Hi,
I’ve just tried updating the docker version of discourse to the latest version and had the following error, the site is down and I’m unable to rebuild. I’ve tried disabling all the plugins, but it still failes with the same error:
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 449 exit 1>
exec failed with the params {"cd"=>"$home", "hook"=>"db_migrate", "cmd"=>["su discourse -c 'bundle exec rake db:migrate'"]}
309140db90850e9ea6644e471ee47f5fea3a1bb6ea36577280d3c431eaf497fe
Here is the output of ./discourse-doctor, any ideas what could be causing this?
DISCOURSE DOCTOR Wed Jun 9 18:15:39 BST 2021
OS: Linux h79-143-80-210 3.13.0-147-generic #196-Ubuntu SMP Wed May 2 15:51:34 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
==================== DOCKER INFO ====================
DOCKER VERSION: Docker version 18.06.1-ce, build e68fc7a
DOCKER PROCESSES (docker ps -a)
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
6084a0e22b64 local_discourse/app "/sbin/boot" 5 weeks ago Exited (5) 9 minutes ago app
==================== SERIOUS PROBLEM!!!! ====================
app not running!
Attempting to rebuild
==================== REBUILD LOG ====================
Fetching origin
Launcher is up-to-date
Stopping old container
+ /usr/bin/docker stop -t 60 app
app
cd /pups && git pull && git checkout v1.0.3 && /pups/bin/pups --stdin
From https://github.com/discourse/pups
17f04ec..44198d7 master -> origin/master
* [new branch] add-ignore-option -> origin/add-ignore-option
+ 4db217f...af226b0 gen-env-args -> origin/gen-env-args (forced update)
Updating 17f04ec..44198d7
Fast-forward
.github/workflows/ci.yml | 29 ++++++
.github/workflows/lint.yml | 27 ++++++
.rubocop.yml | 3 +
Gemfile | 2 +
Guardfile | 4 +-
README.md | 9 ++
Rakefile | 14 +--
bin/pups | 8 +-
lib/pups.rb | 32 ++++---
lib/pups/cli.rb | 85 +++++++++--------
lib/pups/command.rb | 25 ++---
lib/pups/config.rb | 217 +++++++++++++++++++++----------------------
lib/pups/exec_command.rb | 182 ++++++++++++++++++------------------
lib/pups/file_command.rb | 60 ++++++------
lib/pups/merge_command.rb | 94 ++++++++++---------
lib/pups/replace_command.rb | 70 +++++++-------
lib/pups/runit.rb | 47 +++++-----
lib/pups/version.rb | 4 +-
pups.gemspec | 37 ++++----
test/cli_test.rb | 25 +++--
test/config_test.rb | 125 +++++++++++++------------
test/exec_command_test.rb | 62 ++++++-------
test/file_command_test.rb | 17 ++--
test/merge_command_test.rb | 64 ++++++-------
test/replace_command_test.rb | 86 +++++++++--------
test/test_helper.rb | 2 +
26 files changed, 712 insertions(+), 618 deletions(-)
create mode 100644 .github/workflows/ci.yml
create mode 100644 .github/workflows/lint.yml
create mode 100644 .rubocop.yml
Note: checking out 'v1.0.3'.
You are in 'detached HEAD' state. You can look around, make experimental
changes and commit them, and you can discard any commits you make in this
state without impacting any branches by performing another checkout.
If you want to create a new branch to retain commits you create, you may
do so (now or later) by using -b with the checkout command again. Example:
git checkout -b <new-branch-name>
HEAD is now at d1db030 cut a new version
I, [2021-06-09T17:15:48.541059 #1] INFO -- : Loading --stdin
I, [2021-06-09T17:15:48.547260 #1] INFO -- : > locale-gen $LANG && update-locale
I, [2021-06-09T17:15:48.581289 #1] INFO -- : Generating locales (this might take a while)...
Generation complete.
I, [2021-06-09T17:15:48.581551 #1] INFO -- : > mkdir -p /shared/postgres_run
I, [2021-06-09T17:15:48.585489 #1] INFO -- :
I, [2021-06-09T17:15:48.585715 #1] INFO -- : > chown postgres:postgres /shared/postgres_run
I, [2021-06-09T17:15:48.588562 #1] INFO -- :
I, [2021-06-09T17:15:48.588757 #1] INFO -- : > chmod 775 /shared/postgres_run
I, [2021-06-09T17:15:48.591247 #1] INFO -- :
I, [2021-06-09T17:15:48.591474 #1] INFO -- : > rm -fr /var/run/postgresql
I, [2021-06-09T17:15:48.594255 #1] INFO -- :
I, [2021-06-09T17:15:48.594478 #1] INFO -- : > ln -s /shared/postgres_run /var/run/postgresql
I, [2021-06-09T17:15:48.597015 #1] INFO -- :
I, [2021-06-09T17:15:48.597231 #1] INFO -- : > socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1
2021/06/09 17:15:48 socat[33] E connect(6, AF=1 "/shared/postgres_run/.s.PGSQL.5432", 36): No such file or directory
I, [2021-06-09T17:15:48.603543 #1] INFO -- :
I, [2021-06-09T17:15:48.603775 #1] INFO -- : > rm -fr /shared/postgres_run/.s*
I, [2021-06-09T17:15:48.607952 #1] INFO -- :
I, [2021-06-09T17:15:48.608200 #1] INFO -- : > rm -fr /shared/postgres_run/*.pid
I, [2021-06-09T17:15:48.612365 #1] INFO -- :
I, [2021-06-09T17:15:48.612608 #1] INFO -- : > mkdir -p /shared/postgres_run/13-main.pg_stat_tmp
I, [2021-06-09T17:15:48.616089 #1] INFO -- :
I, [2021-06-09T17:15:48.616338 #1] INFO -- : > chown postgres:postgres /shared/postgres_run/13-main.pg_stat_tmp
I, [2021-06-09T17:15:48.619784 #1] INFO -- :
I, [2021-06-09T17:15:48.627365 #1] INFO -- : File > /etc/service/postgres/run chmod: +x chown:
I, [2021-06-09T17:15:48.634715 #1] INFO -- : File > /etc/service/postgres/log/run chmod: +x chown:
I, [2021-06-09T17:15:48.641257 #1] INFO -- : File > /etc/runit/3.d/99-postgres chmod: +x chown:
I, [2021-06-09T17:15:48.647799 #1] INFO -- : File > /root/upgrade_postgres chmod: +x chown:
I, [2021-06-09T17:15:48.648283 #1] INFO -- : > chown -R root /var/lib/postgresql/13/main
I, [2021-06-09T17:15:48.745062 #1] INFO -- :
I, [2021-06-09T17:15:48.745241 #1] INFO -- : > [ ! -e /shared/postgres_data ] && install -d -m 0755 -o postgres -g postgres /shared/postgres_data && sudo -E -u postgres /usr/lib/postgresql/13/bin/initdb -D /shared/postgres_data || exit 0
I, [2021-06-09T17:15:48.747853 #1] INFO -- :
I, [2021-06-09T17:15:48.747918 #1] INFO -- : > chown -R postgres:postgres /shared/postgres_data
I, [2021-06-09T17:15:48.768688 #1] INFO -- :
I, [2021-06-09T17:15:48.768793 #1] INFO -- : > chown -R postgres:postgres /var/run/postgresql
I, [2021-06-09T17:15:48.770937 #1] INFO -- :
I, [2021-06-09T17:15:48.771145 #1] INFO -- : > /root/upgrade_postgres
I, [2021-06-09T17:15:48.776325 #1] INFO -- :
I, [2021-06-09T17:15:48.776522 #1] INFO -- : > rm /root/upgrade_postgres
I, [2021-06-09T17:15:48.778762 #1] INFO -- :
I, [2021-06-09T17:15:48.779198 #1] INFO -- : Replacing data_directory = '/var/lib/postgresql/13/main' with data_directory = '/shared/postgres_data' in /etc/postgresql/13/main/postgresql.conf
I, [2021-06-09T17:15:48.780060 #1] INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addresses = '*' in /etc/postgresql/13/main/postgresql.conf
I, [2021-06-09T17:15:48.780857 #1] INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchronous_commit = $db_synchronous_commit in /etc/postgresql/13/main/postgresql.conf
I, [2021-06-09T17:15:48.781387 #1] INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffers = $db_shared_buffers in /etc/postgresql/13/main/postgresql.conf
I, [2021-06-09T17:15:48.781909 #1] INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work_mem in /etc/postgresql/13/main/postgresql.conf
I, [2021-06-09T17:15:48.782428 #1] INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with default_text_search_config = '$db_default_text_search_config' in /etc/postgresql/13/main/postgresql.conf
I, [2021-06-09T17:15:48.782909 #1] INFO -- : > install -d -m 0755 -o postgres -g postgres /shared/postgres_backup
I, [2021-06-09T17:15:48.786951 #1] INFO -- :
I, [2021-06-09T17:15:48.787418 #1] INFO -- : Replacing (?-mix:#?checkpoint_segments *=.*) with checkpoint_segments = $db_checkpoint_segments in /etc/postgresql/13/main/postgresql.conf
