ssia. I’ve been unable to update, either in console or within Discourse. Have tried countless things, including disabling all plugins, to no avail. If anyone can deduce anything from the screencap of the console when I tried to rebuild, I’d be super grateful.
סיכום מבוסס בינה מלאכותית
Unable to Rebuild App
b481 is experiencing issues rebuilding their Discourse app, with an error message indicating a failure to bootstrap. The issue started after a failed upgrade attempt through the Dashboard, although upgrades can now be performed successfully through the Dashboard, rebuilds through the command line are still failing.
Falco and pfaffman suspect a database migration issue, but b481 confirmed that it’s not a migration issue.
After providing the full log, pfaffman suspects a Redis issue, which b481 also considers a possibility due to Discourse’s use of Redis for Sidekiq.
pfaffman found a hidden Redis error in the logs, which might be the root cause of the issue. However, the exact solution remains unclear.
Looks like a failed migration, but we need the log lines from earlier in order to determine why they are failing.
Not a migration, though I did migrate a few months ago though I was able to update and rebuild a good few times after that. This is just a rebuild however. Will try and get the entire log later.
He means a database migration. Upgrades sometimes include changes to the database structure. It looks like that’s what failed (perhaps a corrupt database index or errant plugin, but those are wild guesses).
If you can’t scroll back, just try again. Rather than a screen shot, copying the text is better. And you can paste it between back ticks like
Your stuff here
Apologies for the very overdue response, but I finally got around to getting a log.
tthe following is everything after starting the rebuild.
Fetching origin
Launcher is up-to-date
Stopping old container
+ /usr/bin/docker stop -t 60 app
app
cd /pups && git pull && git checkout v1.0.3 && /pups/bin/pups --stdin
Already up to date.
Note: checking out 'v1.0.3'.
You are in 'detached HEAD' state. You can look around, make experimental
changes and commit them, and you can discard any commits you make in this
state without impacting any branches by performing another checkout.
If you want to create a new branch to retain commits you create, you may
do so (now or later) by using -b with the checkout command again. Example:
git checkout -b <new-branch-name>
HEAD is now at d1db030 cut a new version
I, [2021-11-01T00:22:36.703574 #1] INFO -- : Loading --stdin
I, [2021-11-01T00:22:36.713107 #1] INFO -- : > locale-gen $LANG && update-locale
I, [2021-11-01T00:22:36.792263 #1] INFO -- : Generating locales (this might take a while)...
Generation complete.
I, [2021-11-01T00:22:36.793270 #1] INFO -- : > mkdir -p /shared/postgres_run
I, [2021-11-01T00:22:36.802760 #1] INFO -- :
I, [2021-11-01T00:22:36.804583 #1] INFO -- : > chown postgres:postgres /shared/postgres_run
I, [2021-11-01T00:22:36.810419 #1] INFO -- :
I, [2021-11-01T00:22:36.811303 #1] INFO -- : > chmod 775 /shared/postgres_run
I, [2021-11-01T00:22:36.816328 #1] INFO -- :
I, [2021-11-01T00:22:36.817118 #1] INFO -- : > rm -fr /var/run/postgresql
I, [2021-11-01T00:22:36.822275 #1] INFO -- :
I, [2021-11-01T00:22:36.823079 #1] INFO -- : > ln -s /shared/postgres_run /var/run/postgresql
I, [2021-11-01T00:22:36.827897 #1] INFO -- :
I, [2021-11-01T00:22:36.828769 #1] INFO -- : > socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1
2021/11/01 00:22:36 socat[27] E connect(6, AF=1 "/shared/postgres_run/.s.PGSQL.5432", 36): No such file or directory
I, [2021-11-01T00:22:36.847474 #1] INFO -- :
I, [2021-11-01T00:22:36.848113 #1] INFO -- : > rm -fr /shared/postgres_run/.s*
I, [2021-11-01T00:22:36.854060 #1] INFO -- :
I, [2021-11-01T00:22:36.854652 #1] INFO -- : > rm -fr /shared/postgres_run/*.pid
I, [2021-11-01T00:22:36.859188 #1] INFO -- :
I, [2021-11-01T00:22:36.859800 #1] INFO -- : > mkdir -p /shared/postgres_run/13-main.pg_stat_tmp
I, [2021-11-01T00:22:36.863659 #1] INFO -- :
I, [2021-11-01T00:22:36.864442 #1] INFO -- : > chown postgres:postgres /shared/postgres_run/13-main.pg_stat_tmp
I, [2021-11-01T00:22:36.868279 #1] INFO -- :
I, [2021-11-01T00:22:36.877938 #1] INFO -- : File > /etc/service/postgres/run chmod: +x chown:
I, [2021-11-01T00:22:36.885613 #1] INFO -- : File > /etc/service/postgres/log/run chmod: +x chown:
I, [2021-11-01T00:22:36.893862 #1] INFO -- : File > /etc/runit/3.d/99-postgres chmod: +x chown:
I, [2021-11-01T00:22:36.901790 #1] INFO -- : File > /root/upgrade_postgres chmod: +x chown:
I, [2021-11-01T00:22:36.902690 #1] INFO -- : > chown -R root /var/lib/postgresql/13/main
I, [2021-11-01T00:22:37.960738 #1] INFO -- :
I, [2021-11-01T00:22:37.961792 #1] INFO -- : > [ ! -e /shared/postgres_data ] && install -d -m 0755 -o postgres -g postgres /shared/postgres_data && sudo -E -u postgres /usr/lib/postgresql/13/bin/initdb -D /shared/postgres_data || exit 0
I, [2021-11-01T00:22:37.965979 #1] INFO -- :
I, [2021-11-01T00:22:37.966532 #1] INFO -- : > chown -R postgres:postgres /shared/postgres_data
I, [2021-11-01T00:22:37.997716 #1] INFO -- :
I, [2021-11-01T00:22:37.998764 #1] INFO -- : > chown -R postgres:postgres /var/run/postgresql
I, [2021-11-01T00:22:38.003595 #1] INFO -- :
I, [2021-11-01T00:22:38.004484 #1] INFO -- : > /root/upgrade_postgres
I, [2021-11-01T00:22:38.015331 #1] INFO -- :
I, [2021-11-01T00:22:38.016143 #1] INFO -- : > rm /root/upgrade_postgres
I, [2021-11-01T00:22:38.020319 #1] INFO -- :
I, [2021-11-01T00:22:38.022437 #1] INFO -- : Replacing data_directory = '/var/lib/postgresql/13/main' with data_directory = '/shared/postgres_data' in /etc/postgresql/13/main/postgresql.conf
I, [2021-11-01T00:22:38.023631 #1] INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addresses = '*' in /etc/postgresql/13/main/postgresql.conf
I, [2021-11-01T00:22:38.024627 #1] INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchronous_commit = $db_synchronous_commit in /etc/postgresql/13/main/postgresql.conf
I, [2021-11-01T00:22:38.025408 #1] INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffers = $db_shared_buffers in /etc/postgresql/13/main/postgresql.conf
I, [2021-11-01T00:22:38.026156 #1] INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work_mem in /etc/postgresql/13/main/postgresql.conf
I, [2021-11-01T00:22:38.026959 #1] INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with default_text_search_config = '$db_default_text_search_config' in /etc/postgresql/13/main/postgresql.conf
I, [2021-11-01T00:22:38.027835 #1] INFO -- : > install -d -m 0755 -o postgres -g postgres /shared/postgres_backup
I, [2021-11-01T00:22:38.035462 #1] INFO -- :
I, [2021-11-01T00:22:38.036596 #1] INFO -- : Replacing (?-mix:#?checkpoint_segments *=.*) with checkpoint_segments = $db_checkpoint_segments in /etc/postgresql/13/main/postgresql.conf
I, [2021-11-01T00:22:38.037385 #1] INFO -- : Replacing (?-mix:#?logging_collector *=.*) with logging_collector = $db_logging_collector in /etc/postgresql/13/main/postgresql.conf
I, [2021-11-01T00:22:38.038251 #1] INFO -- : Replacing (?-mix:#?log_min_duration_statement *=.*) with log_min_duration_statement = $db_log_min_duration_statement in /etc/postgresql/13/main/postgresql.conf
I, [2021-11-01T00:22:38.039441 #1] INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) with local replication postgres peer in /etc/postgresql/13/main/pg_hba.conf
I, [2021-11-01T00:22:38.040287 #1] INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2021-11-01T00:22:38.041101 #1] INFO -- : Replacing (?-mix:^host.*all.*all.*::1\/128.*$) with host all all ::/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2021-11-01T00:22:38.041740 #1] INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main
I, [2021-11-01T00:22:38.045506 #1] INFO -- : > sleep 5
2021-11-01 00:22:38.165 UTC [50] LOG: starting PostgreSQL 13.4 (Debian 13.4-4.pgdg100+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 8.3.0-6) 8.3.0, 64-bit
2021-11-01 00:22:38.166 UTC [50] LOG: listening on IPv4 address "0.0.0.0", port 5432
2021-11-01 00:22:38.166 UTC [50] LOG: listening on IPv6 address "::", port 5432
2021-11-01 00:22:38.168 UTC [50] LOG: listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2021-11-01 00:22:38.173 UTC [53] LOG: database system was shut down at 2021-11-01 00:22:25 UTC
2021-11-01 00:22:38.184 UTC [50] LOG: database system is ready to accept connections
I, [2021-11-01T00:22:43.056258 #1] INFO -- :
I, [2021-11-01T00:22:43.057405 #1] INFO -- : > su postgres -c 'createdb discourse' || true
2021-11-01 00:22:43.211 UTC [63] postgres@postgres ERROR: database "discourse" already exists
2021-11-01 00:22:43.211 UTC [63] postgres@postgres STATEMENT: CREATE DATABASE discourse;
createdb: error: database creation failed: ERROR: database "discourse" already exists
I, [2021-11-01T00:22:43.217515 #1] INFO -- :
I, [2021-11-01T00:22:43.218432 #1] INFO -- : > su postgres -c 'psql discourse -c "create user discourse;"' || true
2021-11-01 00:22:43.328 UTC [67] postgres@discourse ERROR: role "discourse" already exists
2021-11-01 00:22:43.328 UTC [67] postgres@discourse STATEMENT: create user discourse;
I, [2021-11-01T00:22:43.332483 #1] INFO -- :
I, [2021-11-01T00:22:43.333388 #1] INFO -- : > su postgres -c 'psql discourse -c "grant all privileges on database discourse to discourse;"' || true
I, [2021-11-01T00:22:43.413486 #1] INFO -- : GRANT
I, [2021-11-01T00:22:43.416156 #1] INFO -- : > su postgres -c 'psql discourse -c "alter schema public owner to discourse;"'
I, [2021-11-01T00:22:43.496728 #1] INFO -- : ALTER SCHEMA
I, [2021-11-01T00:22:43.497561 #1] INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists hstore;"'
NOTICE: extension "hstore" already exists, skipping
I, [2021-11-01T00:22:43.587289 #1] INFO -- : CREATE EXTENSION
I, [2021-11-01T00:22:43.588057 #1] INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists pg_trgm;"'
NOTICE: extension "pg_trgm" already exists, skipping
I, [2021-11-01T00:22:43.675828 #1] INFO -- : CREATE EXTENSION
I, [2021-11-01T00:22:43.676536 #1] INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists hstore;"'
I, [2021-11-01T00:22:43.767365 #1] INFO -- : CREATE EXTENSION
I, [2021-11-01T00:22:43.768328 #1] INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists pg_trgm;"'
I, [2021-11-01T00:22:43.858974 #1] INFO -- : CREATE EXTENSION
I, [2021-11-01T00:22:43.859774 #1] INFO -- : > sudo -u postgres psql discourse
I, [2021-11-01T00:22:43.868861 #1] INFO -- : update pg_database set encoding = pg_char_to_encoding('UTF8') where datname = 'discourse' AND encoding = pg_char_to_encoding('SQL_ASCII');
I, [2021-11-01T00:22:43.980816 #1] INFO -- : File > /var/lib/postgresql/take-database-backup chmod: +x chown: postgres:postgres
I, [2021-11-01T00:22:43.987765 #1] INFO -- : File > /var/spool/cron/crontabs/postgres chmod: chown:
I, [2021-11-01T00:22:43.988814 #1] INFO -- : > echo postgres installed!
I, [2021-11-01T00:22:43.994179 #1] INFO -- : postgres installed!
I, [2021-11-01T00:22:43.995093 #1] INFO -- : > thpoff echo "thpoff is installed!"
I, [2021-11-01T00:22:44.001005 #1] INFO -- : thpoff is installed!
I, [2021-11-01T00:22:44.001771 #1] INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_SMTP_ADDRESS"] == "smtp.example.com"; puts "Aborting! Mail is not configured!"; exit 1; end'
I, [2021-11-01T00:22:44.112583 #1] INFO -- :
I, [2021-11-01T00:22:44.113427 #1] INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_HOSTNAME"] == "discourse.example.com"; puts "Aborting! Domain is not configured!"; exit 1; end'
I, [2021-11-01T00:22:44.220062 #1] INFO -- :
I, [2021-11-01T00:22:44.220942 #1] INFO -- : > /usr/local/bin/ruby -e 'if (ENV["DISCOURSE_CDN_URL"] || "")[0..1] == "//"; puts "Aborting! CDN must have a protocol specified. Once fixed you should rebake your posts now to correct all posts."; exit 1; end'
I, [2021-11-01T00:22:44.333546 #1] INFO -- :
I, [2021-11-01T00:22:44.334424 #1] INFO -- : > rm -f /etc/cron.d/anacron
I, [2021-11-01T00:22:44.339698 #1] INFO -- :
I, [2021-11-01T00:22:44.345525 #1] INFO -- : File > /etc/cron.d/anacron chmod: chown:
I, [2021-11-01T00:22:44.356542 #1] INFO -- : File > /etc/runit/1.d/copy-env chmod: +x chown:
I, [2021-11-01T00:22:44.367195 #1] INFO -- : File > /etc/service/unicorn/run chmod: +x chown:
I, [2021-11-01T00:22:44.378077 #1] INFO -- : File > /etc/service/nginx/run chmod: +x chown:
I, [2021-11-01T00:22:44.387243 #1] INFO -- : File > /etc/runit/3.d/01-nginx chmod: +x chown:
I, [2021-11-01T00:22:44.396258 #1] INFO -- : File > /etc/runit/3.d/02-unicorn chmod: +x chown:
I, [2021-11-01T00:22:44.396988 #1] INFO -- : Replacing # postgres with sv start postgres || exit 1 in /etc/service/unicorn/run
I, [2021-11-01T00:22:44.398977 #1] INFO -- : > cd /var/www/discourse && git reset --hard
Checking out files: 25% (6593/26168)
Checking out files: 26% (6804/26168)
Checking out files: 27% (7066/26168)
Checking out files: 28% (7328/26168)
Checking out files: 29% (7589/26168)
Checking out files: 30% (7851/26168)
Checking out files: 31% (8113/26168)
Checking out files: 32% (8374/26168)
Checking out files: 33% (8636/26168)
Checking out files: 34% (8898/26168)
Checking out files: 35% (9159/26168)
Checking out files: 36% (9421/26168)
Checking out files: 37% (9683/26168)
Checking out files: 38% (9944/26168)
Checking out files: 39% (10206/26168)
Checking out files: 40% (10468/26168)
Checking out files: 41% (10729/26168)
Checking out files: 42% (10991/26168)
Checking out files: 43% (11253/26168)
Checking out files: 44% (11514/26168)
Checking out files: 45% (11776/26168)
Checking out files: 46% (12038/26168)
Checking out files: 47% (12299/26168)
Checking out files: 48% (12561/26168)
Checking out files: 49% (12823/26168)
Checking out files: 50% (13084/26168)
Checking out files: 51% (13346/26168)
Checking out files: 52% (13608/26168)
Checking out files: 53% (13870/26168)
Checking out files: 54% (14131/26168)
Checking out files: 55% (14393/26168)
Checking out files: 56% (14655/26168)
Checking out files: 57% (14916/26168)
Checking out files: 58% (15178/26168)
Checking out files: 59% (15440/26168)
Checking out files: 60% (15701/26168)
Checking out files: 60% (15780/26168)
Checking out files: 61% (15963/26168)
Checking out files: 62% (16225/26168)
Checking out files: 63% (16486/26168)
Checking out files: 64% (16748/26168)
Checking out files: 65% (17010/26168)
Checking out files: 66% (17271/26168)
Checking out files: 67% (17533/26168)
Checking out files: 68% (17795/26168)
Checking out files: 69% (18056/26168)
Checking out files: 70% (18318/26168)
Checking out files: 71% (18580/26168)
Checking out files: 72% (18841/26168)
Checking out files: 73% (19103/26168)
Checking out files: 74% (19365/26168)
Checking out files: 75% (19626/26168)
Checking out files: 76% (19888/26168)
Checking out files: 77% (20150/26168)
Checking out files: 78% (20412/26168)
Checking out files: 79% (20673/26168)
Checking out files: 80% (20935/26168)
Checking out files: 81% (21197/26168)
Checking out files: 82% (21458/26168)
Checking out files: 83% (21720/26168)
Checking out files: 84% (21982/26168)
Checking out files: 85% (22243/26168)
Checking out files: 86% (22505/26168)
Checking out files: 87% (22767/26168)
Checking out files: 88% (23028/26168)
Checking out files: 89% (23290/26168)
Checking out files: 90% (23552/26168)
Checking out files: 91% (23813/26168)
Checking out files: 92% (24075/26168)
Checking out files: 92% (24315/26168)
Checking out files: 93% (24337/26168)
Checking out files: 94% (24598/26168)
Checking out files: 95% (24860/26168)
Checking out files: 96% (25122/26168)
Checking out files: 97% (25383/26168)
Checking out files: 98% (25645/26168)
Checking out files: 99% (25907/26168)
Checking out files: 100% (26168/26168)
Checking out files: 100% (26168/26168), done.
