché?
So che questo SQL funzionava in precedenza nella creazione dei badge.
Anything starting with a : is a named parameter meant to be replaced by mini_sql prior to being sent to the DBMS, it’s not valid SQL by itself.
Example, see [2] below:
[1] pry(main)> User.find_by(username: 'anon43915857').id
=> 5
[2] pry(main)> DB.query(
  "SELECT id FROM users WHERE username = :username",
  { username: 'anon43915857' }
).first.id
=> 5
[3] pry(main)> DB.query(
  "SELECT id FROM users WHERE username = ?",
  'anon43915857'
).first.id
=> 5
Thank you. This is clear.