I, [2021-06-09T17:15:48.787937 #1] INFO -- : Replacing (?-mix:#?logging_collector *=.*) with logging_collector = $db_logging_collector in /etc/postgresql/13/main/postgresql.conf
I, [2021-06-09T17:15:48.788464 #1] INFO -- : Replacing (?-mix:#?log_min_duration_statement *=.*) with log_min_duration_statement = $db_log_min_duration_statement in /etc/postgresql/13/main/postgresql.conf
I, [2021-06-09T17:15:48.788988 #1] INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) with local replication postgres peer in /etc/postgresql/13/main/pg_hba.conf
I, [2021-06-09T17:15:48.789493 #1] INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2021-06-09T17:15:48.789922 #1] INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main
I, [2021-06-09T17:15:48.792209 #1] INFO -- : > sleep 5
2021-06-09 17:15:48.829 UTC [56] LOG: starting PostgreSQL 13.3 (Debian 13.3-1.pgdg100+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 8.3.0-6) 8.3.0, 64-bit
2021-06-09 17:15:48.829 UTC [56] LOG: listening on IPv4 address "0.0.0.0", port 5432
2021-06-09 17:15:48.829 UTC [56] LOG: listening on IPv6 address "::", port 5432
2021-06-09 17:15:48.830 UTC [56] LOG: listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2021-06-09 17:15:48.833 UTC [59] LOG: database system was shut down at 2021-06-09 17:06:49 UTC
2021-06-09 17:15:48.837 UTC [56] LOG: database system is ready to accept connections
I, [2021-06-09T17:15:53.795707 #1] INFO -- :
I, [2021-06-09T17:15:53.796024 #1] INFO -- : > su postgres -c 'createdb discourse' || true
2021-06-09 17:15:53.858 UTC [69] postgres@postgres ERROR: database "discourse" already exists
2021-06-09 17:15:53.858 UTC [69] postgres@postgres STATEMENT: CREATE DATABASE discourse;
createdb: error: database creation failed: ERROR: database "discourse" already exists
I, [2021-06-09T17:15:53.860168 #1] INFO -- :
I, [2021-06-09T17:15:53.860419 #1] INFO -- : > su postgres -c 'psql discourse -c "create user discourse;"' || true
2021-06-09 17:15:53.929 UTC [80] postgres@discourse ERROR: role "discourse" already exists
2021-06-09 17:15:53.929 UTC [80] postgres@discourse STATEMENT: create user discourse;
I, [2021-06-09T17:15:53.931099 #1] INFO -- :
I, [2021-06-09T17:15:53.931380 #1] INFO -- : > su postgres -c 'psql discourse -c "grant all privileges on database discourse to discourse;"' || true
I, [2021-06-09T17:15:53.999605 #1] INFO -- : GRANT
I, [2021-06-09T17:15:53.999906 #1] INFO -- : > su postgres -c 'psql discourse -c "alter schema public owner to discourse;"'
I, [2021-06-09T17:15:54.072279 #1] INFO -- : ALTER SCHEMA
I, [2021-06-09T17:15:54.072566 #1] INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists hstore;"'
NOTICE: extension "hstore" already exists, skipping
I, [2021-06-09T17:15:54.146269 #1] INFO -- : CREATE EXTENSION
I, [2021-06-09T17:15:54.146478 #1] INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists pg_trgm;"'
NOTICE: extension "pg_trgm" already exists, skipping
I, [2021-06-09T17:15:54.214671 #1] INFO -- : CREATE EXTENSION
I, [2021-06-09T17:15:54.215057 #1] INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists hstore;"'
I, [2021-06-09T17:15:54.287421 #1] INFO -- : CREATE EXTENSION
I, [2021-06-09T17:15:54.287676 #1] INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists pg_trgm;"'
I, [2021-06-09T17:15:54.358707 #1] INFO -- : CREATE EXTENSION
I, [2021-06-09T17:15:54.359168 #1] INFO -- : > sudo -u postgres psql discourse
I, [2021-06-09T17:15:54.361595 #1] INFO -- : update pg_database set encoding = pg_char_to_encoding('UTF8') where datname = 'discourse' AND encoding = pg_char_to_encoding('SQL_ASCII');
I, [2021-06-09T17:15:54.441578 #1] INFO -- : File > /var/lib/postgresql/take-database-backup chmod: +x chown: postgres:postgres
I, [2021-06-09T17:15:54.445975 #1] INFO -- : File > /var/spool/cron/crontabs/postgres chmod: chown:
I, [2021-06-09T17:15:54.446132 #1] INFO -- : > echo postgres installed!
I, [2021-06-09T17:15:54.449248 #1] INFO -- : postgres installed!
I, [2021-06-09T17:15:54.455508 #1] INFO -- : File > /etc/service/redis/run chmod: +x chown:
I, [2021-06-09T17:15:54.461760 #1] INFO -- : File > /etc/service/redis/log/run chmod: +x chown:
I, [2021-06-09T17:15:54.467970 #1] INFO -- : File > /etc/runit/3.d/10-redis chmod: +x chown:
I, [2021-06-09T17:15:54.468236 #1] INFO -- : Replacing daemonize yes with in /etc/redis/redis.conf
I, [2021-06-09T17:15:54.469064 #1] INFO -- : Replacing (?-mix:^pidfile.*$) with in /etc/redis/redis.conf
I, [2021-06-09T17:15:54.470014 #1] INFO -- : > install -d -m 0755 -o redis -g redis /shared/redis_data
I, [2021-06-09T17:15:54.472748 #1] INFO -- :
I, [2021-06-09T17:15:54.473111 #1] INFO -- : Replacing (?-mix:^logfile.*$) with logfile "" in /etc/redis/redis.conf
I, [2021-06-09T17:15:54.473856 #1] INFO -- : Replacing (?-mix:^bind .*$) with in /etc/redis/redis.conf
I, [2021-06-09T17:15:54.474545 #1] INFO -- : Replacing (?-mix:^dir .*$) with dir /shared/redis_data in /etc/redis/redis.conf
I, [2021-06-09T17:15:54.475408 #1] INFO -- : Replacing (?-mix:^protected-mode yes) with protected-mode no in /etc/redis/redis.conf
I, [2021-06-09T17:15:54.476042 #1] INFO -- : Replacing # io-threads 4 with io-threads $redis_io_threads in /etc/redis/redis.conf
I, [2021-06-09T17:15:54.476623 #1] INFO -- : > echo redis installed
I, [2021-06-09T17:15:54.478913 #1] INFO -- : redis installed
I, [2021-06-09T17:15:54.479100 #1] INFO -- : > cat /etc/redis/redis.conf | grep logfile
I, [2021-06-09T17:15:54.482701 #1] INFO -- : logfile ""
I, [2021-06-09T17:15:54.482860 #1] INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2021-06-09T17:15:54.484286 #1] INFO -- : > sleep 10
173:C 09 Jun 2021 17:15:54.489 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
173:C 09 Jun 2021 17:15:54.489 # Redis version=6.2.3, bits=64, commit=00000000, modified=0, pid=173, just started
173:C 09 Jun 2021 17:15:54.489 # Configuration loaded
173:M 09 Jun 2021 17:15:54.489 * monotonic clock: POSIX clock_gettime
173:M 09 Jun 2021 17:15:54.490 * Running mode=standalone, port=6379.
173:M 09 Jun 2021 17:15:54.490 # WARNING: The TCP backlog setting of 511 cannot be enforced because /proc/sys/net/core/somaxconn is set to the lower value of 128.
173:M 09 Jun 2021 17:15:54.490 # Server initialized
173:M 09 Jun 2021 17:15:54.490 # WARNING overcommit_memory is set to 0! Background save may fail under low memory condition. To fix this issue add 'vm.overcommit_memory = 1' to /etc/sysctl.conf and then reboot or run the command 'sysctl vm.overcommit_memory=1' for this to take effect.
173:M 09 Jun 2021 17:15:54.490 # WARNING you have Transparent Huge Pages (THP) support enabled in your kernel. This will create latency and memory usage issues with Redis. To fix this issue run the command 'echo madvise > /sys/kernel/mm/transparent_hugepage/enabled' as root, and add it to your /etc/rc.local in order to retain the setting after a reboot. Redis must be restarted after THP is disabled (set to 'madvise' or 'never').
173:M 09 Jun 2021 17:15:54.490 * Loading RDB produced by version 6.2.3
173:M 09 Jun 2021 17:15:54.490 * RDB age 545 seconds
173:M 09 Jun 2021 17:15:54.490 * RDB memory usage when created 48.75 Mb
173:M 09 Jun 2021 17:15:54.632 * DB loaded from disk: 0.142 seconds
173:M 09 Jun 2021 17:15:54.632 * Ready to accept connections
I, [2021-06-09T17:16:04.486234 #1] INFO -- :
I, [2021-06-09T17:16:04.486551 #1] INFO -- : > thpoff echo "thpoff is installed!"
