Failed to bootstrap on DO/Docker Fresh install
User cyborg reported a failure when bootstrapping Discourse on a DigitalOcean server using the official DO guide, encountering an invalid byte sequence error. Community members codinghorror and zogstrip suggested verifying the installation steps and validating the app.yml file using an online validator. Despite confirming the YAML was valid, cyborg attempted a fresh install using the official Discourse guide, which resulted in a different error: invalid value for parameter "shared_buffers": "MB".
Users sam and codinghorror identified that the shared_buffers configuration in app.yml was missing a numerical value, likely due to editing errors. cyborg confirmed this was the root cause after checking the pastebin of their configuration, successfully resolving the issue.
I’ve just started a new server following DO instructions step by step and once did “./launcher bootstrap app” I got the following
cd /pups && git pull && /pups/bin/pups --stdin
Already up-to-date.
I, [2015-08-07T08:28:55.099744 #36]  INFO -- : Loading --stdin
/pups/lib/pups/cli.rb:15:in `split': invalid byte sequence in US-ASCII (ArgumentError)
	from /pups/lib/pups/cli.rb:15:in `run'
	from /pups/bin/pups:8:in `<main>'
0863bc0343acd6434412d672772acd2b69b6b565fce7aa9848fd12fc83a554ae
** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may be more than one
Any hint on why and how to solve it?
  • Did you follow the guide exactly, or did you deviate from any of the steps in any way or add anything else?
  • Is this a default english installation?
  • Does the YAML pass an online YAML validator?
I followed this guide exactly. Not even one step out of it: https://www.digitalocean.com/community/tutorials/how-to-install-discourse-on-ubuntu-14-04
history
    1  sudo apt-get update
    2  sudo apt-get upgrade
    3  apt-get install git
    4  sudo install -o root -g root -m 0600 /dev/null /swapfile
    5  dd if=/dev/zero of=/swapfile bs=1k count=2048k
    6  mkswap /swapfile
    7  swapon /swapfile
    8  echo "/swapfile       swap    swap    auto      0       0" | sudo tee -a /etc/fstab
    9  sudo sysctl -w vm.swappiness=10
   10  echo vm.swappiness = 10 | sudo tee -a /etc/sysctl.conf
   11  free -m
   12  wget -qO- https://get.docker.io/ | sh
   13  mkdir /var/discourse
   14  git clone https://github.com/discourse/discourse_docker.git /var/discourse
   15  cd /var/discourse
   16  cp samples/standalone.yml containers/app.yml
   17  nano containers/app.yml
   18  nano /etc/default/docker
   19  service docker restart
   20  ./launcher bootstrap app
   21  history
Default english installation
I don’t know how to check the YAML online validator
Instance type 1GB / Frankfurt zone / Ubuntu 14.04
Just copy and paste the content of you app.yml file into http://www.yamllint.com/.
Thanks @zogstrip, the validator said:
Valid YAML!
I would start over from scratch (reset droplet) and follow our official guide instead.
The DO one is also semi-official, but.. ours is best :wink:
Will do and revert shortly.
Exactly the same issue. (well, not exactly the same but fails anyways)
    Success. You can now start the database server using:
    /usr/lib/postgresql/9.3/bin/postgres -D /shared/postgres_data
or
    /usr/lib/postgresql/9.3/bin/pg_ctl -D /shared/postgres_data -l logfile start
I, [2015-08-07T09:13:52.554231 #40]  INFO -- : > chown -R postgres:postgres /shared/postgres_data
I, [2015-08-07T09:13:52.561658 #40]  INFO -- :
I, [2015-08-07T09:13:52.562149 #40]  INFO -- : > chown -R postgres:postgres /var/run/postgresql
I, [2015-08-07T09:13:52.565338 #40]  INFO -- :
I, [2015-08-07T09:13:52.566234 #40]  INFO -- : > /root/upgrade_postgres
I, [2015-08-07T09:13:52.574080 #40]  INFO -- :
I, [2015-08-07T09:13:52.576076 #40]  INFO -- : > rm /root/upgrade_postgres
I, [2015-08-07T09:13:52.577873 #40]  INFO -- :
I, [2015-08-07T09:13:52.578767 #40]  INFO -- : Replacing data_directory = '/var/lib/postgresql/9.3/main' with data_directory = '/shared/postgres_data' in /etc/postgresql/9.3/main/postgresql.conf
I, [2015-08-07T09:13:52.579961 #40]  INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addresses = '*' in /etc/postgresql/9.3/main/postgresql.conf
I, [2015-08-07T09:13:52.581886 #40]  INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchronous_commit = $db_synchronous_commit in /etc/postgresql/9.3/main/postgresql.conf
I, [2015-08-07T09:13:52.583446 #40]  INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffers = $db_shared_buffers in /etc/postgresql/9.3/main/postgresql.conf
I, [2015-08-07T09:13:52.585126 #40]  INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work_mem in /etc/postgresql/9.3/main/postgresql.conf
I, [2015-08-07T09:13:52.587949 #40]  INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with default_text_search_config = '$db_default_text_search_config' in /etc/postgresql/9.3/main/postgresql.conf