I, [2021-11-01T00:22:48.823644 #1] INFO -- : HEAD is now at 92afa74d Mark shared-edits plugin as official (#14639)
I, [2021-11-01T00:22:48.824440 #1] INFO -- : > cd /var/www/discourse && git clean -f
I, [2021-11-01T00:22:48.963352 #1] INFO -- :
I, [2021-11-01T00:22:48.964200 #1] INFO -- : > cd /var/www/discourse && git remote set-branches --add origin main
I, [2021-11-01T00:22:48.970667 #1] INFO -- :
I, [2021-11-01T00:22:48.971205 #1] INFO -- : > cd /var/www/discourse && git remote set-branches origin tests-passed
I, [2021-11-01T00:22:48.977199 #1] INFO -- :
I, [2021-11-01T00:22:48.977738 #1] INFO -- : > cd /var/www/discourse && git fetch --depth 1 origin tests-passed
From https://github.com/discourse/discourse
* branch tests-passed -> FETCH_HEAD
* [new branch] tests-passed -> origin/tests-passed
I, [2021-11-01T00:22:51.160808 #1] INFO -- :
I, [2021-11-01T00:22:51.161471 #1] INFO -- : > cd /var/www/discourse && git checkout tests-passed
Switched to a new branch 'tests-passed'
I, [2021-11-01T00:22:52.301107 #1] INFO -- : Branch 'tests-passed' set up to track remote branch 'tests-passed' from 'origin'.
I, [2021-11-01T00:22:52.301706 #1] INFO -- : > cd /var/www/discourse && mkdir -p tmp
I, [2021-11-01T00:22:52.311733 #1] INFO -- :
I, [2021-11-01T00:22:52.316030 #1] INFO -- : > cd /var/www/discourse && chown discourse:www-data tmp
I, [2021-11-01T00:22:52.325749 #1] INFO -- :
I, [2021-11-01T00:22:52.326348 #1] INFO -- : > cd /var/www/discourse && mkdir -p tmp/pids
I, [2021-11-01T00:22:52.336068 #1] INFO -- :
I, [2021-11-01T00:22:52.340034 #1] INFO -- : > cd /var/www/discourse && mkdir -p tmp/sockets
I, [2021-11-01T00:22:52.348003 #1] INFO -- :
I, [2021-11-01T00:22:52.348517 #1] INFO -- : > cd /var/www/discourse && touch tmp/.gitkeep
I, [2021-11-01T00:22:52.359960 #1] INFO -- :
I, [2021-11-01T00:22:52.360073 #1] INFO -- : > cd /var/www/discourse && mkdir -p /shared/log/rails
I, [2021-11-01T00:22:52.370560 #1] INFO -- :
I, [2021-11-01T00:22:52.371174 #1] INFO -- : > cd /var/www/discourse && bash -c "touch -a /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log"
I, [2021-11-01T00:22:52.388493 #1] INFO -- :
I, [2021-11-01T00:22:52.388629 #1] INFO -- : > cd /var/www/discourse && bash -c "ln -s /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log /var/www/discourse/log"
I, [2021-11-01T00:22:52.404830 #1] INFO -- :
I, [2021-11-01T00:22:52.404969 #1] INFO -- : > cd /var/www/discourse && bash -c "mkdir -p /shared/{uploads,backups}"
I, [2021-11-01T00:22:52.421061 #1] INFO -- :
I, [2021-11-01T00:22:52.421741 #1] INFO -- : > cd /var/www/discourse && bash -c "ln -s /shared/{uploads,backups} /var/www/discourse/public"
I, [2021-11-01T00:22:52.437357 #1] INFO -- :
I, [2021-11-01T00:22:52.437479 #1] INFO -- : > cd /var/www/discourse && bash -c "mkdir -p /shared/tmp/{backups,restores}"
I, [2021-11-01T00:22:52.452669 #1] INFO -- :
I, [2021-11-01T00:22:52.453309 #1] INFO -- : > cd /var/www/discourse && bash -c "ln -s /shared/tmp/{backups,restores} /var/www/discourse/tmp"
I, [2021-11-01T00:22:52.468750 #1] INFO -- :
I, [2021-11-01T00:22:52.468882 #1] INFO -- : > cd /var/www/discourse && chown -R discourse:www-data /shared/log/rails /shared/uploads /shared/backups /shared/tmp
I, [2021-11-01T00:22:52.755036 #1] INFO -- :
I, [2021-11-01T00:22:52.755781 #1] INFO -- : > cd /var/www/discourse && find public/plugins/ -maxdepth 1 -xtype l -delete
I, [2021-11-01T00:22:52.763377 #1] INFO -- :
I, [2021-11-01T00:22:52.764430 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/docker_manager.git
Cloning into 'docker_manager'...
I, [2021-11-01T00:22:53.944491 #1] INFO -- :
I, [2021-11-01T00:22:53.945294 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-spoiler-alert
Cloning into 'discourse-spoiler-alert'...
I, [2021-11-01T00:22:54.349404 #1] INFO -- :
I, [2021-11-01T00:22:54.350150 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/cpradio/discourse-giphy
Cloning into 'discourse-giphy'...
I, [2021-11-01T00:22:54.988087 #1] INFO -- :
I, [2021-11-01T00:22:54.989060 #1] INFO -- : > cp /var/www/discourse/config/nginx.sample.conf /etc/nginx/conf.d/discourse.conf
I, [2021-11-01T00:22:54.995794 #1] INFO -- :
I, [2021-11-01T00:22:54.996738 #1] INFO -- : > rm /etc/nginx/sites-enabled/default
I, [2021-11-01T00:22:55.001383 #1] INFO -- :
I, [2021-11-01T00:22:55.002328 #1] INFO -- : > mkdir -p /var/nginx/cache
I, [2021-11-01T00:22:55.007086 #1] INFO -- :
I, [2021-11-01T00:22:55.008486 #1] INFO -- : Replacing pid /run/nginx.pid; with daemon off; in /etc/nginx/nginx.conf
I, [2021-11-01T00:22:55.009378 #1] INFO -- : Replacing (?m-ix:upstream[^\}]+\}) with upstream discourse { server 127.0.0.1:3000; } in /etc/nginx/conf.d/discourse.conf
I, [2021-11-01T00:22:55.010106 #1] INFO -- : Replacing (?-mix:server_name.+$) with server_name _ ; in /etc/nginx/conf.d/discourse.conf
I, [2021-11-01T00:22:55.010864 #1] INFO -- : Replacing (?-mix:client_max_body_size.+$) with client_max_body_size $upload_size ; in /etc/nginx/conf.d/discourse.conf
I, [2021-11-01T00:22:55.011539 #1] INFO -- : > echo "done configuring web"
I, [2021-11-01T00:22:55.015681 #1] INFO -- : done configuring web
I, [2021-11-01T00:22:55.016534 #1] INFO -- : > cd /var/www/discourse && gem install bundler --conservative -v $(awk '/BUNDLED WITH/ { getline; gsub(/ /,""); print $0 }' Gemfile.lock)
I, [2021-11-01T00:22:55.971470 #1] INFO -- : Successfully installed bundler-2.2.26
1 gem installed
I, [2021-11-01T00:22:55.972367 #1] INFO -- : > cd /var/www/discourse && find /var/www/discourse ! -user discourse -exec chown discourse {} \+
I, [2021-11-01T00:22:59.921873 #1] INFO -- :
I, [2021-11-01T00:22:59.922743 #1] INFO -- : > cd /var/www/discourse && su discourse -c 'bundle install --deployment --retry 3 --jobs 4 --verbose --without test development'
[DEPRECATED] The `--deployment` flag is deprecated because it relies on being remembered across bundler invocations, which bundler will no longer do in future versions. Instead please use `bundle config set --local deployment 'true'`, and stop using this flag
[DEPRECATED] The `--without` flag is deprecated because it relies on being remembered across bundler invocations, which bundler will no longer do in future versions. Instead please use `bundle config set --local without 'test development'`, and stop using this flag
I, [2021-11-01T00:23:12.863463 #1] INFO -- : Running `bundle install --deployment --jobs 4 --retry 3 --verbose --without "test" "development"` with bundler 2.2.26
Frozen, using resolution from the lockfile
The definition is missing ["json-2.6.1", "json-2.6.1", "json-2.6.1", "json-2.6.1", "json-2.6.1", "json-2.6.1", "aws-sdk-sns-1.46.0", "aws-sdk-sns-1.46.0", "aws-sdk-sns-1.46.0", "aws-sdk-sns-1.46.0", "aws-sdk-sns-1.46.0", "aws-sdk-sns-1.46.0", "excon-0.88.0", "excon-0.88.0", "excon-0.88.0", "excon-0.88.0", "excon-0.88.0", "excon-0.88.0", "image_optim-0.31.1", "image_optim-0.31.1", "image_optim-0.31.1", "image_optim-0.31.1", "image_optim-0.31.1", "image_optim-0.31.1", "omniauth-facebook-9.0.0", "omniauth-facebook-9.0.0", "omniauth-facebook-9.0.0", "omniauth-facebook-9.0.0", "omniauth-facebook-9.0.0", "omniauth-facebook-9.0.0", "logster-2.9.8", "logster-2.9.8", "logster-2.9.8", "logster-2.9.8", "logster-2.9.8", "logster-2.9.8", "zeitwerk-2.5.1", "zeitwerk-2.5.1", "zeitwerk-2.5.1", "zeitwerk-2.5.1", "zeitwerk-2.5.1", "zeitwerk-2.5.1", "aws-sdk-core-3.121.2", "aws-sdk-core-3.121.2", "aws-sdk-core-3.121.2", "aws-sdk-core-3.121.2", "aws-sdk-core-3.121.2", "aws-sdk-core-3.121.2", "aws-sigv4-1.4.0", "aws-sigv4-1.4.0", "aws-sigv4-1.4.0", "aws-sigv4-1.4.0", "aws-sigv4-1.4.0", "aws-sigv4-1.4.0", "image_size-3.0.1", "image_size-3.0.1", "image_size-3.0.1", "image_size-3.0.1", "image_size-3.0.1", "image_size-3.0.1", "racc-1.6.0", "racc-1.6.0", "racc-1.6.0", "racc-1.6.0", "racc-1.6.0", "racc-1.6.0", "aws-partitions-1.516.0", "aws-partitions-1.516.0", "aws-partitions-1.516.0", "aws-partitions-1.516.0", "aws-partitions-1.516.0", "aws-partitions-1.516.0", "ipaddr-1.2.3", "ipaddr-1.2.3", "ipaddr-1.2.3", "ipaddr-1.2.3", "ipaddr-1.2.3", "ipaddr-1.2.3"]
HTTP GET https://index.rubygems.org/versions
HTTP 206 Partial Content https://index.rubygems.org/versions
Fetching gem metadata from https://rubygems.org/
Looking up gems ["actionmailer", "actionpack", "actionview", "actionview_precompiler", "active_model_serializers", "activejob", "activemodel", "activerecord", "activesupport", "addressable", "annotate", "ast", "aws-eventstream", "aws-partitions", "aws-sdk-core", "aws-sdk-kms", "aws-sdk-s3", "aws-sdk-sns", "aws-sigv4", "barber", "better_errors", "binding_of_caller", "bootsnap", "builder", "bullet", "byebug", "cbor", "certified", "chunky_png", "coderay", "colored2", "concurrent-ruby", "connection_pool", "cose", "cppjieba_rb", "crack", "crass", "css_parser", "debug_inspector", "diff-lcs", "diffy", "discourse-ember-rails", "discourse-ember-source", "discourse-fonts", "discourse_dev_assets", "docile", "ecma-re-validator", "email_reply_trimmer", "ember-data-source", "ember-handlebars-template", "ember-source", "erubi", "excon", "execjs", "exifr", "fabrication", "faker", "fakeweb", "faraday", "faraday-em_http", "faraday-em_synchrony", "faraday-excon", "faraday-httpclient", "faraday-net_http", "faraday-net_http_persistent", "faraday-patron", "faraday-rack", "fast_blank", "fast_xs", "fastimage", "ffi", "fspath", "gc_tracer", "globalid", "guess_html_encoding", "hana", "hashdiff", "hashie", "highline", "hkdf", "htmlentities", "http_accept_language", "i18n", "image_optim", "image_size", "in_threads", "ipaddr", "jmespath", "jquery-rails", "json", "json-schema", "json_schemer", "jwt", "kgio", "libv8-node", "listen", "literate_randomizer", "lograge", "logstash-event", "logstash-logger", "logster", "loofah", "lru_redux", "lz4-ruby", "maxminddb", "memory_profiler", "message_bus", "method_source", "mini_mime", "mini_portile2", "mini_racer", "mini_scheduler", "mini_sql", "mini_suffix", "minitest", "mocha", "mock_redis", "msgpack", "multi_json", "multi_xml", "multipart-post", "mustache", "nio4r", "nokogiri", "oauth", "oauth2", "oj", "omniauth", "omniauth-facebook", "omniauth-github", "omniauth-google-oauth2", "omniauth-oauth", "omniauth-oauth2", "omniauth-twitter", "openssl", "openssl-signature_algorithm", "optimist", "parallel", "parallel_tests", "parser", "pg", "progress", "pry", "pry-byebug", "pry-rails", "public_suffix", "puma", "r2", "racc", "rack", "rack-mini-profiler", "rack-protection", "rack-test", "rails-dom-testing", "rails-html-sanitizer", "rails_failover", "rails_multisite", "railties", "rainbow", "raindrops", "rake", "rb-fsevent", "rb-inotify", "rbtrace", "rchardet", "redis", "redis-namespace", "regexp_parser", "request_store", "rexml", "rinku", "rotp", "rqrcode", "rqrcode_core", "rspec", "rspec-core", "rspec-expectations", "rspec-html-matchers", "rspec-mocks", "rspec-rails", "rspec-support", "rss", "rswag-specs", "rtlit", "rubocop", "rubocop-ast", "rubocop-discourse", "rubocop-rspec", "ruby-prof", "ruby-progressbar", "ruby-readability", "ruby2_keywords", "rubyzip", "sanitize", "sassc", "sassc-rails", "seed-fu", "shoulda-matchers", "sidekiq", "simplecov", "simplecov-html", "simplecov_json_formatter", "sprockets", "sprockets-rails", "sshkey", "stackprof", "test-prof", "thor", "tilt", "tzinfo", "uglifier", "unf", "unf_ext", "unicode-display_width", "unicorn", "uniform_notifier", "uri_template", "webmock", "webpush", "xorcist", "yaml-lint", "zeitwerk"]
HTTP GET https://index.rubygems.org/info/aws-partitions
HTTP 206 Partial Content https://index.rubygems.org/info/aws-partitions
HTTP GET https://index.rubygems.org/info/aws-sdk-core
HTTP 206 Partial Content https://index.rubygems.org/info/aws-sdk-core
HTTP GET https://index.rubygems.org/info/excon
HTTP 206 Partial Content https://index.rubygems.org/info/excon
HTTP GET https://index.rubygems.org/info/faraday
HTTP 206 Partial Content https://index.rubygems.org/info/faraday
HTTP GET https://index.rubygems.org/info/image_optim
HTTP 206 Partial Content https://index.rubygems.org/info/image_optim
HTTP GET https://index.rubygems.org/info/image_size
HTTP 206 Partial Content https://index.rubygems.org/info/image_size
HTTP GET https://index.rubygems.org/info/ipaddr
HTTP 206 Partial Content https://index.rubygems.org/info/ipaddr
HTTP GET https://index.rubygems.org/info/json
HTTP 206 Partial Content https://index.rubygems.org/info/json
HTTP GET https://index.rubygems.org/info/logster
HTTP 206 Partial Content https://index.rubygems.org/info/logster
HTTP GET https://index.rubygems.org/info/mini_portile2
HTTP 206 Partial Content https://index.rubygems.org/info/mini_portile2
HTTP GET https://index.rubygems.org/info/omniauth-facebook
HTTP 206 Partial Content https://index.rubygems.org/info/omniauth-facebook
HTTP GET https://index.rubygems.org/info/racc
HTTP 206 Partial Content https://index.rubygems.org/info/racc
HTTP GET https://index.rubygems.org/info/rubocop
HTTP 206 Partial Content https://index.rubygems.org/info/rubocop
HTTP GET https://index.rubygems.org/info/zeitwerk
HTTP 206 Partial Content https://index.rubygems.org/info/zeitwerk
Looking up gems ["mail", "text-format", "erubis", "rack-mount", "rack-cache", "journey", "rails-deprecated_sanitizer", "jsonapi", "case_transform", "jsonapi-renderer", "activemodel-globalid", "bcrypt-ruby", "arel", "activerecord-deprecated_finders", "memcache-client", "thread_safe", "jamespath", "http-2", "aws-crt", "ember-template-compiler-source", "handlebars-source", "rouge", "snappy", "columnize", "debugger-linecache", "slop", "rb-readline", "functional-ruby", "ref", "safe_yaml", "rdoc", "pastel", "tty-pager", "tty-screen", "tty-tree", "rcov", "net-http-persistent", "rake-compiler", "rb-appscript", "xattr", "ffi-xattr", "termios", "json_pure", "rails", "rdf", "rb-fchange", "rb-kqueue", "celluloid", "celluloid-io", "ruby_dep", "stud", "eventmachine", "thin", "ruby_parser", "net-ftp", "libv8", "metaclass", "hoe", "weakling", "mini_portile", "pkg-config", "ruby-hmac", "faraday-middleware", "httpauth", "bigdecimal", "oa-core", "oa-oauth", "oa-openid", "oa-basic", "oa-enterprise", "oa-more", "sexp_processor", "win32console", "yard", "spoon", "pry-doc", "escape_utils", "rack-ssl", "trollop", "base32", "webrat", "rspec-collection_matchers", "term-ansicolor", "backports", "powerpack", "astrolabe", "tins", "jaro_winkler", "psych", "strscan", "hpricot", "nokogumbo", "bundler", "sass", "bourne", "compass", "sprockets-sass", "sinatra", "slim", "lockfile", "hike", "therubyracer"]
HTTP GET https://index.rubygems.org/info/json_pure
HTTP 206 Partial Content https://index.rubygems.org/info/json_pure
HTTP GET https://index.rubygems.org/info/ruby_parser
HTTP 206 Partial Content https://index.rubygems.org/info/ruby_parser
HTTP GET https://index.rubygems.org/info/sexp_processor
HTTP 206 Partial Content https://index.rubygems.org/info/sexp_processor
HTTP GET https://index.rubygems.org/info/psych
HTTP 206 Partial Content https://index.rubygems.org/info/psych
HTTP GET https://index.rubygems.org/info/strscan
HTTP 206 Partial Content https://index.rubygems.org/info/strscan
HTTP GET https://index.rubygems.org/info/bundler
HTTP 206 Partial Content https://index.rubygems.org/info/bundler
Looking up gems ["mime-types", "treetop", "tlsmail", "text-hyphen", "abstract", "multimap", "jsonapi-parser", "bcrypt", "ZenTest", "RubyInline", "atomic", "snappy-jars", "ruby_core_source", "debugger-ruby_core_source", "equatable", "tty-color", "tty-which", "verse", "strings", "spruz", "activeresource", "actionwebservice", "actioncable", "activestorage", "actionmailbox", "actiontext", "link_header", "hamster", "win32-api", "timers", "facter", "celluloid-essentials", "celluloid-extras", "celluloid-fsm", "celluloid-pool", "celluloid-supervision", "dotenv", "nenv", "rspec-logsplit", "metriks", "daemons", "ParseTree", "net-protocol", "time", "rubyforge", "gemcutter", "rack-openid", "ruby-openid-apps-discovery", "restclient", "rest-client", "net-ldap", "rubyntlm", "pyu-ruby-sasl", "uuid", "XMLCanonicalizer", "curses", "sync", "jar-dependencies", "sass-listen", "haml", "fssm", "compass-core", "compass-import-once", "sprockets-helpers", "mongrel", "mustermann", "temple"]
HTTP GET https://index.rubygems.org/info/net-protocol
HTTP 206 Partial Content https://index.rubygems.org/info/net-protocol
Looking up gems ["mime-types-data", "facets", "polyglot", "archive-tar-minitar", "unicode_utils", "strings-ansi", "rails-observers", "activemodel-serializers-xml", "coffee-rails", "em-hiredis", "faye-websocket", "websocket-driver", "marcel", "mimemagic", "test-unit", "hitimes", "CFPropertyList", "sys-admin", "win32-dir", "windows-api", "windows-pr", "win32-security", "hocon", "celluloid-gems", "coveralls", "dotenv-deployment", "rbtree", "faraday_middleware", "yajl-ruby", "avl_tree", "SexpProcessor", "io-wait", "timeout", "date", "net-scp", "ruby-openid", "netrc", "http-cookie", "http-accept", "macaddr", "log4r", "ruby-maven", "cgi_multipart_eof_fix", "fastthread", "gem_plugin", "tool"]
HTTP GET https://index.rubygems.org/info/io-wait
HTTP 206 Partial Content https://index.rubygems.org/info/io-wait
Looking up gems ["minitar", "minitar-cli", "coffee-script", "hiredis", "websocket-extensions", "power_assert", "configuration", "mkrf", "libxml-ruby", "ffi-win32-extensions", "colorize", "roauth", "net-ssh", "ruby-yadis", "domain_name", "sqlite3", "systemu", "maven-tools", "ruby-maven-libs"]
Looking up gems ["powerbar", "coffee-script-source", "pattern-match", "needle", "jruby-pageant", "bcrypt_pbkdf", "rbnacl", "rbnacl-libsodium", "virtus"]
Looking up gems ["ansi", "descendants_tracker", "axiom-types", "coercible", "equalizer"]
Looking up gems ["ice_nine", "adamantium"]
Looking up gems ["memoizable"]
Using rake 13.0.6
0: rake (13.0.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rake-13.0.6.gemspec
Using concurrent-ruby 1.1.9
0: concurrent-ruby (1.1.9) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/concurrent-ruby-1.1.9.gemspec
Using minitest 5.14.4
0: minitest (5.14.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/minitest-5.14.4.gemspec
Using builder 3.2.4
3: builder (3.2.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/builder-3.2.4.gemspec
Using erubi 1.10.0
3: erubi (1.10.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/erubi-1.10.0.gemspec
Fetching racc 1.6.0
Using crass 1.0.6
2: crass (1.0.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/crass-1.0.6.gemspec
Using rack 2.2.3
2: rack (2.2.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rack-2.2.3.gemspec
Using mini_mime 1.1.2
2: mini_mime (1.1.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/mini_mime-1.1.2.gemspec
Using public_suffix 4.0.6
2: public_suffix (4.0.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/public_suffix-4.0.6.gemspec
Using aws-eventstream 1.2.0
2: aws-eventstream (1.2.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-eventstream-1.2.0.gemspec
Using jmespath 1.4.0
1: jmespath (1.4.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/jmespath-1.4.0.gemspec
Using ember-source 2.18.2
1: ember-source (2.18.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ember-source-2.18.2.gemspec
Using execjs 2.8.1
1: execjs (2.8.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/execjs-2.8.1.gemspec
Using msgpack 1.4.2
1: msgpack (1.4.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/msgpack-1.4.2.gemspec
Using bundler 2.2.26
1: bundler (2.2.26) from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.26/lib/bundler/source
Using byebug 11.1.3
1: byebug (11.1.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/byebug-11.1.3.gemspec
Using cbor 0.5.9.6
1: cbor (0.5.9.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/cbor-0.5.9.6.gemspec
Using chunky_png 1.4.0
1: chunky_png (1.4.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/chunky_png-1.4.0.gemspec
Using coderay 1.1.3
1: coderay (1.1.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/coderay-1.1.3.gemspec
Using colored2 3.1.2
1: colored2 (3.1.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/colored2-3.1.2.gemspec
Using connection_pool 2.2.5
1: connection_pool (2.2.5) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/connection_pool-2.2.5.gemspec
Fetching ipaddr 1.2.3
Fetching zeitwerk 2.5.1
Fetching aws-partitions 1.516.0
Installing zeitwerk 2.5.1
Installing ipaddr 1.2.3
Installing racc 1.6.0 with native extensions
Installing aws-partitions 1.516.0
1: ipaddr (1.2.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ipaddr-1.2.3.gemspec
Using cppjieba_rb 0.3.3
1: cppjieba_rb (0.3.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/cppjieba_rb-0.3.3.gemspec
Using diffy 3.4.0
1: diffy (3.4.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/diffy-3.4.0.gemspec
Using method_source 1.0.0
1: method_source (1.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/method_source-1.0.0.gemspec
Using thor 1.1.0
1: thor (1.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/thor-1.1.0.gemspec
Using discourse-ember-source 3.12.2.3
1: discourse-ember-source (3.12.2.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/discourse-ember-source-3.12.2.3.gemspec
Using discourse-fonts 0.0.9
1: discourse-fonts (0.0.9) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/discourse-fonts-0.0.9.gemspec
Using regexp_parser 2.1.1
1: regexp_parser (2.1.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/regexp_parser-2.1.1.gemspec
Using email_reply_trimmer 0.1.13
1: email_reply_trimmer (0.1.13) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/email_reply_trimmer-0.1.13.gemspec
Fetching excon 0.88.0
0: zeitwerk (2.5.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/zeitwerk-2.5.1.gemspec
Using exifr 1.3.9
0: exifr (1.3.9) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/exifr-1.3.9.gemspec
Using faraday-em_http 1.0.0
0: faraday-em_http (1.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-em_http-1.0.0.gemspec
Using faraday-em_synchrony 1.0.0
2: aws-partitions (1.516.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-partitions-1.516.0.gemspec
Using faraday-excon 1.1.0
2: faraday-excon (1.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-excon-1.1.0.gemspec
Using faraday-httpclient 1.0.1
2: faraday-httpclient (1.0.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-httpclient-1.0.1.gemspec
Using faraday-net_http 1.0.1
2: faraday-net_http (1.0.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-net_http-1.0.1.gemspec
Using faraday-net_http_persistent 1.2.0
2: faraday-net_http_persistent (1.2.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-net_http_persistent-1.2.0.gemspec
Using faraday-patron 1.0.0
2: faraday-patron (1.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-patron-1.0.0.gemspec
Using faraday-rack 1.0.0
2: faraday-rack (1.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-rack-1.0.0.gemspec
Using multipart-post 2.1.1
2: multipart-post (2.1.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/multipart-post-2.1.1.gemspec
Using ruby2_keywords 0.0.5
2: ruby2_keywords (0.0.5) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ruby2_keywords-0.0.5.gemspec
Using fast_blank 1.0.1
2: fast_blank (1.0.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/fast_blank-1.0.1.gemspec
Using fast_xs 0.8.0
0: faraday-em_synchrony (1.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-em_synchrony-1.0.0.gemspec
2: fast_xs (0.8.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/fast_xs-0.8.0.gemspec
Using fastimage 2.2.5
2: fastimage (2.2.5) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/fastimage-2.2.5.gemspec
Using ffi 1.15.4
2: ffi (1.15.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ffi-1.15.4.gemspec
Using fspath 3.1.2
2: fspath (3.1.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/fspath-3.1.2.gemspec
Using gc_tracer 1.5.1
2: gc_tracer (1.5.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/gc_tracer-1.5.1.gemspec
Using guess_html_encoding 0.0.11
2: guess_html_encoding (0.0.11) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/guess_html_encoding-0.0.11.gemspec
Using hana 1.3.7
2: hana (1.3.7) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/hana-1.3.7.gemspec
Using hashie 4.1.0
2: hashie (4.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/hashie-4.1.0.gemspec
Using highline 2.0.3
2: highline (2.0.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/highline-2.0.3.gemspec
Using hkdf 0.3.0
2: hkdf (0.3.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/hkdf-0.3.0.gemspec
Using htmlentities 4.3.4
2: htmlentities (4.3.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/htmlentities-4.3.4.gemspec
Using http_accept_language 2.1.1
2: http_accept_language (2.1.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/http_accept_language-2.1.1.gemspec
Fetching image_size 3.0.1
Installing excon 0.88.0
Using in_threads 1.5.4
0: in_threads (1.5.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/in_threads-1.5.4.gemspec
Using progress 3.6.0
0: progress (3.6.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/progress-3.6.0.gemspec
Fetching json 2.6.1
Building native extensions. This could take a while...
Installing image_size 3.0.1
Installing json 2.6.1 with native extensions
1: excon (0.88.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/excon-0.88.0.gemspec
Using uri_template 0.7.0
1: uri_template (0.7.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/uri_template-0.7.0.gemspec
Using jwt 2.3.0
1: jwt (2.3.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/jwt-2.3.0.gemspec
Using kgio 2.11.4
1: kgio (2.11.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/kgio-2.11.4.gemspec
Using libv8-node 15.14.0.1 (x86_64-linux)
1: libv8-node (15.14.0.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/libv8-node-15.14.0.1-x86_64-linux.gemspec
Using logstash-event 1.2.02
1: logstash-event (1.2.02) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/logstash-event-1.2.02.gemspec
Fetching logster 2.9.8
2: image_size (3.0.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/image_size-3.0.1.gemspec
Using lru_redux 1.1.0
2: lru_redux (1.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/lru_redux-1.1.0.gemspec
Using lz4-ruby 0.3.3
2: lz4-ruby (0.3.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/lz4-ruby-0.3.3.gemspec
Using maxminddb 0.1.22
2: maxminddb (0.1.22) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/maxminddb-0.1.22.gemspec
Using memory_profiler 1.0.0
2: memory_profiler (1.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/memory_profiler-1.0.0.gemspec
Using redis 4.5.1
2: redis (4.5.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/redis-4.5.1.gemspec
Using mini_sql 1.1.3
2: mini_sql (1.1.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/mini_sql-1.1.3.gemspec
Using multi_json 1.15.0
2: multi_json (1.15.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/multi_json-1.15.0.gemspec
Using multi_xml 0.6.0
2: multi_xml (0.6.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/multi_xml-0.6.0.gemspec
Using mustache 1.1.1
2: mustache (1.1.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/mustache-1.1.1.gemspec
Using nio4r 2.5.8
2: nio4r (2.5.8) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/nio4r-2.5.8.gemspec
Using oauth 0.5.6
2: oauth (0.5.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/oauth-0.5.6.gemspec
Using oj 3.13.2
2: oj (3.13.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/oj-3.13.2.gemspec
Using optimist 3.0.1
2: optimist (3.0.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/optimist-3.0.1.gemspec
Using pg 1.2.3
2: pg (1.2.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/pg-1.2.3.gemspec
Using r2 0.2.7
2: r2 (0.2.7) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/r2-0.2.7.gemspec
Using raindrops 0.19.2
2: raindrops (0.19.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/raindrops-0.19.2.gemspec
Using rchardet 1.8.0
2: rchardet (1.8.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rchardet-1.8.0.gemspec
Using rexml 3.2.5
2: rexml (3.2.5) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rexml-3.2.5.gemspec
Using rinku 2.0.6
2: rinku (2.0.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rinku-2.0.6.gemspec
Using rotp 6.2.0
2: rotp (6.2.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rotp-6.2.0.gemspec
Using rqrcode_core 1.2.0
2: rqrcode_core (1.2.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rqrcode_core-1.2.0.gemspec
Using rtlit 0.0.5
2: rtlit (0.0.5) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rtlit-0.0.5.gemspec
Using rubyzip 2.3.2
2: rubyzip (2.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rubyzip-2.3.2.gemspec
Using tilt 2.0.10
2: tilt (2.0.10) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/tilt-2.0.10.gemspec
Using sshkey 2.0.0
2: sshkey (2.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sshkey-2.0.0.gemspec
Using stackprof 0.2.17
2: stackprof (0.2.17) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/stackprof-0.2.17.gemspec
Using unf_ext 0.0.8
2: unf_ext (0.0.8) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/unf_ext-0.0.8.gemspec
Using xorcist 1.1.2
2: xorcist (1.1.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/xorcist-1.1.2.gemspec
Using i18n 1.8.10
2: i18n (1.8.10) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/i18n-1.8.10.gemspec
Using tzinfo 2.0.4
2: tzinfo (2.0.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/tzinfo-2.0.4.gemspec
Using rack-test 1.1.0
2: rack-test (1.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rack-test-1.1.0.gemspec
Using mail 2.8.0.edge from https://github.com/discourse/mail.git (at master@5b700fc)
2: mail (2.8.0.edge) from /var/www/discourse/vendor/bundle/ruby/2.7.0/bundler/gems/mail-5b700fc95ee6/mail.gemspec
Using addressable 2.8.0
2: addressable (2.8.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/addressable-2.8.0.gemspec
Fetching aws-sigv4 1.4.0
Installing logster 2.9.8
Installing aws-sigv4 1.4.0
2: aws-sigv4 (1.4.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-sigv4-1.4.0.gemspec
Using barber 0.12.2
2: barber (0.12.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/barber-0.12.2.gemspec
Using bootsnap 1.9.1
2: bootsnap (1.9.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/bootsnap-1.9.1.gemspec
Using ember-data-source 3.0.2
2: ember-data-source (3.0.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ember-data-source-3.0.2.gemspec
Using sprockets 3.7.2
2: sprockets (3.7.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sprockets-3.7.2.gemspec
Using request_store 1.5.0
2: request_store (1.5.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/request_store-1.5.0.gemspec
Using message_bus 3.3.6
2: message_bus (3.3.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/message_bus-3.3.6.gemspec
Using rack-mini-profiler 2.3.3
2: rack-mini-profiler (2.3.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rack-mini-profiler-2.3.3.gemspec
Using rack-protection 2.1.0
2: rack-protection (2.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rack-protection-2.1.0.gemspec
Using uglifier 4.2.0
2: uglifier (4.2.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/uglifier-4.2.0.gemspec
Using openssl 2.2.1
2: openssl (2.2.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/openssl-2.2.1.gemspec
Using pry 0.13.1
2: pry (0.13.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/pry-0.13.1.gemspec
Using ecma-re-validator 0.3.0
2: ecma-re-validator (0.3.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ecma-re-validator-0.3.0.gemspec
Using mini_suffix 0.3.2
2: mini_suffix (0.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/mini_suffix-0.3.2.gemspec
Using omniauth 1.9.1
2: omniauth (1.9.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-1.9.1.gemspec
Using sassc 2.0.1
2: sassc (2.0.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sassc-2.0.1.gemspec
Using faraday 1.8.0
2: faraday (1.8.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-1.8.0.gemspec
Using logstash-logger 0.26.1
2: logstash-logger (0.26.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/logstash-logger-0.26.1.gemspec
Using mini_racer 0.4.0
2: mini_racer (0.4.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/mini_racer-0.4.0.gemspec
Using webpush 1.1.0
2: webpush (1.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/webpush-1.1.0.gemspec
Fetching image_optim 0.31.1
Installing image_optim 0.31.1
Rails image assets optimization is extracted into image_optim_rails gem
You can safely remove `config.assets.image_optim = false` if you are not going to use that gem
2: image_optim (0.31.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/image_optim-0.31.1.gemspec
Using sidekiq 6.2.2
2: sidekiq (6.2.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sidekiq-6.2.2.gemspec
Using puma 5.5.2
2: puma (5.5.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/puma-5.5.2.gemspec
Using redis-namespace 1.8.1
2: redis-namespace (1.8.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/redis-namespace-1.8.1.gemspec
Using rbtrace 0.4.14
2: rbtrace (0.4.14) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rbtrace-0.4.14.gemspec
Using rqrcode 2.1.0
2: rqrcode (2.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rqrcode-2.1.0.gemspec
Using rss 0.2.9
2: rss (0.2.9) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rss-0.2.9.gemspec
Using unicorn 6.0.0
2: unicorn (6.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/unicorn-6.0.0.gemspec
Using unf 0.1.4
2: unf (0.1.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/unf-0.1.4.gemspec
Using activesupport 6.1.4.1
2: activesupport (6.1.4.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/activesupport-6.1.4.1.gemspec
Using css_parser 1.10.0
2: css_parser (1.10.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/css_parser-1.10.0.gemspec
Fetching aws-sdk-core 3.121.2
1: logster (2.9.8) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/logster-2.9.8.gemspec
Using ember-handlebars-template 0.8.0
1: ember-handlebars-template (0.8.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ember-handlebars-template-0.8.0.gemspec
Using openssl-signature_algorithm 1.1.1
1: openssl-signature_algorithm (1.1.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/openssl-signature_algorithm-1.1.1.gemspec
Using json_schemer 0.2.18
1: json_schemer (0.2.18) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/json_schemer-0.2.18.gemspec
Using oauth2 1.4.7
1: oauth2 (1.4.7) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/oauth2-1.4.7.gemspec
Using omniauth-oauth 1.2.0
1: omniauth-oauth (1.2.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-oauth-1.2.0.gemspec
Using pry-byebug 3.9.0
1: pry-byebug (3.9.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/pry-byebug-3.9.0.gemspec
Using pry-rails 0.3.9
1: pry-rails (0.3.9) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/pry-rails-0.3.9.gemspec
Using mini_scheduler 0.13.0
1: mini_scheduler (0.13.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/mini_scheduler-0.13.0.gemspec
Using globalid 0.5.2
1: globalid (0.5.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/globalid-0.5.2.gemspec
Using activemodel 6.1.4.1
1: activemodel (6.1.4.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/activemodel-6.1.4.1.gemspec
Using cose 1.2.0
1: cose (1.2.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/cose-1.2.0.gemspec
Using activejob 6.1.4.1
1: activejob (6.1.4.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/activejob-6.1.4.1.gemspec
Using active_model_serializers 0.8.4
1: active_model_serializers (0.8.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/active_model_serializers-0.8.4.gemspec
Using activerecord 6.1.4.1
1: activerecord (6.1.4.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/activerecord-6.1.4.1.gemspec
Using omniauth-oauth2 1.7.1
1: omniauth-oauth2 (1.7.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-oauth2-1.7.1.gemspec
Using omniauth-twitter 1.4.0
1: omniauth-twitter (1.4.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-twitter-1.4.0.gemspec
Fetching omniauth-facebook 9.0.0
Installing omniauth-facebook 9.0.0
Installing aws-sdk-core 3.121.2
1: omniauth-facebook (9.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-facebook-9.0.0.gemspec
Using omniauth-github 1.4.0
1: omniauth-github (1.4.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-github-1.4.0.gemspec
Using omniauth-google-oauth2 0.8.2
1: omniauth-google-oauth2 (0.8.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-google-oauth2-0.8.2.gemspec
Using seed-fu 2.3.9
1: seed-fu (2.3.9) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/seed-fu-2.3.9.gemspec
2: aws-sdk-core (3.121.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-sdk-core-3.121.2.gemspec
Using aws-sdk-kms 1.44.0
1: aws-sdk-kms (1.44.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-sdk-kms-1.44.0.gemspec
Fetching aws-sdk-sns 1.46.0
Using aws-sdk-s3 1.96.1
2: aws-sdk-s3 (1.96.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-sdk-s3-1.96.1.gemspec
Installing aws-sdk-sns 1.46.0
1: aws-sdk-sns (1.46.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-sdk-sns-1.46.0.gemspec
3: racc (1.6.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/racc-1.6.0.gemspec
Using nokogiri 1.12.5 (x86_64-linux)
2: nokogiri (1.12.5) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/nokogiri-1.12.5-x86_64-linux.gemspec
Using rails-dom-testing 2.0.3
1: rails-dom-testing (2.0.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rails-dom-testing-2.0.3.gemspec
Using loofah 2.12.0
1: loofah (2.12.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/loofah-2.12.0.gemspec
Using ruby-readability 0.7.0
1: ruby-readability (0.7.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ruby-readability-0.7.0.gemspec
Using sanitize 6.0.0
1: sanitize (6.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sanitize-6.0.0.gemspec
Using rails-html-sanitizer 1.4.2
1: rails-html-sanitizer (1.4.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rails-html-sanitizer-1.4.2.gemspec
Using actionview 6.1.4.1
2: actionview (6.1.4.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/actionview-6.1.4.1.gemspec
Using actionpack 6.1.4.1
3: actionpack (6.1.4.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/actionpack-6.1.4.1.gemspec
Using actionview_precompiler 0.2.3
3: actionview_precompiler (0.2.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/actionview_precompiler-0.2.3.gemspec
Using actionmailer 6.1.4.1
2: actionmailer (6.1.4.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/actionmailer-6.1.4.1.gemspec
Using railties 6.1.4.1
2: railties (6.1.4.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/railties-6.1.4.1.gemspec
Using sprockets-rails 3.2.2
2: sprockets-rails (3.2.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sprockets-rails-3.2.2.gemspec
Using jquery-rails 4.4.0
2: jquery-rails (4.4.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/jquery-rails-4.4.0.gemspec
Using lograge 0.11.2
2: lograge (0.11.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/lograge-0.11.2.gemspec
Using rails_failover 0.7.3
2: rails_failover (0.7.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rails_failover-0.7.3.gemspec
Using rails_multisite 3.1.0
2: rails_multisite (3.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rails_multisite-3.1.0.gemspec
Using sassc-rails 2.1.2
2: sassc-rails (2.1.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sassc-rails-2.1.2.gemspec
Using discourse-ember-rails 0.18.6
2: discourse-ember-rails (0.18.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/discourse-ember-rails-0.18.6.gemspec
0: json (2.6.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/json-2.6.1.gemspec
Bundle complete! 127 Gemfile dependencies, 174 gems now installed.
Gems in the groups 'test' and 'development' were not installed.
Bundled gems are installed into `./vendor/bundle`
Post-install message from image_optim:
I, [2021-11-01T00:23:12.867848 #1] INFO -- : > cd /var/www/discourse && [ ! -d 'node_modules' ] || su discourse -c 'yarn install --production && yarn cache clean'
warning Resolution field "lodash@4.17.21" is incompatible with requested version "lodash@4.17.15"
I, [2021-11-01T00:24:36.073253 #1] INFO -- : yarn install v1.22.15
[1/5] Validating package.json...
[2/5] Resolving packages...
success Already up-to-date.
$ yarn --cwd app/assets/javascripts/discourse
[1/4] Resolving packages...
[2/4] Fetching packages...
info fsevents@2.3.2: The platform "linux" is incompatible with this module.
info "fsevents@2.3.2" is an optional dependency and failed compatibility check. Excluding it from installation.
info fsevents@1.2.13: The platform "linux" is incompatible with this module.
info "fsevents@1.2.13" is an optional dependency and failed compatibility check. Excluding it from installation.
[3/4] Linking dependencies...
[4/4] Building fresh packages...
success Saved lockfile.
Done in 72.85s.
Done in 74.41s.
yarn cache v1.22.15
success Cleared cache.
Done in 8.01s.
I, [2021-11-01T00:24:36.084785 #1] INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake plugin:pull_compatible_all'
I, [2021-11-01T00:24:40.486973 #1] INFO -- : discourse-spoiler-alert is already at latest compatible version
docker_manager is already at latest compatible version
discourse-giphy is already at latest compatible version
I, [2021-11-01T00:24:40.487911 #1] INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
Failed to report error: Error connecting to Redis on localhost:6379 (Errno::EADDRNOTAVAIL) 2 Error connecting to Redis on localhost:6379 (Errno::EADDRNOTAVAIL) subscribe failed, reconnecting in 1 second. Call stack /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis/client.rb:398:in `rescue in establish_connection'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis/client.rb:379:in `establish_connection'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis/client.rb:117:in `block in connect'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis/client.rb:344:in `with_reconnect'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis/client.rb:116:in `connect'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis/client.rb:325:in `with_socket_timeout'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis/client.rb:175:in `call_loop'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis/subscribe.rb:44:in `subscription'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis/subscribe.rb:14:in `subscribe'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis.rb:3789:in `_subscription'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis.rb:2552:in `block in subscribe'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis.rb:72:in `block in synchronize'
/usr/local/lib/ruby/2.7.0/monitor.rb:202:in `synchronize'
/usr/local/lib/ruby/2.7.0/monitor.rb:202:in `mon_synchronize'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis.rb:72:in `synchronize'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis.rb:2551:in `subscribe'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/message_bus-3.3.6/lib/message_bus/backends/redis.rb:285:in `global_subscribe'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/message_bus-3.3.6/lib/message_bus.rb:781:in `global_subscribe_thread'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/message_bus-3.3.6/lib/message_bus.rb:729:in `block in new_subscriber_thread'
rake aborted!
Redis::CannotConnectError: Error connecting to Redis on localhost:6379 (Errno::EADDRNOTAVAIL)
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis/client.rb:417:in `ensure_connected'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis/client.rb:269:in `block in process'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis/client.rb:356:in `logging'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis/client.rb:268:in `process'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis/client.rb:162:in `call'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis.rb:564:in `block in del'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis.rb:563:in `del'
/var/www/discourse/lib/discourse_redis.rb:81:in `block in del'
/var/www/discourse/lib/discourse_redis.rb:29:in `ignore_readonly'
/var/www/discourse/lib/discourse_redis.rb:79:in `del'
/var/www/discourse/lib/cache.rb:75:in `delete'
/var/www/discourse/lib/site_setting_extension.rb:455:in `clear_cache!'
/var/www/discourse/lib/site_setting_extension.rb:311:in `block in refresh!'
/var/www/discourse/lib/site_setting_extension.rb:290:in `synchronize'
/var/www/discourse/lib/site_setting_extension.rb:290:in `refresh!'
/var/www/discourse/lib/site_setting_extension.rb:529:in `block in setup_methods'
/var/www/discourse/config/initializers/004-message_bus.rb:122:in `<main>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.9.1/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:60:in `load'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.1/lib/active_support/dependencies.rb:326:in `block in load'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.1/lib/active_support/dependencies.rb:299:in `load_dependency'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.1/lib/active_support/dependencies.rb:326:in `load'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/engine.rb:681:in `block in load_config_initializer'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.1/lib/active_support/notifications.rb:205:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/engine.rb:680:in `load_config_initializer'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/engine.rb:634:in `block (2 levels) in <class:Engine>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/engine.rb:633:in `each'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/engine.rb:633:in `block in <class:Engine>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/initializable.rb:32:in `instance_exec'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/initializable.rb:32:in `run'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/initializable.rb:61:in `block in run_initializers'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/initializable.rb:50:in `each'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/initializable.rb:50:in `tsort_each_child'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/initializable.rb:60:in `run_initializers'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/application.rb:391:in `initialize!'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/railtie.rb:207:in `public_send'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/railtie.rb:207:in `method_missing'
/var/www/discourse/config/environment.rb:7:in `<main>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.9.1/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:23:in `require'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.9.1/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:23:in `block in require_with_bootsnap_lfi'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.9.1/lib/bootsnap/load_path_cache/loaded_features_index.rb:92:in `register'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.9.1/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:22:in `require_with_bootsnap_lfi'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.9.1/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:31:in `require'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/zeitwerk-2.5.1/lib/zeitwerk/kernel.rb:35:in `require'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.1/lib/active_support/dependencies.rb:332:in `block in require'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.1/lib/active_support/dependencies.rb:332:in `require'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/application.rb:367:in `require_environment!'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/application.rb:533:in `block in run_tasks_blocks'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/exe/rake:27:in `<top (required)>'
/usr/local/bin/bundle:23:in `load'
/usr/local/bin/bundle:23:in `<main>'
Caused by:
Errno::EADDRNOTAVAIL: Cannot assign requested address - connect(2) for [::1]:6379
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis/connection/ruby.rb:155:in `connect_addrinfo'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis/connection/ruby.rb:193:in `block in connect'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis/connection/ruby.rb:191:in `each'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis/connection/ruby.rb:191:in `each_with_index'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis/connection/ruby.rb:191:in `connect'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis/connection/ruby.rb:305:in `connect'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis/client.rb:385:in `establish_connection'
Tasks: TOP => db:migrate => db:load_config => environment
I, [2021-11-01T00:24:45.349348 #1] INFO -- :
I, [2021-11-01T00:24:45.350577 #1] INFO -- : Terminating async processes
I, [2021-11-01T00:24:45.351061 #1] INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 50
2021-11-01 00:24:45.351 UTC [50] LOG: received fast shutdown request
2021-11-01 00:24:45.356 UTC [50] LOG: aborting any active transactions
2021-11-01 00:24:45.366 UTC [50] LOG: background worker "logical replication launcher" (PID 59) exited with exit code 1
2021-11-01 00:24:45.369 UTC [54] LOG: shutting down
2021-11-01 00:24:45.391 UTC [50] LOG: database system is shut down
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 464 exit 1>
exec failed with the params {"cd"=>"$home", "hook"=>"db_migrate", "cmd"=>["su discourse -c 'bundle exec rake db:migrate'"]}
09f25264156537f25494937344ff03601bd3a17fe9d32a3c88112ae7b18dc7c5
The issue is with redis. Is this a single container (app.yml) installation?