I, [2021-06-09T17:16:04.492079 #1] INFO -- : thpoff is installed!
I, [2021-06-09T17:16:04.492318 #1] INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_SMTP_ADDRESS"] == "smtp.example.com"; puts "Aborting! Mail is not configured!"; exit 1; end'
I, [2021-06-09T17:16:04.564478 #1] INFO -- :
I, [2021-06-09T17:16:04.564833 #1] INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_HOSTNAME"] == "discourse.example.com"; puts "Aborting! Domain is not configured!"; exit 1; end'
I, [2021-06-09T17:16:04.633789 #1] INFO -- :
I, [2021-06-09T17:16:04.634145 #1] INFO -- : > /usr/local/bin/ruby -e 'if (ENV["DISCOURSE_CDN_URL"] || "")[0..1] == "//"; puts "Aborting! CDN must have a protocol specified. Once fixed you should rebake your posts now to correct all posts."; exit 1; end'
I, [2021-06-09T17:16:04.702442 #1] INFO -- :
I, [2021-06-09T17:16:04.702787 #1] INFO -- : > chown -R discourse /home/discourse
I, [2021-06-09T17:16:04.756374 #1] INFO -- :
I, [2021-06-09T17:16:04.756704 #1] INFO -- : > rm -f /etc/cron.d/anacron
I, [2021-06-09T17:16:04.760585 #1] INFO -- :
I, [2021-06-09T17:16:04.764495 #1] INFO -- : File > /etc/cron.d/anacron chmod: chown:
I, [2021-06-09T17:16:04.770841 #1] INFO -- : File > /etc/runit/1.d/copy-env chmod: +x chown:
I, [2021-06-09T17:16:04.777110 #1] INFO -- : File > /etc/service/unicorn/run chmod: +x chown:
I, [2021-06-09T17:16:04.784325 #1] INFO -- : File > /etc/service/nginx/run chmod: +x chown:
I, [2021-06-09T17:16:04.791191 #1] INFO -- : File > /etc/runit/3.d/01-nginx chmod: +x chown:
I, [2021-06-09T17:16:04.797822 #1] INFO -- : File > /etc/runit/3.d/02-unicorn chmod: +x chown:
I, [2021-06-09T17:16:04.798063 #1] INFO -- : Replacing # postgres with sv start postgres || exit 1 in /etc/service/unicorn/run
I, [2021-06-09T17:16:04.798498 #1] INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2021-06-09T17:16:04.801159 #1] INFO -- : > cd /var/www/discourse && git reset --hard
202:C 09 Jun 2021 17:16:04.805 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
202:C 09 Jun 2021 17:16:04.805 # Redis version=6.2.3, bits=64, commit=00000000, modified=0, pid=202, just started
202:C 09 Jun 2021 17:16:04.805 # Configuration loaded
202:M 09 Jun 2021 17:16:04.806 * monotonic clock: POSIX clock_gettime
202:M 09 Jun 2021 17:16:04.806 # Warning: Could not create server TCP listening socket *:6379: bind: Address already in use
202:M 09 Jun 2021 17:16:04.806 # Failed listening on port 6379 (TCP), aborting.
Checking out files: 100% (28860/28860), done.
I, [2021-06-09T17:16:06.924867 #1] INFO -- : HEAD is now at 74f71503 FEATURE: Automatically timed delete stub topics after entire topic is merged into another topic (#13187)
I, [2021-06-09T17:16:06.924989 #1] INFO -- : > cd /var/www/discourse && git clean -f
I, [2021-06-09T17:16:07.016232 #1] INFO -- :
I, [2021-06-09T17:16:07.016466 #1] INFO -- : > cd /var/www/discourse && git remote set-branches --add origin master
I, [2021-06-09T17:16:07.020571 #1] INFO -- :
I, [2021-06-09T17:16:07.020650 #1] INFO -- : > cd /var/www/discourse && git remote set-branches origin tests-passed
I, [2021-06-09T17:16:07.420156 #1] INFO -- :
I, [2021-06-09T17:16:07.420323 #1] INFO -- : > cd /var/www/discourse && git fetch --depth 1 origin tests-passed
From https://github.com/discourse/discourse
* branch tests-passed -> FETCH_HEAD
* [new branch] tests-passed -> origin/tests-passed
I, [2021-06-09T17:16:13.888848 #1] INFO -- :
I, [2021-06-09T17:16:13.889069 #1] INFO -- : > cd /var/www/discourse && git checkout tests-passed
Switched to a new branch 'tests-passed'
I, [2021-06-09T17:16:14.942809 #1] INFO -- : Branch 'tests-passed' set up to track remote branch 'tests-passed' from 'origin'.
I, [2021-06-09T17:16:14.943087 #1] INFO -- : > cd /var/www/discourse && mkdir -p tmp
I, [2021-06-09T17:16:14.948641 #1] INFO -- :
I, [2021-06-09T17:16:14.948775 #1] INFO -- : > cd /var/www/discourse && chown discourse:www-data tmp
I, [2021-06-09T17:16:14.953695 #1] INFO -- :
I, [2021-06-09T17:16:14.953805 #1] INFO -- : > cd /var/www/discourse && mkdir -p tmp/pids
I, [2021-06-09T17:16:14.958785 #1] INFO -- :
I, [2021-06-09T17:16:14.958884 #1] INFO -- : > cd /var/www/discourse && mkdir -p tmp/sockets
I, [2021-06-09T17:16:14.964009 #1] INFO -- :
I, [2021-06-09T17:16:14.964161 #1] INFO -- : > cd /var/www/discourse && touch tmp/.gitkeep
I, [2021-06-09T17:16:14.968736 #1] INFO -- :
I, [2021-06-09T17:16:14.968878 #1] INFO -- : > cd /var/www/discourse && mkdir -p /shared/log/rails
I, [2021-06-09T17:16:14.973740 #1] INFO -- :
I, [2021-06-09T17:16:14.973868 #1] INFO -- : > cd /var/www/discourse && bash -c "touch -a /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log"
I, [2021-06-09T17:16:14.981370 #1] INFO -- :
I, [2021-06-09T17:16:14.981509 #1] INFO -- : > cd /var/www/discourse && bash -c "ln -s /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log /var/www/discourse/log"
I, [2021-06-09T17:16:14.988896 #1] INFO -- :
I, [2021-06-09T17:16:14.989030 #1] INFO -- : > cd /var/www/discourse && bash -c "mkdir -p /shared/{uploads,backups}"
I, [2021-06-09T17:16:14.996745 #1] INFO -- :
I, [2021-06-09T17:16:14.996917 #1] INFO -- : > cd /var/www/discourse && bash -c "ln -s /shared/{uploads,backups} /var/www/discourse/public"
I, [2021-06-09T17:16:15.004403 #1] INFO -- :
I, [2021-06-09T17:16:15.004570 #1] INFO -- : > cd /var/www/discourse && bash -c "mkdir -p /shared/tmp/{backups,restores}"
I, [2021-06-09T17:16:15.012290 #1] INFO -- :
I, [2021-06-09T17:16:15.012457 #1] INFO -- : > cd /var/www/discourse && bash -c "ln -s /shared/tmp/{backups,restores} /var/www/discourse/tmp"
I, [2021-06-09T17:16:15.020418 #1] INFO -- :
I, [2021-06-09T17:16:15.020572 #1] INFO -- : > cd /var/www/discourse && chown -R discourse:www-data /shared/log/rails /shared/uploads /shared/backups /shared/tmp
I, [2021-06-09T17:16:15.298235 #1] INFO -- :
I, [2021-06-09T17:16:15.298369 #1] INFO -- : > cd /var/www/discourse && find public/plugins/ -maxdepth 1 -xtype l -delete
I, [2021-06-09T17:16:15.303229 #1] INFO -- :
I, [2021-06-09T17:16:15.303539 #1] INFO -- : Replacing # redis with sv start redis || exit 1 in /etc/service/unicorn/run
I, [2021-06-09T17:16:15.304417 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/docker_manager.git
Cloning into 'docker_manager'...
I, [2021-06-09T17:16:18.074871 #1] INFO -- :
I, [2021-06-09T17:16:18.075094 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-tagging.git
Cloning into 'discourse-tagging'...
I, [2021-06-09T17:16:18.637146 #1] INFO -- :
I, [2021-06-09T17:16:18.637340 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-solved.git
Cloning into 'discourse-solved'...
I, [2021-06-09T17:16:20.184574 #1] INFO -- :
I, [2021-06-09T17:16:20.184741 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-oauth2-basic.git
Cloning into 'discourse-oauth2-basic'...
I, [2021-06-09T17:16:21.214907 #1] INFO -- :
I, [2021-06-09T17:16:21.215135 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-akismet.git
Cloning into 'discourse-akismet'...
