Hi!
Here is the error I get when I try to rebuild my app (Git revision: beta):
Compressing: application-db30cb7af624e44f554adaa4f48e592c263b25627dac6aaded087b41331c3a55.js
uglifyjs '/var/www/discourse/public/assets/_application-db30cb7af624e44f554adaa4f48e592c263b25627dac6aaded087b41331c3a55.js' -p relative -c -m -o '/var/www/discourse/public/assets/application-db30cb7af624e44f554adaa4f48e592c263b25627dac6aaded087b41331c3a55.js' --source-map-root '/assets' --source-map '/var/www/discourse/public/assets/application-db30cb7af624e44f554adaa4f48e592c263b25627dac6aaded087b41331c3a55.js.map' --source-map-url '/assets/application-db30cb7af624e44f554adaa4f48e592c263b25627dac6aaded087b41331c3a55.js.map'
Parse error at _application-db30cb7af624e44f554adaa4f48e592c263b25627dac6aaded087b41331c3a55.js:99232,22
Unexpected token name «of», expected punc «;»
Error
at new JS_Parse_Error (eval at <anonymous> (/usr/lib/node_modules/uglify-js/tools/node.js:22:1), <anonymous>:1526:18)
at js_error (eval at <anonymous> (/usr/lib/node_modules/uglify-js/tools/node.js:22:1), <anonymous>:1534:11)
at croak (eval at <anonymous> (/usr/lib/node_modules/uglify-js/tools/node.js:22:1), <anonymous>:2026:9)
at token_error (eval at <anonymous> (/usr/lib/node_modules/uglify-js/tools/node.js:22:1), <anonymous>:2034:9)
at expect_token (eval at <anonymous> (/usr/lib/node_modules/uglify-js/tools/node.js:22:1), <anonymous>:2047:9)
at expect (eval at <anonymous> (/usr/lib/node_modules/uglify-js/tools/node.js:22:1), <anonymous>:2050:36)
at regular_for (eval at <anonymous> (/usr/lib/node_modules/uglify-js/tools/node.js:22:1), <anonymous>:2280:9)
at for_ (eval at <anonymous> (/usr/lib/node_modules/uglify-js/tools/node.js:22:1), <anonymous>:2276:16)
at eval (eval at <anonymous> (/usr/lib/node_modules/uglify-js/tools/node.js:22:1), <anonymous>:2158:24)
at eval (eval at <anonymous> (/usr/lib/node_modules/uglify-js/tools/node.js:22:1), <anonymous>:2073:24)
at block_ (eval at <anonymous> (/usr/lib/node_modules/uglify-js/tools/node.js:22:1), <anonymous>:2353:20)
I, [2016-07-29T17:37:24.968689 #13] INFO -- : Purging temp files
Bundling assets
Compressing Javascript and Generating Source Maps
I, [2016-07-29T17:37:24.998638 #13] INFO -- : Terminating async processes
I, [2016-07-29T17:37:25.000414 #13] INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/9.3/bin/postmaster -D /etc/postgresql/9.3/main pid: 1471
I, [2016-07-29T17:37:25.003670 #13] INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 1584
1584:signal-handler (1469813845) Received SIGTERM scheduling shutdown...
2016-07-29 17:37:25 UTC [1471-2] LOG: received fast shutdown request
2016-07-29 17:37:25 UTC [1471-3] LOG: aborting any active transactions
2016-07-29 17:37:25 UTC [1478-2] LOG: autovacuum launcher shutting down
1584:M 29 Jul 17:37:25.013 # User requested shutdown...
1584:M 29 Jul 17:37:25.015 * Saving the final RDB snapshot before exiting.
2016-07-29 17:37:25 UTC [1475-1] LOG: shutting down
2016-07-29 17:37:25 UTC [1475-2] LOG: database system is shut down
1584:M 29 Jul 17:37:31.212 * DB saved on disk
1584:M 29 Jul 17:37:31.216 # Redis is now ready to exit, bye bye...
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake assets:precompile' failed with return #<Process::Status: pid 2330 exit 1>
Location of failure: /pups/lib/pups/exec_command.rb:108:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"bundle_exec", "cmd"=>["su discourse -c 'bundle install --deployment --verbose --without test --without development'", "su discourse -c 'bundle exec rake db:migrate'", "su discourse -c 'bundle exec rake assets:precompile'"]}
57e43153b440f230cf2513f54b0ef86c917261ed63e668021b3d134f7cc4715b
** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may be more than one
Here are the plugins I’m using:
- git clone https://github.com/discourse/discourse-akismet.git
- git clone https://github.com/discourse/discourse-affiliate.git