How much ram do you have? Is there swap?
Before I reply, and I have no idea why I didn’t mention this in the OP, but I’m fairly certain this arose after I tried performing an upgrade through the Dashboard and it failed. Funnily enough, I can upgrade through the Dashboard fine now, but ever since then I’ve been unable to do a rebuild through the command line. As such, I’m unable to make edits to the app.yml file.
Yes.
2GB, with 50GB of storage if that’s at all relevant.
I don’t think so, especially unlikely if it’s something that needed to be set up manually.
Of you used discourse-setup then it would be.
What does
free -h
Say?
Strange. Not enough memory was my best guess. That’s not it. ![]()
Yeah, I’m pretty much at a loss. Wouldn’t mind even paying to have someone to possibly analyze this further and at fix it if possible or even diagnose it at this point.
AFAIK Discourse largely uses Redis as part of/to complement Sidekiq. Could the issue be stemming from there?
Bump. Anyone else run into anything similar to the errors presented in the log before? Going to give it a few more months before I just pay someone to hopefully give this a fix.
Fetching origin
Launcher is up-to-date
Stopping old container
+ /usr/bin/docker stop -t 60 app
app
cd /pups && git pull && git checkout v1.0.3 && /pups/bin/pups --stdin
Already up to date.
Note: checking out 'v1.0.3'.
You are in 'detached HEAD' state. You can look around, make experimental
changes and commit them, and you can discard any commits you make in this
state without impacting any branches by performing another checkout.
If you want to create a new branch to retain commits you create, you may
do so (now or later) by using -b with the checkout command again. Example:
git checkout -b <new-branch-name>
HEAD is now at d1db030 cut a new version
I, [2021-11-01T00:22:36.703574 #1] INFO -- : Loading --stdin
I, [2021-11-01T00:22:36.713107 #1] INFO -- : > locale-gen $LANG && update-locale
I, [2021-11-01T00:22:36.792263 #1] INFO -- : Generating locales (this might take a while)...
Generation complete.
I, [2021-11-01T00:22:36.793270 #1] INFO -- : > mkdir -p /shared/postgres_run
I, [2021-11-01T00:22:36.802760 #1] INFO -- :
I, [2021-11-01T00:22:36.804583 #1] INFO -- : > chown postgres:postgres /shared/postgres_run
I, [2021-11-01T00:22:36.810419 #1] INFO -- :
I, [2021-11-01T00:22:36.811303 #1] INFO -- : > chmod 775 /shared/postgres_run
I, [2021-11-01T00:22:36.816328 #1] INFO -- :
I, [2021-11-01T00:22:36.817118 #1] INFO -- : > rm -fr /var/run/postgresql
I, [2021-11-01T00:22:36.822275 #1] INFO -- :
I, [2021-11-01T00:22:36.823079 #1] INFO -- : > ln -s /shared/postgres_run /var/run/postgresql
I, [2021-11-01T00:22:36.827897 #1] INFO -- :
I, [2021-11-01T00:22:36.828769 #1] INFO -- : > socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1
2021/11/01 00:22:36 socat[27] E connect(6, AF=1 "/shared/postgres_run/.s.PGSQL.5432", 36): No such file or directory
I, [2021-11-01T00:22:36.847474 #1] INFO -- :
I, [2021-11-01T00:22:36.848113 #1] INFO -- : > rm -fr /shared/postgres_run/.s*
I, [2021-11-01T00:22:36.854060 #1] INFO -- :
I, [2021-11-01T00:22:36.854652 #1] INFO -- : > rm -fr /shared/postgres_run/*.pid
I, [2021-11-01T00:22:36.859188 #1] INFO -- :
I, [2021-11-01T00:22:36.859800 #1] INFO -- : > mkdir -p /shared/postgres_run/13-main.pg_stat_tmp
I, [2021-11-01T00:22:36.863659 #1] INFO -- :
I, [2021-11-01T00:22:36.864442 #1] INFO -- : > chown postgres:postgres /shared/postgres_run/13-main.pg_stat_tmp
I, [2021-11-01T00:22:36.868279 #1] INFO -- :
I, [2021-11-01T00:22:36.877938 #1] INFO -- : File > /etc/service/postgres/run chmod: +x chown:
I, [2021-11-01T00:22:36.885613 #1] INFO -- : File > /etc/service/postgres/log/run chmod: +x chown:
I, [2021-11-01T00:22:36.893862 #1] INFO -- : File > /etc/runit/3.d/99-postgres chmod: +x chown:
I, [2021-11-01T00:22:36.901790 #1] INFO -- : File > /root/upgrade_postgres chmod: +x chown:
I, [2021-11-01T00:22:36.902690 #1] INFO -- : > chown -R root /var/lib/postgresql/13/main
I, [2021-11-01T00:22:37.960738 #1] INFO -- :
I, [2021-11-01T00:22:37.961792 #1] INFO -- : > [ ! -e /shared/postgres_data ] && install -d -m 0755 -o postgres -g postgres /shared/postgres_data && sudo -E -u postgres /usr/lib/postgresql/13/bin/initdb -D /shared/postgres_data || exit 0
I, [2021-11-01T00:22:37.965979 #1] INFO -- :
I, [2021-11-01T00:22:37.966532 #1] INFO -- : > chown -R postgres:postgres /shared/postgres_data
I, [2021-11-01T00:22:37.997716 #1] INFO -- :
I, [2021-11-01T00:22:37.998764 #1] INFO -- : > chown -R postgres:postgres /var/run/postgresql
I, [2021-11-01T00:22:38.003595 #1] INFO -- :
I, [2021-11-01T00:22:38.004484 #1] INFO -- : > /root/upgrade_postgres
I, [2021-11-01T00:22:38.015331 #1] INFO -- :
I, [2021-11-01T00:22:38.016143 #1] INFO -- : > rm /root/upgrade_postgres
I, [2021-11-01T00:22:38.020319 #1] INFO -- :
I, [2021-11-01T00:22:38.022437 #1] INFO -- : Replacing data_directory = '/var/lib/postgresql/13/main' with data_directory = '/shared/postgres_data' in /etc/postgresql/13/main/postgresql.conf
I, [2021-11-01T00:22:38.023631 #1] INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addresses = '*' in /etc/postgresql/13/main/postgresql.conf
I, [2021-11-01T00:22:38.024627 #1] INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchronous_commit = $db_synchronous_commit in /etc/postgresql/13/main/postgresql.conf
I, [2021-11-01T00:22:38.025408 #1] INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffers = $db_shared_buffers in /etc/postgresql/13/main/postgresql.conf
I, [2021-11-01T00:22:38.026156 #1] INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work_mem in /etc/postgresql/13/main/postgresql.conf
I, [2021-11-01T00:22:38.026959 #1] INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with default_text_search_config = '$db_default_text_search_config' in /etc/postgresql/13/main/postgresql.conf
I, [2021-11-01T00:22:38.027835 #1] INFO -- : > install -d -m 0755 -o postgres -g postgres /shared/postgres_backup
I, [2021-11-01T00:22:38.035462 #1] INFO -- :
I, [2021-11-01T00:22:38.036596 #1] INFO -- : Replacing (?-mix:#?checkpoint_segments *=.*) with checkpoint_segments = $db_checkpoint_segments in /etc/postgresql/13/main/postgresql.conf
I, [2021-11-01T00:22:38.037385 #1] INFO -- : Replacing (?-mix:#?logging_collector *=.*) with logging_collector = $db_logging_collector in /etc/postgresql/13/main/postgresql.conf
I, [2021-11-01T00:22:38.038251 #1] INFO -- : Replacing (?-mix:#?log_min_duration_statement *=.*) with log_min_duration_statement = $db_log_min_duration_statement in /etc/postgresql/13/main/postgresql.conf
I, [2021-11-01T00:22:38.039441 #1] INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) with local replication postgres peer in /etc/postgresql/13/main/pg_hba.conf
I, [2021-11-01T00:22:38.040287 #1] INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2021-11-01T00:22:38.041101 #1] INFO -- : Replacing (?-mix:^host.*all.*all.*::1\/128.*$) with host all all ::/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2021-11-01T00:22:38.041740 #1] INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main
I, [2021-11-01T00:22:38.045506 #1] INFO -- : > sleep 5
2021-11-01 00:22:38.165 UTC [50] LOG: starting PostgreSQL 13.4 (Debian 13.4-4.pgdg100+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 8.3.0-6) 8.3.0, 64-bit
2021-11-01 00:22:38.166 UTC [50] LOG: listening on IPv4 address "0.0.0.0", port 5432
2021-11-01 00:22:38.166 UTC [50] LOG: listening on IPv6 address "::", port 5432
2021-11-01 00:22:38.168 UTC [50] LOG: listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2021-11-01 00:22:38.173 UTC [53] LOG: database system was shut down at 2021-11-01 00:22:25 UTC
2021-11-01 00:22:38.184 UTC [50] LOG: database system is ready to accept connections
I, [2021-11-01T00:22:43.056258 #1] INFO -- :
I, [2021-11-01T00:22:43.057405 #1] INFO -- : > su postgres -c 'createdb discourse' || true
2021-11-01 00:22:43.211 UTC [63] postgres@postgres ERROR: database "discourse" already exists
2021-11-01 00:22:43.211 UTC [63] postgres@postgres STATEMENT: CREATE DATABASE discourse;
createdb: error: database creation failed: ERROR: database "discourse" already exists
I, [2021-11-01T00:22:43.217515 #1] INFO -- :
I, [2021-11-01T00:22:43.218432 #1] INFO -- : > su postgres -c 'psql discourse -c "create user discourse;"' || true
2021-11-01 00:22:43.328 UTC [67] postgres@discourse ERROR: role "discourse" already exists
2021-11-01 00:22:43.328 UTC [67] postgres@discourse STATEMENT: create user discourse;
I, [2021-11-01T00:22:43.332483 #1] INFO -- :
I, [2021-11-01T00:22:43.333388 #1] INFO -- : > su postgres -c 'psql discourse -c "grant all privileges on database discourse to discourse;"' || true
I, [2021-11-01T00:22:43.413486 #1] INFO -- : GRANT
I, [2021-11-01T00:22:43.416156 #1] INFO -- : > su postgres -c 'psql discourse -c "alter schema public owner to discourse;"'
I, [2021-11-01T00:22:43.496728 #1] INFO -- : ALTER SCHEMA
I, [2021-11-01T00:22:43.497561 #1] INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists hstore;"'
NOTICE: extension "hstore" already exists, skipping
I, [2021-11-01T00:22:43.587289 #1] INFO -- : CREATE EXTENSION
I, [2021-11-01T00:22:43.588057 #1] INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists pg_trgm;"'
NOTICE: extension "pg_trgm" already exists, skipping
I, [2021-11-01T00:22:43.675828 #1] INFO -- : CREATE EXTENSION
I, [2021-11-01T00:22:43.676536 #1] INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists hstore;"'
I, [2021-11-01T00:22:43.767365 #1] INFO -- : CREATE EXTENSION
I, [2021-11-01T00:22:43.768328 #1] INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists pg_trgm;"'
I, [2021-11-01T00:22:43.858974 #1] INFO -- : CREATE EXTENSION
I, [2021-11-01T00:22:43.859774 #1] INFO -- : > sudo -u postgres psql discourse
I, [2021-11-01T00:22:43.868861 #1] INFO -- : update pg_database set encoding = pg_char_to_encoding('UTF8') where datname = 'discourse' AND encoding = pg_char_to_encoding('SQL_ASCII');
I, [2021-11-01T00:22:43.980816 #1] INFO -- : File > /var/lib/postgresql/take-database-backup chmod: +x chown: postgres:postgres
I, [2021-11-01T00:22:43.987765 #1] INFO -- : File > /var/spool/cron/crontabs/postgres chmod: chown:
I, [2021-11-01T00:22:43.988814 #1] INFO -- : > echo postgres installed!
I, [2021-11-01T00:22:43.994179 #1] INFO -- : postgres installed!
I, [2021-11-01T00:22:43.995093 #1] INFO -- : > thpoff echo "thpoff is installed!"
I, [2021-11-01T00:22:44.001005 #1] INFO -- : thpoff is installed!
I, [2021-11-01T00:22:44.001771 #1] INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_SMTP_ADDRESS"] == "smtp.example.com"; puts "Aborting! Mail is not configured!"; exit 1; end'
I, [2021-11-01T00:22:44.112583 #1] INFO -- :
I, [2021-11-01T00:22:44.113427 #1] INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_HOSTNAME"] == "discourse.example.com"; puts "Aborting! Domain is not configured!"; exit 1; end'
I, [2021-11-01T00:22:44.220062 #1] INFO -- :
I, [2021-11-01T00:22:44.220942 #1] INFO -- : > /usr/local/bin/ruby -e 'if (ENV["DISCOURSE_CDN_URL"] || "")[0..1] == "//"; puts "Aborting! CDN must have a protocol specified. Once fixed you should rebake your posts now to correct all posts."; exit 1; end'
I, [2021-11-01T00:22:44.333546 #1] INFO -- :
I, [2021-11-01T00:22:44.334424 #1] INFO -- : > rm -f /etc/cron.d/anacron
I, [2021-11-01T00:22:44.339698 #1] INFO -- :
I, [2021-11-01T00:22:44.345525 #1] INFO -- : File > /etc/cron.d/anacron chmod: chown:
I, [2021-11-01T00:22:44.356542 #1] INFO -- : File > /etc/runit/1.d/copy-env chmod: +x chown:
I, [2021-11-01T00:22:44.367195 #1] INFO -- : File > /etc/service/unicorn/run chmod: +x chown:
I, [2021-11-01T00:22:44.378077 #1] INFO -- : File > /etc/service/nginx/run chmod: +x chown:
I, [2021-11-01T00:22:44.387243 #1] INFO -- : File > /etc/runit/3.d/01-nginx chmod: +x chown:
I, [2021-11-01T00:22:44.396258 #1] INFO -- : File > /etc/runit/3.d/02-unicorn chmod: +x chown:
I, [2021-11-01T00:22:44.396988 #1] INFO -- : Replacing # postgres with sv start postgres || exit 1 in /etc/service/unicorn/run
I, [2021-11-01T00:22:44.398977 #1] INFO -- : > cd /var/www/discourse && git reset --hard
Checking out files: 25% (6593/26168)
Checking out files: 26% (6804/26168)
Checking out files: 27% (7066/26168)
Checking out files: 28% (7328/26168)
Checking out files: 29% (7589/26168)
Checking out files: 30% (7851/26168)
Checking out files: 31% (8113/26168)
Checking out files: 32% (8374/26168)
Checking out files: 33% (8636/26168)
Checking out files: 34% (8898/26168)
Checking out files: 35% (9159/26168)
Checking out files: 36% (9421/26168)
Checking out files: 37% (9683/26168)
Checking out files: 38% (9944/26168)
Checking out files: 39% (10206/26168)
Checking out files: 40% (10468/26168)
Checking out files: 41% (10729/26168)
Checking out files: 42% (10991/26168)
Checking out files: 43% (11253/26168)
Checking out files: 44% (11514/26168)
Checking out files: 45% (11776/26168)
Checking out files: 46% (12038/26168)
Checking out files: 47% (12299/26168)
Checking out files: 48% (12561/26168)
Checking out files: 49% (12823/26168)
Checking out files: 50% (13084/26168)
Checking out files: 51% (13346/26168)
Checking out files: 52% (13608/26168)
Checking out files: 53% (13870/26168)
Checking out files: 54% (14131/26168)
Checking out files: 55% (14393/26168)
Checking out files: 56% (14655/26168)
Checking out files: 57% (14916/26168)
Checking out files: 58% (15178/26168)
Checking out files: 59% (15440/26168)
Checking out files: 60% (15701/26168)
Checking out files: 60% (15780/26168)
Checking out files: 61% (15963/26168)
Checking out files: 62% (16225/26168)
Checking out files: 63% (16486/26168)
Checking out files: 64% (16748/26168)
Checking out files: 65% (17010/26168)
Checking out files: 66% (17271/26168)
Checking out files: 67% (17533/26168)
Checking out files: 68% (17795/26168)
Checking out files: 69% (18056/26168)
Checking out files: 70% (18318/26168)
Checking out files: 71% (18580/26168)
Checking out files: 72% (18841/26168)
Checking out files: 73% (19103/26168)
Checking out files: 74% (19365/26168)
Checking out files: 75% (19626/26168)
Checking out files: 76% (19888/26168)
Checking out files: 77% (20150/26168)
Checking out files: 78% (20412/26168)
Checking out files: 79% (20673/26168)
Checking out files: 80% (20935/26168)
Checking out files: 81% (21197/26168)
Checking out files: 82% (21458/26168)
Checking out files: 83% (21720/26168)
Checking out files: 84% (21982/26168)
Checking out files: 85% (22243/26168)
Checking out files: 86% (22505/26168)
Checking out files: 87% (22767/26168)
Checking out files: 88% (23028/26168)
Checking out files: 89% (23290/26168)
Checking out files: 90% (23552/26168)
Checking out files: 91% (23813/26168)
Checking out files: 92% (24075/26168)
Checking out files: 92% (24315/26168)
Checking out files: 93% (24337/26168)
Checking out files: 94% (24598/26168)
Checking out files: 95% (24860/26168)
Checking out files: 96% (25122/26168)
Checking out files: 97% (25383/26168)
Checking out files: 98% (25645/26168)
Checking out files: 99% (25907/26168)
Checking out files: 100% (26168/26168)
Checking out files: 100% (26168/26168), done.
I, [2021-11-01T00:22:48.823644 #1] INFO -- : HEAD is now at 92afa74d Mark shared-edits plugin as official (#14639)
I, [2021-11-01T00:22:48.824440 #1] INFO -- : > cd /var/www/discourse && git clean -f
I, [2021-11-01T00:22:48.963352 #1] INFO -- :
I, [2021-11-01T00:22:48.964200 #1] INFO -- : > cd /var/www/discourse && git remote set-branches --add origin main
I, [2021-11-01T00:22:48.970667 #1] INFO -- :
I, [2021-11-01T00:22:48.971205 #1] INFO -- : > cd /var/www/discourse && git remote set-branches origin tests-passed
I, [2021-11-01T00:22:48.977199 #1] INFO -- :
I, [2021-11-01T00:22:48.977738 #1] INFO -- : > cd /var/www/discourse && git fetch --depth 1 origin tests-passed
From https://github.com/discourse/discourse
* branch tests-passed -> FETCH_HEAD
* [new branch] tests-passed -> origin/tests-passed
I, [2021-11-01T00:22:51.160808 #1] INFO -- :
I, [2021-11-01T00:22:51.161471 #1] INFO -- : > cd /var/www/discourse && git checkout tests-passed
Switched to a new branch 'tests-passed'
I, [2021-11-01T00:22:52.301107 #1] INFO -- : Branch 'tests-passed' set up to track remote branch 'tests-passed' from 'origin'.
I, [2021-11-01T00:22:52.301706 #1] INFO -- : > cd /var/www/discourse && mkdir -p tmp
I, [2021-11-01T00:22:52.311733 #1] INFO -- :
I, [2021-11-01T00:22:52.316030 #1] INFO -- : > cd /var/www/discourse && chown discourse:www-data tmp
I, [2021-11-01T00:22:52.325749 #1] INFO -- :
I, [2021-11-01T00:22:52.326348 #1] INFO -- : > cd /var/www/discourse && mkdir -p tmp/pids
I, [2021-11-01T00:22:52.336068 #1] INFO -- :
I, [2021-11-01T00:22:52.340034 #1] INFO -- : > cd /var/www/discourse && mkdir -p tmp/sockets
I, [2021-11-01T00:22:52.348003 #1] INFO -- :
I, [2021-11-01T00:22:52.348517 #1] INFO -- : > cd /var/www/discourse && touch tmp/.gitkeep
I, [2021-11-01T00:22:52.359960 #1] INFO -- :
I, [2021-11-01T00:22:52.360073 #1] INFO -- : > cd /var/www/discourse && mkdir -p /shared/log/rails
I, [2021-11-01T00:22:52.370560 #1] INFO -- :
I, [2021-11-01T00:22:52.371174 #1] INFO -- : > cd /var/www/discourse && bash -c "touch -a /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log"
I, [2021-11-01T00:22:52.388493 #1] INFO -- :
I, [2021-11-01T00:22:52.388629 #1] INFO -- : > cd /var/www/discourse && bash -c "ln -s /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log /var/www/discourse/log"
I, [2021-11-01T00:22:52.404830 #1] INFO -- :
I, [2021-11-01T00:22:52.404969 #1] INFO -- : > cd /var/www/discourse && bash -c "mkdir -p /shared/{uploads,backups}"
I, [2021-11-01T00:22:52.421061 #1] INFO -- :
I, [2021-11-01T00:22:52.421741 #1] INFO -- : > cd /var/www/discourse && bash -c "ln -s /shared/{uploads,backups} /var/www/discourse/public"
I, [2021-11-01T00:22:52.437357 #1] INFO -- :
I, [2021-11-01T00:22:52.437479 #1] INFO -- : > cd /var/www/discourse && bash -c "mkdir -p /shared/tmp/{backups,restores}"
I, [2021-11-01T00:22:52.452669 #1] INFO -- :
I, [2021-11-01T00:22:52.453309 #1] INFO -- : > cd /var/www/discourse && bash -c "ln -s /shared/tmp/{backups,restores} /var/www/discourse/tmp"
I, [2021-11-01T00:22:52.468750 #1] INFO -- :
I, [2021-11-01T00:22:52.468882 #1] INFO -- : > cd /var/www/discourse && chown -R discourse:www-data /shared/log/rails /shared/uploads /shared/backups /shared/tmp
I, [2021-11-01T00:22:52.755036 #1] INFO -- :
I, [2021-11-01T00:22:52.755781 #1] INFO -- : > cd /var/www/discourse && find public/plugins/ -maxdepth 1 -xtype l -delete
I, [2021-11-01T00:22:52.763377 #1] INFO -- :
I, [2021-11-01T00:22:52.764430 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/docker_manager.git
Cloning into 'docker_manager'...
I, [2021-11-01T00:22:53.944491 #1] INFO -- :
I, [2021-11-01T00:22:53.945294 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-spoiler-alert
Cloning into 'discourse-spoiler-alert'...
I, [2021-11-01T00:22:54.349404 #1] INFO -- :
I, [2021-11-01T00:22:54.350150 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/cpradio/discourse-giphy
Cloning into 'discourse-giphy'...
I, [2021-11-01T00:22:54.988087 #1] INFO -- :
I, [2021-11-01T00:22:54.989060 #1] INFO -- : > cp /var/www/discourse/config/nginx.sample.conf /etc/nginx/conf.d/discourse.conf
I, [2021-11-01T00:22:54.995794 #1] INFO -- :
I, [2021-11-01T00:22:54.996738 #1] INFO -- : > rm /etc/nginx/sites-enabled/default
I, [2021-11-01T00:22:55.001383 #1] INFO -- :
I, [2021-11-01T00:22:55.002328 #1] INFO -- : > mkdir -p /var/nginx/cache
I, [2021-11-01T00:22:55.007086 #1] INFO -- :
I, [2021-11-01T00:22:55.008486 #1] INFO -- : Replacing pid /run/nginx.pid; with daemon off; in /etc/nginx/nginx.conf
I, [2021-11-01T00:22:55.009378 #1] INFO -- : Replacing (?m-ix:upstream[^\}]+\}) with upstream discourse { server 127.0.0.1:3000; } in /etc/nginx/conf.d/discourse.conf
I, [2021-11-01T00:22:55.010106 #1] INFO -- : Replacing (?-mix:server_name.+$) with server_name _ ; in /etc/nginx/conf.d/discourse.conf
I, [2021-11-01T00:22:55.010864 #1] INFO -- : Replacing (?-mix:client_max_body_size.+$) with client_max_body_size $upload_size ; in /etc/nginx/conf.d/discourse.conf
I, [2021-11-01T00:22:55.011539 #1] INFO -- : > echo "done configuring web"
I, [2021-11-01T00:22:55.015681 #1] INFO -- : done configuring web
I, [2021-11-01T00:22:55.016534 #1] INFO -- : > cd /var/www/discourse && gem install bundler --conservative -v $(awk '/BUNDLED WITH/ { getline; gsub(/ /,""); print $0 }' Gemfile.lock)
I, [2021-11-01T00:22:55.971470 #1] INFO -- : Successfully installed bundler-2.2.26
1 gem installed
I, [2021-11-01T00:22:55.972367 #1] INFO -- : > cd /var/www/discourse && find /var/www/discourse ! -user discourse -exec chown discourse {} \+
I, [2021-11-01T00:22:59.921873 #1] INFO -- :
I, [2021-11-01T00:22:59.922743 #1] INFO -- : > cd /var/www/discourse && su discourse -c 'bundle install --deployment --retry 3 --jobs 4 --verbose --without test development'
[DEPRECATED] The `--deployment` flag is deprecated because it relies on being remembered across bundler invocations, which bundler will no longer do in future versions. Instead please use `bundle config set --local deployment 'true'`, and stop using this flag
[DEPRECATED] The `--without` flag is deprecated because it relies on being remembered across bundler invocations, which bundler will no longer do in future versions. Instead please use `bundle config set --local without 'test development'`, and stop using this flag
I, [2021-11-01T00:23:12.863463 #1] INFO -- : Running `bundle install --deployment --jobs 4 --retry 3 --verbose --without "test" "development"` with bundler 2.2.26
Frozen, using resolution from the lockfile
The definition is missing ["json-2.6.1", "json-2.6.1", "json-2.6.1", "json-2.6.1", "json-2.6.1", "json-2.6.1", "aws-sdk-sns-1.46.0", "aws-sdk-sns-1.46.0", "aws-sdk-sns-1.46.0", "aws-sdk-sns-1.46.0", "aws-sdk-sns-1.46.0", "aws-sdk-sns-1.46.0", "excon-0.88.0", "excon-0.88.0", "excon-0.88.0", "excon-0.88.0", "excon-0.88.0", "excon-0.88.0", "image_optim-0.31.1", "image_optim-0.31.1", "image_optim-0.31.1", "image_optim-0.31.1", "image_optim-0.31.1", "image_optim-0.31.1", "omniauth-facebook-9.0.0", "omniauth-facebook-9.0.0", "omniauth-facebook-9.0.0", "omniauth-facebook-9.0.0", "omniauth-facebook-9.0.0", "omniauth-facebook-9.0.0", "logster-2.9.8", "logster-2.9.8", "logster-2.9.8", "logster-2.9.8", "logster-2.9.8", "logster-2.9.8", "zeitwerk-2.5.1", "zeitwerk-2.5.1", "zeitwerk-2.5.1", "zeitwerk-2.5.1", "zeitwerk-2.5.1", "zeitwerk-2.5.1", "aws-sdk-core-3.121.2", "aws-sdk-core-3.121.2", "aws-sdk-core-3.121.2", "aws-sdk-core-3.121.2", "aws-sdk-core-3.121.2", "aws-sdk-core-3.121.2", "aws-sigv4-1.4.0", "aws-sigv4-1.4.0", "aws-sigv4-1.4.0", "aws-sigv4-1.4.0", "aws-sigv4-1.4.0", "aws-sigv4-1.4.0", "image_size-3.0.1", "image_size-3.0.1", "image_size-3.0.1", "image_size-3.0.1", "image_size-3.0.1", "image_size-3.0.1", "racc-1.6.0", "racc-1.6.0", "racc-1.6.0", "racc-1.6.0", "racc-1.6.0", "racc-1.6.0", "aws-partitions-1.516.0", "aws-partitions-1.516.0", "aws-partitions-1.516.0", "aws-partitions-1.516.0", "aws-partitions-1.516.0", "aws-partitions-1.516.0", "ipaddr-1.2.3", "ipaddr-1.2.3", "ipaddr-1.2.3", "ipaddr-1.2.3", "ipaddr-1.2.3", "ipaddr-1.2.3"]
HTTP GET https://index.rubygems.org/versions
HTTP 206 Partial Content https://index.rubygems.org/versions
Fetching gem metadata from https://rubygems.org/
Looking up gems ["actionmailer", "actionpack", "actionview", "actionview_precompiler", "active_model_serializers", "activejob", "activemodel", "activerecord", "activesupport", "addressable", "annotate", "ast", "aws-eventstream", "aws-partitions", "aws-sdk-core", "aws-sdk-kms", "aws-sdk-s3", "aws-sdk-sns", "aws-sigv4", "barber", "better_errors", "binding_of_caller", "bootsnap", "builder", "bullet", "byebug", "cbor", "certified", "chunky_png", "coderay", "colored2", "concurrent-ruby", "connection_pool", "cose", "cppjieba_rb", "crack", "crass", "css_parser", "debug_inspector", "diff-lcs", "diffy", "discourse-ember-rails", "discourse-ember-source", "discourse-fonts", "discourse_dev_assets", "docile", "ecma-re-validator", "email_reply_trimmer", "ember-data-source", "ember-handlebars-template", "ember-source", "erubi", "excon", "execjs", "exifr", "fabrication", "faker", "fakeweb", "faraday", "faraday-em_http", "faraday-em_synchrony", "faraday-excon", "faraday-httpclient", "faraday-net_http", "faraday-net_http_persistent", "faraday-patron", "faraday-rack", "fast_blank", "fast_xs", "fastimage", "ffi", "fspath", "gc_tracer", "globalid", "guess_html_encoding", "hana", "hashdiff", "hashie", "highline", "hkdf", "htmlentities", "http_accept_language", "i18n", "image_optim", "image_size", "in_threads", "ipaddr", "jmespath", "jquery-rails", "json", "json-schema", "json_schemer", "jwt", "kgio", "libv8-node", "listen", "literate_randomizer", "lograge", "logstash-event", "logstash-logger", "logster", "loofah", "lru_redux", "lz4-ruby", "maxminddb", "memory_profiler", "message_bus", "method_source", "mini_mime", "mini_portile2", "mini_racer", "mini_scheduler", "mini_sql", "mini_suffix", "minitest", "mocha", "mock_redis", "msgpack", "multi_json", "multi_xml", "multipart-post", "mustache", "nio4r", "nokogiri", "oauth", "oauth2", "oj", "omniauth", "omniauth-facebook", "omniauth-github", "omniauth-google-oauth2", "omniauth-oauth", "omniauth-oauth2", "omniauth-twitter", "openssl", "openssl-signature_algorithm", "optimist", "parallel", "parallel_tests", "parser", "pg", "progress", "pry", "pry-byebug", "pry-rails", "public_suffix", "puma", "r2", "racc", "rack", "rack-mini-profiler", "rack-protection", "rack-test", "rails-dom-testing", "rails-html-sanitizer", "rails_failover", "rails_multisite", "railties", "rainbow", "raindrops", "rake", "rb-fsevent", "rb-inotify", "rbtrace", "rchardet", "redis", "redis-namespace", "regexp_parser", "request_store", "rexml", "rinku", "rotp", "rqrcode", "rqrcode_core", "rspec", "rspec-core", "rspec-expectations", "rspec-html-matchers", "rspec-mocks", "rspec-rails", "rspec-support", "rss", "rswag-specs", "rtlit", "rubocop", "rubocop-ast", "rubocop-discourse", "rubocop-rspec", "ruby-prof", "ruby-progressbar", "ruby-readability", "ruby2_keywords", "rubyzip", "sanitize", "sassc", "sassc-rails", "seed-fu", "shoulda-matchers", "sidekiq", "simplecov", "simplecov-html", "simplecov_json_formatter", "sprockets", "sprockets-rails", "sshkey", "stackprof", "test-prof", "thor", "tilt", "tzinfo", "uglifier", "unf", "unf_ext", "unicode-display_width", "unicorn", "uniform_notifier", "uri_template", "webmock", "webpush", "xorcist", "yaml-lint", "zeitwerk"]
HTTP GET https://index.rubygems.org/info/aws-partitions
HTTP 206 Partial Content https://index.rubygems.org/info/aws-partitions
HTTP GET https://index.rubygems.org/info/aws-sdk-core
HTTP 206 Partial Content https://index.rubygems.org/info/aws-sdk-core
HTTP GET https://index.rubygems.org/info/excon
HTTP 206 Partial Content https://index.rubygems.org/info/excon
HTTP GET https://index.rubygems.org/info/faraday
HTTP 206 Partial Content https://index.rubygems.org/info/faraday
HTTP GET https://index.rubygems.org/info/image_optim
HTTP 206 Partial Content https://index.rubygems.org/info/image_optim
HTTP GET https://index.rubygems.org/info/image_size
HTTP 206 Partial Content https://index.rubygems.org/info/image_size
HTTP GET https://index.rubygems.org/info/ipaddr
HTTP 206 Partial Content https://index.rubygems.org/info/ipaddr
HTTP GET https://index.rubygems.org/info/json
HTTP 206 Partial Content https://index.rubygems.org/info/json
HTTP GET https://index.rubygems.org/info/logster
HTTP 206 Partial Content https://index.rubygems.org/info/logster
HTTP GET https://index.rubygems.org/info/mini_portile2