I, [2021-06-09T17:16:21.964386 #1] INFO -- :
I, [2021-06-09T17:16:21.964566 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-staff-notes.git
Cloning into 'discourse-staff-notes'...
I, [2021-06-09T17:16:22.629042 #1] INFO -- :
I, [2021-06-09T17:16:22.629590 #1] INFO -- : > cp /var/www/discourse/config/nginx.sample.conf /etc/nginx/conf.d/discourse.conf
I, [2021-06-09T17:16:22.633683 #1] INFO -- :
I, [2021-06-09T17:16:22.633844 #1] INFO -- : > rm /etc/nginx/sites-enabled/default
I, [2021-06-09T17:16:22.637380 #1] INFO -- :
I, [2021-06-09T17:16:22.637513 #1] INFO -- : > mkdir -p /var/nginx/cache
I, [2021-06-09T17:16:22.641418 #1] INFO -- :
I, [2021-06-09T17:16:22.641789 #1] INFO -- : Replacing pid /run/nginx.pid; with daemon off; in /etc/nginx/nginx.conf
I, [2021-06-09T17:16:22.642367 #1] INFO -- : Replacing (?m-ix:upstream[^\}]+\}) with upstream discourse { server 127.0.0.1:3000; } in /etc/nginx/conf.d/discourse.conf
I, [2021-06-09T17:16:22.642860 #1] INFO -- : Replacing (?-mix:server_name.+$) with server_name _ ; in /etc/nginx/conf.d/discourse.conf
I, [2021-06-09T17:16:22.643347 #1] INFO -- : Replacing (?-mix:client_max_body_size.+$) with client_max_body_size $upload_size ; in /etc/nginx/conf.d/discourse.conf
I, [2021-06-09T17:16:22.643816 #1] INFO -- : > echo "done configuring web"
I, [2021-06-09T17:16:22.646689 #1] INFO -- : done configuring web
I, [2021-06-09T17:16:22.647211 #1] INFO -- : > cd /var/www/discourse && gem install bundler --conservative -v $(awk '/BUNDLED WITH/ { getline; gsub(/ /,""); print $0 }' Gemfile.lock)
I, [2021-06-09T17:16:23.381227 #1] INFO -- : Successfully installed bundler-2.2.19
1 gem installed
I, [2021-06-09T17:16:23.381582 #1] INFO -- : > cd /var/www/discourse && find /var/www/discourse ! -user discourse -exec chown discourse {} \+
I, [2021-06-09T17:16:24.411208 #1] INFO -- :
I, [2021-06-09T17:16:24.411610 #1] INFO -- : > cd /var/www/discourse && su discourse -c 'bundle install --deployment --retry 3 --jobs 4 --verbose --without test development'
[DEPRECATED] The `--deployment` flag is deprecated because it relies on being remembered across bundler invocations, which bundler will no longer do in future versions. Instead please use `bundle config set --local deployment 'true'`, and stop using this flag
[DEPRECATED] The `--without` flag is deprecated because it relies on being remembered across bundler invocations, which bundler will no longer do in future versions. Instead please use `bundle config set --local without 'test development'`, and stop using this flag
I, [2021-06-09T17:16:30.739824 #1] INFO -- : Running `bundle install --deployment --jobs 4 --retry 3 --verbose --without "test" "development"` with bundler 2.2.19
Frozen, using resolution from the lockfile
The definition is missing ["concurrent-ruby-1.1.9", "nokogiri-1.11.7-x86_64-linux", "loofah-2.10.0", "fastimage-2.2.4", "message_bus-3.3.6"]
HTTP GET https://index.rubygems.org/versions
HTTP 416 Range Not Satisfiable https://index.rubygems.org/versions
HTTP 200 OK https://index.rubygems.org/versions
Fetching gem metadata from https://rubygems.org/
Double checking for ["rake", "concurrent-ruby", "i18n", "minitest", "tzinfo", "zeitwerk", "activesupport", "builder", "erubi", "racc", "nokogiri", "rails-dom-testing", "crass", "loofah", "rails-html-sanitizer", "actionview", "rack", "rack-test", "actionpack", "globalid", "activejob", "mini_mime", "actionmailer", "actionview_precompiler", "activemodel", "active_model_serializers", "activerecord", "public_suffix", "addressable", "aws-eventstream", "aws-partitions", "aws-sigv4", "jmespath", "aws-sdk-core", "aws-sdk-kms", "aws-sdk-s3", "aws-sdk-sns", "ember-source", "execjs", "barber", "msgpack", "bootsnap", "byebug", "cbor", "chunky_png", "coderay", "colored2", "connection_pool", "openssl", "openssl-signature_algorithm", "cose", "cppjieba_rb", "css_parser", "diffy", "ember-data-source", "sprockets", "ember-handlebars-template", "method_source", "thor", "railties", "jquery-rails", "discourse-ember-rails", "discourse-ember-source", "discourse-fonts", "regexp_parser", "ecma-re-validator", "email_reply_trimmer", "excon", "exifr", "faraday-em_http", "faraday-em_synchrony", "faraday-excon", "faraday-net_http", "faraday-net_http_persistent", "multipart-post", "ruby2_keywords", "faraday", "fast_blank", "fast_xs", "fastimage", "ffi", "fspath", "gc_tracer", "guess_html_encoding", "hana", "hashie", "highline", "hkdf", "htmlentities", "http_accept_language", "image_size", "in_threads", "progress", "image_optim", "json", "uri_template", "json_schemer", "jwt", "kgio", "libv8-node", "request_store", "lograge", "logstash-event", "logstash-logger", "logster", "lru_redux", "lz4-ruby", "maxminddb", "memory_profiler", "message_bus", "mini_racer", "redis", "sidekiq", "mini_scheduler", "mini_sql", "mini_suffix", "multi_json", "multi_xml", "mustache", "nio4r", "nokogumbo", "oauth", "oauth2", "oj", "omniauth", "omniauth-oauth2", "omniauth-facebook", "omniauth-github", "omniauth-google-oauth2", "omniauth-oauth", "omniauth-twitter", "optimist", "pg", "pry", "pry-byebug", "pry-rails", "puma", "r2", "rack-mini-profiler", "rack-protection", "rails_failover", "rails_multisite", "raindrops", "rbtrace", "rchardet", "redis-namespace", "rinku", "rotp", "rqrcode_core", "rqrcode", "rtlit", "ruby-readability", "rubyzip", "sanitize", "sassc", "sprockets-rails", "tilt", "sassc-rails", "seed-fu", "sshkey", "stackprof", "uglifier", "unf_ext", "unf", "unicorn", "webpush", "xorcist"] in rubygems repository https://rubygems.org/ or installed locally
Looking up gems ["rake", "concurrent-ruby", "i18n", "minitest", "tzinfo", "zeitwerk", "activesupport", "builder", "erubi", "racc", "nokogiri", "rails-dom-testing", "crass", "loofah", "rails-html-sanitizer", "actionview", "rack", "rack-test", "actionpack", "globalid", "activejob", "mini_mime", "actionmailer", "actionview_precompiler", "activemodel", "active_model_serializers", "activerecord", "public_suffix", "addressable", "aws-eventstream", "aws-partitions", "aws-sigv4", "jmespath", "aws-sdk-core", "aws-sdk-kms", "aws-sdk-s3", "aws-sdk-sns", "ember-source", "execjs", "barber", "msgpack", "bootsnap", "byebug", "cbor", "chunky_png", "coderay", "colored2", "connection_pool", "openssl", "openssl-signature_algorithm", "cose", "cppjieba_rb", "css_parser", "diffy", "ember-data-source", "sprockets", "ember-handlebars-template", "method_source", "thor", "railties", "jquery-rails", "discourse-ember-rails", "discourse-ember-source", "discourse-fonts", "regexp_parser", "ecma-re-validator", "email_reply_trimmer", "excon", "exifr", "faraday-em_http", "faraday-em_synchrony", "faraday-excon", "faraday-net_http", "faraday-net_http_persistent", "multipart-post", "ruby2_keywords", "faraday", "fast_blank", "fast_xs", "fastimage", "ffi", "fspath", "gc_tracer", "guess_html_encoding", "hana", "hashie", "highline", "hkdf", "htmlentities", "http_accept_language", "image_size", "in_threads", "progress", "image_optim", "json", "uri_template", "json_schemer", "jwt", "kgio", "libv8-node", "request_store", "lograge", "logstash-event", "logstash-logger", "logster", "lru_redux", "lz4-ruby", "maxminddb", "memory_profiler", "message_bus", "mini_racer", "redis", "sidekiq", "mini_scheduler", "mini_sql", "mini_suffix", "multi_json", "multi_xml", "mustache", "nio4r", "nokogumbo", "oauth", "oauth2", "oj", "omniauth", "omniauth-oauth2", "omniauth-facebook", "omniauth-github", "omniauth-google-oauth2", "omniauth-oauth", "omniauth-twitter", "optimist", "pg", "pry", "pry-byebug", "pry-rails", "puma", "r2", "rack-mini-profiler", "rack-protection", "rails_failover", "rails_multisite", "raindrops", "rbtrace", "rchardet", "redis-namespace", "rinku", "rotp", "rqrcode_core", "rqrcode", "rtlit", "ruby-readability", "rubyzip", "sanitize", "sassc", "sprockets-rails", "tilt", "sassc-rails", "seed-fu", "sshkey", "stackprof", "uglifier", "unf_ext", "unf", "unicorn", "webpush", "xorcist"]
HTTP GET https://index.rubygems.org/info/concurrent-ruby
HTTP GET https://index.rubygems.org/info/aws-partitions
HTTP 206 Partial Content https://index.rubygems.org/info/concurrent-ruby
HTTP GET https://index.rubygems.org/info/loofah
HTTP GET https://index.rubygems.org/info/aws-sdk-s3
HTTP 206 Partial Content https://index.rubygems.org/info/loofah
HTTP GET https://index.rubygems.org/info/aws-sdk-core
HTTP GET https://index.rubygems.org/info/nokogiri
HTTP 206 Partial Content https://index.rubygems.org/info/aws-sdk-core
HTTP GET https://index.rubygems.org/info/cppjieba_rb
HTTP GET https://index.rubygems.org/info/aws-sdk-sns
HTTP 206 Partial Content https://index.rubygems.org/info/aws-partitions
HTTP 206 Partial Content https://index.rubygems.org/info/aws-sdk-s3
HTTP 206 Partial Content https://index.rubygems.org/info/nokogiri
HTTP GET https://index.rubygems.org/info/fastimage
HTTP 206 Partial Content https://index.rubygems.org/info/aws-sdk-sns
HTTP GET https://index.rubygems.org/info/message_bus
HTTP 206 Partial Content https://index.rubygems.org/info/fastimage
HTTP 206 Partial Content https://index.rubygems.org/info/message_bus
HTTP 206 Partial Content https://index.rubygems.org/info/cppjieba_rb
Looking up gems ["thread_safe", "rails-deprecated_sanitizer", "rspec", "jsonapi", "case_transform", "jsonapi-renderer", "arel", "activerecord-deprecated_finders", "erubis", "rack-mount", "rack-cache", "journey", "json_pure", "activemodel-globalid", "mail", "text-format", "bcrypt-ruby", "memcache-client", "rdoc", "snappy", "handlebars-source", "ember-template-compiler-source", "columnize", "debugger-linecache", "slop", "rb-readline", "hike", "rack-ssl", "rails", "net-http-persistent", "ruby_parser", "rb-appscript", "xattr", "ffi-xattr", "hoe", "rake-compiler", "termios", "rdf", "celluloid", "compass", "sass", "sprockets-sass", "sinatra", "slim", "stud", "libv8", "ruby-hmac", "faraday-middleware", "httpauth", "oa-core", "oa-oauth", "oa-openid", "oa-basic", "oa-enterprise", "oa-more", "functional-ruby", "ref", "win32console", "yard", "spoon", "bigdecimal", "escape_utils", "listen", "pry-doc", "base32", "jamespath", "http-2", "hpricot", "bundler", "trollop", "therubyracer", "weakling", "mini_portile", "mini_portile2", "pkg-config", "eventmachine", "thin"]
HTTP GET https://index.rubygems.org/info/slop
HTTP GET https://index.rubygems.org/info/hoe
HTTP 206 Partial Content https://index.rubygems.org/info/slop
HTTP 206 Partial Content https://index.rubygems.org/info/hoe
HTTP GET https://index.rubygems.org/info/rdf
HTTP GET https://index.rubygems.org/info/bundler
HTTP GET https://index.rubygems.org/info/mini_portile2
HTTP 206 Partial Content https://index.rubygems.org/info/bundler
HTTP 206 Partial Content https://index.rubygems.org/info/mini_portile2
HTTP 206 Partial Content https://index.rubygems.org/info/rdf
Looking up gems ["spruz", "mime-types", "treetop", "tlsmail", "jsonapi-parser", "ZenTest", "RubyInline", "snappy-jars", "rspec-core", "rspec-expectations", "rspec-mocks", "activeresource", "actionwebservice", "actioncable", "activestorage", "actionmailbox", "actiontext", "text-hyphen", "atomic", "ParseTree", "sexp_processor", "multimap", "bcrypt", "ruby_core_source", "debugger-ruby_core_source", "abstract", "timers", "facter", "celluloid-essentials", "celluloid-extras", "celluloid-fsm", "celluloid-pool", "celluloid-supervision", "dotenv", "nenv", "rspec-logsplit", "mongrel", "backports", "mustermann", "metriks", "net-ldap", "rubyntlm", "pyu-ruby-sasl", "uuid", "XMLCanonicalizer", "haml", "fssm", "compass-core", "compass-import-once", "rb-fsevent", "rb-inotify", "sass-listen", "sprockets-helpers", "rack-openid", "ruby-openid-apps-discovery", "temple", "restclient", "rest-client", "curses", "rb-fchange", "rb-kqueue", "celluloid-io", "ruby_dep", "daemons", "rubyforge", "gemcutter", "net-ftp", "link_header", "hamster"]
HTTP GET https://index.rubygems.org/info/net-ftp
HTTP GET https://index.rubygems.org/info/facter
HTTP 200 OK https://index.rubygems.org/info/net-ftp
HTTP 206 Partial Content https://index.rubygems.org/info/facter
Looking up gems ["facets", "polyglot", "rspec-support", "rails-observers", "activemodel-serializers-xml", "SexpProcessor", "diff-lcs", "coffee-rails", "em-hiredis", "faye-websocket", "websocket-driver", "mime-types-data", "coveralls", "rubocop", "marcel", "mimemagic", "hitimes", "archive-tar-minitar", "tool", "macaddr", "cgi_multipart_eof_fix", "fastthread", "gem_plugin", "netrc", "http-cookie", "http-accept", "rbtree", "faraday_middleware", "yajl-ruby", "avl_tree", "celluloid-gems", "dotenv-deployment", "ruby-openid", "log4r", "win32-api", "net-scp", "net-protocol", "time", "CFPropertyList", "sys-admin", "win32-dir", "windows-api", "windows-pr", "win32-security", "hocon"]
HTTP GET https://index.rubygems.org/info/time
HTTP GET https://index.rubygems.org/info/net-protocol
HTTP 200 OK https://index.rubygems.org/info/time
HTTP 200 OK https://index.rubygems.org/info/net-protocol
HTTP GET https://index.rubygems.org/info/rubocop
HTTP GET https://index.rubygems.org/info/http-cookie
HTTP 206 Partial Content https://index.rubygems.org/info/rubocop
HTTP 206 Partial Content https://index.rubygems.org/info/http-cookie
Looking up gems ["coffee-script", "configuration", "mkrf", "websocket-extensions", "colorize", "simplecov", "term-ansicolor", "tins", "minitar", "minitar-cli", "ruby-yadis", "hiredis", "roauth", "libxml-ruby", "systemu", "test-unit", "ffi-win32-extensions", "net-ssh", "io-wait", "timeout", "domain_name", "sqlite3", "rainbow", "parser", "powerpack", "ruby-progressbar", "astrolabe", "unicode-display_width", "parallel", "jaro_winkler", "psych", "rexml", "rubocop-ast"]
HTTP GET https://index.rubygems.org/info/io-wait
HTTP GET https://index.rubygems.org/info/timeout
HTTP 200 OK https://index.rubygems.org/info/io-wait
HTTP 200 OK https://index.rubygems.org/info/timeout
HTTP GET https://index.rubygems.org/info/test-unit
HTTP GET https://index.rubygems.org/info/psych
HTTP 206 Partial Content https://index.rubygems.org/info/test-unit
HTTP 206 Partial Content https://index.rubygems.org/info/psych
Looking up gems ["coffee-script-source", "needle", "jruby-pageant", "bcrypt_pbkdf", "rbnacl", "rbnacl-libsodium", "ast", "simplecov-html", "docile", "lockfile", "simplecov_json_formatter", "sync", "powerbar", "strscan", "power_assert", "jar-dependencies"]
Looking up gems ["pattern-match", "ruby-maven", "ansi"]
Looking up gems ["maven-tools", "ruby-maven-libs"]
Looking up gems ["virtus"]
HTTP GET https://index.rubygems.org/info/virtus
HTTP 206 Partial Content https://index.rubygems.org/info/virtus
Looking up gems ["descendants_tracker", "axiom-types", "coercible", "equalizer"]
Looking up gems ["adamantium", "ice_nine"]
Looking up gems ["memoizable"]
Using rake 13.0.3
0: rake (13.0.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rake-13.0.3.gemspec
Using minitest 5.14.4
Using zeitwerk 2.4.2
Using builder 3.2.4
3: minitest (5.14.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/minitest-5.14.4.gemspec
Fetching concurrent-ruby 1.1.9
Using erubi 1.10.0
1: zeitwerk (2.4.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/zeitwerk-2.4.2.gemspec
Using racc 1.5.2
1: racc (1.5.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/racc-1.5.2.gemspec
Using crass 1.0.6
1: crass (1.0.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/crass-1.0.6.gemspec
Using rack 2.2.3
1: rack (2.2.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rack-2.2.3.gemspec
3: erubi (1.10.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/erubi-1.10.0.gemspec
Using mini_mime 1.1.0
0: builder (3.2.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/builder-3.2.4.gemspec
Using public_suffix 4.0.6
1: public_suffix (4.0.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/public_suffix-4.0.6.gemspec
Using aws-eventstream 1.1.1
1: aws-eventstream (1.1.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-eventstream-1.1.1.gemspec
3: mini_mime (1.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/mini_mime-1.1.0.gemspec
Using aws-partitions 1.432.0
1: aws-partitions (1.432.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-partitions-1.432.0.gemspec
Using jmespath 1.4.0
1: jmespath (1.4.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/jmespath-1.4.0.gemspec
Using ember-source 2.18.2
0: ember-source (2.18.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ember-source-2.18.2.gemspec
Using execjs 2.8.1
Using msgpack 1.4.2
0: execjs (2.8.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/execjs-2.8.1.gemspec
3: msgpack (1.4.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/msgpack-1.4.2.gemspec
Using bundler 2.2.19
Using byebug 11.1.3
3: bundler (2.2.19) from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/lib/bundler/source
0: byebug (11.1.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/byebug-11.1.3.gemspec
Using cbor 0.5.9.6
3: cbor (0.5.9.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/cbor-0.5.9.6.gemspec
Using chunky_png 1.4.0
0: chunky_png (1.4.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/chunky_png-1.4.0.gemspec
Using coderay 1.1.3
0: coderay (1.1.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/coderay-1.1.3.gemspec
Using colored2 3.1.2
0: colored2 (3.1.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/colored2-3.1.2.gemspec
Using connection_pool 2.2.5
0: connection_pool (2.2.5) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/connection_pool-2.2.5.gemspec
Using openssl 2.2.0
Using cppjieba_rb 0.3.3
Using diffy 3.4.0
0: diffy (3.4.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/diffy-3.4.0.gemspec
1: cppjieba_rb (0.3.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/cppjieba_rb-0.3.3.gemspec
Using method_source 1.0.0
1: method_source (1.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/method_source-1.0.0.gemspec
3: openssl (2.2.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/openssl-2.2.0.gemspec
Using thor 1.1.0
3: thor (1.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/thor-1.1.0.gemspec
Using discourse-ember-source 3.12.2.3
3: discourse-ember-source (3.12.2.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/discourse-ember-source-3.12.2.3.gemspec
Using discourse-fonts 0.0.8
3: discourse-fonts (0.0.8) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/discourse-fonts-0.0.8.gemspec
Using regexp_parser 2.1.1
3: regexp_parser (2.1.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/regexp_parser-2.1.1.gemspec
Using email_reply_trimmer 0.1.13
3: email_reply_trimmer (0.1.13) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/email_reply_trimmer-0.1.13.gemspec
Using excon 0.82.0
3: excon (0.82.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/excon-0.82.0.gemspec
Using exifr 1.3.9
3: exifr (1.3.9) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/exifr-1.3.9.gemspec
Using faraday-em_http 1.0.0
3: faraday-em_http (1.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-em_http-1.0.0.gemspec
Using faraday-em_synchrony 1.0.0
3: faraday-em_synchrony (1.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-em_synchrony-1.0.0.gemspec
Using faraday-excon 1.1.0
3: faraday-excon (1.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-excon-1.1.0.gemspec
Using faraday-net_http 1.0.1
Using faraday-net_http_persistent 1.1.0
3: faraday-net_http_persistent (1.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-net_http_persistent-1.1.0.gemspec
Using multipart-post 2.1.1
3: multipart-post (2.1.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/multipart-post-2.1.1.gemspec
Using ruby2_keywords 0.0.4
Using fast_blank 1.0.0
1: faraday-net_http (1.0.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-net_http-1.0.1.gemspec
Using fast_xs 0.8.0
1: fast_xs (0.8.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/fast_xs-0.8.0.gemspec
3: fast_blank (1.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/fast_blank-1.0.0.gemspec
Using ffi 1.15.1
3: ffi (1.15.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ffi-1.15.1.gemspec
Using fspath 3.1.2
3: fspath (3.1.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/fspath-3.1.2.gemspec
Using gc_tracer 1.5.1
3: gc_tracer (1.5.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/gc_tracer-1.5.1.gemspec
Using guess_html_encoding 0.0.11
3: guess_html_encoding (0.0.11) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/guess_html_encoding-0.0.11.gemspec
Using hana 1.3.7
3: hana (1.3.7) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/hana-1.3.7.gemspec
Using hashie 4.1.0
3: hashie (4.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/hashie-4.1.0.gemspec
Fetching fastimage 2.2.4
Using highline 2.0.3
3: highline (2.0.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/highline-2.0.3.gemspec
Using hkdf 0.3.0
3: hkdf (0.3.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/hkdf-0.3.0.gemspec
Using htmlentities 4.3.4
3: htmlentities (4.3.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/htmlentities-4.3.4.gemspec
Using http_accept_language 2.1.1
3: http_accept_language (2.1.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/http_accept_language-2.1.1.gemspec
Using image_size 2.1.0
3: image_size (2.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/image_size-2.1.0.gemspec
Using in_threads 1.5.4
3: in_threads (1.5.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/in_threads-1.5.4.gemspec
Using progress 3.6.0
3: progress (3.6.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/progress-3.6.0.gemspec
Using json 2.5.1
3: json (2.5.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/json-2.5.1.gemspec
Using uri_template 0.7.0
3: uri_template (0.7.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/uri_template-0.7.0.gemspec
Using jwt 2.2.3
3: jwt (2.2.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/jwt-2.2.3.gemspec
Using kgio 2.11.4
3: kgio (2.11.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/kgio-2.11.4.gemspec
Using libv8-node 15.14.0.1 (x86_64-linux)
3: libv8-node (15.14.0.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/libv8-node-15.14.0.1-x86_64-linux.gemspec
0: ruby2_keywords (0.0.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ruby2_keywords-0.0.4.gemspec
Using logstash-event 1.2.02
3: logstash-event (1.2.02) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/logstash-event-1.2.02.gemspec
Using logster 2.9.6
3: logster (2.9.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/logster-2.9.6.gemspec
Using lru_redux 1.1.0
3: lru_redux (1.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/lru_redux-1.1.0.gemspec
Using lz4-ruby 0.3.3
3: lz4-ruby (0.3.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/lz4-ruby-0.3.3.gemspec
Using maxminddb 0.1.22
3: maxminddb (0.1.22) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/maxminddb-0.1.22.gemspec
Using memory_profiler 1.0.0
3: memory_profiler (1.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/memory_profiler-1.0.0.gemspec
Using redis 4.2.5
3: redis (4.2.5) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/redis-4.2.5.gemspec
Using mini_sql 1.1.3
3: mini_sql (1.1.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/mini_sql-1.1.3.gemspec
Using multi_json 1.15.0
3: multi_json (1.15.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/multi_json-1.15.0.gemspec
Using multi_xml 0.6.0
3: multi_xml (0.6.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/multi_xml-0.6.0.gemspec
Using mustache 1.1.1
3: mustache (1.1.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/mustache-1.1.1.gemspec
Using nio4r 2.5.7
3: nio4r (2.5.7) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/nio4r-2.5.7.gemspec
Using oauth 0.5.6
3: oauth (0.5.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/oauth-0.5.6.gemspec
Using oj 3.11.5
3: oj (3.11.5) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/oj-3.11.5.gemspec
Using optimist 3.0.1
3: optimist (3.0.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/optimist-3.0.1.gemspec
Using pg 1.2.3
3: pg (1.2.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/pg-1.2.3.gemspec
Using r2 0.2.7
3: r2 (0.2.7) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/r2-0.2.7.gemspec
Using raindrops 0.19.2
3: raindrops (0.19.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/raindrops-0.19.2.gemspec
Using rchardet 1.8.0
3: rchardet (1.8.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rchardet-1.8.0.gemspec
Using rinku 2.0.6
3: rinku (2.0.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rinku-2.0.6.gemspec
Using rotp 6.2.0
3: rotp (6.2.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rotp-6.2.0.gemspec
Using rqrcode_core 1.0.0
3: rqrcode_core (1.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rqrcode_core-1.0.0.gemspec
Using rtlit 0.0.5
3: rtlit (0.0.5) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rtlit-0.0.5.gemspec
Using rubyzip 2.3.0
3: rubyzip (2.3.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rubyzip-2.3.0.gemspec
Using tilt 2.0.10
3: tilt (2.0.10) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/tilt-2.0.10.gemspec
Using sshkey 2.0.0
3: sshkey (2.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sshkey-2.0.0.gemspec
Using stackprof 0.2.17
3: stackprof (0.2.17) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/stackprof-0.2.17.gemspec
Using unf_ext 0.0.7.7
3: unf_ext (0.0.7.7) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/unf_ext-0.0.7.7.gemspec
Using xorcist 1.1.2
3: xorcist (1.1.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/xorcist-1.1.2.gemspec
Using rack-test 1.1.0
0: rack-test (1.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rack-test-1.1.0.gemspec
Using request_store 1.5.0
0: request_store (1.5.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/request_store-1.5.0.gemspec
Fetching nokogiri 1.11.7 (x86_64-linux)
Fetching message_bus 3.3.6
Installing fastimage 2.2.4
1: fastimage (2.2.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/fastimage-2.2.4.gemspec
Using rack-mini-profiler 2.3.2
1: rack-mini-profiler (2.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rack-mini-profiler-2.3.2.gemspec
Using rack-protection 2.1.0
1: rack-protection (2.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rack-protection-2.1.0.gemspec
Using addressable 2.7.0
1: addressable (2.7.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/addressable-2.7.0.gemspec
Using aws-sigv4 1.2.3
1: aws-sigv4 (1.2.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-sigv4-1.2.3.gemspec
Using ember-data-source 3.0.2
1: ember-data-source (3.0.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ember-data-source-3.0.2.gemspec
Using mail 2.8.0.edge from https://github.com/discourse/mail.git (at master@5b700fc)
1: mail (2.8.0.edge) from /var/www/discourse/vendor/bundle/ruby/2.7.0/bundler/gems/mail-5b700fc95ee6/mail.gemspec