I, [2015-08-07T09:13:52.589979 #40]  INFO -- : > install -d -m 0755 -o postgres -g postgres /shared/postgres_backup
I, [2015-08-07T09:13:52.595172 #40]  INFO -- :
I, [2015-08-07T09:13:52.596220 #40]  INFO -- : Replacing (?-mix:#?max_wal_senders *=.*) with max_wal_senders = $db_max_wal_senders in /etc/postgresql/9.3/main/postgresql.conf
I, [2015-08-07T09:13:52.597622 #40]  INFO -- : Replacing (?-mix:#?wal_level *=.*) with wal_level = $db_wal_level in /etc/postgresql/9.3/main/postgresql.conf
I, [2015-08-07T09:13:52.600259 #40]  INFO -- : Replacing (?-mix:#?checkpoint_segments *=.*) with checkpoint_segments = $db_checkpoint_segments in /etc/postgresql/9.3/main/postgresql.conf
I, [2015-08-07T09:13:52.601921 #40]  INFO -- : Replacing (?-mix:#?logging_collector *=.*) with logging_collector = $db_logging_collector in /etc/postgresql/9.3/main/postgresql.conf
I, [2015-08-07T09:13:52.603712 #40]  INFO -- : Replacing (?-mix:#?log_min_duration_statement *=.*) with log_min_duration_statement = $db_log_min_duration_statement in /etc/postgresql/9.3/main/postgresql.conf
I, [2015-08-07T09:13:52.605656 #40]  INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) with local replication postgres  peer in /etc/postgresql/9.3/main/pg_hba.conf
I, [2015-08-07T09:13:52.607642 #40]  INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/0 md5 in /etc/postgresql/9.3/main/pg_hba.conf
I, [2015-08-07T09:13:52.609477 #40]  INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/9.3/bin/postmaster -D /etc/postgresql/9.3/main
LOG:  invalid value for parameter "shared_buffers": "MB"
2015-08-07 09:13:52 UTC [110-2] FATAL:  configuration file "/etc/postgresql/9.3/main/postgresql.conf" contains errors
I, [2015-08-07T09:13:52.645170 #40]  INFO -- : > sleep 5
I, [2015-08-07T09:13:57.649656 #40]  INFO -- :
I, [2015-08-07T09:13:57.653807 #40]  INFO -- : > su postgres -c 'createdb discourse' || true
createdb: could not connect to database template1: could not connect to server: No such file or directory
	Is the server running locally and accepting
	connections on Unix domain socket "/var/run/postgresql/.s.PGSQL.5432"?
I, [2015-08-07T09:13:57.763683 #40]  INFO -- :
I, [2015-08-07T09:13:57.765645 #40]  INFO -- : > su postgres -c 'psql discourse -c "create user discourse;"' || true
psql: could not connect to server: No such file or directory
I, [2015-08-07T09:13:57.848521 #40]  INFO -- :
I, [2015-08-07T09:13:57.850881 #40]  INFO -- : > su postgres -c 'psql discourse -c "grant all privileges on database discourse to discourse;"' || true
I, [2015-08-07T09:13:57.924048 #40]  INFO -- :
I, [2015-08-07T09:13:57.925495 #40]  INFO -- : > su postgres -c 'psql discourse -c "alter schema public owner to discourse;"'
I, [2015-08-07T09:13:57.995779 #40]  INFO -- :
I, [2015-08-07T09:13:57.996709 #40]  INFO -- : Terminating async processes
FAILED
RuntimeError: su postgres -c 'psql discourse -c "alter schema public owner to discourse;"' failed with return #<Process::Status: pid 136 exit 2>
Location of failure: /pups/lib/pups/exec_command.rb:105:in `spawn'
exec failed with the params "su postgres -c 'psql $db_name -c \"alter schema public owner to $db_user;\"'"
10049654150ec47827e12132b1ebc9ab5fe2e8dfc4ededdda2bd15ee492afac4
root@clubmr2:/var/discourse#
History of commands from fresh install following the official instructions:
history
    1  sudo install -o root -g root -m 0600 /dev/null /swapfile
    2  dd if=/dev/zero of=/swapfile bs=1k count=1024k
    3  dd if=/dev/zero of=/swapfile bs=1k count=2048k
    4  mkswap /swapfile
    5  swapon /swapfile
    6  echo "/swapfile       swap    swap    auto      0       0" | sudo tee -a /etc/fstab
    7  sudo sysctl -w vm.swappiness=10
    8  echo vm.swappiness = 10 | sudo tee -a /etc/sysctl.conf
    9  wget -qO- https://get.docker.com/ | sh
   10  mkdir /var/discourse
   11  git clone https://github.com/discourse/discourse_docker.git /var/discourse
   12  cd /var/discourse
   13  cp samples/standalone.yml containers/app.yml
   14  nano containers/app.yml
   15  ./launcher bootstrap app
   16  history
what editor did you use to edit your app.yml, it looks like you saved it in a weird format.
Used nano, but it passes YAML tests. Above is a copy paste from your web to the command line.
Something in your app.yml is messed up and passing invalid data into postgres conf. what did you change.
This is a pastebin directly from command line.
Only changed what is strictly mentioned on the tutorial. SMTP settings and unicorn workers / 128MB
I, [2015-08-07T09:13:52.609477 #40] INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/9.3/bin/postmaster -D /etc/postgresql/9.3/main LOG: invalid value for parameter "shared_buffers": "MB"
This is your error. Whatever you are using to edit this file, or the contents of it, you’re entering something invalid.
that is likely it, it wants to know how many MB… a number to denote that would be helpful
Exactly @sam That was the issue there. Thanks for your help. :blush:
