ディスコース・アルト・ロゴのテーマコンポーネントが原因でブートストラップに失敗しました
I tried upgrading this morning via the UI which failed so I did a rebuild which also failed. I disabled all plugins and it still fails.
Looking through the logs it appears the db may be corrupt? Any other ideas?
I, [2021-06-30T18:10:17.952185 #1]  INFO -- : > su postgres -c 'createdb discourse' || true
2021-06-30 18:10:18.088 UTC [68] postgres@postgres ERROR:  database "discourse" already exists
2021-06-30 18:10:18.088 UTC [68] postgres@postgres STATEMENT:  CREATE DATABASE discourse;
createdb: error: database creation failed: ERROR:  database "discourse" already exists
I, [2021-06-30T18:10:18.091429 #1]  INFO -- :
I, [2021-06-30T18:10:18.092062 #1]  INFO -- : > su postgres -c 'psql discourse -c "create user discourse;"' || true
2021-06-30 18:10:18.210 UTC [79] postgres@discourse ERROR:  role "discourse" already exists
2021-06-30 18:10:18.210 UTC [79] postgres@discourse STATEMENT:  create user discourse;
Full Logs
Fetching origin
Launcher is up-to-date
Stopping old container
+ /usr/bin/docker stop -t 60 app
app
cd /pups && git pull && git checkout v1.0.3 && /pups/bin/pups --stdin
From https://github.com/discourse/pups
   17f04ec..e0ff889  master     -> origin/master
 * [new tag]         v1.1.1     -> v1.1.1
 * [new tag]         v1.1.0     -> v1.1.0
Updating 17f04ec..e0ff889
Fast-forward
 .github/workflows/ci.yml     |  29 ++++++
 .github/workflows/lint.yml   |  27 +++++
 .rubocop.yml                 |   3 +
 Gemfile                      |   2 +
 Guardfile                    |   4 +-
 README.md                    |  21 ++++
 Rakefile                     |  14 +--
 bin/pups                     |   8 +-
 lib/pups.rb                  |  32 ++++--
 lib/pups/cli.rb              |  92 ++++++++++-------
 lib/pups/command.rb          |  25 +++--
 lib/pups/config.rb           | 240 +++++++++++++++++++++++--------------------
 lib/pups/docker.rb           |  69 +++++++++++++
 lib/pups/exec_command.rb     | 182 ++++++++++++++++----------------
 lib/pups/file_command.rb     |  60 +++++------
 lib/pups/merge_command.rb    |  94 ++++++++---------
 lib/pups/replace_command.rb  |  70 +++++++------
 lib/pups/runit.rb            |  47 +++++----
 lib/pups/version.rb          |   4 +-
 pups.gemspec                 |  37 ++++---
 test/cli_test.rb             | 102 +++++++++++++++---
 test/config_test.rb          | 215 ++++++++++++++++++++++++++++----------
 test/docker_test.rb          | 157 ++++++++++++++++++++++++++++
 test/exec_command_test.rb    |  62 ++++++-----
 test/file_command_test.rb    |  17 ++-
 test/merge_command_test.rb   |  64 ++++++------
 test/replace_command_test.rb |  86 ++++++++--------
 test/test_helper.rb          |   2 +
 28 files changed, 1158 insertions(+), 607 deletions(-)
 create mode 100644 .github/workflows/ci.yml
 create mode 100644 .github/workflows/lint.yml
 create mode 100644 .rubocop.yml
 create mode 100644 lib/pups/docker.rb
 create mode 100644 test/docker_test.rb
Note: checking out 'v1.0.3'.
You are in 'detached HEAD' state. You can look around, make experimental
changes and commit them, and you can discard any commits you make in this
state without impacting any branches by performing another checkout.
If you want to create a new branch to retain commits you create, you may
do so (now or later) by using -b with the checkout command again. Example:
  git checkout -b <new-branch-name>
HEAD is now at d1db030 cut a new version
I, [2021-06-30T18:10:11.171423 #1]  INFO -- : Loading --stdin
I, [2021-06-30T18:10:11.188039 #1]  INFO -- : > locale-gen $LANG && update-locale
I, [2021-06-30T18:10:11.242004 #1]  INFO -- : Generating locales (this might take a while)...
Generation complete.
I, [2021-06-30T18:10:11.242515 #1]  INFO -- : > mkdir -p /shared/postgres_run
I, [2021-06-30T18:10:11.246546 #1]  INFO -- :
I, [2021-06-30T18:10:11.247454 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run
I, [2021-06-30T18:10:11.251426 #1]  INFO -- :
I, [2021-06-30T18:10:11.252143 #1]  INFO -- : > chmod 775 /shared/postgres_run
I, [2021-06-30T18:10:11.255623 #1]  INFO -- :
I, [2021-06-30T18:10:11.256264 #1]  INFO -- : > rm -fr /var/run/postgresql
I, [2021-06-30T18:10:11.260752 #1]  INFO -- :
I, [2021-06-30T18:10:11.261505 #1]  INFO -- : > ln -s /shared/postgres_run /var/run/postgresql
I, [2021-06-30T18:10:11.266317 #1]  INFO -- :
I, [2021-06-30T18:10:11.267122 #1]  INFO -- : > socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1
2021/06/30 18:10:11 socat[32] E connect(6, AF=1 "/shared/postgres_run/.s.PGSQL.5432", 36): No such file or directory
I, [2021-06-30T18:10:11.278874 #1]  INFO -- :
I, [2021-06-30T18:10:11.279314 #1]  INFO -- : > rm -fr /shared/postgres_run/.s*
I, [2021-06-30T18:10:11.284187 #1]  INFO -- :
I, [2021-06-30T18:10:11.284814 #1]  INFO -- : > rm -fr /shared/postgres_run/*.pid
I, [2021-06-30T18:10:11.289693 #1]  INFO -- :
I, [2021-06-30T18:10:11.290249 #1]  INFO -- : > mkdir -p /shared/postgres_run/13-main.pg_stat_tmp
I, [2021-06-30T18:10:11.293706 #1]  INFO -- :
I, [2021-06-30T18:10:11.294369 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run/13-main.pg_stat_tmp
I, [2021-06-30T18:10:11.297689 #1]  INFO -- :
I, [2021-06-30T18:10:11.305014 #1]  INFO -- : File > /etc/service/postgres/run  chmod: +x  chown:
I, [2021-06-30T18:10:11.311575 #1]  INFO -- : File > /etc/service/postgres/log/run  chmod: +x  chown:
I, [2021-06-30T18:10:11.320034 #1]  INFO -- : File > /etc/runit/3.d/99-postgres  chmod: +x  chown:
I, [2021-06-30T18:10:11.328515 #1]  INFO -- : File > /root/upgrade_postgres  chmod: +x  chown:
I, [2021-06-30T18:10:11.329279 #1]  INFO -- : > chown -R root /var/lib/postgresql/13/main
I, [2021-06-30T18:10:12.847204 #1]  INFO -- :
I, [2021-06-30T18:10:12.847624 #1]  INFO -- : > [ ! -e /shared/postgres_data ] && install -d -m 0755 -o postgres -g postgres /shared/postgres_data && sudo -E -u postgres /usr/lib/postgresql/13/bin/initdb -D /shared/postgres_data || exit 0
I, [2021-06-30T18:10:12.851379 #1]  INFO -- :
I, [2021-06-30T18:10:12.851718 #1]  INFO -- : > chown -R postgres:postgres /shared/postgres_data
I, [2021-06-30T18:10:12.902218 #1]  INFO -- :
I, [2021-06-30T18:10:12.902887 #1]  INFO -- : > chown -R postgres:postgres /var/run/postgresql
I, [2021-06-30T18:10:12.907514 #1]  INFO -- :
I, [2021-06-30T18:10:12.908239 #1]  INFO -- : > /root/upgrade_postgres
I, [2021-06-30T18:10:12.917510 #1]  INFO -- :
I, [2021-06-30T18:10:12.918194 #1]  INFO -- : > rm /root/upgrade_postgres
I, [2021-06-30T18:10:12.922574 #1]  INFO -- :
I, [2021-06-30T18:10:12.923911 #1]  INFO -- : Replacing data_directory = '/var/lib/postgresql/13/main' with data_directory = '/shared/postgres_data' in /etc/postgresql/13/main/postgresql.conf
I, [2021-06-30T18:10:12.925138 #1]  INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addresses = '*' in /etc/postgresql/13/main/postgresql.conf
I, [2021-06-30T18:10:12.926015 #1]  INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchronous_commit = $db_synchronous_commit in /etc/postgresql/13/main/postgresql.conf
I, [2021-06-30T18:10:12.926953 #1]  INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffers = $db_shared_buffers in /etc/postgresql/13/main/postgresql.conf
I, [2021-06-30T18:10:12.927801 #1]  INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work_mem in /etc/postgresql/13/main/postgresql.conf
I, [2021-06-30T18:10:12.928766 #1]  INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with default_text_search_config = '$db_default_text_search_config' in /etc/postgresql/13/main/postgresql.conf
I, [2021-06-30T18:10:12.929636 #1]  INFO -- : > install -d -m 0755 -o postgres -g postgres /shared/postgres_backup
I, [2021-06-30T18:10:12.937347 #1]  INFO -- :
I, [2021-06-30T18:10:12.938427 #1]  INFO -- : Replacing (?-mix:#?checkpoint_segments *=.*) with checkpoint_segments = $db_checkpoint_segments in /etc/postgresql/13/main/postgresql.conf
I, [2021-06-30T18:10:12.939275 #1]  INFO -- : Replacing (?-mix:#?logging_collector *=.*) with logging_collector = $db_logging_collector in /etc/postgresql/13/main/postgresql.conf
I, [2021-06-30T18:10:12.940177 #1]  INFO -- : Replacing (?-mix:#?log_min_duration_statement *=.*) with log_min_duration_statement = $db_log_min_duration_statement in /etc/postgresql/13/main/postgresql.conf
I, [2021-06-30T18:10:12.941381 #1]  INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) with local replication postgres  peer in /etc/postgresql/13/main/pg_hba.conf
I, [2021-06-30T18:10:12.942176 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2021-06-30T18:10:12.943419 #1]  INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main
I, [2021-06-30T18:10:12.947647 #1]  INFO -- : > sleep 5
2021-06-30 18:10:12.997 UTC [55] LOG:  starting PostgreSQL 13.3 (Debian 13.3-1.pgdg100+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 8.3.0-6) 8.3.0, 64-bit
2021-06-30 18:10:12.997 UTC [55] LOG:  listening on IPv4 address "0.0.0.0", port 5432
2021-06-30 18:10:12.998 UTC [55] LOG:  listening on IPv6 address "::", port 5432
2021-06-30 18:10:13.001 UTC [55] LOG:  listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2021-06-30 18:10:13.009 UTC [58] LOG:  database system was shut down at 2021-06-30 18:10:00 UTC
2021-06-30 18:10:13.021 UTC [55] LOG:  database system is ready to accept connections
I, [2021-06-30T18:10:17.951784 #1]  INFO -- :
I, [2021-06-30T18:10:18.212403 #1]  INFO -- :
I, [2021-06-30T18:10:18.213122 #1]  INFO -- : > su postgres -c 'psql discourse -c "grant all privileges on database discourse to discourse;"' || true
I, [2021-06-30T18:10:18.304163 #1]  INFO -- : GRANT
I, [2021-06-30T18:10:18.305053 #1]  INFO -- : > su postgres -c 'psql discourse -c "alter schema public owner to discourse;"'
I, [2021-06-30T18:10:18.394467 #1]  INFO -- : ALTER SCHEMA
I, [2021-06-30T18:10:18.395154 #1]  INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists hstore;"'
NOTICE:  extension "hstore" already exists, skipping
I, [2021-06-30T18:10:18.502851 #1]  INFO -- : CREATE EXTENSION
I, [2021-06-30T18:10:18.503667 #1]  INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists pg_trgm;"'
NOTICE:  extension "pg_trgm" already exists, skipping
I, [2021-06-30T18:10:18.597195 #1]  INFO -- : CREATE EXTENSION
I, [2021-06-30T18:10:18.598031 #1]  INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists hstore;"'
I, [2021-06-30T18:10:18.696763 #1]  INFO -- : CREATE EXTENSION
I, [2021-06-30T18:10:18.697534 #1]  INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists pg_trgm;"'
I, [2021-06-30T18:10:18.778354 #1]  INFO -- : CREATE EXTENSION
I, [2021-06-30T18:10:18.778943 #1]  INFO -- : > sudo -u postgres psql discourse
I, [2021-06-30T18:10:18.782930 #1]  INFO -- : update pg_database set encoding = pg_char_to_encoding('UTF8') where datname = 'discourse' AND encoding = pg_char_to_encoding('SQL_ASCII');
I, [2021-06-30T18:10:18.895244 #1]  INFO -- : File > /var/lib/postgresql/take-database-backup  chmod: +x  chown: postgres:postgres
I, [2021-06-30T18:10:18.900039 #1]  INFO -- : File > /var/spool/cron/crontabs/postgres  chmod:   chown:
I, [2021-06-30T18:10:18.900513 #1]  INFO -- : > echo postgres installed!
I, [2021-06-30T18:10:18.903860 #1]  INFO -- : postgres installed!
I, [2021-06-30T18:10:18.911693 #1]  INFO -- : File > /etc/service/redis/run  chmod: +x  chown:
I, [2021-06-30T18:10:18.918705 #1]  INFO -- : File > /etc/service/redis/log/run  chmod: +x  chown:
I, [2021-06-30T18:10:18.928631 #1]  INFO -- : File > /etc/runit/3.d/10-redis  chmod: +x  chown:
I, [2021-06-30T18:10:18.930511 #1]  INFO -- : Replacing daemonize yes with  in /etc/redis/redis.conf
I, [2021-06-30T18:10:18.931736 #1]  INFO -- : Replacing (?-mix:^pidfile.*$) with  in /etc/redis/redis.conf
I, [2021-06-30T18:10:18.932803 #1]  INFO -- : > install -d -m 0755 -o redis -g redis /shared/redis_data
I, [2021-06-30T18:10:18.938286 #1]  INFO -- :
I, [2021-06-30T18:10:18.939301 #1]  INFO -- : Replacing (?-mix:^logfile.*$) with logfile "" in /etc/redis/redis.conf
I, [2021-06-30T18:10:18.940356 #1]  INFO -- : Replacing (?-mix:^bind .*$) with  in /etc/redis/redis.conf
I, [2021-06-30T18:10:18.941363 #1]  INFO -- : Replacing (?-mix:^dir .*$) with dir /shared/redis_data in /etc/redis/redis.conf
I, [2021-06-30T18:10:18.942417 #1]  INFO -- : Replacing (?-mix:^protected-mode yes) with protected-mode no in /etc/redis/redis.conf
I, [2021-06-30T18:10:18.943406 #1]  INFO -- : Replacing # io-threads 4 with io-threads $redis_io_threads in /etc/redis/redis.conf
I, [2021-06-30T18:10:18.944282 #1]  INFO -- : > echo redis installed
I, [2021-06-30T18:10:18.948826 #1]  INFO -- : redis installed
I, [2021-06-30T18:10:18.949623 #1]  INFO -- : > cat /etc/redis/redis.conf | grep logfile
I, [2021-06-30T18:10:18.957937 #1]  INFO -- : logfile ""
I, [2021-06-30T18:10:18.958871 #1]  INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2021-06-30T18:10:18.962172 #1]  INFO -- : > sleep 10
172:C 30 Jun 2021 18:10:18.970 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
172:C 30 Jun 2021 18:10:18.970 # Redis version=6.2.3, bits=64, commit=00000000, modified=0, pid=172, just started
172:C 30 Jun 2021 18:10:18.970 # Configuration loaded
172:M 30 Jun 2021 18:10:18.972 * monotonic clock: POSIX clock_gettime
172:M 30 Jun 2021 18:10:18.973 * Running mode=standalone, port=6379.
172:M 30 Jun 2021 18:10:18.974 # WARNING: The TCP backlog setting of 511 cannot be enforced because /proc/sys/net/core/somaxconn is set to the lower value of 128.
172:M 30 Jun 2021 18:10:18.974 # Server initialized
172:M 30 Jun 2021 18:10:18.974 # WARNING overcommit_memory is set to 0! Background save may fail under low memory condition. To fix this issue add 'vm.overcommit_memory = 1' to /etc/sysctl.conf and then reboot or run the command 'sysctl vm.overcommit_memory=1' for this to take effect.
172:M 30 Jun 2021 18:10:18.975 * Loading RDB produced by version 6.2.3
172:M 30 Jun 2021 18:10:18.976 * RDB age 28 seconds
172:M 30 Jun 2021 18:10:18.976 * RDB memory usage when created 103.43 Mb
172:M 30 Jun 2021 18:10:19.341 * DB loaded from disk: 0.366 seconds
172:M 30 Jun 2021 18:10:19.342 * Ready to accept connections
I, [2021-06-30T18:10:28.967142 #1]  INFO -- :
I, [2021-06-30T18:10:28.967394 #1]  INFO -- : > thpoff echo "thpoff is installed!"
I, [2021-06-30T18:10:28.972969 #1]  INFO -- : thpoff is installed!
I, [2021-06-30T18:10:28.973312 #1]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_SMTP_ADDRESS"] == "smtp.example.com"; puts "Aborting! Mail is not configured!"; exit 1; end'
I, [2021-06-30T18:10:29.131042 #1]  INFO -- :
I, [2021-06-30T18:10:29.131261 #1]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_HOSTNAME"] == "discourse.example.com"; puts "Aborting! Domain is not configured!"; exit 1; end'
I, [2021-06-30T18:10:29.248950 #1]  INFO -- :
I, [2021-06-30T18:10:29.250193 #1]  INFO -- : > /usr/local/bin/ruby -e 'if (ENV["DISCOURSE_CDN_URL"] || "")[0..1] == "//"; puts "Aborting! CDN must have a protocol specified. Once fixed you should rebake your posts now to correct all posts."; exit 1; end'
I, [2021-06-30T18:10:29.360146 #1]  INFO -- :
I, [2021-06-30T18:10:29.360381 #1]  INFO -- : > chown -R discourse /home/discourse
I, [2021-06-30T18:10:30.140423 #1]  INFO -- :
I, [2021-06-30T18:10:30.141176 #1]  INFO -- : > rm -f /etc/cron.d/anacron
I, [2021-06-30T18:10:30.144983 #1]  INFO -- :
I, [2021-06-30T18:10:30.149315 #1]  INFO -- : File > /etc/cron.d/anacron  chmod:   chown:
I, [2021-06-30T18:10:30.156035 #1]  INFO -- : File > /etc/runit/1.d/copy-env  chmod: +x  chown:
I, [2021-06-30T18:10:30.162878 #1]  INFO -- : File > /etc/service/unicorn/run  chmod: +x  chown:
I, [2021-06-30T18:10:30.170949 #1]  INFO -- : File > /etc/service/nginx/run  chmod: +x  chown:
I, [2021-06-30T18:10:30.178818 #1]  INFO -- : File > /etc/runit/3.d/01-nginx  chmod: +x  chown:
I, [2021-06-30T18:10:30.185297 #1]  INFO -- : File > /etc/runit/3.d/02-unicorn  chmod: +x  chown:
I, [2021-06-30T18:10:30.185528 #1]  INFO -- : Replacing # postgres with sv start postgres || exit 1 in /etc/service/unicorn/run
I, [2021-06-30T18:10:30.185884 #1]  INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2021-06-30T18:10:30.189293 #1]  INFO -- : > cd /var/www/discourse && git reset --hard
200:C 30 Jun 2021 18:10:30.196 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
200:C 30 Jun 2021 18:10:30.196 # Redis version=6.2.3, bits=64, commit=00000000, modified=0, pid=200, just started
200:C 30 Jun 2021 18:10:30.196 # Configuration loaded
200:M 30 Jun 2021 18:10:30.197 * monotonic clock: POSIX clock_gettime
200:M 30 Jun 2021 18:10:30.197 # Warning: Could not create server TCP listening socket *:6379: bind: Address already in use
200:M 30 Jun 2021 18:10:30.197 # Failed listening on port 6379 (TCP), aborting.
Checking out files: 100% (28860/28860), done.
I, [2021-06-30T18:10:34.585153 #1]  INFO -- : HEAD is now at 74f71503 FEATURE: Automatically timed delete stub topics after entire topic is merged into another topic (#13187)
I, [2021-06-30T18:10:34.585395 #1]  INFO -- : > cd /var/www/discourse && git clean -f
I, [2021-06-30T18:10:34.715549 #1]  INFO -- :
I, [2021-06-30T18:10:34.715751 #1]  INFO -- : > cd /var/www/discourse && git remote set-branches --add origin master
I, [2021-06-30T18:10:34.723480 #1]  INFO -- :
I, [2021-06-30T18:10:34.723634 #1]  INFO -- : > cd /var/www/discourse && git remote set-branches origin tests-passed
I, [2021-06-30T18:10:34.731308 #1]  INFO -- :
I, [2021-06-30T18:10:34.732135 #1]  INFO -- : > cd /var/www/discourse && git fetch --depth 1 origin tests-passed
From https://github.com/discourse/discourse
 * branch              tests-passed -> FETCH_HEAD
 * [new branch]        tests-passed -> origin/tests-passed
I, [2021-06-30T18:10:38.036204 #1]  INFO -- :
I, [2021-06-30T18:10:38.036386 #1]  INFO -- : > cd /var/www/discourse && git checkout tests-passed
Switched to a new branch 'tests-passed'
I, [2021-06-30T18:10:39.431879 #1]  INFO -- : Branch 'tests-passed' set up to track remote branch 'tests-passed' from 'origin'.
I, [2021-06-30T18:10:39.432099 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp
I, [2021-06-30T18:10:39.436899 #1]  INFO -- :
I, [2021-06-30T18:10:39.437503 #1]  INFO -- : > cd /var/www/discourse && chown discourse:www-data tmp
I, [2021-06-30T18:10:39.444310 #1]  INFO -- :
I, [2021-06-30T18:10:39.444491 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp/pids
I, [2021-06-30T18:10:39.451112 #1]  INFO -- :
I, [2021-06-30T18:10:39.451852 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp/sockets
I, [2021-06-30T18:10:39.456603 #1]  INFO -- :
I, [2021-06-30T18:10:39.457371 #1]  INFO -- : > cd /var/www/discourse && touch tmp/.gitkeep
I, [2021-06-30T18:10:39.461639 #1]  INFO -- :
I, [2021-06-30T18:10:39.462420 #1]  INFO -- : > cd /var/www/discourse && mkdir -p                    /shared/log/rails
I, [2021-06-30T18:10:39.466952 #1]  INFO -- :
I, [2021-06-30T18:10:39.467525 #1]  INFO -- : > cd /var/www/discourse && bash -c "touch -a           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log"
I, [2021-06-30T18:10:39.473895 #1]  INFO -- :
I, [2021-06-30T18:10:39.474615 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log /var/www/discourse/log"
I, [2021-06-30T18:10:39.482394 #1]  INFO -- :
I, [2021-06-30T18:10:39.482534 #1]  INFO -- : > cd /var/www/discourse && bash -c "mkdir -p           /shared/{uploads,backups}"
I, [2021-06-30T18:10:39.490178 #1]  INFO -- :
I, [2021-06-30T18:10:39.490823 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/{uploads,backups} /var/www/discourse/public"
I, [2021-06-30T18:10:39.497749 #1]  INFO -- :
I, [2021-06-30T18:10:39.498235 #1]  INFO -- : > cd /var/www/discourse && bash -c "mkdir -p           /shared/tmp/{backups,restores}"
I, [2021-06-30T18:10:39.505409 #1]  INFO -- :
I, [2021-06-30T18:10:39.506216 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/tmp/{backups,restores} /var/www/discourse/tmp"
I, [2021-06-30T18:10:39.512670 #1]  INFO -- :
I, [2021-06-30T18:10:39.513129 #1]  INFO -- : > cd /var/www/discourse && chown -R discourse:www-data /shared/log/rails /shared/uploads /shared/backups /shared/tmp
I, [2021-06-30T18:10:39.526166 #1]  INFO -- :
I, [2021-06-30T18:10:39.526307 #1]  INFO -- : > cd /var/www/discourse && find public/plugins/ -maxdepth 1 -xtype l -delete
I, [2021-06-30T18:10:39.533675 #1]  INFO -- :
I, [2021-06-30T18:10:39.534560 #1]  INFO -- : Replacing # redis with sv start redis || exit 1 in /etc/service/unicorn/run
I, [2021-06-30T18:10:39.535032 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/docker_manager.git
Cloning into 'docker_manager'...
I, [2021-06-30T18:10:40.766351 #1]  INFO -- :
I, [2021-06-30T18:10:40.767334 #1]  INFO -- : > cp /var/www/discourse/config/nginx.sample.conf /etc/nginx/conf.d/discourse.conf
I, [2021-06-30T18:10:40.772113 #1]  INFO -- :
I, [2021-06-30T18:10:40.772965 #1]  INFO -- : > rm /etc/nginx/sites-enabled/default
I, [2021-06-30T18:10:40.778201 #1]  INFO -- :
I, [2021-06-30T18:10:40.778968 #1]  INFO -- : > mkdir -p /var/nginx/cache
I, [2021-06-30T18:10:40.783974 #1]  INFO -- :
I, [2021-06-30T18:10:40.785540 #1]  INFO -- : Replacing pid /run/nginx.pid; with daemon off; in /etc/nginx/nginx.conf
I, [2021-06-30T18:10:40.786796 #1]  INFO -- : Replacing (?m-ix:upstream[^\}]+\}) with upstream discourse { server 127.0.0.1:3000; } in /etc/nginx/conf.d/discourse.conf
I, [2021-06-30T18:10:40.787559 #1]  INFO -- : Replacing (?-mix:server_name.+$) with server_name _ ; in /etc/nginx/conf.d/discourse.conf
I, [2021-06-30T18:10:40.788426 #1]  INFO -- : Replacing (?-mix:client_max_body_size.+$) with client_max_body_size $upload_size ; in /etc/nginx/conf.d/discourse.conf
I, [2021-06-30T18:10:40.790240 #1]  INFO -- : > echo "done configuring web"
I, [2021-06-30T18:10:40.794766 #1]  INFO -- : done configuring web
I, [2021-06-30T18:10:40.795828 #1]  INFO -- : > cd /var/www/discourse && gem install bundler --conservative -v $(awk '/BUNDLED WITH/ { getline; gsub(/ /,""); print $0 }' Gemfile.lock)
I, [2021-06-30T18:10:41.756624 #1]  INFO -- : Successfully installed bundler-2.2.19
1 gem installed
I, [2021-06-30T18:10:41.756817 #1]  INFO -- : > cd /var/www/discourse && find /var/www/discourse ! -user discourse -exec chown discourse {} \+
I, [2021-06-30T18:10:46.354664 #1]  INFO -- :
I, [2021-06-30T18:10:46.355129 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle install --deployment --retry 3 --jobs 4 --verbose --without test development'
[DEPRECATED] The `--deployment` flag is deprecated because it relies on being remembered across bundler invocations, which bundler will no longer do in future versions. Instead please use `bundle config set --local deployment 'true'`, and stop using this flag
[DEPRECATED] The `--without` flag is deprecated because it relies on being remembered across bundler invocations, which bundler will no longer do in future versions. Instead please use `bundle config set --local without 'test development'`, and stop using this flag
I, [2021-06-30T18:11:25.028669 #1]  INFO -- : Running `bundle install --deployment --jobs 4 --retry 3 --verbose --without "test" "development"` with bundler 2.2.19
Frozen, using resolution from the lockfile
The definition is missing ["concurrent-ruby-1.1.9", "nokogiri-1.11.7-x86_64-linux", "loofah-2.10.0", "aws-sdk-kms-1.44.0", "aws-sdk-s3-1.96.1", "excon-0.83.0", "faraday-1.4.3", "fastimage-2.2.4", "ffi-1.15.3", "message_bus-3.3.6", "redis-4.3.1", "oj-3.11.7"]
HTTP GET https://index.rubygems.org/versions
HTTP 416 Range Not Satisfiable https://index.rubygems.org/versions
HTTP 200 OK https://index.rubygems.org/versions
Fetching gem metadata from https://rubygems.org/
Double checking for ["rake", "concurrent-ruby", "i18n", "minitest", "tzinfo", "zeitwerk", "activesupport", "builder", "erubi", "racc", "nokogiri", "rails-dom-testing", "crass", "loofah", "rails-html-sanitizer", "actionview", "rack", "rack-test", "actionpack", "globalid", "activejob", "mini_mime", "actionmailer", "actionview_precompiler", "activemodel", "active_model_serializers", "activerecord", "public_suffix", "addressable", "aws-eventstream", "aws-partitions", "aws-sigv4", "jmespath", "aws-sdk-core", "aws-sdk-kms", "aws-sdk-s3", "aws-sdk-sns", "ember-source", "execjs", "barber", "msgpack", "bootsnap", "byebug", "cbor", "chunky_png", "coderay", "colored2", "connection_pool", "openssl", "openssl-signature_algorithm", "cose", "cppjieba_rb", "css_parser", "diffy", "ember-data-source", "sprockets", "ember-handlebars-template", "method_source", "thor", "railties", "jquery-rails", "discourse-ember-rails", "discourse-ember-source", "discourse-fonts", "regexp_parser", "ecma-re-validator", "email_reply_trimmer", "excon", "exifr", "faraday-em_http", "faraday-em_synchrony", "faraday-excon", "faraday-net_http", "faraday-net_http_persistent", "multipart-post", "ruby2_keywords", "faraday", "fast_blank", "fast_xs", "fastimage", "ffi", "fspath", "gc_tracer", "guess_html_encoding", "hana", "hashie", "highline", "hkdf", "htmlentities", "http_accept_language", "image_size", "in_threads", "progress", "image_optim", "json", "uri_template", "json_schemer", "jwt", "kgio", "libv8-node", "request_store", "lograge", "logstash-event", "logstash-logger", "logster", "lru_redux", "lz4-ruby", "maxminddb", "memory_profiler", "message_bus", "mini_racer", "redis", "sidekiq", "mini_scheduler", "mini_sql", "mini_suffix", "multi_json", "multi_xml", "mustache", "nio4r", "nokogumbo", "oauth", "oauth2", "oj", "omniauth", "omniauth-oauth2", "omniauth-facebook", "omniauth-github", "omniauth-google-oauth2", "omniauth-oauth", "omniauth-twitter", "optimist", "pg", "pry", "pry-byebug", "pry-rails", "puma", "r2", "rack-mini-profiler", "rack-protection", "rails_failover", "rails_multisite", "raindrops", "rbtrace", "rchardet", "redis-namespace", "rinku", "rotp", "rqrcode_core", "rqrcode", "rtlit", "ruby-readability", "rubyzip", "sanitize", "sassc", "sprockets-rails", "tilt", "sassc-rails", "seed-fu", "sshkey", "stackprof", "uglifier", "unf_ext", "unf", "unicorn", "webpush", "xorcist"] in rubygems repository https://rubygems.org/ or installed locally
Looking up gems ["rake", "concurrent-ruby", "i18n", "minitest", "tzinfo", "zeitwerk", "activesupport", "builder", "erubi", "racc", "nokogiri", "rails-dom-testing", "crass", "loofah", "rails-html-sanitizer", "actionview", "rack", "rack-test", "actionpack", "globalid", "activejob", "mini_mime", "actionmailer", "actionview_precompiler", "activemodel", "active_model_serializers", "activerecord", "public_suffix", "addressable", "aws-eventstream", "aws-partitions", "aws-sigv4", "jmespath", "aws-sdk-core", "aws-sdk-kms", "aws-sdk-s3", "aws-sdk-sns", "ember-source", "execjs", "barber", "msgpack", "bootsnap", "byebug", "cbor", "chunky_png", "coderay", "colored2", "connection_pool", "openssl", "openssl-signature_algorithm", "cose", "cppjieba_rb", "css_parser", "diffy", "ember-data-source", "sprockets", "ember-handlebars-template", "method_source", "thor", "railties", "jquery-rails", "discourse-ember-rails", "discourse-ember-source", "discourse-fonts", "regexp_parser", "ecma-re-validator", "email_reply_trimmer", "excon", "exifr", "faraday-em_http", "faraday-em_synchrony", "faraday-excon", "faraday-net_http", "faraday-net_http_persistent", "multipart-post", "ruby2_keywords", "faraday", "fast_blank", "fast_xs", "fastimage", "ffi", "fspath", "gc_tracer", "guess_html_encoding", "hana", "hashie", "highline", "hkdf", "htmlentities", "http_accept_language", "image_size", "in_threads", "progress", "image_optim", "json", "uri_template", "json_schemer", "jwt", "kgio", "libv8-node", "request_store", "lograge", "logstash-event", "logstash-logger", "logster", "lru_redux", "lz4-ruby", "maxminddb", "memory_profiler", "message_bus", "mini_racer", "redis", "sidekiq", "mini_scheduler", "mini_sql", "mini_suffix", "multi_json", "multi_xml", "mustache", "nio4r", "nokogumbo", "oauth", "oauth2", "oj", "omniauth", "omniauth-oauth2", "omniauth-facebook", "omniauth-github", "omniauth-google-oauth2", "omniauth-oauth", "omniauth-twitter", "optimist", "pg", "pry", "pry-byebug", "pry-rails", "puma", "r2", "rack-mini-profiler", "rack-protection", "rails_failover", "rails_multisite", "raindrops", "rbtrace", "rchardet", "redis-namespace", "rinku", "rotp", "rqrcode_core", "rqrcode", "rtlit", "ruby-readability", "rubyzip", "sanitize", "sassc", "sprockets-rails", "tilt", "sassc-rails", "seed-fu", "sshkey", "stackprof", "uglifier", "unf_ext", "unf", "unicorn", "webpush", "xorcist"]
HTTP GET https://index.rubygems.org/info/concurrent-ruby
HTTP GET https://index.rubygems.org/info/activesupport
HTTP GET https://index.rubygems.org/info/nokogiri
HTTP GET https://index.rubygems.org/info/loofah
HTTP GET https://index.rubygems.org/info/actionview
HTTP GET https://index.rubygems.org/info/actionpack
HTTP GET https://index.rubygems.org/info/activejob
HTTP GET https://index.rubygems.org/info/activemodel
HTTP GET https://index.rubygems.org/info/aws-sdk-kms
HTTP GET https://index.rubygems.org/info/aws-sdk-s3
HTTP GET https://index.rubygems.org/info/aws-sdk-sns
HTTP GET https://index.rubygems.org/info/activerecord
HTTP GET https://index.rubygems.org/info/actionmailer
HTTP GET https://index.rubygems.org/info/cppjieba_rb
HTTP GET https://index.rubygems.org/info/aws-sdk-core
HTTP GET https://index.rubygems.org/info/railties
HTTP GET https://index.rubygems.org/info/fastimage
HTTP 206 Partial Content https://index.rubygems.org/info/concurrent-ruby
HTTP GET https://index.rubygems.org/info/ffi
HTTP GET https://index.rubygems.org/info/faraday
HTTP GET https://index.rubygems.org/info/aws-partitions
HTTP 206 Partial Content https://index.rubygems.org/info/cppjieba_rb
HTTP 206 Partial Content https://index.rubygems.org/info/activerecord
HTTP GET https://index.rubygems.org/info/excon
HTTP 206 Partial Content https://index.rubygems.org/info/railties
HTTP 206 Partial Content https://index.rubygems.org/info/aws-sdk-kms
HTTP 206 Partial Content https://index.rubygems.org/info/fastimage
HTTP 206 Partial Content https://index.rubygems.org/info/aws-partitions
HTTP 206 Partial Content https://index.rubygems.org/info/aws-sdk-core
HTTP 206 Partial Content https://index.rubygems.org/info/activemodel
HTTP 206 Partial Content https://index.rubygems.org/info/actionmailer
HTTP GET https://index.rubygems.org/info/redis
HTTP GET https://index.rubygems.org/info/message_bus
HTTP 206 Partial Content https://index.rubygems.org/info/actionview
HTTP 206 Partial Content https://index.rubygems.org/info/ffi
HTTP 206 Partial Content https://index.rubygems.org/info/redis
HTTP 206 Partial Content https://index.rubygems.org/info/message_bus
HTTP 206 Partial Content https://index.rubygems.org/info/nokogiri
HTTP 206 Partial Content https://index.rubygems.org/info/aws-sdk-s3
HTTP 206 Partial Content https://index.rubygems.org/info/aws-sdk-sns
HTTP 206 Partial Content https://index.rubygems.org/info/actionpack
HTTP 206 Partial Content https://index.rubygems.org/info/excon
HTTP 206 Partial Content https://index.rubygems.org/info/activejob
HTTP 206 Partial Content https://index.rubygems.org/info/faraday
HTTP 206 Partial Content https://index.rubygems.org/info/activesupport
HTTP 206 Partial Content https://index.rubygems.org/info/loofah
HTTP GET https://index.rubygems.org/info/oj
HTTP 206 Partial Content https://index.rubygems.org/info/oj
Looking up gems ["rails-deprecated_sanitizer", "jsonapi", "case_transform", "jsonapi-renderer", "rspec", "json_pure", "handlebars-source", "snappy", "rdoc", "ruby_parser", "columnize", "debugger-linecache", "slop", "rb-readline", "hoe", "hike", "rake-compiler", "ember-template-compiler-source", "rails", "thread_safe", "net-http-persistent", "termios", "rb-appscript", "xattr", "ffi-xattr", "rdf", "stud", "arel", "activerecord-deprecated_finders", "libv8", "functional-ruby", "ref", "celluloid", "compass", "sass", "sprockets-sass", "sinatra", "slim", "ruby-hmac", "activemodel-globalid", "weakling", "mini_portile", "mini_portile2", "pkg-config", "pry-doc", "erubis", "rack-mount", "rack-cache", "journey", "escape_utils", "rack-ssl", "eventmachine", "thin", "base32", "bcrypt-ruby", "hpricot", "mail", "text-format", "faraday-middleware", "httpauth", "therubyracer", "listen", "oa-core", "oa-oauth", "oa-openid", "oa-basic", "oa-enterprise", "oa-more", "jamespath", "http-2", "bundler", "trollop", "win32console", "yard", "spoon", "memcache-client", "bigdecimal"]
HTTP GET https://index.rubygems.org/info/slop
HTTP GET https://index.rubygems.org/info/hoe
HTTP 206 Partial Content https://index.rubygems.org/info/hoe
HTTP GET https://index.rubygems.org/info/rdf
HTTP GET https://index.rubygems.org/info/mini_portile2
HTTP 206 Partial Content https://index.rubygems.org/info/slop
HTTP GET https://index.rubygems.org/info/bundler
HTTP GET https://index.rubygems.org/info/rails
HTTP 206 Partial Content https://index.rubygems.org/info/rails
HTTP 206 Partial Content https://index.rubygems.org/info/mini_portile2
HTTP 206 Partial Content https://index.rubygems.org/info/rdf
HTTP 206 Partial Content https://index.rubygems.org/info/bundler
Looking up gems ["jsonapi-parser", "rspec-core", "rspec-expectations", "rspec-mocks", "snappy-jars", "ruby_core_source", "debugger-ruby_core_source", "timers", "facter", "celluloid-essentials", "celluloid-extras", "celluloid-fsm", "celluloid-pool", "celluloid-supervision", "dotenv", "nenv", "rspec-logsplit", "mongrel", "backports", "mustermann", "temple", "abstract", "multimap", "daemons", "bcrypt", "mime-types", "treetop", "tlsmail", "text-hyphen", "spruz", "rack-openid", "ruby-openid-apps-discovery", "restclient", "rest-client", "sass-listen", "ZenTest", "RubyInline", "rubyforge", "gemcutter", "atomic", "sprockets-helpers", "curses", "metriks", "haml", "fssm", "compass-core", "compass-import-once", "rb-fsevent", "rb-inotify", "net-ftp", "net-ldap", "rubyntlm", "pyu-ruby-sasl", "uuid", "XMLCanonicalizer", "ParseTree", "sexp_processor", "link_header", "hamster", "rb-fchange", "rb-kqueue", "celluloid-io", "ruby_dep", "activeresource", "actionwebservice", "actioncable", "activestorage", "actionmailbox", "actiontext"]
HTTP GET https://index.rubygems.org/info/curses
HTTP GET https://index.rubygems.org/info/net-ftp
HTTP 206 Partial Content https://index.rubygems.org/info/curses
HTTP 200 OK https://index.rubygems.org/info/net-ftp
HTTP GET https://index.rubygems.org/info/facter
HTTP GET https://index.rubygems.org/info/actionmailbox
HTTP GET https://index.rubygems.org/info/actiontext
HTTP 206 Partial Content https://index.rubygems.org/info/actionmailbox
HTTP GET https://index.rubygems.org/info/activestorage
HTTP 206 Partial Content https://index.rubygems.org/info/facter
HTTP 206 Partial Content https://index.rubygems.org/info/actiontext
HTTP 206 Partial Content https://index.rubygems.org/info/activestorage
HTTP GET https://index.rubygems.org/info/actioncable
HTTP 206 Partial Content https://index.rubygems.org/info/actioncable
Looking up gems ["rspec-support", "diff-lcs", "archive-tar-minitar", "hitimes", "mime-types-data", "facets", "polyglot", "ruby-openid", "netrc", "http-cookie", "http-accept", "net-scp", "rbtree", "faraday_middleware", "yajl-ruby", "avl_tree", "macaddr", "log4r", "SexpProcessor", "win32-api", "coveralls", "rubocop", "rails-observers", "activemodel-serializers-xml", "celluloid-gems", "dotenv-deployment", "cgi_multipart_eof_fix", "fastthread", "gem_plugin", "tool", "net-protocol", "time", "CFPropertyList", "sys-admin", "win32-dir", "windows-api", "windows-pr", "win32-security", "hocon", "marcel", "mimemagic", "coffee-rails", "em-hiredis", "faye-websocket", "websocket-driver"]
HTTP GET https://index.rubygems.org/info/http-cookie
HTTP GET https://index.rubygems.org/info/net-protocol
HTTP GET https://index.rubygems.org/info/websocket-driver
HTTP GET https://index.rubygems.org/info/time
HTTP 206 Partial Content https://index.rubygems.org/info/http-cookie
HTTP 200 OK https://index.rubygems.org/info/time
HTTP 206 Partial Content https://index.rubygems.org/info/websocket-driver
HTTP 200 OK https://index.rubygems.org/info/net-protocol
HTTP GET https://index.rubygems.org/info/rubocop
HTTP 206 Partial Content https://index.rubygems.org/info/rubocop
Looking up gems ["minitar", "minitar-cli", "configuration", "mkrf", "roauth", "systemu", "test-unit", "colorize", "simplecov", "term-ansicolor", "tins", "libxml-ruby", "hiredis", "net-ssh", "ruby-yadis", "coffee-script", "ffi-win32-extensions", "domain_name", "sqlite3", "io-wait", "timeout", "websocket-extensions", "rainbow", "parser", "powerpack", "ruby-progressbar", "astrolabe", "unicode-display_width", "parallel", "jaro_winkler", "psych", "rexml", "rubocop-ast"]
HTTP GET https://index.rubygems.org/info/io-wait
HTTP GET https://index.rubygems.org/info/timeout
HTTP GET https://index.rubygems.org/info/psych
HTTP 200 OK https://index.rubygems.org/info/io-wait
HTTP 200 OK https://index.rubygems.org/info/timeout
HTTP 206 Partial Content https://index.rubygems.org/info/psych
HTTP GET https://index.rubygems.org/info/test-unit
HTTP 206 Partial Content https://index.rubygems.org/info/test-unit
Looking up gems ["powerbar", "needle", "jruby-pageant", "bcrypt_pbkdf", "rbnacl", "rbnacl-libsodium", "strscan", "simplecov-html", "docile", "lockfile", "simplecov_json_formatter", "sync", "coffee-script-source", "ast", "jar-dependencies", "power_assert"]
Looking up gems ["ruby-maven", "pattern-match", "ansi"]
Looking up gems ["maven-tools", "ruby-maven-libs"]
Looking up gems ["virtus"]
HTTP GET https://index.rubygems.org/info/virtus
HTTP 206 Partial Content https://index.rubygems.org/info/virtus
Looking up gems ["descendants_tracker", "axiom-types", "coercible", "equalizer"]
Looking up gems ["ice_nine", "adamantium"]
Looking up gems ["memoizable"]
Using rake 13.0.3
0:  rake (13.0.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rake-13.0.3.gemspec
Using minitest 5.14.4
1:  minitest (5.14.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/minitest-5.14.4.gemspec
Using zeitwerk 2.4.2
1:  zeitwerk (2.4.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/zeitwerk-2.4.2.gemspec
Using builder 3.2.4
Using erubi 1.10.0
Using racc 1.5.2
1:  builder (3.2.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/builder-3.2.4.gemspec
0:  erubi (1.10.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/erubi-1.10.0.gemspec
Fetching concurrent-ruby 1.1.9
Using crass 1.0.6
0:  crass (1.0.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/crass-1.0.6.gemspec
Using rack 2.2.3
0:  rack (2.2.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rack-2.2.3.gemspec
Using mini_mime 1.1.0
0:  mini_mime (1.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/mini_mime-1.1.0.gemspec
Using public_suffix 4.0.6
0:  public_suffix (4.0.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/public_suffix-4.0.6.gemspec
Using aws-eventstream 1.1.1
0:  aws-eventstream (1.1.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-eventstream-1.1.1.gemspec
Using aws-partitions 1.432.0
0:  aws-partitions (1.432.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-partitions-1.432.0.gemspec
Using jmespath 1.4.0
0:  jmespath (1.4.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/jmespath-1.4.0.gemspec
Using ember-source 2.18.2
0:  ember-source (2.18.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ember-source-2.18.2.gemspec
Using execjs 2.8.1
0:  execjs (2.8.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/execjs-2.8.1.gemspec
Using msgpack 1.4.2
0:  msgpack (1.4.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/msgpack-1.4.2.gemspec
Using bundler 2.2.19
0:  bundler (2.2.19) from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/lib/bundler/source
Using byebug 11.1.3
0:  byebug (11.1.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/byebug-11.1.3.gemspec
Using cbor 0.5.9.6
0:  cbor (0.5.9.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/cbor-0.5.9.6.gemspec
Using chunky_png 1.4.0
0:  chunky_png (1.4.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/chunky_png-1.4.0.gemspec
Using coderay 1.1.3
0:  coderay (1.1.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/coderay-1.1.3.gemspec
Using colored2 3.1.2
0:  colored2 (3.1.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/colored2-3.1.2.gemspec
Using connection_pool 2.2.5
0:  connection_pool (2.2.5) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/connection_pool-2.2.5.gemspec
Using openssl 2.2.0
0:  openssl (2.2.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/openssl-2.2.0.gemspec
Using cppjieba_rb 0.3.3
0:  cppjieba_rb (0.3.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/cppjieba_rb-0.3.3.gemspec
Using diffy 3.4.0
0:  diffy (3.4.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/diffy-3.4.0.gemspec
Using method_source 1.0.0
0:  method_source (1.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/method_source-1.0.0.gemspec
Using thor 1.1.0
0:  thor (1.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/thor-1.1.0.gemspec
Using discourse-ember-source 3.12.2.3
0:  discourse-ember-source (3.12.2.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/discourse-ember-source-3.12.2.3.gemspec
Using discourse-fonts 0.0.8
0:  discourse-fonts (0.0.8) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/discourse-fonts-0.0.8.gemspec
Using regexp_parser 2.1.1
0:  regexp_parser (2.1.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/regexp_parser-2.1.1.gemspec
Using email_reply_trimmer 0.1.13
0:  email_reply_trimmer (0.1.13) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/email_reply_trimmer-0.1.13.gemspec
3:  racc (1.5.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/racc-1.5.2.gemspec
Using exifr 1.3.9
3:  exifr (1.3.9) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/exifr-1.3.9.gemspec
Using faraday-em_http 1.0.0
3:  faraday-em_http (1.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-em_http-1.0.0.gemspec
Using faraday-em_synchrony 1.0.0
3:  faraday-em_synchrony (1.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-em_synchrony-1.0.0.gemspec
Using faraday-excon 1.1.0
3:  faraday-excon (1.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-excon-1.1.0.gemspec
Using faraday-net_http 1.0.1
3:  faraday-net_http (1.0.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-net_http-1.0.1.gemspec
Using faraday-net_http_persistent 1.1.0
3:  faraday-net_http_persistent (1.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-net_http_persistent-1.1.0.gemspec
Using multipart-post 2.1.1
3:  multipart-post (2.1.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/multipart-post-2.1.1.gemspec
Using ruby2_keywords 0.0.4
3:  ruby2_keywords (0.0.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ruby2_keywords-0.0.4.gemspec
Using fast_blank 1.0.0
3:  fast_blank (1.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/fast_blank-1.0.0.gemspec
Using fast_xs 0.8.0
3:  fast_xs (0.8.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/fast_xs-0.8.0.gemspec
Fetching fastimage 2.2.4
Fetching excon 0.83.0
Fetching ffi 1.15.3
Installing fastimage 2.2.4
Installing concurrent-ruby 1.1.9
Installing excon 0.83.0
3:  fastimage (2.2.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/fastimage-2.2.4.gemspec
Using fspath 3.1.2
3:  fspath (3.1.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/fspath-3.1.2.gemspec
Using gc_tracer 1.5.1
3:  gc_tracer (1.5.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/gc_tracer-1.5.1.gemspec
Using guess_html_encoding 0.0.11
3:  guess_html_encoding (0.0.11) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/guess_html_encoding-0.0.11.gemspec
Using hana 1.3.7
3:  hana (1.3.7) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/hana-1.3.7.gemspec
Using hashie 4.1.0
3:  hashie (4.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/hashie-4.1.0.gemspec
Using highline 2.0.3
3:  highline (2.0.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/highline-2.0.3.gemspec
Using hkdf 0.3.0
3:  hkdf (0.3.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/hkdf-0.3.0.gemspec
Using htmlentities 4.3.4
3:  htmlentities (4.3.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/htmlentities-4.3.4.gemspec
Using http_accept_language 2.1.1
3:  http_accept_language (2.1.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/http_accept_language-2.1.1.gemspec
Using image_size 2.1.0
3:  image_size (2.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/image_size-2.1.0.gemspec
Using in_threads 1.5.4
3:  in_threads (1.5.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/in_threads-1.5.4.gemspec
Using progress 3.6.0
3:  progress (3.6.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/progress-3.6.0.gemspec
Using json 2.5.1
3:  json (2.5.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/json-2.5.1.gemspec
Using uri_template 0.7.0
3:  uri_template (0.7.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/uri_template-0.7.0.gemspec
Using jwt 2.2.3
3:  jwt (2.2.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/jwt-2.2.3.gemspec
Using kgio 2.11.4
3:  kgio (2.11.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/kgio-2.11.4.gemspec
Using libv8-node 15.14.0.1 (x86_64-linux)
3:  libv8-node (15.14.0.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/libv8-node-15.14.0.1-x86_64-linux.gemspec
Using logstash-event 1.2.02
3:  logstash-event (1.2.02) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/logstash-event-1.2.02.gemspec
Using logster 2.9.6
3:  logster (2.9.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/logster-2.9.6.gemspec
Using lru_redux 1.1.0
3:  lru_redux (1.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/lru_redux-1.1.0.gemspec
Using lz4-ruby 0.3.3
3:  lz4-ruby (0.3.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/lz4-ruby-0.3.3.gemspec
Using maxminddb 0.1.22
3:  maxminddb (0.1.22) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/maxminddb-0.1.22.gemspec
Using memory_profiler 1.0.0
3:  memory_profiler (1.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/memory_profiler-1.0.0.gemspec
Fetching redis 4.3.1
Installing ffi 1.15.3 with native extensions
Installing redis 4.3.1
0:  excon (0.83.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/excon-0.83.0.gemspec
Using mini_sql 1.1.3
0:  mini_sql (1.1.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/mini_sql-1.1.3.gemspec
Using multi_json 1.15.0
0:  multi_json (1.15.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/multi_json-1.15.0.gemspec
Using multi_xml 0.6.0
0:  multi_xml (0.6.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/multi_xml-0.6.0.gemspec
Using mustache 1.1.1
0:  mustache (1.1.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/mustache-1.1.1.gemspec
Using nio4r 2.5.7
0:  nio4r (2.5.7) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/nio4r-2.5.7.gemspec
Using oauth 0.5.6
0:  oauth (0.5.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/oauth-0.5.6.gemspec
Fetching oj 3.11.7
Installing oj 3.11.7 with native extensions
3:  redis (4.3.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/redis-4.3.1.gemspec
Using optimist 3.0.1
3:  optimist (3.0.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/optimist-3.0.1.gemspec
Using pg 1.2.3
3:  pg (1.2.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/pg-1.2.3.gemspec
Using r2 0.2.7
3:  r2 (0.2.7) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/r2-0.2.7.gemspec
Using raindrops 0.19.2
3:  raindrops (0.19.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/raindrops-0.19.2.gemspec
Using rchardet 1.8.0
3:  rchardet (1.8.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rchardet-1.8.0.gemspec
Using rinku 2.0.6
3:  rinku (2.0.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rinku-2.0.6.gemspec
Using rotp 6.2.0
3:  rotp (6.2.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rotp-6.2.0.gemspec
Using rqrcode_core 1.0.0
3:  rqrcode_core (1.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rqrcode_core-1.0.0.gemspec
Using rtlit 0.0.5
3:  rtlit (0.0.5) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rtlit-0.0.5.gemspec
Using rubyzip 2.3.0
3:  rubyzip (2.3.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rubyzip-2.3.0.gemspec
Using tilt 2.0.10
3:  tilt (2.0.10) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/tilt-2.0.10.gemspec
Using sshkey 2.0.0
3:  sshkey (2.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sshkey-2.0.0.gemspec
Using stackprof 0.2.17
3:  stackprof (0.2.17) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/stackprof-0.2.17.gemspec
Using unf_ext 0.0.7.7
3:  unf_ext (0.0.7.7) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/unf_ext-0.0.7.7.gemspec
Using xorcist 1.1.2
3:  xorcist (1.1.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/xorcist-1.1.2.gemspec
Using rack-test 1.1.0
3:  rack-test (1.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rack-test-1.1.0.gemspec
Using request_store 1.5.0
3:  request_store (1.5.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/request_store-1.5.0.gemspec
Fetching message_bus 3.3.6
Installing message_bus 3.3.6
2:  concurrent-ruby (1.1.9) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/concurrent-ruby-1.1.9.gemspec
Using rack-mini-profiler 2.3.2
2:  rack-mini-profiler (2.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rack-mini-profiler-2.3.2.gemspec
Using rack-protection 2.1.0
2:  rack-protection (2.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rack-protection-2.1.0.gemspec
Using mail 2.8.0.edge from https://github.com/discourse/mail.git (at master@5b700fc)
2:  mail (2.8.0.edge) from /var/www/discourse/vendor/bundle/ruby/2.7.0/bundler/gems/mail-5b700fc95ee6/mail.gemspec
Using addressable 2.7.0
2:  addressable (2.7.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/addressable-2.7.0.gemspec
Using aws-sigv4 1.2.3
2:  aws-sigv4 (1.2.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-sigv4-1.2.3.gemspec
Using ember-data-source 3.0.2
2:  ember-data-source (3.0.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ember-data-source-3.0.2.gemspec
Using barber 0.12.2
2:  barber (0.12.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/barber-0.12.2.gemspec
Using uglifier 4.2.0
2:  uglifier (4.2.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/uglifier-4.2.0.gemspec
Using bootsnap 1.7.5
2:  bootsnap (1.7.5) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/bootsnap-1.7.5.gemspec
Using openssl-signature_algorithm 1.1.1
2:  openssl-signature_algorithm (1.1.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/openssl-signature_algorithm-1.1.1.gemspec
Using pry 0.13.1
2:  pry (0.13.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/pry-0.13.1.gemspec
Using ecma-re-validator 0.3.0
2:  ecma-re-validator (0.3.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ecma-re-validator-0.3.0.gemspec
Fetching nokogiri 1.11.7 (x86_64-linux)
Building native extensions. This could take a while...
3:  message_bus (3.3.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/message_bus-3.3.6.gemspec
Fetching faraday 1.4.3
Installing faraday 1.4.3
Installing nokogiri 1.11.7 (x86_64-linux)
3:  faraday (1.4.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-1.4.3.gemspec
Using omniauth 1.9.1
3:  omniauth (1.9.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-1.9.1.gemspec
Using image_optim 0.30.0
3:  image_optim (0.30.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/image_optim-0.30.0.gemspec
Using webpush 1.1.0
3:  webpush (1.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/webpush-1.1.0.gemspec
Using logstash-logger 0.26.1
3:  logstash-logger (0.26.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/logstash-logger-0.26.1.gemspec
Using mini_racer 0.4.0
3:  mini_racer (0.4.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/mini_racer-0.4.0.gemspec
Using puma 5.3.2
3:  puma (5.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/puma-5.3.2.gemspec
Using sidekiq 6.2.1
3:  sidekiq (6.2.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sidekiq-6.2.1.gemspec
Using redis-namespace 1.8.1
3:  redis-namespace (1.8.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/redis-namespace-1.8.1.gemspec
Using rqrcode 2.0.0
3:  rqrcode (2.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rqrcode-2.0.0.gemspec
Using unicorn 6.0.0
3:  unicorn (6.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/unicorn-6.0.0.gemspec
Using unf 0.1.4
3:  unf (0.1.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/unf-0.1.4.gemspec
Using i18n 1.8.10
3:  i18n (1.8.10) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/i18n-1.8.10.gemspec
Using tzinfo 2.0.4
3:  tzinfo (2.0.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/tzinfo-2.0.4.gemspec
Using sprockets 3.7.2
3:  sprockets (3.7.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sprockets-3.7.2.gemspec
Using aws-sdk-core 3.112.1
3:  aws-sdk-core (3.112.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-sdk-core-3.112.1.gemspec
Using css_parser 1.9.0
3:  css_parser (1.9.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/css_parser-1.9.0.gemspec
Using cose 1.2.0
3:  cose (1.2.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/cose-1.2.0.gemspec
Using json_schemer 0.2.18
3:  json_schemer (0.2.18) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/json_schemer-0.2.18.gemspec
Using pry-byebug 3.9.0
3:  pry-byebug (3.9.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/pry-byebug-3.9.0.gemspec
Using pry-rails 0.3.9
3:  pry-rails (0.3.9) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/pry-rails-0.3.9.gemspec
Using mini_scheduler 0.13.0
3:  mini_scheduler (0.13.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/mini_scheduler-0.13.0.gemspec
Using oauth2 1.4.7
3:  oauth2 (1.4.7) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/oauth2-1.4.7.gemspec
Using omniauth-oauth 1.2.0
3:  omniauth-oauth (1.2.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-oauth-1.2.0.gemspec
Using activesupport 6.1.3.2
3:  activesupport (6.1.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/activesupport-6.1.3.2.gemspec
Fetching aws-sdk-kms 1.44.0
Installing aws-sdk-kms 1.44.0
3:  aws-sdk-kms (1.44.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-sdk-kms-1.44.0.gemspec
Using aws-sdk-sns 1.38.0
3:  aws-sdk-sns (1.38.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-sdk-sns-1.38.0.gemspec
Using ember-handlebars-template 0.8.0
3:  ember-handlebars-template (0.8.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ember-handlebars-template-0.8.0.gemspec
Using omniauth-oauth2 1.7.1
3:  omniauth-oauth2 (1.7.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-oauth2-1.7.1.gemspec
Using omniauth-twitter 1.4.0
3:  omniauth-twitter (1.4.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-twitter-1.4.0.gemspec
Using globalid 0.4.2
3:  globalid (0.4.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/globalid-0.4.2.gemspec
Using activemodel 6.1.3.2
3:  activemodel (6.1.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/activemodel-6.1.3.2.gemspec
Fetching aws-sdk-s3 1.96.1
Installing aws-sdk-s3 1.96.1
3:  aws-sdk-s3 (1.96.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-sdk-s3-1.96.1.gemspec
Using activejob 6.1.3.2
3:  activejob (6.1.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/activejob-6.1.3.2.gemspec
Using active_model_serializers 0.8.4
3:  active_model_serializers (0.8.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/active_model_serializers-0.8.4.gemspec
Using activerecord 6.1.3.2
3:  activerecord (6.1.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/activerecord-6.1.3.2.gemspec
Using omniauth-facebook 8.0.0
3:  omniauth-facebook (8.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-facebook-8.0.0.gemspec
Using omniauth-github 1.4.0
3:  omniauth-github (1.4.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-github-1.4.0.gemspec
Using omniauth-google-oauth2 0.8.2
3:  omniauth-google-oauth2 (0.8.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-google-oauth2-0.8.2.gemspec
Using seed-fu 2.3.9
3:  seed-fu (2.3.9) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/seed-fu-2.3.9.gemspec
2:  nokogiri (1.11.7) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/nokogiri-1.11.7-x86_64-linux.gemspec
Fetching loofah 2.10.0
Using rails-dom-testing 2.0.3
3:  rails-dom-testing (2.0.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rails-dom-testing-2.0.3.gemspec
Using nokogumbo 2.0.5
3:  nokogumbo (2.0.5) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/nokogumbo-2.0.5.gemspec
Using ruby-readability 0.7.0
3:  ruby-readability (0.7.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ruby-readability-0.7.0.gemspec
Using sanitize 5.2.3
3:  sanitize (5.2.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sanitize-5.2.3.gemspec
Installing loofah 2.10.0
2:  loofah (2.10.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/loofah-2.10.0.gemspec
Using rails-html-sanitizer 1.3.0
3:  rails-html-sanitizer (1.3.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rails-html-sanitizer-1.3.0.gemspec
Using actionview 6.1.3.2
2:  actionview (6.1.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/actionview-6.1.3.2.gemspec
Using actionpack 6.1.3.2
3:  actionpack (6.1.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/actionpack-6.1.3.2.gemspec
Using actionview_precompiler 0.2.3
3:  actionview_precompiler (0.2.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/actionview_precompiler-0.2.3.gemspec
Using actionmailer 6.1.3.2
3:  actionmailer (6.1.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/actionmailer-6.1.3.2.gemspec
Using railties 6.1.3.2
3:  railties (6.1.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/railties-6.1.3.2.gemspec
Using sprockets-rails 3.2.2
3:  sprockets-rails (3.2.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sprockets-rails-3.2.2.gemspec
Using jquery-rails 4.4.0
2:  jquery-rails (4.4.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/jquery-rails-4.4.0.gemspec
Using lograge 0.11.2
2:  lograge (0.11.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/lograge-0.11.2.gemspec
Using rails_failover 0.7.3
2:  rails_failover (0.7.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rails_failover-0.7.3.gemspec
Using rails_multisite 3.0.0
2:  rails_multisite (3.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rails_multisite-3.0.0.gemspec
Using discourse-ember-rails 0.18.6
2:  discourse-ember-rails (0.18.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/discourse-ember-rails-0.18.6.gemspec
0:  oj (3.11.7) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/oj-3.11.7.gemspec
1:  ffi (1.15.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ffi-1.15.3.gemspec
Using mini_suffix 0.3.2
0:  mini_suffix (0.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/mini_suffix-0.3.2.gemspec
Using rbtrace 0.4.14
0:  rbtrace (0.4.14) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rbtrace-0.4.14.gemspec
Using sassc 2.0.1
0:  sassc (2.0.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sassc-2.0.1.gemspec
Using sassc-rails 2.1.2
1:  sassc-rails (2.1.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sassc-rails-2.1.2.gemspec
Bundle complete! 126 Gemfile dependencies, 169 gems now installed.
Gems in the groups 'test' and 'development' were not installed.
Bundled gems are installed into `./vendor/bundle`
I, [2021-06-30T18:11:25.032747 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake plugin:pull_compatible_all'
I, [2021-06-30T18:11:28.411968 #1]  INFO -- : docker_manager is already at latest compatible version
I, [2021-06-30T18:11:28.412905 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
I, [2021-06-30T18:11:36.837298 #1]  INFO -- :
I, [2021-06-30T18:11:36.838255 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake themes:update assets:precompile'
Failed to update Light Logos
about.json contains invalid values: Maximum discourse version is invalid
/var/www/discourse/app/models/remote_theme.rb:169:in `update_from_remote'
/var/www/discourse/lib/tasks/themes.rake:61:in `block (2 levels) in <main>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/relation/batches.rb:71:in `block (2 levels) in find_each'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/relation/batches.rb:71:in `each'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/relation/batches.rb:71:in `block in find_each'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/relation/batches.rb:138:in `block in find_in_batches'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/relation/batches.rb:245:in `block in in_batches'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/relation/batches.rb:229:in `loop'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/relation/batches.rb:229:in `in_batches'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/relation/batches.rb:137:in `find_in_batches'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/relation/batches.rb:70:in `find_each'
/var/www/discourse/lib/tasks/themes.rake:57:in `block in <main>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/task.rb:281:in `block in execute'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/task.rb:281:in `each'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/task.rb:281:in `execute'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/task.rb:219:in `block in invoke_with_call_chain'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/task.rb:199:in `synchronize'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/task.rb:199:in `invoke_with_call_chain'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/task.rb:188:in `invoke'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/application.rb:160:in `invoke_task'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/application.rb:116:in `block (2 levels) in top_level'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/application.rb:116:in `each'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/application.rb:116:in `block in top_level'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/application.rb:125:in `run_with_threads'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/application.rb:110:in `top_level'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/application.rb:83:in `block in run'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/application.rb:186:in `standard_exception_handling'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/application.rb:80:in `run'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/exe/rake:27:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/bin/rake:23:in `load'
/var/www/discourse/vendor/bundle/ruby/2.7.0/bin/rake:23:in `<top (required)>'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/lib/bundler/cli/exec.rb:63:in `load'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/lib/bundler/cli/exec.rb:63:in `kernel_load'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/lib/bundler/cli/exec.rb:28:in `run'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/lib/bundler/cli.rb:474:in `exec'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/lib/bundler/vendor/thor/lib/thor.rb:392:in `dispatch'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/lib/bundler/cli.rb:30:in `dispatch'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/lib/bundler/vendor/thor/lib/thor/base.rb:485:in `start'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/lib/bundler/cli.rb:24:in `start'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/exe/bundle:49:in `block in <top (required)>'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/lib/bundler/friendly_errors.rb:130:in `with_friendly_errors'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/exe/bundle:37:in `<top (required)>'
/usr/local/bin/bundle:23:in `load'
/usr/local/bin/bundle:23:in `<main>'
I, [2021-06-30T18:11:46.174318 #1]  INFO -- : Updating Hamburger links component...
Updating Category Banners...
Updating New Like icon...
Updating Buttons...
Updating Hamburger Theme Selector...
Updating Light Logos...
I, [2021-06-30T18:11:46.175067 #1]  INFO -- : Terminating async processes
I, [2021-06-30T18:11:46.175133 #1]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 55
I, [2021-06-30T18:11:46.175188 #1]  INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 172
2021-06-30 18:11:46.175 UTC [55] LOG:  received fast shutdown request
172:signal-handler (1625076706) Received SIGTERM scheduling shutdown...
2021-06-30 18:11:46.177 UTC [55] LOG:  aborting any active transactions
2021-06-30 18:11:46.181 UTC [55] LOG:  background worker "logical replication launcher" (PID 64) exited with exit code 1
2021-06-30 18:11:46.182 UTC [59] LOG:  shutting down
2021-06-30 18:11:46.208 UTC [55] LOG:  database system is shut down
172:M 30 Jun 2021 18:11:46.235 # User requested shutdown...
172:M 30 Jun 2021 18:11:46.235 * Saving the final RDB snapshot before exiting.
172:M 30 Jun 2021 18:11:46.825 * DB saved on disk
172:M 30 Jun 2021 18:11:46.825 # Redis is now ready to exit, bye bye...
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake themes:update assets:precompile' failed with return #<Process::Status: pid 3753 exit 1>
exec failed with the params {"cd"=>"$home", "hook"=>"assets_precompile", "cmd"=>["su discourse -c 'bundle exec rake themes:update assets:precompile'"]}
06a3eaec7a931a79157477327261a44ac39732eba872e906fdbf30068b626ca2
root@community:/var/discourse#
Thankfully the doctor brings the site back up, but I can still not rebuild.
Have plenty of memory and disk space, have tried rebooting…
Doctor Log
DISCOURSE DOCTOR Wed Jun 30 18:17:13 UTC 2021
OS: Linux community 4.4.0-210-generic #242-Ubuntu SMP Fri Apr 16 09:57:56 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
Found containers/app.yml
==================== YML SETTINGS ====================
DISCOURSE_HOSTNAME=community.naturephotographers.network
SMTP_ADDRESS=smtp.postmarkapp.com
DEVELOPER_EMAILS=editor@naturephotographers.network
SMTP_PASSWORD=redacted
SMTP_PORT=25
SMTP_USER_NAME=redacted
LETSENCRYPT_ACCOUNT_EMAIL=redacted
==================== DOCKER INFO ====================
DOCKER VERSION: Docker version 19.03.13, build 4484c46d9d
DOCKER PROCESSES (docker ps -a)
CONTAINER ID        IMAGE                           COMMAND             CREATED             STATUS                     PORTS                NAMES
aae342f545ad        local_discourse/app             "/sbin/boot"        4 weeks ago         Exited (5) 7 minutes ago                        app
b1c5b390e4fb        local_discourse/mail-receiver   "/sbin/boot"        15 months ago       Up 7 minutes               0.0.0.0:25->25/tcp   mail-receiver
==================== SERIOUS PROBLEM!!!! ====================
app not running!
Attempting to rebuild
==================== REBUILD LOG ====================
Fetching origin
Launcher is up-to-date
Stopping old container
+ /usr/bin/docker stop -t 60 app
app
cd /pups && git pull && git checkout v1.0.3 && /pups/bin/pups --stdin
From https://github.com/discourse/pups
   17f04ec..e0ff889  master     -> origin/master
 * [new tag]         v1.1.1     -> v1.1.1
 * [new tag]         v1.1.0     -> v1.1.0
Updating 17f04ec..e0ff889
Fast-forward
 .github/workflows/ci.yml     |  29 ++++++
 .github/workflows/lint.yml   |  27 +++++
 .rubocop.yml                 |   3 +
 Gemfile                      |   2 +
 Guardfile                    |   4 +-
 README.md                    |  21 ++++
 Rakefile                     |  14 +--
 bin/pups                     |   8 +-
 lib/pups.rb                  |  32 ++++--
 lib/pups/cli.rb              |  92 ++++++++++-------
 lib/pups/command.rb          |  25 +++--
 lib/pups/config.rb           | 240 +++++++++++++++++++++++--------------------
 lib/pups/docker.rb           |  69 +++++++++++++
 lib/pups/exec_command.rb     | 182 ++++++++++++++++----------------
 lib/pups/file_command.rb     |  60 +++++------
 lib/pups/merge_command.rb    |  94 ++++++++---------
 lib/pups/replace_command.rb  |  70 +++++++------
 lib/pups/runit.rb            |  47 +++++----
 lib/pups/version.rb          |   4 +-
 pups.gemspec                 |  37 ++++---
 test/cli_test.rb             | 102 +++++++++++++++---
 test/config_test.rb          | 215 ++++++++++++++++++++++++++++----------
 test/docker_test.rb          | 157 ++++++++++++++++++++++++++++
 test/exec_command_test.rb    |  62 ++++++-----
 test/file_command_test.rb    |  17 ++-
 test/merge_command_test.rb   |  64 ++++++------
 test/replace_command_test.rb |  86 ++++++++--------
 test/test_helper.rb          |   2 +
 28 files changed, 1158 insertions(+), 607 deletions(-)
 create mode 100644 .github/workflows/ci.yml
 create mode 100644 .github/workflows/lint.yml
 create mode 100644 .rubocop.yml
 create mode 100644 lib/pups/docker.rb
 create mode 100644 test/docker_test.rb
Note: checking out 'v1.0.3'.
You are in 'detached HEAD' state. You can look around, make experimental
changes and commit them, and you can discard any commits you make in this
state without impacting any branches by performing another checkout.
If you want to create a new branch to retain commits you create, you may
do so (now or later) by using -b with the checkout command again. Example:
  git checkout -b <new-branch-name>
HEAD is now at d1db030 cut a new version
I, [2021-06-30T18:17:25.316554 #1]  INFO -- : Loading --stdin
I, [2021-06-30T18:17:25.325291 #1]  INFO -- : > locale-gen $LANG && update-locale
I, [2021-06-30T18:17:25.375244 #1]  INFO -- : Generating locales (this might take a while)...
Generation complete.
I, [2021-06-30T18:17:25.375763 #1]  INFO -- : > mkdir -p /shared/postgres_run
I, [2021-06-30T18:17:25.379807 #1]  INFO -- :
I, [2021-06-30T18:17:25.380422 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run
I, [2021-06-30T18:17:25.384276 #1]  INFO -- :
I, [2021-06-30T18:17:25.384905 #1]  INFO -- : > chmod 775 /shared/postgres_run
I, [2021-06-30T18:17:25.388917 #1]  INFO -- :
I, [2021-06-30T18:17:25.389503 #1]  INFO -- : > rm -fr /var/run/postgresql
I, [2021-06-30T18:17:25.393398 #1]  INFO -- :
I, [2021-06-30T18:17:25.393989 #1]  INFO -- : > ln -s /shared/postgres_run /var/run/postgresql
I, [2021-06-30T18:17:25.397263 #1]  INFO -- :
I, [2021-06-30T18:17:25.397986 #1]  INFO -- : > socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1
2021/06/30 18:17:25 socat[32] E connect(6, AF=1 "/shared/postgres_run/.s.PGSQL.5432", 36): No such file or directory
I, [2021-06-30T18:17:25.406792 #1]  INFO -- :
I, [2021-06-30T18:17:25.407296 #1]  INFO -- : > rm -fr /shared/postgres_run/.s*
I, [2021-06-30T18:17:25.413288 #1]  INFO -- :
I, [2021-06-30T18:17:25.413916 #1]  INFO -- : > rm -fr /shared/postgres_run/*.pid
I, [2021-06-30T18:17:25.419980 #1]  INFO -- :
I, [2021-06-30T18:17:25.420551 #1]  INFO -- : > mkdir -p /shared/postgres_run/13-main.pg_stat_tmp
I, [2021-06-30T18:17:25.425664 #1]  INFO -- :
I, [2021-06-30T18:17:25.426443 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run/13-main.pg_stat_tmp
I, [2021-06-30T18:17:25.430366 #1]  INFO -- :
I, [2021-06-30T18:17:25.439005 #1]  INFO -- : File > /etc/service/postgres/run  chmod: +x  chown:
I, [2021-06-30T18:17:25.447154 #1]  INFO -- : File > /etc/service/postgres/log/run  chmod: +x  chown:
I, [2021-06-30T18:17:25.455020 #1]  INFO -- : File > /etc/runit/3.d/99-postgres  chmod: +x  chown:
I, [2021-06-30T18:17:25.462786 #1]  INFO -- : File > /root/upgrade_postgres  chmod: +x  chown:
I, [2021-06-30T18:17:25.463585 #1]  INFO -- : > chown -R root /var/lib/postgresql/13/main
I, [2021-06-30T18:17:26.617011 #1]  INFO -- :
I, [2021-06-30T18:17:26.617639 #1]  INFO -- : > [ ! -e /shared/postgres_data ] && install -d -m 0755 -o postgres -g postgres /shared/postgres_data && sudo -E -u postgres /usr/lib/postgresql/13/bin/initdb -D /shared/postgres_data || exit 0
I, [2021-06-30T18:17:26.621619 #1]  INFO -- :
I, [2021-06-30T18:17:26.621815 #1]  INFO -- : > chown -R postgres:postgres /shared/postgres_data
I, [2021-06-30T18:17:26.648876 #1]  INFO -- :
I, [2021-06-30T18:17:26.649677 #1]  INFO -- : > chown -R postgres:postgres /var/run/postgresql
I, [2021-06-30T18:17:26.654877 #1]  INFO -- :
I, [2021-06-30T18:17:26.655505 #1]  INFO -- : > /root/upgrade_postgres
I, [2021-06-30T18:17:26.664780 #1]  INFO -- :
I, [2021-06-30T18:17:26.665486 #1]  INFO -- : > rm /root/upgrade_postgres
I, [2021-06-30T18:17:26.670533 #1]  INFO -- :
I, [2021-06-30T18:17:26.671386 #1]  INFO -- : Replacing data_directory = '/var/lib/postgresql/13/main' with data_directory = '/shared/postgres_data' in /etc/postgresql/13/main/postgresql.conf
I, [2021-06-30T18:17:26.672569 #1]  INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addresses = '*' in /etc/postgresql/13/main/postgresql.conf
I, [2021-06-30T18:17:26.673331 #1]  INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchronous_commit = $db_synchronous_commit in /etc/postgresql/13/main/postgresql.conf
I, [2021-06-30T18:17:26.674116 #1]  INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffers = $db_shared_buffers in /etc/postgresql/13/main/postgresql.conf
I, [2021-06-30T18:17:26.674838 #1]  INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work_mem in /etc/postgresql/13/main/postgresql.conf
I, [2021-06-30T18:17:26.675556 #1]  INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with default_text_search_config = '$db_default_text_search_config' in /etc/postgresql/13/main/postgresql.conf
I, [2021-06-30T18:17:26.676269 #1]  INFO -- : > install -d -m 0755 -o postgres -g postgres /shared/postgres_backup
I, [2021-06-30T18:17:26.682638 #1]  INFO -- :
I, [2021-06-30T18:17:26.683568 #1]  INFO -- : Replacing (?-mix:#?checkpoint_segments *=.*) with checkpoint_segments = $db_checkpoint_segments in /etc/postgresql/13/main/postgresql.conf
I, [2021-06-30T18:17:26.684379 #1]  INFO -- : Replacing (?-mix:#?logging_collector *=.*) with logging_collector = $db_logging_collector in /etc/postgresql/13/main/postgresql.conf
I, [2021-06-30T18:17:26.685256 #1]  INFO -- : Replacing (?-mix:#?log_min_duration_statement *=.*) with log_min_duration_statement = $db_log_min_duration_statement in /etc/postgresql/13/main/postgresql.conf
I, [2021-06-30T18:17:26.686113 #1]  INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) with local replication postgres  peer in /etc/postgresql/13/main/pg_hba.conf
I, [2021-06-30T18:17:26.686787 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2021-06-30T18:17:26.687416 #1]  INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main
I, [2021-06-30T18:17:26.692123 #1]  INFO -- : > sleep 5
2021-06-30 18:17:26.737 UTC [55] LOG:  starting PostgreSQL 13.3 (Debian 13.3-1.pgdg100+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 8.3.0-6) 8.3.0, 64-bit
2021-06-30 18:17:26.738 UTC [55] LOG:  listening on IPv4 address "0.0.0.0", port 5432
2021-06-30 18:17:26.739 UTC [55] LOG:  listening on IPv6 address "::", port 5432
2021-06-30 18:17:26.741 UTC [55] LOG:  listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2021-06-30 18:17:26.747 UTC [58] LOG:  database system was shut down at 2021-06-30 18:11:46 UTC
2021-06-30 18:17:26.763 UTC [55] LOG:  database system is ready to accept connections
I, [2021-06-30T18:17:31.697021 #1]  INFO -- :
I, [2021-06-30T18:17:31.697737 #1]  INFO -- : > su postgres -c 'createdb discourse' || true
2021-06-30 18:17:31.777 UTC [68] postgres@postgres ERROR:  database "discourse" already exists
2021-06-30 18:17:31.777 UTC [68] postgres@postgres STATEMENT:  CREATE DATABASE discourse;
createdb: error: database creation failed: ERROR:  database "discourse" already exists
I, [2021-06-30T18:17:31.779604 #1]  INFO -- :
I, [2021-06-30T18:17:31.780242 #1]  INFO -- : > su postgres -c 'psql discourse -c "create user discourse;"' || true
2021-06-30 18:17:31.865 UTC [79] postgres@discourse ERROR:  role "discourse" already exists
2021-06-30 18:17:31.865 UTC [79] postgres@discourse STATEMENT:  create user discourse;
I, [2021-06-30T18:17:31.869758 #1]  INFO -- :
I, [2021-06-30T18:17:31.870295 #1]  INFO -- : > su postgres -c 'psql discourse -c "grant all privileges on database discourse to discourse;"' || true
I, [2021-06-30T18:17:31.966286 #1]  INFO -- : GRANT
I, [2021-06-30T18:17:31.966758 #1]  INFO -- : > su postgres -c 'psql discourse -c "alter schema public owner to discourse;"'
I, [2021-06-30T18:17:32.057039 #1]  INFO -- : ALTER SCHEMA
I, [2021-06-30T18:17:32.057490 #1]  INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists hstore;"'
NOTICE:  extension "hstore" already exists, skipping
I, [2021-06-30T18:17:32.174533 #1]  INFO -- : CREATE EXTENSION
I, [2021-06-30T18:17:32.175101 #1]  INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists pg_trgm;"'
NOTICE:  extension "pg_trgm" already exists, skipping
I, [2021-06-30T18:17:32.267217 #1]  INFO -- : CREATE EXTENSION
I, [2021-06-30T18:17:32.267664 #1]  INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists hstore;"'
I, [2021-06-30T18:17:32.362888 #1]  INFO -- : CREATE EXTENSION
I, [2021-06-30T18:17:32.363592 #1]  INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists pg_trgm;"'
I, [2021-06-30T18:17:32.454929 #1]  INFO -- : CREATE EXTENSION
I, [2021-06-30T18:17:32.455700 #1]  INFO -- : > sudo -u postgres psql discourse
I, [2021-06-30T18:17:32.458638 #1]  INFO -- : update pg_database set encoding = pg_char_to_encoding('UTF8') where datname = 'discourse' AND encoding = pg_char_to_encoding('SQL_ASCII');
I, [2021-06-30T18:17:32.559282 #1]  INFO -- : File > /var/lib/postgresql/take-database-backup  chmod: +x  chown: postgres:postgres
I, [2021-06-30T18:17:32.563650 #1]  INFO -- : File > /var/spool/cron/crontabs/postgres  chmod:   chown:
I, [2021-06-30T18:17:32.564227 #1]  INFO -- : > echo postgres installed!
I, [2021-06-30T18:17:32.567677 #1]  INFO -- : postgres installed!
I, [2021-06-30T18:17:32.576232 #1]  INFO -- : File > /etc/service/redis/run  chmod: +x  chown:
I, [2021-06-30T18:17:32.583981 #1]  INFO -- : File > /etc/service/redis/log/run  chmod: +x  chown:
I, [2021-06-30T18:17:32.592681 #1]  INFO -- : File > /etc/runit/3.d/10-redis  chmod: +x  chown:
I, [2021-06-30T18:17:32.593587 #1]  INFO -- : Replacing daemonize yes with  in /etc/redis/redis.conf
I, [2021-06-30T18:17:32.594795 #1]  INFO -- : Replacing (?-mix:^pidfile.*$) with  in /etc/redis/redis.conf
I, [2021-06-30T18:17:32.595747 #1]  INFO -- : > install -d -m 0755 -o redis -g redis /shared/redis_data
I, [2021-06-30T18:17:32.602308 #1]  INFO -- :
I, [2021-06-30T18:17:32.603639 #1]  INFO -- : Replacing (?-mix:^logfile.*$) with logfile "" in /etc/redis/redis.conf
I, [2021-06-30T18:17:32.604689 #1]  INFO -- : Replacing (?-mix:^bind .*$) with  in /etc/redis/redis.conf
I, [2021-06-30T18:17:32.605705 #1]  INFO -- : Replacing (?-mix:^dir .*$) with dir /shared/redis_data in /etc/redis/redis.conf
I, [2021-06-30T18:17:32.606870 #1]  INFO -- : Replacing (?-mix:^protected-mode yes) with protected-mode no in /etc/redis/redis.conf
I, [2021-06-30T18:17:32.607772 #1]  INFO -- : Replacing # io-threads 4 with io-threads $redis_io_threads in /etc/redis/redis.conf
I, [2021-06-30T18:17:32.608737 #1]  INFO -- : > echo redis installed
I, [2021-06-30T18:17:32.612692 #1]  INFO -- : redis installed
I, [2021-06-30T18:17:32.613116 #1]  INFO -- : > cat /etc/redis/redis.conf | grep logfile
I, [2021-06-30T18:17:32.618476 #1]  INFO -- : logfile ""
I, [2021-06-30T18:17:32.618947 #1]  INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2021-06-30T18:17:32.622264 #1]  INFO -- : > sleep 10
172:C 30 Jun 2021 18:17:32.630 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
172:C 30 Jun 2021 18:17:32.630 # Redis version=6.2.3, bits=64, commit=00000000, modified=0, pid=172, just started
172:C 30 Jun 2021 18:17:32.630 # Configuration loaded
172:M 30 Jun 2021 18:17:32.632 * monotonic clock: POSIX clock_gettime
172:M 30 Jun 2021 18:17:32.633 * Running mode=standalone, port=6379.
172:M 30 Jun 2021 18:17:32.633 # WARNING: The TCP backlog setting of 511 cannot be enforced because /proc/sys/net/core/somaxconn is set to the lower value of 128.
172:M 30 Jun 2021 18:17:32.633 # Server initialized
172:M 30 Jun 2021 18:17:32.634 # WARNING overcommit_memory is set to 0! Background save may fail under low memory condition. To fix this issue add 'vm.overcommit_memory = 1' to /etc/sysctl.conf and then reboot or run the command 'sysctl vm.overcommit_memory=1' for this to take effect.
172:M 30 Jun 2021 18:17:32.634 * Loading RDB produced by version 6.2.3
172:M 30 Jun 2021 18:17:32.634 * RDB age 346 seconds
172:M 30 Jun 2021 18:17:32.634 * RDB memory usage when created 103.35 Mb
172:M 30 Jun 2021 18:17:33.012 * DB loaded from disk: 0.377 seconds
172:M 30 Jun 2021 18:17:33.012 * Ready to accept connections
I, [2021-06-30T18:17:42.626128 #1]  INFO -- :
I, [2021-06-30T18:17:42.626926 #1]  INFO -- : > thpoff echo "thpoff is installed!"
I, [2021-06-30T18:17:42.632774 #1]  INFO -- : thpoff is installed!
I, [2021-06-30T18:17:42.632986 #1]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_SMTP_ADDRESS"] == "smtp.example.com"; puts "Aborting! Mail is not configured!"; exit 1; end'
I, [2021-06-30T18:17:42.760451 #1]  INFO -- :
I, [2021-06-30T18:17:42.760769 #1]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_HOSTNAME"] == "discourse.example.com"; puts "Aborting! Domain is not configured!"; exit 1; end'
I, [2021-06-30T18:17:42.888068 #1]  INFO -- :
I, [2021-06-30T18:17:42.888394 #1]  INFO -- : > /usr/local/bin/ruby -e 'if (ENV["DISCOURSE_CDN_URL"] || "")[0..1] == "//"; puts "Aborting! CDN must have a protocol specified. Once fixed you should rebake your posts now to correct all posts."; exit 1; end'
I, [2021-06-30T18:17:43.010055 #1]  INFO -- :
I, [2021-06-30T18:17:43.010302 #1]  INFO -- : > chown -R discourse /home/discourse
I, [2021-06-30T18:17:43.524337 #1]  INFO -- :
I, [2021-06-30T18:17:43.524605 #1]  INFO -- : > rm -f /etc/cron.d/anacron
I, [2021-06-30T18:17:43.528436 #1]  INFO -- :
I, [2021-06-30T18:17:43.532976 #1]  INFO -- : File > /etc/cron.d/anacron  chmod:   chown:
I, [2021-06-30T18:17:43.539437 #1]  INFO -- : File > /etc/runit/1.d/copy-env  chmod: +x  chown:
I, [2021-06-30T18:17:43.545743 #1]  INFO -- : File > /etc/service/unicorn/run  chmod: +x  chown:
I, [2021-06-30T18:17:43.552390 #1]  INFO -- : File > /etc/service/nginx/run  chmod: +x  chown:
I, [2021-06-30T18:17:43.558757 #1]  INFO -- : File > /etc/runit/3.d/01-nginx  chmod: +x  chown:
I, [2021-06-30T18:17:43.565070 #1]  INFO -- : File > /etc/runit/3.d/02-unicorn  chmod: +x  chown:
I, [2021-06-30T18:17:43.565232 #1]  INFO -- : Replacing # postgres with sv start postgres || exit 1 in /etc/service/unicorn/run
I, [2021-06-30T18:17:43.565595 #1]  INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2021-06-30T18:17:43.569186 #1]  INFO -- : > cd /var/www/discourse && git reset --hard
200:C 30 Jun 2021 18:17:43.578 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
200:C 30 Jun 2021 18:17:43.579 # Redis version=6.2.3, bits=64, commit=00000000, modified=0, pid=200, just started
200:C 30 Jun 2021 18:17:43.579 # Configuration loaded
200:M 30 Jun 2021 18:17:43.581 * monotonic clock: POSIX clock_gettime
200:M 30 Jun 2021 18:17:43.581 # Warning: Could not create server TCP listening socket *:6379: bind: Address already in use
200:M 30 Jun 2021 18:17:43.582 # Failed listening on port 6379 (TCP), aborting.
Checking out files: 100% (28860/28860), done.
I, [2021-06-30T18:17:47.138719 #1]  INFO -- : HEAD is now at 74f71503 FEATURE: Automatically timed delete stub topics after entire topic is merged into another topic (#13187)
I, [2021-06-30T18:17:47.139313 #1]  INFO -- : > cd /var/www/discourse && git clean -f
I, [2021-06-30T18:17:47.286669 #1]  INFO -- :
I, [2021-06-30T18:17:47.287144 #1]  INFO -- : > cd /var/www/discourse && git remote set-branches --add origin master
I, [2021-06-30T18:17:47.292472 #1]  INFO -- :
I, [2021-06-30T18:17:47.293091 #1]  INFO -- : > cd /var/www/discourse && git remote set-branches origin tests-passed
I, [2021-06-30T18:17:47.300084 #1]  INFO -- :
I, [2021-06-30T18:17:47.300808 #1]  INFO -- : > cd /var/www/discourse && git fetch --depth 1 origin tests-passed
From https://github.com/discourse/discourse
 * branch              tests-passed -> FETCH_HEAD
 * [new branch]        tests-passed -> origin/tests-passed
I, [2021-06-30T18:17:50.431451 #1]  INFO -- :
I, [2021-06-30T18:17:50.431892 #1]  INFO -- : > cd /var/www/discourse && git checkout tests-passed
Switched to a new branch 'tests-passed'
I, [2021-06-30T18:17:51.485788 #1]  INFO -- : Branch 'tests-passed' set up to track remote branch 'tests-passed' from 'origin'.
I, [2021-06-30T18:17:51.486332 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp
I, [2021-06-30T18:17:51.492407 #1]  INFO -- :
I, [2021-06-30T18:17:51.492618 #1]  INFO -- : > cd /var/www/discourse && chown discourse:www-data tmp
I, [2021-06-30T18:17:51.499617 #1]  INFO -- :
I, [2021-06-30T18:17:51.499785 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp/pids
I, [2021-06-30T18:17:51.506467 #1]  INFO -- :
I, [2021-06-30T18:17:51.506698 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp/sockets
I, [2021-06-30T18:17:51.513837 #1]  INFO -- :
I, [2021-06-30T18:17:51.514417 #1]  INFO -- : > cd /var/www/discourse && touch tmp/.gitkeep
I, [2021-06-30T18:17:51.519961 #1]  INFO -- :
I, [2021-06-30T18:17:51.520531 #1]  INFO -- : > cd /var/www/discourse && mkdir -p                    /shared/log/rails
I, [2021-06-30T18:17:51.526477 #1]  INFO -- :
I, [2021-06-30T18:17:51.527100 #1]  INFO -- : > cd /var/www/discourse && bash -c "touch -a           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log"
I, [2021-06-30T18:17:51.535696 #1]  INFO -- :
I, [2021-06-30T18:17:51.536338 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log /var/www/discourse/log"
I, [2021-06-30T18:17:51.544007 #1]  INFO -- :
I, [2021-06-30T18:17:51.544172 #1]  INFO -- : > cd /var/www/discourse && bash -c "mkdir -p           /shared/{uploads,backups}"
I, [2021-06-30T18:17:51.552564 #1]  INFO -- :
I, [2021-06-30T18:17:51.552707 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/{uploads,backups} /var/www/discourse/public"
I, [2021-06-30T18:17:51.560949 #1]  INFO -- :
I, [2021-06-30T18:17:51.561148 #1]  INFO -- : > cd /var/www/discourse && bash -c "mkdir -p           /shared/tmp/{backups,restores}"
I, [2021-06-30T18:17:51.569336 #1]  INFO -- :
I, [2021-06-30T18:17:51.570021 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/tmp/{backups,restores} /var/www/discourse/tmp"
I, [2021-06-30T18:17:51.577082 #1]  INFO -- :
I, [2021-06-30T18:17:51.577679 #1]  INFO -- : > cd /var/www/discourse && chown -R discourse:www-data /shared/log/rails /shared/uploads /shared/backups /shared/tmp
I, [2021-06-30T18:17:51.584070 #1]  INFO -- :
I, [2021-06-30T18:17:51.584668 #1]  INFO -- : > cd /var/www/discourse && find public/plugins/ -maxdepth 1 -xtype l -delete
I, [2021-06-30T18:17:51.589576 #1]  INFO -- :
I, [2021-06-30T18:17:51.590168 #1]  INFO -- : Replacing # redis with sv start redis || exit 1 in /etc/service/unicorn/run
I, [2021-06-30T18:17:51.590754 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/docker_manager.git
Cloning into 'docker_manager'...
I, [2021-06-30T18:17:52.829840 #1]  INFO -- :
I, [2021-06-30T18:17:52.830638 #1]  INFO -- : > cp /var/www/discourse/config/nginx.sample.conf /etc/nginx/conf.d/discourse.conf
I, [2021-06-30T18:17:52.836459 #1]  INFO -- :
I, [2021-06-30T18:17:52.837197 #1]  INFO -- : > rm /etc/nginx/sites-enabled/default
I, [2021-06-30T18:17:52.841841 #1]  INFO -- :
I, [2021-06-30T18:17:52.842416 #1]  INFO -- : > mkdir -p /var/nginx/cache
I, [2021-06-30T18:17:52.846834 #1]  INFO -- :
I, [2021-06-30T18:17:52.847480 #1]  INFO -- : Replacing pid /run/nginx.pid; with daemon off; in /etc/nginx/nginx.conf
I, [2021-06-30T18:17:52.848166 #1]  INFO -- : Replacing (?m-ix:upstream[^\}]+\}) with upstream discourse { server 127.0.0.1:3000; } in /etc/nginx/conf.d/discourse.conf
I, [2021-06-30T18:17:52.848798 #1]  INFO -- : Replacing (?-mix:server_name.+$) with server_name _ ; in /etc/nginx/conf.d/discourse.conf
I, [2021-06-30T18:17:52.849394 #1]  INFO -- : Replacing (?-mix:client_max_body_size.+$) with client_max_body_size $upload_size ; in /etc/nginx/conf.d/discourse.conf
I, [2021-06-30T18:17:52.850034 #1]  INFO -- : > echo "done configuring web"
I, [2021-06-30T18:17:52.853919 #1]  INFO -- : done configuring web
I, [2021-06-30T18:17:52.854747 #1]  INFO -- : > cd /var/www/discourse && gem install bundler --conservative -v $(awk '/BUNDLED WITH/ { getline; gsub(/ /,""); print $0 }' Gemfile.lock)
I, [2021-06-30T18:17:53.802093 #1]  INFO -- : Successfully installed bundler-2.2.19
1 gem installed
I, [2021-06-30T18:17:53.802290 #1]  INFO -- : > cd /var/www/discourse && find /var/www/discourse ! -user discourse -exec chown discourse {} \+
I, [2021-06-30T18:17:57.009782 #1]  INFO -- :
I, [2021-06-30T18:17:57.010500 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle install --deployment --retry 3 --jobs 4 --verbose --without test development'
[DEPRECATED] The `--deployment` flag is deprecated because it relies on being remembered across bundler invocations, which bundler will no longer do in future versions. Instead please use `bundle config set --local deployment 'true'`, and stop using this flag
[DEPRECATED] The `--without` flag is deprecated because it relies on being remembered across bundler invocations, which bundler will no longer do in future versions. Instead please use `bundle config set --local without 'test development'`, and stop using this flag
I, [2021-06-30T18:18:35.157341 #1]  INFO -- : Running `bundle install --deployment --jobs 4 --retry 3 --verbose --without "test" "development"` with bundler 2.2.19
Frozen, using resolution from the lockfile
The definition is missing ["concurrent-ruby-1.1.9", "nokogiri-1.11.7-x86_64-linux", "loofah-2.10.0", "aws-sdk-kms-1.44.0", "aws-sdk-s3-1.96.1", "excon-0.83.0", "faraday-1.4.3", "fastimage-2.2.4", "ffi-1.15.3", "message_bus-3.3.6", "redis-4.3.1", "oj-3.11.7"]
HTTP GET https://index.rubygems.org/versions
HTTP 416 Range Not Satisfiable https://index.rubygems.org/versions
HTTP 200 OK https://index.rubygems.org/versions
Fetching gem metadata from https://rubygems.org/
Double checking for ["rake", "concurrent-ruby", "i18n", "minitest", "tzinfo", "zeitwerk", "activesupport", "builder", "erubi", "racc", "nokogiri", "rails-dom-testing", "crass", "loofah", "rails-html-sanitizer", "actionview", "rack", "rack-test", "actionpack", "globalid", "activejob", "mini_mime", "actionmailer", "actionview_precompiler", "activemodel", "active_model_serializers", "activerecord", "public_suffix", "addressable", "aws-eventstream", "aws-partitions", "aws-sigv4", "jmespath", "aws-sdk-core", "aws-sdk-kms", "aws-sdk-s3", "aws-sdk-sns", "ember-source", "execjs", "barber", "msgpack", "bootsnap", "byebug", "cbor", "chunky_png", "coderay", "colored2", "connection_pool", "openssl", "openssl-signature_algorithm", "cose", "cppjieba_rb", "css_parser", "diffy", "ember-data-source", "sprockets", "ember-handlebars-template", "method_source", "thor", "railties", "jquery-rails", "discourse-ember-rails", "discourse-ember-source", "discourse-fonts", "regexp_parser", "ecma-re-validator", "email_reply_trimmer", "excon", "exifr", "faraday-em_http", "faraday-em_synchrony", "faraday-excon", "faraday-net_http", "faraday-net_http_persistent", "multipart-post", "ruby2_keywords", "faraday", "fast_blank", "fast_xs", "fastimage", "ffi", "fspath", "gc_tracer", "guess_html_encoding", "hana", "hashie", "highline", "hkdf", "htmlentities", "http_accept_language", "image_size", "in_threads", "progress", "image_optim", "json", "uri_template", "json_schemer", "jwt", "kgio", "libv8-node", "request_store", "lograge", "logstash-event", "logstash-logger", "logster", "lru_redux", "lz4-ruby", "maxminddb", "memory_profiler", "message_bus", "mini_racer", "redis", "sidekiq", "mini_scheduler", "mini_sql", "mini_suffix", "multi_json", "multi_xml", "mustache", "nio4r", "nokogumbo", "oauth", "oauth2", "oj", "omniauth", "omniauth-oauth2", "omniauth-facebook", "omniauth-github", "omniauth-google-oauth2", "omniauth-oauth", "omniauth-twitter", "optimist", "pg", "pry", "pry-byebug", "pry-rails", "puma", "r2", "rack-mini-profiler", "rack-protection", "rails_failover", "rails_multisite", "raindrops", "rbtrace", "rchardet", "redis-namespace", "rinku", "rotp", "rqrcode_core", "rqrcode", "rtlit", "ruby-readability", "rubyzip", "sanitize", "sassc", "sprockets-rails", "tilt", "sassc-rails", "seed-fu", "sshkey", "stackprof", "uglifier", "unf_ext", "unf", "unicorn", "webpush", "xorcist"] in rubygems repository https://rubygems.org/ or installed locally
Looking up gems ["rake", "concurrent-ruby", "i18n", "minitest", "tzinfo", "zeitwerk", "activesupport", "builder", "erubi", "racc", "nokogiri", "rails-dom-testing", "crass", "loofah", "rails-html-sanitizer", "actionview", "rack", "rack-test", "actionpack", "globalid", "activejob", "mini_mime", "actionmailer", "actionview_precompiler", "activemodel", "active_model_serializers", "activerecord", "public_suffix", "addressable", "aws-eventstream", "aws-partitions", "aws-sigv4", "jmespath", "aws-sdk-core", "aws-sdk-kms", "aws-sdk-s3", "aws-sdk-sns", "ember-source", "execjs", "barber", "msgpack", "bootsnap", "byebug", "cbor", "chunky_png", "coderay", "colored2", "connection_pool", "openssl", "openssl-signature_algorithm", "cose", "cppjieba_rb", "css_parser", "diffy", "ember-data-source", "sprockets", "ember-handlebars-template", "method_source", "thor", "railties", "jquery-rails", "discourse-ember-rails", "discourse-ember-source", "discourse-fonts", "regexp_parser", "ecma-re-validator", "email_reply_trimmer", "excon", "exifr", "faraday-em_http", "faraday-em_synchrony", "faraday-excon", "faraday-net_http", "faraday-net_http_persistent", "multipart-post", "ruby2_keywords", "faraday", "fast_blank", "fast_xs", "fastimage", "ffi", "fspath", "gc_tracer", "guess_html_encoding", "hana", "hashie", "highline", "hkdf", "htmlentities", "http_accept_language", "image_size", "in_threads", "progress", "image_optim", "json", "uri_template", "json_schemer", "jwt", "kgio", "libv8-node", "request_store", "lograge", "logstash-event", "logstash-logger", "logster", "lru_redux", "lz4-ruby", "maxminddb", "memory_profiler", "message_bus", "mini_racer", "redis", "sidekiq", "mini_scheduler", "mini_sql", "mini_suffix", "multi_json", "multi_xml", "mustache", "nio4r", "nokogumbo", "oauth", "oauth2", "oj", "omniauth", "omniauth-oauth2", "omniauth-facebook", "omniauth-github", "omniauth-google-oauth2", "omniauth-oauth", "omniauth-twitter", "optimist", "pg", "pry", "pry-byebug", "pry-rails", "puma", "r2", "rack-mini-profiler", "rack-protection", "rails_failover", "rails_multisite", "raindrops", "rbtrace", "rchardet", "redis-namespace", "rinku", "rotp", "rqrcode_core", "rqrcode", "rtlit", "ruby-readability", "rubyzip", "sanitize", "sassc", "sprockets-rails", "tilt", "sassc-rails", "seed-fu", "sshkey", "stackprof", "uglifier", "unf_ext", "unf", "unicorn", "webpush", "xorcist"]
HTTP GET https://index.rubygems.org/info/concurrent-ruby
HTTP GET https://index.rubygems.org/info/nokogiri
HTTP GET https://index.rubygems.org/info/loofah
HTTP GET https://index.rubygems.org/info/actionview
HTTP GET https://index.rubygems.org/info/actionpack
HTTP GET https://index.rubygems.org/info/actionmailer
HTTP GET https://index.rubygems.org/info/activemodel
HTTP GET https://index.rubygems.org/info/activerecord
HTTP GET https://index.rubygems.org/info/aws-sdk-core
HTTP GET https://index.rubygems.org/info/aws-sdk-s3
HTTP GET https://index.rubygems.org/info/aws-sdk-sns
HTTP GET https://index.rubygems.org/info/cppjieba_rb
HTTP GET https://index.rubygems.org/info/railties
HTTP GET https://index.rubygems.org/info/activejob
HTTP GET https://index.rubygems.org/info/excon
HTTP GET https://index.rubygems.org/info/faraday
HTTP GET https://index.rubygems.org/info/aws-sdk-kms
HTTP GET https://index.rubygems.org/info/aws-partitions
HTTP 206 Partial Content https://index.rubygems.org/info/concurrent-ruby
HTTP GET https://index.rubygems.org/info/fastimage
HTTP GET https://index.rubygems.org/info/activesupport
HTTP GET https://index.rubygems.org/info/ffi
HTTP 206 Partial Content https://index.rubygems.org/info/excon
HTTP 206 Partial Content https://index.rubygems.org/info/activejob
HTTP GET https://index.rubygems.org/info/redis
HTTP 206 Partial Content https://index.rubygems.org/info/nokogiri
HTTP 206 Partial Content https://index.rubygems.org/info/aws-sdk-core
HTTP 206 Partial Content https://index.rubygems.org/info/faraday
HTTP 206 Partial Content https://index.rubygems.org/info/activesupport
HTTP 206 Partial Content https://index.rubygems.org/info/actionpack
HTTP 206 Partial Content https://index.rubygems.org/info/railties
HTTP 206 Partial Content https://index.rubygems.org/info/redis
HTTP 206 Partial Content https://index.rubygems.org/info/actionmailer
HTTP GET https://index.rubygems.org/info/oj
HTTP 206 Partial Content https://index.rubygems.org/info/ffi
HTTP 206 Partial Content https://index.rubygems.org/info/activemodel
HTTP 206 Partial Content https://index.rubygems.org/info/oj
HTTP 206 Partial Content https://index.rubygems.org/info/aws-partitions
HTTP 206 Partial Content https://index.rubygems.org/info/fastimage
HTTP 206 Partial Content https://index.rubygems.org/info/loofah
HTTP 206 Partial Content https://index.rubygems.org/info/aws-sdk-s3
HTTP GET https://index.rubygems.org/info/message_bus
HTTP 206 Partial Content https://index.rubygems.org/info/activerecord
HTTP 206 Partial Content https://index.rubygems.org/info/aws-sdk-sns
HTTP 206 Partial Content https://index.rubygems.org/info/cppjieba_rb
HTTP 206 Partial Content https://index.rubygems.org/info/actionview
HTTP 206 Partial Content https://index.rubygems.org/info/aws-sdk-kms
HTTP 206 Partial Content https://index.rubygems.org/info/message_bus
Looking up gems ["thread_safe", "rails-deprecated_sanitizer", "jsonapi", "case_transform", "jsonapi-renderer", "rspec", "json_pure", "handlebars-source", "ember-template-compiler-source", "snappy", "rdoc", "hike", "ruby_parser", "rails", "net-http-persistent", "hoe", "rake-compiler", "rb-appscript", "xattr", "ffi-xattr", "termios", "rdf", "stud", "columnize", "debugger-linecache", "slop", "rb-readline", "libv8", "celluloid", "compass", "sass", "sprockets-sass", "sinatra", "slim", "memcache-client", "faraday-middleware", "httpauth", "ruby-hmac", "bigdecimal", "functional-ruby", "ref", "oa-core", "oa-oauth", "oa-openid", "oa-basic", "oa-enterprise", "oa-more", "jamespath", "http-2", "escape_utils", "listen", "trollop", "base32", "hpricot", "mail", "text-format", "erubis", "rack-mount", "rack-cache", "journey", "therubyracer", "bcrypt-ruby", "win32console", "yard", "spoon", "activemodel-globalid", "rack-ssl", "arel", "activerecord-deprecated_finders", "bundler", "weakling", "mini_portile", "mini_portile2", "pkg-config", "pry-doc", "eventmachine", "thin"]
HTTP GET https://index.rubygems.org/info/rails
HTTP GET https://index.rubygems.org/info/rdf
HTTP GET https://index.rubygems.org/info/slop
HTTP 206 Partial Content https://index.rubygems.org/info/rails
HTTP GET https://index.rubygems.org/info/bundler
HTTP 206 Partial Content https://index.rubygems.org/info/bundler
HTTP 206 Partial Content https://index.rubygems.org/info/slop
HTTP 206 Partial Content https://index.rubygems.org/info/rdf
HTTP GET https://index.rubygems.org/info/mini_portile2
HTTP GET https://index.rubygems.org/info/hoe
HTTP 206 Partial Content https://index.rubygems.org/info/mini_portile2
HTTP 206 Partial Content https://index.rubygems.org/info/hoe
Looking up gems ["atomic", "rspec-core", "rspec-expectations", "rspec-mocks", "spruz", "ParseTree", "sexp_processor", "metriks", "ruby_core_source", "debugger-ruby_core_source", "sprockets-helpers", "mongrel", "backports", "mustermann", "temple", "rack-openid", "ruby-openid-apps-discovery", "restclient", "rest-client", "net-ldap", "rubyntlm", "pyu-ruby-sasl", "uuid", "XMLCanonicalizer", "rb-fchange", "rb-fsevent", "rb-inotify", "rb-kqueue", "celluloid-io", "ruby_dep", "curses", "text-hyphen", "abstract", "multimap", "bcrypt", "haml", "fssm", "compass-core", "compass-import-once", "jsonapi-parser", "timers", "facter", "celluloid-essentials", "celluloid-extras", "celluloid-fsm", "celluloid-pool", "celluloid-supervision", "dotenv", "nenv", "rspec-logsplit", "snappy-jars", "mime-types", "treetop", "tlsmail", "ZenTest", "RubyInline", "activeresource", "actionwebservice", "actioncable", "activestorage", "actionmailbox", "actiontext", "sass-listen", "daemons", "link_header", "hamster", "net-ftp", "rubyforge", "gemcutter"]
HTTP GET https://index.rubygems.org/info/actionmailbox
HTTP GET https://index.rubygems.org/info/facter
HTTP 206 Partial Content https://index.rubygems.org/info/actionmailbox
HTTP GET https://index.rubygems.org/info/net-ftp
HTTP GET https://index.rubygems.org/info/curses
HTTP GET https://index.rubygems.org/info/actiontext
HTTP 206 Partial Content https://index.rubygems.org/info/facter
HTTP 206 Partial Content https://index.rubygems.org/info/curses
HTTP 200 OK https://index.rubygems.org/info/net-ftp
HTTP GET https://index.rubygems.org/info/activestorage
HTTP GET https://index.rubygems.org/info/actioncable
HTTP 206 Partial Content https://index.rubygems.org/info/actiontext
HTTP 206 Partial Content https://index.rubygems.org/info/activestorage
HTTP 206 Partial Content https://index.rubygems.org/info/actioncable
Looking up gems ["rspec-support", "diff-lcs", "SexpProcessor", "hitimes", "rbtree", "faraday_middleware", "yajl-ruby", "avl_tree", "archive-tar-minitar", "cgi_multipart_eof_fix", "fastthread", "gem_plugin", "tool", "ruby-openid", "netrc", "http-cookie", "http-accept", "macaddr", "celluloid-gems", "coveralls", "rubocop", "dotenv-deployment", "log4r", "facets", "polyglot", "win32-api", "mime-types-data", "rails-observers", "activemodel-serializers-xml", "net-scp", "CFPropertyList", "sys-admin", "win32-dir", "windows-api", "windows-pr", "win32-security", "hocon", "net-protocol", "time", "marcel", "mimemagic", "coffee-rails", "em-hiredis", "faye-websocket", "websocket-driver"]
HTTP GET https://index.rubygems.org/info/http-cookie
HTTP GET https://index.rubygems.org/info/rubocop
HTTP GET https://index.rubygems.org/info/websocket-driver
HTTP 206 Partial Content https://index.rubygems.org/info/http-cookie
HTTP 206 Partial Content https://index.rubygems.org/info/rubocop
HTTP GET https://index.rubygems.org/info/time
HTTP 206 Partial Content https://index.rubygems.org/info/websocket-driver
HTTP 200 OK https://index.rubygems.org/info/time
HTTP GET https://index.rubygems.org/info/net-protocol
HTTP 200 OK https://index.rubygems.org/info/net-protocol
Looking up gems ["minitar", "minitar-cli", "ruby-yadis", "systemu", "colorize", "simplecov", "term-ansicolor", "tins", "test-unit", "net-ssh", "libxml-ruby", "ffi-win32-extensions", "coffee-script", "configuration", "mkrf", "domain_name", "sqlite3", "hiredis", "roauth", "websocket-extensions", "rainbow", "parser", "powerpack", "ruby-progressbar", "astrolabe", "unicode-display_width", "parallel", "jaro_winkler", "psych", "rexml", "rubocop-ast", "io-wait", "timeout"]
HTTP GET https://index.rubygems.org/info/io-wait
HTTP GET https://index.rubygems.org/info/timeout
HTTP 200 OK https://index.rubygems.org/info/io-wait
HTTP 200 OK https://index.rubygems.org/info/timeout
HTTP GET https://index.rubygems.org/info/psych
HTTP GET https://index.rubygems.org/info/test-unit
HTTP 206 Partial Content https://index.rubygems.org/info/psych
HTTP 206 Partial Content https://index.rubygems.org/info/test-unit
Looking up gems ["powerbar", "sync", "coffee-script-source", "ast", "strscan", "needle", "jruby-pageant", "bcrypt_pbkdf", "rbnacl", "rbnacl-libsodium", "simplecov-html", "docile", "lockfile", "simplecov_json_formatter", "jar-dependencies", "power_assert"]
Looking up gems ["ansi", "ruby-maven", "pattern-match"]
Looking up gems ["maven-tools", "ruby-maven-libs"]
Looking up gems ["virtus"]
HTTP GET https://index.rubygems.org/info/virtus
HTTP 206 Partial Content https://index.rubygems.org/info/virtus
Looking up gems ["descendants_tracker", "axiom-types", "coercible", "equalizer"]
Looking up gems ["ice_nine", "adamantium"]
Looking up gems ["memoizable"]
Using rake 13.0.3
0:  rake (13.0.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rake-13.0.3.gemspec
Using minitest 5.14.4
0:  minitest (5.14.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/minitest-5.14.4.gemspec
Using zeitwerk 2.4.2
0:  zeitwerk (2.4.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/zeitwerk-2.4.2.gemspec
Using builder 3.2.4
0:  builder (3.2.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/builder-3.2.4.gemspec
Using erubi 1.10.0
0:  erubi (1.10.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/erubi-1.10.0.gemspec
Using racc 1.5.2
0:  racc (1.5.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/racc-1.5.2.gemspec
Using crass 1.0.6
0:  crass (1.0.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/crass-1.0.6.gemspec
Using rack 2.2.3
0:  rack (2.2.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rack-2.2.3.gemspec
Using mini_mime 1.1.0
0:  mini_mime (1.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/mini_mime-1.1.0.gemspec
Using public_suffix 4.0.6
0:  public_suffix (4.0.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/public_suffix-4.0.6.gemspec
Using aws-eventstream 1.1.1
0:  aws-eventstream (1.1.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-eventstream-1.1.1.gemspec
Using aws-partitions 1.432.0
0:  aws-partitions (1.432.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-partitions-1.432.0.gemspec
Using jmespath 1.4.0
0:  jmespath (1.4.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/jmespath-1.4.0.gemspec
Using ember-source 2.18.2
0:  ember-source (2.18.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ember-source-2.18.2.gemspec
Using execjs 2.8.1
0:  execjs (2.8.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/execjs-2.8.1.gemspec
Using msgpack 1.4.2
0:  msgpack (1.4.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/msgpack-1.4.2.gemspec
Using bundler 2.2.19
0:  bundler (2.2.19) from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/lib/bundler/source
Using byebug 11.1.3
0:  byebug (11.1.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/byebug-11.1.3.gemspec
Using cbor 0.5.9.6
0:  cbor (0.5.9.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/cbor-0.5.9.6.gemspec
Using chunky_png 1.4.0
0:  chunky_png (1.4.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/chunky_png-1.4.0.gemspec
Using coderay 1.1.3
0:  coderay (1.1.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/coderay-1.1.3.gemspec
Using colored2 3.1.2
0:  colored2 (3.1.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/colored2-3.1.2.gemspec
Using connection_pool 2.2.5
0:  connection_pool (2.2.5) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/connection_pool-2.2.5.gemspec
Using openssl 2.2.0
0:  openssl (2.2.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/openssl-2.2.0.gemspec
Using cppjieba_rb 0.3.3
0:  cppjieba_rb (0.3.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/cppjieba_rb-0.3.3.gemspec
Using diffy 3.4.0
0:  diffy (3.4.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/diffy-3.4.0.gemspec
Using method_source 1.0.0
0:  method_source (1.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/method_source-1.0.0.gemspec
Using thor 1.1.0
0:  thor (1.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/thor-1.1.0.gemspec
Using discourse-ember-source 3.12.2.3
0:  discourse-ember-source (3.12.2.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/discourse-ember-source-3.12.2.3.gemspec
Using discourse-fonts 0.0.8
0:  discourse-fonts (0.0.8) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/discourse-fonts-0.0.8.gemspec
Using regexp_parser 2.1.1
0:  regexp_parser (2.1.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/regexp_parser-2.1.1.gemspec
Using email_reply_trimmer 0.1.13
0:  email_reply_trimmer (0.1.13) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/email_reply_trimmer-0.1.13.gemspec
Fetching excon 0.83.0
Using exifr 1.3.9
3:  exifr (1.3.9) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/exifr-1.3.9.gemspec
Using faraday-em_http 1.0.0
2:  faraday-em_http (1.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-em_http-1.0.0.gemspec
Using faraday-em_synchrony 1.0.0
2:  faraday-em_synchrony (1.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-em_synchrony-1.0.0.gemspec
Using faraday-excon 1.1.0
2:  faraday-excon (1.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-excon-1.1.0.gemspec
Using faraday-net_http 1.0.1
2:  faraday-net_http (1.0.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-net_http-1.0.1.gemspec
Using faraday-net_http_persistent 1.1.0
2:  faraday-net_http_persistent (1.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-net_http_persistent-1.1.0.gemspec
Using multipart-post 2.1.1
2:  multipart-post (2.1.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/multipart-post-2.1.1.gemspec
Using ruby2_keywords 0.0.4
2:  ruby2_keywords (0.0.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ruby2_keywords-0.0.4.gemspec
Using fast_blank 1.0.0
2:  fast_blank (1.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/fast_blank-1.0.0.gemspec
Using fast_xs 0.8.0
2:  fast_xs (0.8.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/fast_xs-0.8.0.gemspec
Fetching fastimage 2.2.4
Fetching concurrent-ruby 1.1.9
Fetching ffi 1.15.3
Installing fastimage 2.2.4
Installing excon 0.83.0
2:  fastimage (2.2.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/fastimage-2.2.4.gemspec
Using fspath 3.1.2
2:  fspath (3.1.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/fspath-3.1.2.gemspec
Using gc_tracer 1.5.1
2:  gc_tracer (1.5.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/gc_tracer-1.5.1.gemspec
Using guess_html_encoding 0.0.11
2:  guess_html_encoding (0.0.11) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/guess_html_encoding-0.0.11.gemspec
Using hana 1.3.7
2:  hana (1.3.7) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/hana-1.3.7.gemspec
Using hashie 4.1.0
2:  hashie (4.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/hashie-4.1.0.gemspec
Using highline 2.0.3
2:  highline (2.0.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/highline-2.0.3.gemspec
Using hkdf 0.3.0
2:  hkdf (0.3.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/hkdf-0.3.0.gemspec
Using htmlentities 4.3.4
2:  htmlentities (4.3.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/htmlentities-4.3.4.gemspec
Using http_accept_language 2.1.1
2:  http_accept_language (2.1.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/http_accept_language-2.1.1.gemspec
Using image_size 2.1.0
2:  image_size (2.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/image_size-2.1.0.gemspec
Using in_threads 1.5.4
2:  in_threads (1.5.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/in_threads-1.5.4.gemspec
Using progress 3.6.0
2:  progress (3.6.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/progress-3.6.0.gemspec
Using json 2.5.1
2:  json (2.5.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/json-2.5.1.gemspec
Using uri_template 0.7.0
2:  uri_template (0.7.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/uri_template-0.7.0.gemspec
Using jwt 2.2.3
2:  jwt (2.2.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/jwt-2.2.3.gemspec
Using kgio 2.11.4
2:  kgio (2.11.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/kgio-2.11.4.gemspec
Using libv8-node 15.14.0.1 (x86_64-linux)
2:  libv8-node (15.14.0.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/libv8-node-15.14.0.1-x86_64-linux.gemspec
Using logstash-event 1.2.02
2:  logstash-event (1.2.02) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/logstash-event-1.2.02.gemspec
Using logster 2.9.6
2:  logster (2.9.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/logster-2.9.6.gemspec
Using lru_redux 1.1.0
2:  lru_redux (1.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/lru_redux-1.1.0.gemspec
Using lz4-ruby 0.3.3
2:  lz4-ruby (0.3.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/lz4-ruby-0.3.3.gemspec
Installing concurrent-ruby 1.1.9
Using maxminddb 0.1.22
2:  maxminddb (0.1.22) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/maxminddb-0.1.22.gemspec
Using memory_profiler 1.0.0
2:  memory_profiler (1.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/memory_profiler-1.0.0.gemspec
Fetching redis 4.3.1
Installing redis 4.3.1
Installing ffi 1.15.3 with native extensions
0:  excon (0.83.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/excon-0.83.0.gemspec
Using mini_sql 1.1.3
0:  mini_sql (1.1.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/mini_sql-1.1.3.gemspec
Using multi_json 1.15.0
0:  multi_json (1.15.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/multi_json-1.15.0.gemspec
Using multi_xml 0.6.0
0:  multi_xml (0.6.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/multi_xml-0.6.0.gemspec
Using mustache 1.1.1
0:  mustache (1.1.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/mustache-1.1.1.gemspec
Using nio4r 2.5.7
0:  nio4r (2.5.7) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/nio4r-2.5.7.gemspec
Using oauth 0.5.6
0:  oauth (0.5.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/oauth-0.5.6.gemspec
Fetching oj 3.11.7
2:  redis (4.3.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/redis-4.3.1.gemspec
Using optimist 3.0.1
2:  optimist (3.0.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/optimist-3.0.1.gemspec
Using pg 1.2.3
2:  pg (1.2.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/pg-1.2.3.gemspec
Using r2 0.2.7
2:  r2 (0.2.7) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/r2-0.2.7.gemspec
Using raindrops 0.19.2
2:  raindrops (0.19.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/raindrops-0.19.2.gemspec
Using rchardet 1.8.0
2:  rchardet (1.8.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rchardet-1.8.0.gemspec
Using rinku 2.0.6
2:  rinku (2.0.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rinku-2.0.6.gemspec
Using rotp 6.2.0
2:  rotp (6.2.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rotp-6.2.0.gemspec
Using rqrcode_core 1.0.0
2:  rqrcode_core (1.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rqrcode_core-1.0.0.gemspec
Using rtlit 0.0.5
2:  rtlit (0.0.5) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rtlit-0.0.5.gemspec
Using rubyzip 2.3.0
2:  rubyzip (2.3.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rubyzip-2.3.0.gemspec
Using tilt 2.0.10
2:  tilt (2.0.10) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/tilt-2.0.10.gemspec
Using sshkey 2.0.0
2:  sshkey (2.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sshkey-2.0.0.gemspec
Using stackprof 0.2.17
2:  stackprof (0.2.17) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/stackprof-0.2.17.gemspec
Using unf_ext 0.0.7.7
2:  unf_ext (0.0.7.7) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/unf_ext-0.0.7.7.gemspec
Using xorcist 1.1.2
2:  xorcist (1.1.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/xorcist-1.1.2.gemspec
Fetching nokogiri 1.11.7 (x86_64-linux)
Installing oj 3.11.7 with native extensions
1:  concurrent-ruby (1.1.9) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/concurrent-ruby-1.1.9.gemspec
Using rack-test 1.1.0
1:  rack-test (1.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rack-test-1.1.0.gemspec
Using mail 2.8.0.edge from https://github.com/discourse/mail.git (at master@5b700fc)
1:  mail (2.8.0.edge) from /var/www/discourse/vendor/bundle/ruby/2.7.0/bundler/gems/mail-5b700fc95ee6/mail.gemspec
Using addressable 2.7.0
1:  addressable (2.7.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/addressable-2.7.0.gemspec
Using aws-sigv4 1.2.3
1:  aws-sigv4 (1.2.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-sigv4-1.2.3.gemspec
Using barber 0.12.2
1:  barber (0.12.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/barber-0.12.2.gemspec
Using bootsnap 1.7.5
1:  bootsnap (1.7.5) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/bootsnap-1.7.5.gemspec
Using openssl-signature_algorithm 1.1.1
1:  openssl-signature_algorithm (1.1.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/openssl-signature_algorithm-1.1.1.gemspec
Using ember-data-source 3.0.2
1:  ember-data-source (3.0.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ember-data-source-3.0.2.gemspec
Using ecma-re-validator 0.3.0
1:  ecma-re-validator (0.3.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ecma-re-validator-0.3.0.gemspec
Fetching faraday 1.4.3
Installing nokogiri 1.11.7 (x86_64-linux)
Installing faraday 1.4.3
Building native extensions. This could take a while...