Using bootsnap 1.7.5
1: bootsnap (1.7.5) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/bootsnap-1.7.5.gemspec
Using barber 0.12.2
1: barber (0.12.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/barber-0.12.2.gemspec
Using uglifier 4.2.0
1: uglifier (4.2.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/uglifier-4.2.0.gemspec
Using openssl-signature_algorithm 1.1.1
1: openssl-signature_algorithm (1.1.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/openssl-signature_algorithm-1.1.1.gemspec
Using ecma-re-validator 0.3.0
1: ecma-re-validator (0.3.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ecma-re-validator-0.3.0.gemspec
Using pry 0.13.1
1: pry (0.13.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/pry-0.13.1.gemspec
Using mini_suffix 0.3.2
1: mini_suffix (0.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/mini_suffix-0.3.2.gemspec
Using sassc 2.0.1
1: sassc (2.0.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sassc-2.0.1.gemspec
Using omniauth 1.9.1
1: omniauth (1.9.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-1.9.1.gemspec
Using image_optim 0.30.0
1: image_optim (0.30.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/image_optim-0.30.0.gemspec
Using webpush 1.1.0
1: webpush (1.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/webpush-1.1.0.gemspec
Using mini_racer 0.4.0
1: mini_racer (0.4.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/mini_racer-0.4.0.gemspec
Using logstash-logger 0.26.1
1: logstash-logger (0.26.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/logstash-logger-0.26.1.gemspec
Using sidekiq 6.2.1
1: sidekiq (6.2.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sidekiq-6.2.1.gemspec
Using redis-namespace 1.8.1
1: redis-namespace (1.8.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/redis-namespace-1.8.1.gemspec
Using puma 5.3.2
1: puma (5.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/puma-5.3.2.gemspec
Using rbtrace 0.4.14
1: rbtrace (0.4.14) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rbtrace-0.4.14.gemspec
Using unicorn 6.0.0
1: unicorn (6.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/unicorn-6.0.0.gemspec
Using rqrcode 2.0.0
1: rqrcode (2.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rqrcode-2.0.0.gemspec
Using faraday 1.4.2
1: faraday (1.4.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-1.4.2.gemspec
Using unf 0.1.4
1: unf (0.1.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/unf-0.1.4.gemspec
Using css_parser 1.9.0
1: css_parser (1.9.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/css_parser-1.9.0.gemspec
Using aws-sdk-core 3.112.1
1: aws-sdk-core (3.112.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-sdk-core-3.112.1.gemspec
Using cose 1.2.0
1: cose (1.2.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/cose-1.2.0.gemspec
Using json_schemer 0.2.18
1: json_schemer (0.2.18) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/json_schemer-0.2.18.gemspec
Using omniauth-oauth 1.2.0
1: omniauth-oauth (1.2.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-oauth-1.2.0.gemspec
Using pry-byebug 3.9.0
1: pry-byebug (3.9.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/pry-byebug-3.9.0.gemspec
Using pry-rails 0.3.9
1: pry-rails (0.3.9) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/pry-rails-0.3.9.gemspec
Using aws-sdk-kms 1.42.0
1: aws-sdk-kms (1.42.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-sdk-kms-1.42.0.gemspec
Using aws-sdk-sns 1.38.0
1: aws-sdk-sns (1.38.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-sdk-sns-1.38.0.gemspec
Using mini_scheduler 0.13.0
1: mini_scheduler (0.13.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/mini_scheduler-0.13.0.gemspec
Using oauth2 1.4.7
1: oauth2 (1.4.7) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/oauth2-1.4.7.gemspec
Using omniauth-twitter 1.4.0
1: omniauth-twitter (1.4.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-twitter-1.4.0.gemspec
Using aws-sdk-s3 1.90.0
1: aws-sdk-s3 (1.90.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-sdk-s3-1.90.0.gemspec
Using omniauth-oauth2 1.7.1
1: omniauth-oauth2 (1.7.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-oauth2-1.7.1.gemspec
Using omniauth-facebook 8.0.0
1: omniauth-facebook (8.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-facebook-8.0.0.gemspec
Using omniauth-github 1.4.0
1: omniauth-github (1.4.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-github-1.4.0.gemspec
Using omniauth-google-oauth2 0.8.2
1: omniauth-google-oauth2 (0.8.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-google-oauth2-0.8.2.gemspec
Installing concurrent-ruby 1.1.9
Installing message_bus 3.3.6
0: message_bus (3.3.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/message_bus-3.3.6.gemspec
2: concurrent-ruby (1.1.9) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/concurrent-ruby-1.1.9.gemspec
Using i18n 1.8.10
Using tzinfo 2.0.4
Using sprockets 3.7.2
1: i18n (1.8.10) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/i18n-1.8.10.gemspec
2: sprockets (3.7.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sprockets-3.7.2.gemspec
0: tzinfo (2.0.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/tzinfo-2.0.4.gemspec
Using ember-handlebars-template 0.8.0
0: ember-handlebars-template (0.8.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ember-handlebars-template-0.8.0.gemspec
Using activesupport 6.1.3.2
2: activesupport (6.1.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/activesupport-6.1.3.2.gemspec
Using globalid 0.4.2
Using activemodel 6.1.3.2
0: activemodel (6.1.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/activemodel-6.1.3.2.gemspec
1: globalid (0.4.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/globalid-0.4.2.gemspec
Using active_model_serializers 0.8.4
1: active_model_serializers (0.8.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/active_model_serializers-0.8.4.gemspec
Using activerecord 6.1.3.2
1: activerecord (6.1.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/activerecord-6.1.3.2.gemspec
Using activejob 6.1.3.2
Using seed-fu 2.3.9
1: activejob (6.1.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/activejob-6.1.3.2.gemspec
2: seed-fu (2.3.9) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/seed-fu-2.3.9.gemspec
Installing nokogiri 1.11.7 (x86_64-linux)
3: nokogiri (1.11.7) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/nokogiri-1.11.7-x86_64-linux.gemspec
Using rails-dom-testing 2.0.3
0: rails-dom-testing (2.0.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rails-dom-testing-2.0.3.gemspec
Using nokogumbo 2.0.5
1: nokogumbo (2.0.5) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/nokogumbo-2.0.5.gemspec
Using ruby-readability 0.7.0
1: ruby-readability (0.7.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ruby-readability-0.7.0.gemspec
Using sanitize 5.2.3
2: sanitize (5.2.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sanitize-5.2.3.gemspec
Fetching loofah 2.10.0
Installing loofah 2.10.0
0: loofah (2.10.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/loofah-2.10.0.gemspec
Using rails-html-sanitizer 1.3.0
3: rails-html-sanitizer (1.3.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rails-html-sanitizer-1.3.0.gemspec
Using actionview 6.1.3.2
1: actionview (6.1.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/actionview-6.1.3.2.gemspec
Using actionpack 6.1.3.2
2: actionpack (6.1.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/actionpack-6.1.3.2.gemspec
Using actionview_precompiler 0.2.3
0: actionview_precompiler (0.2.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/actionview_precompiler-0.2.3.gemspec
Using actionmailer 6.1.3.2
0: actionmailer (6.1.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/actionmailer-6.1.3.2.gemspec
Using railties 6.1.3.2
0: railties (6.1.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/railties-6.1.3.2.gemspec
Using sprockets-rails 3.2.2
0: sprockets-rails (3.2.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sprockets-rails-3.2.2.gemspec
Using jquery-rails 4.4.0
0: jquery-rails (4.4.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/jquery-rails-4.4.0.gemspec
Using lograge 0.11.2
0: lograge (0.11.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/lograge-0.11.2.gemspec
Using rails_failover 0.7.3
Using rails_multisite 3.0.0
Using sassc-rails 2.1.2
Using discourse-ember-rails 0.18.6
0: discourse-ember-rails (0.18.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/discourse-ember-rails-0.18.6.gemspec
2: sassc-rails (2.1.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sassc-rails-2.1.2.gemspec
1: rails_multisite (3.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rails_multisite-3.0.0.gemspec
3: rails_failover (0.7.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rails_failover-0.7.3.gemspec
Bundle complete! 125 Gemfile dependencies, 169 gems now installed.