HTTP 206 Partial Content https://index.rubygems.org/info/mini_portile2
HTTP GET https://index.rubygems.org/info/omniauth-facebook
HTTP 206 Partial Content https://index.rubygems.org/info/omniauth-facebook
HTTP GET https://index.rubygems.org/info/racc
HTTP 206 Partial Content https://index.rubygems.org/info/racc
HTTP GET https://index.rubygems.org/info/rubocop
HTTP 206 Partial Content https://index.rubygems.org/info/rubocop
HTTP GET https://index.rubygems.org/info/zeitwerk
HTTP 206 Partial Content https://index.rubygems.org/info/zeitwerk
Looking up gems ["mail", "text-format", "erubis", "rack-mount", "rack-cache", "journey", "rails-deprecated_sanitizer", "jsonapi", "case_transform", "jsonapi-renderer", "activemodel-globalid", "bcrypt-ruby", "arel", "activerecord-deprecated_finders", "memcache-client", "thread_safe", "jamespath", "http-2", "aws-crt", "ember-template-compiler-source", "handlebars-source", "rouge", "snappy", "columnize", "debugger-linecache", "slop", "rb-readline", "functional-ruby", "ref", "safe_yaml", "rdoc", "pastel", "tty-pager", "tty-screen", "tty-tree", "rcov", "net-http-persistent", "rake-compiler", "rb-appscript", "xattr", "ffi-xattr", "termios", "json_pure", "rails", "rdf", "rb-fchange", "rb-kqueue", "celluloid", "celluloid-io", "ruby_dep", "stud", "eventmachine", "thin", "ruby_parser", "net-ftp", "libv8", "metaclass", "hoe", "weakling", "mini_portile", "pkg-config", "ruby-hmac", "faraday-middleware", "httpauth", "bigdecimal", "oa-core", "oa-oauth", "oa-openid", "oa-basic", "oa-enterprise", "oa-more", "sexp_processor", "win32console", "yard", "spoon", "pry-doc", "escape_utils", "rack-ssl", "trollop", "base32", "webrat", "rspec-collection_matchers", "term-ansicolor", "backports", "powerpack", "astrolabe", "tins", "jaro_winkler", "psych", "strscan", "hpricot", "nokogumbo", "bundler", "sass", "bourne", "compass", "sprockets-sass", "sinatra", "slim", "lockfile", "hike", "therubyracer"]
HTTP GET https://index.rubygems.org/info/json_pure
HTTP 206 Partial Content https://index.rubygems.org/info/json_pure
HTTP GET https://index.rubygems.org/info/ruby_parser
HTTP 206 Partial Content https://index.rubygems.org/info/ruby_parser
HTTP GET https://index.rubygems.org/info/sexp_processor
HTTP 206 Partial Content https://index.rubygems.org/info/sexp_processor
HTTP GET https://index.rubygems.org/info/psych
HTTP 206 Partial Content https://index.rubygems.org/info/psych
HTTP GET https://index.rubygems.org/info/strscan
HTTP 206 Partial Content https://index.rubygems.org/info/strscan
HTTP GET https://index.rubygems.org/info/bundler
HTTP 206 Partial Content https://index.rubygems.org/info/bundler
Looking up gems ["mime-types", "treetop", "tlsmail", "text-hyphen", "abstract", "multimap", "jsonapi-parser", "bcrypt", "ZenTest", "RubyInline", "atomic", "snappy-jars", "ruby_core_source", "debugger-ruby_core_source", "equatable", "tty-color", "tty-which", "verse", "strings", "spruz", "activeresource", "actionwebservice", "actioncable", "activestorage", "actionmailbox", "actiontext", "link_header", "hamster", "win32-api", "timers", "facter", "celluloid-essentials", "celluloid-extras", "celluloid-fsm", "celluloid-pool", "celluloid-supervision", "dotenv", "nenv", "rspec-logsplit", "metriks", "daemons", "ParseTree", "net-protocol", "time", "rubyforge", "gemcutter", "rack-openid", "ruby-openid-apps-discovery", "restclient", "rest-client", "net-ldap", "rubyntlm", "pyu-ruby-sasl", "uuid", "XMLCanonicalizer", "curses", "sync", "jar-dependencies", "sass-listen", "haml", "fssm", "compass-core", "compass-import-once", "sprockets-helpers", "mongrel", "mustermann", "temple"]
HTTP GET https://index.rubygems.org/info/net-protocol
HTTP 206 Partial Content https://index.rubygems.org/info/net-protocol
Looking up gems ["mime-types-data", "facets", "polyglot", "archive-tar-minitar", "unicode_utils", "strings-ansi", "rails-observers", "activemodel-serializers-xml", "coffee-rails", "em-hiredis", "faye-websocket", "websocket-driver", "marcel", "mimemagic", "test-unit", "hitimes", "CFPropertyList", "sys-admin", "win32-dir", "windows-api", "windows-pr", "win32-security", "hocon", "celluloid-gems", "coveralls", "dotenv-deployment", "rbtree", "faraday_middleware", "yajl-ruby", "avl_tree", "SexpProcessor", "io-wait", "timeout", "date", "net-scp", "ruby-openid", "netrc", "http-cookie", "http-accept", "macaddr", "log4r", "ruby-maven", "cgi_multipart_eof_fix", "fastthread", "gem_plugin", "tool"]
HTTP GET https://index.rubygems.org/info/io-wait
HTTP 206 Partial Content https://index.rubygems.org/info/io-wait
Looking up gems ["minitar", "minitar-cli", "coffee-script", "hiredis", "websocket-extensions", "power_assert", "configuration", "mkrf", "libxml-ruby", "ffi-win32-extensions", "colorize", "roauth", "net-ssh", "ruby-yadis", "domain_name", "sqlite3", "systemu", "maven-tools", "ruby-maven-libs"]
Looking up gems ["powerbar", "coffee-script-source", "pattern-match", "needle", "jruby-pageant", "bcrypt_pbkdf", "rbnacl", "rbnacl-libsodium", "virtus"]
Looking up gems ["ansi", "descendants_tracker", "axiom-types", "coercible", "equalizer"]
Looking up gems ["ice_nine", "adamantium"]
Looking up gems ["memoizable"]
Using rake 13.0.6
0: rake (13.0.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rake-13.0.6.gemspec
Using concurrent-ruby 1.1.9
0: concurrent-ruby (1.1.9) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/concurrent-ruby-1.1.9.gemspec
Using minitest 5.14.4
0: minitest (5.14.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/minitest-5.14.4.gemspec
Using builder 3.2.4
3: builder (3.2.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/builder-3.2.4.gemspec
Using erubi 1.10.0
3: erubi (1.10.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/erubi-1.10.0.gemspec
Fetching racc 1.6.0
Using crass 1.0.6
2: crass (1.0.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/crass-1.0.6.gemspec
Using rack 2.2.3
2: rack (2.2.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rack-2.2.3.gemspec
Using mini_mime 1.1.2
2: mini_mime (1.1.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/mini_mime-1.1.2.gemspec
Using public_suffix 4.0.6
2: public_suffix (4.0.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/public_suffix-4.0.6.gemspec
Using aws-eventstream 1.2.0
2: aws-eventstream (1.2.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-eventstream-1.2.0.gemspec
Using jmespath 1.4.0
1: jmespath (1.4.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/jmespath-1.4.0.gemspec
Using ember-source 2.18.2
1: ember-source (2.18.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ember-source-2.18.2.gemspec
Using execjs 2.8.1
1: execjs (2.8.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/execjs-2.8.1.gemspec
Using msgpack 1.4.2
1: msgpack (1.4.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/msgpack-1.4.2.gemspec
Using bundler 2.2.26
1: bundler (2.2.26) from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.26/lib/bundler/source
Using byebug 11.1.3
1: byebug (11.1.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/byebug-11.1.3.gemspec
Using cbor 0.5.9.6
1: cbor (0.5.9.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/cbor-0.5.9.6.gemspec
Using chunky_png 1.4.0
1: chunky_png (1.4.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/chunky_png-1.4.0.gemspec
Using coderay 1.1.3
1: coderay (1.1.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/coderay-1.1.3.gemspec
Using colored2 3.1.2
1: colored2 (3.1.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/colored2-3.1.2.gemspec
Using connection_pool 2.2.5
1: connection_pool (2.2.5) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/connection_pool-2.2.5.gemspec
Fetching ipaddr 1.2.3
Fetching zeitwerk 2.5.1
Fetching aws-partitions 1.516.0
Installing zeitwerk 2.5.1
Installing ipaddr 1.2.3
Installing racc 1.6.0 with native extensions
Installing aws-partitions 1.516.0
1: ipaddr (1.2.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ipaddr-1.2.3.gemspec
Using cppjieba_rb 0.3.3
1: cppjieba_rb (0.3.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/cppjieba_rb-0.3.3.gemspec
Using diffy 3.4.0
1: diffy (3.4.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/diffy-3.4.0.gemspec
Using method_source 1.0.0
1: method_source (1.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/method_source-1.0.0.gemspec
Using thor 1.1.0
1: thor (1.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/thor-1.1.0.gemspec
Using discourse-ember-source 3.12.2.3
1: discourse-ember-source (3.12.2.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/discourse-ember-source-3.12.2.3.gemspec
Using discourse-fonts 0.0.9
1: discourse-fonts (0.0.9) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/discourse-fonts-0.0.9.gemspec
Using regexp_parser 2.1.1
1: regexp_parser (2.1.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/regexp_parser-2.1.1.gemspec
Using email_reply_trimmer 0.1.13
1: email_reply_trimmer (0.1.13) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/email_reply_trimmer-0.1.13.gemspec
Fetching excon 0.88.0
0: zeitwerk (2.5.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/zeitwerk-2.5.1.gemspec
Using exifr 1.3.9
0: exifr (1.3.9) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/exifr-1.3.9.gemspec
Using faraday-em_http 1.0.0
0: faraday-em_http (1.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-em_http-1.0.0.gemspec
Using faraday-em_synchrony 1.0.0
2: aws-partitions (1.516.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-partitions-1.516.0.gemspec
Using faraday-excon 1.1.0
2: faraday-excon (1.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-excon-1.1.0.gemspec
Using faraday-httpclient 1.0.1
2: faraday-httpclient (1.0.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-httpclient-1.0.1.gemspec
Using faraday-net_http 1.0.1
2: faraday-net_http (1.0.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-net_http-1.0.1.gemspec
Using faraday-net_http_persistent 1.2.0
2: faraday-net_http_persistent (1.2.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-net_http_persistent-1.2.0.gemspec
Using faraday-patron 1.0.0
2: faraday-patron (1.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-patron-1.0.0.gemspec
Using faraday-rack 1.0.0
2: faraday-rack (1.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-rack-1.0.0.gemspec
Using multipart-post 2.1.1
2: multipart-post (2.1.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/multipart-post-2.1.1.gemspec
Using ruby2_keywords 0.0.5
2: ruby2_keywords (0.0.5) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ruby2_keywords-0.0.5.gemspec
Using fast_blank 1.0.1
2: fast_blank (1.0.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/fast_blank-1.0.1.gemspec
Using fast_xs 0.8.0
0: faraday-em_synchrony (1.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-em_synchrony-1.0.0.gemspec
2: fast_xs (0.8.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/fast_xs-0.8.0.gemspec
Using fastimage 2.2.5
2: fastimage (2.2.5) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/fastimage-2.2.5.gemspec
Using ffi 1.15.4
2: ffi (1.15.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ffi-1.15.4.gemspec
Using fspath 3.1.2
2: fspath (3.1.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/fspath-3.1.2.gemspec
Using gc_tracer 1.5.1
2: gc_tracer (1.5.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/gc_tracer-1.5.1.gemspec
Using guess_html_encoding 0.0.11
2: guess_html_encoding (0.0.11) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/guess_html_encoding-0.0.11.gemspec
Using hana 1.3.7
2: hana (1.3.7) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/hana-1.3.7.gemspec
Using hashie 4.1.0
2: hashie (4.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/hashie-4.1.0.gemspec
Using highline 2.0.3
2: highline (2.0.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/highline-2.0.3.gemspec
Using hkdf 0.3.0
2: hkdf (0.3.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/hkdf-0.3.0.gemspec
Using htmlentities 4.3.4
2: htmlentities (4.3.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/htmlentities-4.3.4.gemspec
Using http_accept_language 2.1.1
2: http_accept_language (2.1.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/http_accept_language-2.1.1.gemspec
Fetching image_size 3.0.1
Installing excon 0.88.0
Using in_threads 1.5.4
0: in_threads (1.5.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/in_threads-1.5.4.gemspec
Using progress 3.6.0
0: progress (3.6.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/progress-3.6.0.gemspec
Fetching json 2.6.1
Building native extensions. This could take a while...
Installing image_size 3.0.1
Installing json 2.6.1 with native extensions
1: excon (0.88.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/excon-0.88.0.gemspec
Using uri_template 0.7.0
1: uri_template (0.7.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/uri_template-0.7.0.gemspec
Using jwt 2.3.0
1: jwt (2.3.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/jwt-2.3.0.gemspec
Using kgio 2.11.4
1: kgio (2.11.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/kgio-2.11.4.gemspec
Using libv8-node 15.14.0.1 (x86_64-linux)
1: libv8-node (15.14.0.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/libv8-node-15.14.0.1-x86_64-linux.gemspec
Using logstash-event 1.2.02
1: logstash-event (1.2.02) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/logstash-event-1.2.02.gemspec
Fetching logster 2.9.8
2: image_size (3.0.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/image_size-3.0.1.gemspec
Using lru_redux 1.1.0
2: lru_redux (1.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/lru_redux-1.1.0.gemspec
Using lz4-ruby 0.3.3
2: lz4-ruby (0.3.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/lz4-ruby-0.3.3.gemspec
Using maxminddb 0.1.22
2: maxminddb (0.1.22) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/maxminddb-0.1.22.gemspec
Using memory_profiler 1.0.0
2: memory_profiler (1.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/memory_profiler-1.0.0.gemspec
Using redis 4.5.1
2: redis (4.5.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/redis-4.5.1.gemspec
Using mini_sql 1.1.3
2: mini_sql (1.1.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/mini_sql-1.1.3.gemspec
Using multi_json 1.15.0
2: multi_json (1.15.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/multi_json-1.15.0.gemspec
Using multi_xml 0.6.0
2: multi_xml (0.6.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/multi_xml-0.6.0.gemspec
Using mustache 1.1.1
2: mustache (1.1.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/mustache-1.1.1.gemspec
Using nio4r 2.5.8
2: nio4r (2.5.8) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/nio4r-2.5.8.gemspec
Using oauth 0.5.6
2: oauth (0.5.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/oauth-0.5.6.gemspec
Using oj 3.13.2
2: oj (3.13.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/oj-3.13.2.gemspec
Using optimist 3.0.1
2: optimist (3.0.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/optimist-3.0.1.gemspec
Using pg 1.2.3
2: pg (1.2.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/pg-1.2.3.gemspec
Using r2 0.2.7
2: r2 (0.2.7) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/r2-0.2.7.gemspec
Using raindrops 0.19.2
2: raindrops (0.19.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/raindrops-0.19.2.gemspec
Using rchardet 1.8.0
2: rchardet (1.8.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rchardet-1.8.0.gemspec
Using rexml 3.2.5
2: rexml (3.2.5) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rexml-3.2.5.gemspec
Using rinku 2.0.6
2: rinku (2.0.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rinku-2.0.6.gemspec
Using rotp 6.2.0
2: rotp (6.2.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rotp-6.2.0.gemspec
Using rqrcode_core 1.2.0
2: rqrcode_core (1.2.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rqrcode_core-1.2.0.gemspec
Using rtlit 0.0.5
2: rtlit (0.0.5) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rtlit-0.0.5.gemspec
Using rubyzip 2.3.2
2: rubyzip (2.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rubyzip-2.3.2.gemspec
Using tilt 2.0.10
2: tilt (2.0.10) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/tilt-2.0.10.gemspec
Using sshkey 2.0.0
2: sshkey (2.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sshkey-2.0.0.gemspec
Using stackprof 0.2.17
2: stackprof (0.2.17) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/stackprof-0.2.17.gemspec
Using unf_ext 0.0.8
2: unf_ext (0.0.8) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/unf_ext-0.0.8.gemspec
Using xorcist 1.1.2
2: xorcist (1.1.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/xorcist-1.1.2.gemspec
Using i18n 1.8.10
2: i18n (1.8.10) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/i18n-1.8.10.gemspec
Using tzinfo 2.0.4
2: tzinfo (2.0.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/tzinfo-2.0.4.gemspec
Using rack-test 1.1.0
2: rack-test (1.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rack-test-1.1.0.gemspec
Using mail 2.8.0.edge from https://github.com/discourse/mail.git (at master@5b700fc)
2: mail (2.8.0.edge) from /var/www/discourse/vendor/bundle/ruby/2.7.0/bundler/gems/mail-5b700fc95ee6/mail.gemspec
Using addressable 2.8.0
2: addressable (2.8.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/addressable-2.8.0.gemspec
Fetching aws-sigv4 1.4.0
Installing logster 2.9.8
Installing aws-sigv4 1.4.0
2: aws-sigv4 (1.4.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-sigv4-1.4.0.gemspec
Using barber 0.12.2
2: barber (0.12.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/barber-0.12.2.gemspec
Using bootsnap 1.9.1
2: bootsnap (1.9.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/bootsnap-1.9.1.gemspec
Using ember-data-source 3.0.2
2: ember-data-source (3.0.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ember-data-source-3.0.2.gemspec
Using sprockets 3.7.2
2: sprockets (3.7.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sprockets-3.7.2.gemspec
Using request_store 1.5.0
2: request_store (1.5.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/request_store-1.5.0.gemspec
Using message_bus 3.3.6
2: message_bus (3.3.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/message_bus-3.3.6.gemspec
Using rack-mini-profiler 2.3.3
2: rack-mini-profiler (2.3.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rack-mini-profiler-2.3.3.gemspec
Using rack-protection 2.1.0
2: rack-protection (2.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rack-protection-2.1.0.gemspec
Using uglifier 4.2.0
2: uglifier (4.2.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/uglifier-4.2.0.gemspec
Using openssl 2.2.1
2: openssl (2.2.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/openssl-2.2.1.gemspec
Using pry 0.13.1
2: pry (0.13.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/pry-0.13.1.gemspec
Using ecma-re-validator 0.3.0
2: ecma-re-validator (0.3.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ecma-re-validator-0.3.0.gemspec
Using mini_suffix 0.3.2
2: mini_suffix (0.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/mini_suffix-0.3.2.gemspec
Using omniauth 1.9.1
2: omniauth (1.9.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-1.9.1.gemspec
Using sassc 2.0.1
2: sassc (2.0.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sassc-2.0.1.gemspec
Using faraday 1.8.0
2: faraday (1.8.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-1.8.0.gemspec
Using logstash-logger 0.26.1
2: logstash-logger (0.26.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/logstash-logger-0.26.1.gemspec
Using mini_racer 0.4.0
2: mini_racer (0.4.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/mini_racer-0.4.0.gemspec
Using webpush 1.1.0
2: webpush (1.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/webpush-1.1.0.gemspec
Fetching image_optim 0.31.1
Installing image_optim 0.31.1
Rails image assets optimization is extracted into image_optim_rails gem
You can safely remove `config.assets.image_optim = false` if you are not going to use that gem
2: image_optim (0.31.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/image_optim-0.31.1.gemspec
Using sidekiq 6.2.2
2: sidekiq (6.2.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sidekiq-6.2.2.gemspec
Using puma 5.5.2
2: puma (5.5.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/puma-5.5.2.gemspec
Using redis-namespace 1.8.1
2: redis-namespace (1.8.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/redis-namespace-1.8.1.gemspec
Using rbtrace 0.4.14
2: rbtrace (0.4.14) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rbtrace-0.4.14.gemspec
Using rqrcode 2.1.0
2: rqrcode (2.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rqrcode-2.1.0.gemspec
Using rss 0.2.9
2: rss (0.2.9) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rss-0.2.9.gemspec
Using unicorn 6.0.0
2: unicorn (6.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/unicorn-6.0.0.gemspec
Using unf 0.1.4
2: unf (0.1.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/unf-0.1.4.gemspec
Using activesupport 6.1.4.1
2: activesupport (6.1.4.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/activesupport-6.1.4.1.gemspec
Using css_parser 1.10.0
2: css_parser (1.10.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/css_parser-1.10.0.gemspec
Fetching aws-sdk-core 3.121.2
1: logster (2.9.8) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/logster-2.9.8.gemspec
Using ember-handlebars-template 0.8.0
1: ember-handlebars-template (0.8.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ember-handlebars-template-0.8.0.gemspec
Using openssl-signature_algorithm 1.1.1
1: openssl-signature_algorithm (1.1.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/openssl-signature_algorithm-1.1.1.gemspec
Using json_schemer 0.2.18
1: json_schemer (0.2.18) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/json_schemer-0.2.18.gemspec
Using oauth2 1.4.7
1: oauth2 (1.4.7) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/oauth2-1.4.7.gemspec
Using omniauth-oauth 1.2.0
1: omniauth-oauth (1.2.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-oauth-1.2.0.gemspec
Using pry-byebug 3.9.0
1: pry-byebug (3.9.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/pry-byebug-3.9.0.gemspec
Using pry-rails 0.3.9
1: pry-rails (0.3.9) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/pry-rails-0.3.9.gemspec
Using mini_scheduler 0.13.0
1: mini_scheduler (0.13.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/mini_scheduler-0.13.0.gemspec
Using globalid 0.5.2
1: globalid (0.5.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/globalid-0.5.2.gemspec
Using activemodel 6.1.4.1
1: activemodel (6.1.4.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/activemodel-6.1.4.1.gemspec
Using cose 1.2.0
1: cose (1.2.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/cose-1.2.0.gemspec
Using activejob 6.1.4.1
1: activejob (6.1.4.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/activejob-6.1.4.1.gemspec
Using active_model_serializers 0.8.4
1: active_model_serializers (0.8.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/active_model_serializers-0.8.4.gemspec
Using activerecord 6.1.4.1
1: activerecord (6.1.4.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/activerecord-6.1.4.1.gemspec
Using omniauth-oauth2 1.7.1
1: omniauth-oauth2 (1.7.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-oauth2-1.7.1.gemspec
Using omniauth-twitter 1.4.0
1: omniauth-twitter (1.4.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-twitter-1.4.0.gemspec
Fetching omniauth-facebook 9.0.0
Installing omniauth-facebook 9.0.0
Installing aws-sdk-core 3.121.2
1: omniauth-facebook (9.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-facebook-9.0.0.gemspec
Using omniauth-github 1.4.0
1: omniauth-github (1.4.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-github-1.4.0.gemspec
Using omniauth-google-oauth2 0.8.2
1: omniauth-google-oauth2 (0.8.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-google-oauth2-0.8.2.gemspec
Using seed-fu 2.3.9
1: seed-fu (2.3.9) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/seed-fu-2.3.9.gemspec
2: aws-sdk-core (3.121.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-sdk-core-3.121.2.gemspec
Using aws-sdk-kms 1.44.0
1: aws-sdk-kms (1.44.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-sdk-kms-1.44.0.gemspec
Fetching aws-sdk-sns 1.46.0
Using aws-sdk-s3 1.96.1
2: aws-sdk-s3 (1.96.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-sdk-s3-1.96.1.gemspec
Installing aws-sdk-sns 1.46.0
1: aws-sdk-sns (1.46.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-sdk-sns-1.46.0.gemspec
3: racc (1.6.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/racc-1.6.0.gemspec
Using nokogiri 1.12.5 (x86_64-linux)
2: nokogiri (1.12.5) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/nokogiri-1.12.5-x86_64-linux.gemspec
Using rails-dom-testing 2.0.3
1: rails-dom-testing (2.0.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rails-dom-testing-2.0.3.gemspec
Using loofah 2.12.0
1: loofah (2.12.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/loofah-2.12.0.gemspec
Using ruby-readability 0.7.0
1: ruby-readability (0.7.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ruby-readability-0.7.0.gemspec
Using sanitize 6.0.0
1: sanitize (6.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sanitize-6.0.0.gemspec
Using rails-html-sanitizer 1.4.2
1: rails-html-sanitizer (1.4.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rails-html-sanitizer-1.4.2.gemspec
Using actionview 6.1.4.1
2: actionview (6.1.4.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/actionview-6.1.4.1.gemspec
Using actionpack 6.1.4.1
3: actionpack (6.1.4.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/actionpack-6.1.4.1.gemspec
Using actionview_precompiler 0.2.3
3: actionview_precompiler (0.2.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/actionview_precompiler-0.2.3.gemspec
Using actionmailer 6.1.4.1
2: actionmailer (6.1.4.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/actionmailer-6.1.4.1.gemspec
Using railties 6.1.4.1
2: railties (6.1.4.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/railties-6.1.4.1.gemspec
Using sprockets-rails 3.2.2
2: sprockets-rails (3.2.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sprockets-rails-3.2.2.gemspec
Using jquery-rails 4.4.0
2: jquery-rails (4.4.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/jquery-rails-4.4.0.gemspec
Using lograge 0.11.2
2: lograge (0.11.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/lograge-0.11.2.gemspec
Using rails_failover 0.7.3
2: rails_failover (0.7.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rails_failover-0.7.3.gemspec
Using rails_multisite 3.1.0
2: rails_multisite (3.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rails_multisite-3.1.0.gemspec
Using sassc-rails 2.1.2
2: sassc-rails (2.1.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sassc-rails-2.1.2.gemspec
Using discourse-ember-rails 0.18.6
2: discourse-ember-rails (0.18.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/discourse-ember-rails-0.18.6.gemspec
0: json (2.6.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/json-2.6.1.gemspec
Bundle complete! 127 Gemfile dependencies, 174 gems now installed.
Gems in the groups 'test' and 'development' were not installed.
Bundled gems are installed into `./vendor/bundle`
Post-install message from image_optim:
I, [2021-11-01T00:23:12.867848 #1] INFO -- : > cd /var/www/discourse && [ ! -d 'node_modules' ] || su discourse -c 'yarn install --production && yarn cache clean'
warning Resolution field "lodash@4.17.21" is incompatible with requested version "lodash@4.17.15"
I, [2021-11-01T00:24:36.073253 #1] INFO -- : yarn install v1.22.15
[1/5] Validating package.json...
[2/5] Resolving packages...
success Already up-to-date.
$ yarn --cwd app/assets/javascripts/discourse
[1/4] Resolving packages...
[2/4] Fetching packages...
info fsevents@2.3.2: The platform "linux" is incompatible with this module.
info "fsevents@2.3.2" is an optional dependency and failed compatibility check. Excluding it from installation.
info fsevents@1.2.13: The platform "linux" is incompatible with this module.
info "fsevents@1.2.13" is an optional dependency and failed compatibility check. Excluding it from installation.
[3/4] Linking dependencies...
[4/4] Building fresh packages...
success Saved lockfile.
Done in 72.85s.
Done in 74.41s.
yarn cache v1.22.15
success Cleared cache.
Done in 8.01s.
I, [2021-11-01T00:24:36.084785 #1] INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake plugin:pull_compatible_all'
I, [2021-11-01T00:24:40.486973 #1] INFO -- : discourse-spoiler-alert is already at latest compatible version
docker_manager is already at latest compatible version
discourse-giphy is already at latest compatible version
I, [2021-11-01T00:24:40.487911 #1] INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
Failed to report error: Error connecting to Redis on localhost:6379 (Errno::EADDRNOTAVAIL) 2 Error connecting to Redis on localhost:6379 (Errno::EADDRNOTAVAIL) subscribe failed, reconnecting in 1 second. Call stack /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis/client.rb:398:in `rescue in establish_connection'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis/client.rb:379:in `establish_connection'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis/client.rb:117:in `block in connect'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis/client.rb:344:in `with_reconnect'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis/client.rb:116:in `connect'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis/client.rb:325:in `with_socket_timeout'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis/client.rb:175:in `call_loop'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis/subscribe.rb:44:in `subscription'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis/subscribe.rb:14:in `subscribe'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis.rb:3789:in `_subscription'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis.rb:2552:in `block in subscribe'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis.rb:72:in `block in synchronize'
/usr/local/lib/ruby/2.7.0/monitor.rb:202:in `synchronize'
/usr/local/lib/ruby/2.7.0/monitor.rb:202:in `mon_synchronize'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis.rb:72:in `synchronize'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis.rb:2551:in `subscribe'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/message_bus-3.3.6/lib/message_bus/backends/redis.rb:285:in `global_subscribe'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/message_bus-3.3.6/lib/message_bus.rb:781:in `global_subscribe_thread'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/message_bus-3.3.6/lib/message_bus.rb:729:in `block in new_subscriber_thread'
rake aborted!
Redis::CannotConnectError: Error connecting to Redis on localhost:6379 (Errno::EADDRNOTAVAIL)
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis/client.rb:417:in `ensure_connected'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis/client.rb:269:in `block in process'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis/client.rb:356:in `logging'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis/client.rb:268:in `process'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis/client.rb:162:in `call'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis.rb:564:in `block in del'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis.rb:563:in `del'
/var/www/discourse/lib/discourse_redis.rb:81:in `block in del'
/var/www/discourse/lib/discourse_redis.rb:29:in `ignore_readonly'
/var/www/discourse/lib/discourse_redis.rb:79:in `del'
/var/www/discourse/lib/cache.rb:75:in `delete'
/var/www/discourse/lib/site_setting_extension.rb:455:in `clear_cache!'
/var/www/discourse/lib/site_setting_extension.rb:311:in `block in refresh!'
/var/www/discourse/lib/site_setting_extension.rb:290:in `synchronize'
/var/www/discourse/lib/site_setting_extension.rb:290:in `refresh!'
/var/www/discourse/lib/site_setting_extension.rb:529:in `block in setup_methods'
/var/www/discourse/config/initializers/004-message_bus.rb:122:in `<main>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.9.1/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:60:in `load'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.1/lib/active_support/dependencies.rb:326:in `block in load'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.1/lib/active_support/dependencies.rb:299:in `load_dependency'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.1/lib/active_support/dependencies.rb:326:in `load'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/engine.rb:681:in `block in load_config_initializer'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.1/lib/active_support/notifications.rb:205:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/engine.rb:680:in `load_config_initializer'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/engine.rb:634:in `block (2 levels) in <class:Engine>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/engine.rb:633:in `each'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/engine.rb:633:in `block in <class:Engine>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/initializable.rb:32:in `instance_exec'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/initializable.rb:32:in `run'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/initializable.rb:61:in `block in run_initializers'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/initializable.rb:50:in `each'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/initializable.rb:50:in `tsort_each_child'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/initializable.rb:60:in `run_initializers'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/application.rb:391:in `initialize!'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/railtie.rb:207:in `public_send'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/railtie.rb:207:in `method_missing'
/var/www/discourse/config/environment.rb:7:in `<main>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.9.1/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:23:in `require'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.9.1/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:23:in `block in require_with_bootsnap_lfi'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.9.1/lib/bootsnap/load_path_cache/loaded_features_index.rb:92:in `register'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.9.1/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:22:in `require_with_bootsnap_lfi'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.9.1/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:31:in `require'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/zeitwerk-2.5.1/lib/zeitwerk/kernel.rb:35:in `require'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.1/lib/active_support/dependencies.rb:332:in `block in require'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.1/lib/active_support/dependencies.rb:332:in `require'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/application.rb:367:in `require_environment!'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/application.rb:533:in `block in run_tasks_blocks'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/exe/rake:27:in `<top (required)>'
/usr/local/bin/bundle:23:in `load'
/usr/local/bin/bundle:23:in `<main>'
Caused by:
Errno::EADDRNOTAVAIL: Cannot assign requested address - connect(2) for [::1]:6379
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis/connection/ruby.rb:155:in `connect_addrinfo'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis/connection/ruby.rb:193:in `block in connect'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis/connection/ruby.rb:191:in `each'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis/connection/ruby.rb:191:in `each_with_index'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis/connection/ruby.rb:191:in `connect'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis/connection/ruby.rb:305:in `connect'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.5.1/lib/redis/client.rb:385:in `establish_connection'
Tasks: TOP => db:migrate => db:load_config => environment
I, [2021-11-01T00:24:45.349348 #1] INFO -- :
I, [2021-11-01T00:24:45.350577 #1] INFO -- : Terminating async processes
I, [2021-11-01T00:24:45.351061 #1] INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 50
2021-11-01 00:24:45.351 UTC [50] LOG: received fast shutdown request
2021-11-01 00:24:45.356 UTC [50] LOG: aborting any active transactions
2021-11-01 00:24:45.366 UTC [50] LOG: background worker "logical replication launcher" (PID 59) exited with exit code 1
2021-11-01 00:24:45.369 UTC [54] LOG: shutting down
2021-11-01 00:24:45.391 UTC [50] LOG: database system is shut down
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 464 exit 1>
exec failed with the params {"cd"=>"$home", "hook"=>"db_migrate", "cmd"=>["su discourse -c 'bundle exec rake db:migrate'"]}
09f25264156537f25494937344ff03601bd3a17fe9d32a3c88112ae7b18dc7c5
Still no idea unless you somehow commented out the redis template.