1:  faraday (1.4.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-1.4.3.gemspec
Using request_store 1.5.0
1:  request_store (1.5.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/request_store-1.5.0.gemspec
Fetching message_bus 3.3.6
Installing message_bus 3.3.6
1:  message_bus (3.3.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/message_bus-3.3.6.gemspec
Using pry 0.13.1
1:  pry (0.13.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/pry-0.13.1.gemspec
Using rack-mini-profiler 2.3.2
1:  rack-mini-profiler (2.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rack-mini-profiler-2.3.2.gemspec
Using rack-protection 2.1.0
1:  rack-protection (2.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rack-protection-2.1.0.gemspec
Using uglifier 4.2.0
1:  uglifier (4.2.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/uglifier-4.2.0.gemspec
Using omniauth 1.9.1
1:  omniauth (1.9.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-1.9.1.gemspec
Using image_optim 0.30.0
1:  image_optim (0.30.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/image_optim-0.30.0.gemspec
Using logstash-logger 0.26.1
1:  logstash-logger (0.26.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/logstash-logger-0.26.1.gemspec
Using mini_racer 0.4.0
1:  mini_racer (0.4.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/mini_racer-0.4.0.gemspec
Using webpush 1.1.0
1:  webpush (1.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/webpush-1.1.0.gemspec
Using puma 5.3.2
1:  puma (5.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/puma-5.3.2.gemspec
Using sidekiq 6.2.1
1:  sidekiq (6.2.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sidekiq-6.2.1.gemspec
Using redis-namespace 1.8.1
1:  redis-namespace (1.8.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/redis-namespace-1.8.1.gemspec
Using rqrcode 2.0.0
1:  rqrcode (2.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rqrcode-2.0.0.gemspec
Using unicorn 6.0.0
1:  unicorn (6.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/unicorn-6.0.0.gemspec
Using unf 0.1.4
1:  unf (0.1.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/unf-0.1.4.gemspec
Using i18n 1.8.10
1:  i18n (1.8.10) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/i18n-1.8.10.gemspec
Using tzinfo 2.0.4
1:  tzinfo (2.0.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/tzinfo-2.0.4.gemspec
Using sprockets 3.7.2
1:  sprockets (3.7.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sprockets-3.7.2.gemspec
Using aws-sdk-core 3.112.1
1:  aws-sdk-core (3.112.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-sdk-core-3.112.1.gemspec
Using cose 1.2.0
1:  cose (1.2.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/cose-1.2.0.gemspec
Using css_parser 1.9.0
1:  css_parser (1.9.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/css_parser-1.9.0.gemspec
Using json_schemer 0.2.18
1:  json_schemer (0.2.18) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/json_schemer-0.2.18.gemspec
Using oauth2 1.4.7
1:  oauth2 (1.4.7) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/oauth2-1.4.7.gemspec
Using activesupport 6.1.3.2
1:  activesupport (6.1.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/activesupport-6.1.3.2.gemspec
Fetching aws-sdk-kms 1.44.0
Installing aws-sdk-kms 1.44.0
1:  aws-sdk-kms (1.44.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-sdk-kms-1.44.0.gemspec
Using aws-sdk-sns 1.38.0
1:  aws-sdk-sns (1.38.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-sdk-sns-1.38.0.gemspec
Using ember-handlebars-template 0.8.0
1:  ember-handlebars-template (0.8.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ember-handlebars-template-0.8.0.gemspec
Using mini_scheduler 0.13.0
1:  mini_scheduler (0.13.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/mini_scheduler-0.13.0.gemspec
Using omniauth-oauth2 1.7.1
1:  omniauth-oauth2 (1.7.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-oauth2-1.7.1.gemspec
Using omniauth-oauth 1.2.0
1:  omniauth-oauth (1.2.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-oauth-1.2.0.gemspec
Using pry-byebug 3.9.0
1:  pry-byebug (3.9.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/pry-byebug-3.9.0.gemspec
Using pry-rails 0.3.9
1:  pry-rails (0.3.9) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/pry-rails-0.3.9.gemspec
Using globalid 0.4.2
1:  globalid (0.4.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/globalid-0.4.2.gemspec
Using activemodel 6.1.3.2
1:  activemodel (6.1.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/activemodel-6.1.3.2.gemspec
Fetching aws-sdk-s3 1.96.1
Installing aws-sdk-s3 1.96.1
1:  aws-sdk-s3 (1.96.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-sdk-s3-1.96.1.gemspec
Using omniauth-facebook 8.0.0
1:  omniauth-facebook (8.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-facebook-8.0.0.gemspec
Using omniauth-github 1.4.0
1:  omniauth-github (1.4.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-github-1.4.0.gemspec
Using omniauth-google-oauth2 0.8.2
1:  omniauth-google-oauth2 (0.8.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-google-oauth2-0.8.2.gemspec
Using omniauth-twitter 1.4.0
1:  omniauth-twitter (1.4.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-twitter-1.4.0.gemspec
Using activejob 6.1.3.2
1:  activejob (6.1.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/activejob-6.1.3.2.gemspec
Using active_model_serializers 0.8.4
1:  active_model_serializers (0.8.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/active_model_serializers-0.8.4.gemspec
Using activerecord 6.1.3.2
1:  activerecord (6.1.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/activerecord-6.1.3.2.gemspec
Using seed-fu 2.3.9
1:  seed-fu (2.3.9) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/seed-fu-2.3.9.gemspec
2:  nokogiri (1.11.7) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/nokogiri-1.11.7-x86_64-linux.gemspec
Using rails-dom-testing 2.0.3
Fetching loofah 2.10.0
2:  rails-dom-testing (2.0.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rails-dom-testing-2.0.3.gemspec
Using nokogumbo 2.0.5
2:  nokogumbo (2.0.5) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/nokogumbo-2.0.5.gemspec
Using ruby-readability 0.7.0
2:  ruby-readability (0.7.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ruby-readability-0.7.0.gemspec
Using sanitize 5.2.3
2:  sanitize (5.2.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sanitize-5.2.3.gemspec
Installing loofah 2.10.0
1:  loofah (2.10.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/loofah-2.10.0.gemspec
Using rails-html-sanitizer 1.3.0
2:  rails-html-sanitizer (1.3.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rails-html-sanitizer-1.3.0.gemspec
Using actionview 6.1.3.2
1:  actionview (6.1.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/actionview-6.1.3.2.gemspec
Using actionview_precompiler 0.2.3
2:  actionview_precompiler (0.2.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/actionview_precompiler-0.2.3.gemspec
Using actionpack 6.1.3.2
1:  actionpack (6.1.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/actionpack-6.1.3.2.gemspec
Using actionmailer 6.1.3.2
2:  actionmailer (6.1.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/actionmailer-6.1.3.2.gemspec
Using railties 6.1.3.2
2:  railties (6.1.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/railties-6.1.3.2.gemspec
Using sprockets-rails 3.2.2
2:  sprockets-rails (3.2.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sprockets-rails-3.2.2.gemspec
Using jquery-rails 4.4.0
2:  jquery-rails (4.4.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/jquery-rails-4.4.0.gemspec
Using lograge 0.11.2
2:  lograge (0.11.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/lograge-0.11.2.gemspec
Using rails_failover 0.7.3
2:  rails_failover (0.7.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rails_failover-0.7.3.gemspec
Using rails_multisite 3.0.0
2:  rails_multisite (3.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rails_multisite-3.0.0.gemspec
Using discourse-ember-rails 0.18.6
2:  discourse-ember-rails (0.18.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/discourse-ember-rails-0.18.6.gemspec
0:  oj (3.11.7) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/oj-3.11.7.gemspec
3:  ffi (1.15.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ffi-1.15.3.gemspec
Using mini_suffix 0.3.2
0:  mini_suffix (0.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/mini_suffix-0.3.2.gemspec
Using rbtrace 0.4.14
0:  rbtrace (0.4.14) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rbtrace-0.4.14.gemspec
Using sassc 2.0.1
0:  sassc (2.0.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sassc-2.0.1.gemspec
Using sassc-rails 2.1.2
3:  sassc-rails (2.1.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sassc-rails-2.1.2.gemspec
Bundle complete! 126 Gemfile dependencies, 169 gems now installed.
Gems in the groups 'test' and 'development' were not installed.
Bundled gems are installed into `./vendor/bundle`
I, [2021-06-30T18:18:35.159818 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake plugin:pull_compatible_all'
I, [2021-06-30T18:18:38.454048 #1]  INFO -- : docker_manager is already at latest compatible version
I, [2021-06-30T18:18:38.454891 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
I, [2021-06-30T18:18:46.643753 #1]  INFO -- :
I, [2021-06-30T18:18:46.644495 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake themes:update assets:precompile'
Failed to update Light Logos
about.json contains invalid values: Maximum discourse version is invalid
/var/www/discourse/app/models/remote_theme.rb:169:in `update_from_remote'
/var/www/discourse/lib/tasks/themes.rake:61:in `block (2 levels) in <main>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/relation/batches.rb:71:in `block (2 levels) in find_each'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/relation/batches.rb:71:in `each'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/relation/batches.rb:71:in `block in find_each'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/relation/batches.rb:138:in `block in find_in_batches'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/relation/batches.rb:245:in `block in in_batches'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/relation/batches.rb:229:in `loop'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/relation/batches.rb:229:in `in_batches'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/relation/batches.rb:137:in `find_in_batches'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/relation/batches.rb:70:in `find_each'
/var/www/discourse/lib/tasks/themes.rake:57:in `block in <main>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/task.rb:281:in `block in execute'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/task.rb:281:in `each'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/task.rb:281:in `execute'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/task.rb:219:in `block in invoke_with_call_chain'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/task.rb:199:in `synchronize'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/task.rb:199:in `invoke_with_call_chain'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/task.rb:188:in `invoke'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/application.rb:160:in `invoke_task'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/application.rb:116:in `block (2 levels) in top_level'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/application.rb:116:in `each'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/application.rb:116:in `block in top_level'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/application.rb:125:in `run_with_threads'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/application.rb:110:in `top_level'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/application.rb:83:in `block in run'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/application.rb:186:in `standard_exception_handling'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/application.rb:80:in `run'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/exe/rake:27:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/bin/rake:23:in `load'
/var/www/discourse/vendor/bundle/ruby/2.7.0/bin/rake:23:in `<top (required)>'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/lib/bundler/cli/exec.rb:63:in `load'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/lib/bundler/cli/exec.rb:63:in `kernel_load'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/lib/bundler/cli/exec.rb:28:in `run'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/lib/bundler/cli.rb:474:in `exec'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/lib/bundler/vendor/thor/lib/thor.rb:392:in `dispatch'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/lib/bundler/cli.rb:30:in `dispatch'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/lib/bundler/vendor/thor/lib/thor/base.rb:485:in `start'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/lib/bundler/cli.rb:24:in `start'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/exe/bundle:49:in `block in <top (required)>'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/lib/bundler/friendly_errors.rb:130:in `with_friendly_errors'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/exe/bundle:37:in `<top (required)>'
/usr/local/bin/bundle:23:in `load'
/usr/local/bin/bundle:23:in `<main>'
I, [2021-06-30T18:18:56.239960 #1]  INFO -- : Updating Hamburger links component...
Updating Category Banners...
Updating New Like icon...
Updating Buttons...
Updating Hamburger Theme Selector...
Updating Light Logos...
I, [2021-06-30T18:18:56.240815 #1]  INFO -- : Terminating async processes
I, [2021-06-30T18:18:56.240979 #1]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 55
I, [2021-06-30T18:18:56.241509 #1]  INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 172
172:signal-handler (1625077136) Received SIGTERM scheduling shutdown...
2021-06-30 18:18:56.241 UTC [55] LOG:  received fast shutdown request
2021-06-30 18:18:56.244 UTC [55] LOG:  aborting any active transactions
2021-06-30 18:18:56.249 UTC [55] LOG:  background worker "logical replication launcher" (PID 64) exited with exit code 1
2021-06-30 18:18:56.250 UTC [59] LOG:  shutting down
2021-06-30 18:18:56.282 UTC [55] LOG:  database system is shut down
172:M 30 Jun 2021 18:18:56.283 # User requested shutdown...
172:M 30 Jun 2021 18:18:56.283 * Saving the final RDB snapshot before exiting.
172:M 30 Jun 2021 18:18:56.794 * DB saved on disk
172:M 30 Jun 2021 18:18:56.794 # Redis is now ready to exit, bye bye...
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake themes:update assets:precompile' failed with return #<Process::Status: pid 3754 exit 1>
exec failed with the params {"cd"=>"$home", "hook"=>"assets_precompile", "cmd"=>["su discourse -c 'bundle exec rake themes:update assets:precompile'"]}
c7fa934b640d7a43d3131a29051487c7b1c82cd2c9563ce2df6961d9001c77b0
==================== END REBUILD LOG ====================
Failed to rebuild app.
Checking your domain name . . .
Connection to community.naturephotographers.network succeeded.
You should probably remove any non-standard plugins and rebuild.
Attempting to restart existing container. . .
starting up existing container
+ /usr/bin/docker start app
app
aae342f545ad        local_discourse/app             "/sbin/boot"        4 weeks ago         Up Less than a second   0.0.0.0:80->80/tcp, 0.0.0.0:443->443/tcp   app
Restarted the container.
==================== PLUGINS ====================
#          - git clone https://github.com/davidtaylorhq/discourse-category-lockdown.git
#          - git clone https://github.com/discourse/discourse-adplugin.git
#          - git clone https://github.com/paviliondev/discourse-locations.git
#          - git clone https://github.com/paviliondev/discourse-events.git
#          - git clone https://github.com/jannolii/discourse-topic-trade-buttons.git
#          - git clone https://github.com/pmusaraj/discourse-onesignal.git
##          - git clone https://github.com/discourse/discourse-data-explorer.git
#          - git clone https://github.com/davidtaylorhq/discourse-whos-online.git
#          - git clone https://github.com/discourse/discourse-canned-replies.git
##          - git clone https://github.com/paviliondev/discourse-follow.git
#          - git clone https://github.com/discourse/discourse-akismet.git
#          - git clone https://github.com/angusmcleod/discourse-knowledge-base.git
##          - git clone https://github.com/paviliondev/discourse-multilingual.git
##          - git clone https://github.com/discourse/discourse-translator.git
#          - git clone https://github.com/discourse/discourse-push-notifications.git
#          - git clone https://github.com/paviliondev/discourse-custom-wizard.git
#          - git clone https://github.com/discourse/discourse-zoom.git
#          - git clone https://github.com/Ebsy/discourse-nationalflags.git
#          - git clone https://github.com/discourse/discourse-calendar.git
#          - git clone https://github.com/discourse/discourse-fontawesome-pro.git
#          - git clone https://github.com/merefield/discourse-topic-previews.git -b "theme_sidecar"
#          - git clone https://github.com/discourse/discourse-reactions.git
#          - git clone https://github.com/discourse/discourse-user-notes.git
WARNING:
You have what appear to be non-official plugins.
If you are having trouble, you should disable them and try rebuilding again.
See https://github.com/discourse/discourse/blob/master/lib/plugin/metadata.rb for the official list.
Discourse version at community.naturephotographers.network: NOT FOUND
Discourse version at localhost: NOT FOUND
==================== MEMORY INFORMATION ====================
RAM (MB): 4046
              total        used        free      shared  buff/cache   available
Mem:           3951         157        2510           5        1284        3484
Swap:          2047           0        2047
==================== DISK SPACE CHECK ====================
---------- OS Disk Space ----------
/dev/vda1        49G   26G   24G  52% /
==================== DISK INFORMATION ====================
Disk /dev/loop0: 9.1 MiB, 9531392 bytes, 18616 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop1: 55.4 MiB, 58114048 bytes, 113504 sectors
Disk /dev/loop2: 99.4 MiB, 104202240 bytes, 203520 sectors
Disk /dev/loop3: 99.4 MiB, 104185856 bytes, 203488 sectors
Disk /dev/loop4: 55.5 MiB, 58134528 bytes, 113544 sectors
Disk /dev/loop5: 9.1 MiB, 9531392 bytes, 18616 sectors
Disk /dev/vda: 50 GiB, 53687091200 bytes, 104857600 sectors
Disklabel type: gpt
Disk identifier: 603625F3-7AE2-40CB-B05E-0BD7EA2D57E4
Device      Start       End   Sectors  Size Type
/dev/vda1  227328 104857566 104630239 49.9G Linux filesystem
/dev/vda14   2048     10239      8192    4M BIOS boot
/dev/vda15  10240    227327    217088  106M Microsoft basic data
Partition table entries are not in disk order.
==================== END DISK INFORMATION ====================
こんにちは、Davidさん。
おそらくここで失敗しているのだと思います。
Light Logos の更新に失敗しました
about.json に無効な値が含まれています:最大 Discourse バージョンが無効です
あなたの問題は、Light Logos のテーマコンポーネントにあるようです。
Jay、ありがとうございます。TC が現在非推奨であることがわかり、それを削除することで問題が解決しました。TC がこんな問題を引き起こすとは知りませんでした!放置されていた古い TC について見直す時期ですね。
おそらく、サイトの設定を確認し、logo dark設定ファミリーを記入してください。それがテーマコンポーネントが非推奨となった理由です!
それはこれですか?それとも、そのようなテーマコンポーネントのファミリーがあったのでしょうか?
別のサイトでも同じ問題が発生しました…
それね、ジェイ。私だけじゃないと聞いて安心したよ!