Gems in the groups 'test' and 'development' were not installed.
Bundled gems are installed into `./vendor/bundle`
I, [2021-06-09T17:16:30.740103 #1] INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake plugin:pull_compatible_all'
I, [2021-06-09T17:16:32.645348 #1] INFO -- : docker_manager is already at latest compatible version
discourse-akismet is already at latest compatible version
discourse-solved is already at latest compatible version
discourse-tagging is already at latest compatible version
discourse-staff-notes is already at latest compatible version
discourse-oauth2-basic is already at latest compatible version
I, [2021-06-09T17:16:32.645620 #1] INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
rake aborted!
NoMethodError: undefined method `client_setting' for #<Class:0x00007f099c5312e8>
Did you mean? client_settings
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.3.2/lib/active_record/dynamic_matchers.rb:22:in `method_missing'
/var/www/discourse/plugins/discourse-tagging/plugin.rb:13:in `block in activate!'
/var/www/discourse/lib/plugin/instance.rb:430:in `block in notify_after_initialize'
/var/www/discourse/lib/plugin/instance.rb:428:in `each'
/var/www/discourse/lib/plugin/instance.rb:428:in `notify_after_initialize'
/var/www/discourse/config/application.rb:351:in `each'
/var/www/discourse/config/application.rb:351:in `block (2 levels) in <class:Application>'
/var/www/discourse/lib/plugin_initialization_guard.rb:5:in `plugin_initialization_guard'
/var/www/discourse/config/application.rb:350:in `block in <class:Application>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.3.2/lib/active_support/lazy_load_hooks.rb:68:in `block in execute_hook'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.3.2/lib/active_support/lazy_load_hooks.rb:61:in `with_execution_control'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.3.2/lib/active_support/lazy_load_hooks.rb:66:in `execute_hook'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.3.2/lib/active_support/lazy_load_hooks.rb:52:in `block in run_load_hooks'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.3.2/lib/active_support/lazy_load_hooks.rb:51:in `each'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.3.2/lib/active_support/lazy_load_hooks.rb:51:in `run_load_hooks'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.3.2/lib/rails/application/finisher.rb:140:in `block in <module:Finisher>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.3.2/lib/rails/initializable.rb:32:in `instance_exec'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.3.2/lib/rails/initializable.rb:32:in `run'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.3.2/lib/rails/initializable.rb:61:in `block in run_initializers'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.3.2/lib/rails/initializable.rb:60:in `run_initializers'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.3.2/lib/rails/application.rb:384:in `initialize!'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.3.2/lib/rails/railtie.rb:207:in `public_send'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.3.2/lib/rails/railtie.rb:207:in `method_missing'
/var/www/discourse/config/environment.rb:7:in `<main>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.7.5/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:23:in `require'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.7.5/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:23:in `block in require_with_bootsnap_lfi'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.7.5/lib/bootsnap/load_path_cache/loaded_features_index.rb:92:in `register'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.7.5/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:22:in `require_with_bootsnap_lfi'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.7.5/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:31:in `require'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/zeitwerk-2.4.2/lib/zeitwerk/kernel.rb:34:in `require'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.3.2/lib/active_support/dependencies.rb:332:in `block in require'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.3.2/lib/active_support/dependencies.rb:299:in `load_dependency'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.3.2/lib/active_support/dependencies.rb:332:in `require'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.3.2/lib/rails/application.rb:360:in `require_environment!'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.3.2/lib/rails/application.rb:526:in `block in run_tasks_blocks'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/exe/rake:27:in `<top (required)>'
/usr/local/bin/bundle:23:in `load'
/usr/local/bin/bundle:23:in `<main>'
Tasks: TOP => db:migrate => db:load_config => environment
I, [2021-06-09T17:16:35.802368 #1] INFO -- :
I, [2021-06-09T17:16:35.802856 #1] INFO -- : Terminating async processes
173:signal-handler (1623258995) Received SIGTERM scheduling shutdown...
I, [2021-06-09T17:16:35.802958 #1] INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 56
I, [2021-06-09T17:16:35.803043 #1] INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 173
2021-06-09 17:16:35.803 UTC [56] LOG: received fast shutdown request
2021-06-09 17:16:35.803 UTC [56] LOG: aborting any active transactions
2021-06-09 17:16:35.805 UTC [56] LOG: background worker "logical replication launcher" (PID 65) exited with exit code 1
2021-06-09 17:16:35.806 UTC [60] LOG: shutting down
173:M 09 Jun 2021 17:16:35.821 # User requested shutdown...
173:M 09 Jun 2021 17:16:35.821 * Saving the final RDB snapshot before exiting.
2021-06-09 17:16:35.825 UTC [56] LOG: database system is shut down
173:M 09 Jun 2021 17:16:39.907 * DB saved on disk
173:M 09 Jun 2021 17:16:39.907 # Redis is now ready to exit, bye bye...
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 449 exit 1>
exec failed with the params {"cd"=>"$home", "hook"=>"db_migrate", "cmd"=>["su discourse -c 'bundle exec rake db:migrate'"]}
309140db90850e9ea6644e471ee47f5fea3a1bb6ea36577280d3c431eaf497fe
==================== END REBUILD LOG ====================
Failed to rebuild app.
Checking your domain name . . .
Connection to xxxx.org succeeded.
You should probably remove any non-standard plugins and rebuild.
Attempting to restart existing container. . .
starting up existing container
+ /usr/bin/docker start app
app
6084a0e22b64 local_discourse/app "/sbin/boot" 5 weeks ago Up Less than a second 0.0.0.0:2222->22/tcp, 0.0.0.0:8123->80/tcp, 0.0.0.0:8124->443/tcp app
Restarted the container.
==================== PLUGINS ====================
- git clone https://github.com/discourse/discourse-tagging.git
- git clone https://github.com/discourse/discourse-solved.git
- git clone https://github.com/discourse/discourse-oauth2-basic.git
- git clone https://github.com/discourse/discourse-akismet.git
- git clone https://github.com/discourse/discourse-staff-notes.git
No non-official plugins detected.
See https://github.com/discourse/discourse/blob/master/lib/plugin/metadata.rb for the official list.
Discourse version at xxxxx.org: NOT FOUND
Discourse version at localhost: NOT FOUND
==================== MEMORY INFORMATION ====================
RAM (MB): 32918
total used free shared buffers cached
Mem: 32146 29958 2187 62 469 26285
-/+ buffers/cache: 3204 28942
Swap: 32734 164 32570
==================== DISK SPACE CHECK ====================
---------- OS Disk Space ----------
Filesystem Size Used Avail Use% Mounted on
/dev/sda1 203G 135G 58G 71% /
/dev/sda1 203G 135G 58G 71% /var/lib/docker
==================== DISK INFORMATION ====================
Disk /dev/sda: 255.4 GB, 255416336384 bytes
255 heads, 63 sectors/track, 31052 cylinders, total 498860032 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x000224d2
Device Boot Start End Blocks Id System
/dev/sda1 * 2048 431814655 215906304 83 Linux
/dev/sda2 431816702 498857983 33520641 5 Extended
/dev/sda5 431816704 498857983 33520640 82 Linux swap / Solaris
==================== END DISK INFORMATION ====================
==================== MAIL TEST ====================
For a robust test, get an address from http://www.mail-tester.com/
Or just send a test message to yourself.
rake aborted!
NoMethodError: undefined method `client_setting' for #<Class:0x00007fc640268938>
Tasks: TOP => emails:test => environment
Replacing: SMTP_PASSWORD
Replacing: LETSENCRYPT_ACCOUNT_EMAIL
Replacing: DEVELOPER_EMAILS
Replacing: DISCOURSE_DB_PASSWORD
Replacing: Sending mail to
==================== DONE! ====================
Would you like to serve a publicly available version of this file? (Y/n)n
Publicly available log not generated.
You can examine the output of this script with
LESS=-Ri less /tmp/discourse-debug.txt
BUT FIRST, make sure that you know the first three commands below!!!
Commands to know when viewing the file with the above command (called 'less'):
q -- quit
/error<ENTER> -- search for the word 'error'
n -- search for the next occurrence
g -- go to the beginning of the file
f -- go forward a page
b -- go back a page
G -- go to the end of the file
