오류: 재빌드 중 qunit 헬퍼에서 예상치 못한 토큰 punc «)» 발생
참고: 현재 Discourse 업그레이드를 진행 중인데, 더 이상 진행 상황이 없으며 스택 트레이스가 출력되고 있어 중단된 것으로 보입니다.
Done compressing google-tag-manager-207e4e7db708ead224f0e2ee6d92492abfe9a29e717480b6f6f2614fa7873019.js : 0.92 secs
8000037.063928327 Compressing: discourse/tests/theme_qunit_helper-db34688652a3fe6992c7a007ef9754196ce9b6897556f2690c93410e88955814.js
uglifyjs '/var/www/discourse/public/assets/discourse/tests/_theme_qunit_helper-db34688652a3fe6992c7a007ef9754196ce9b6897556f2690c93410e88955814.js' -m -c -o '/var/www/discourse/public/assets/discourse/tests/theme_qunit_helper-db34688652a3fe6992c7a007ef9754196ce9b6897556f2690c93410e88955814.js' --source-map "base='/var/www/discourse/public/assets/discourse/tests',root='/assets/discourse/tests',url='/assets/discourse/tests/theme_qunit_helper-db34688652a3fe6992c7a007ef9754196ce9b6897556f2690c93410e88955814.js.map'"
Parse error at _theme_qunit_helper-db34688652a3fe6992c7a007ef9754196ce9b6897556f2690c93410e88955814.js:27884,17
define("sinon", () => {
ERROR: Unexpected token: punc «)»
    at JS_Parse_Error.get (eval at <anonymous> (/usr/lib/node_modules/uglify-js/tools/node.js:18:1), <anonymous>:71:23)
    at fatal (/usr/lib/node_modules/uglify-js/bin/uglifyjs:409:27)
    at run (/usr/lib/node_modules/uglify-js/bin/uglifyjs:347:9)
    at Object.<anonymous> (/usr/lib/node_modules/uglify-js/bin/uglifyjs:261:5)
    at Module._compile (internal/modules/cjs/loader.js:778:30)
    at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
    at Module.load (internal/modules/cjs/loader.js:653:32)
    at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    at Function.Module._load (internal/modules/cjs/loader.js:585:3)
    at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
rake aborted!
Errno::ENOENT: No such file or directory @ rb_file_s_size - /var/www/discourse/public/assets/discourse/tests/theme_qunit_helper-db34688652a3fe6992c7a007ef9754196ce9b6897556f2690c93410e88955814.js
/var/www/discourse/lib/tasks/assets.rake:290:in `size'
/var/www/discourse/lib/tasks/assets.rake:290:in `block (4 levels) in <main>'
/var/www/discourse/lib/tasks/assets.rake:181:in `block in concurrent?'
/var/www/discourse/lib/tasks/assets.rake:281:in `block (3 levels) in <main>'
/var/www/discourse/lib/tasks/assets.rake:272:in `each'
/var/www/discourse/lib/tasks/assets.rake:272:in `block (2 levels) in <main>'
/var/www/discourse/lib/tasks/assets.rake:181:in `concurrent?'
/var/www/discourse/lib/tasks/assets.rake:269:in `block in <main>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/exe/rake:27:in `<top (required)>'
/usr/local/bin/bundle:23:in `load'
/usr/local/bin/bundle:23:in `<main>'
Tasks: TOP => assets:precompile
Docker Manager: FAILED TO UPGRADE
#<RuntimeError: RuntimeError>
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:196:in `run'
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:104:in `upgrade'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:19:in `block in <main>'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:6:in `fork'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:6:in `<main>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.7.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:59:in `load'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.0.3.3/lib/rails/commands/runner/runner_command.rb:42:in `perform'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/thor-1.1.0/lib/thor/command.rb:27:in `run'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/thor-1.1.0/lib/thor/invocation.rb:127:in `invoke_command'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/thor-1.1.0/lib/thor.rb:392:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.0.3.3/lib/rails/command/base.rb:69:in `perform'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.0.3.3/lib/rails/command.rb:46:in `invoke'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.0.3.3/lib/rails/commands.rb:18:in `<main>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.7.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:23:in `require'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.7.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:23:in `block in require_with_bootsnap_lfi'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.7.2/lib/bootsnap/load_path_cache/loaded_features_index.rb:92:in `register'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.7.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:22:in `require_with_bootsnap_lfi'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.7.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:31:in `require'
bin/rails:17:in `<main>'
Spinning up 3 Unicorn worker(s) that were stopped initially
이 문제가 테마 컴포넌트의 오류 때문인지(그리고 그럴 가능성이 있는지), 아니면 qunit 테마 테스트 관련 부분에 다른 문제가 있는지는 확신이 서지 않습니다. qunit에 대해 잘 아시는 분이 알아채실 수 있도록 제목을 변경해 두었습니다.
더 이상 uglify를 사용하지 않습니다. 재빌드 시 기본 이미지를 업데이트하도록 안내를 받으실 텐데, 이를 통해 해당 문제가 해결됩니다.
아래 명령어를 실행하여 다시 시도해 주시겠어요?
cd /var/discourse
git pull
./launcher rebuild app
CLI를 통한 업그레이드는 성공적으로 완료되었습니다.
이 스레드는 단순히 버그 보고를 위해 작성한 것입니다. 지금은 문제가 해결되어 Discourse가 정상적으로 작동하고 있습니다. 감사합니다.
앞으로는 웹 인터페이스를 통해 업그레이드하지 않겠습니다.
참고로, 저는 셀프호스팅 사이트(컨테이너 2개 실행 중)에서도 동일한 문제를 겪었습니다.
./launcher rebuild app은 자동으로 git pull을 실행하지만, ./launcher bootstrap web_only는 그렇지 않습니다. /var/discourse에서 git pull을 실행하면 정상적으로 작동하는지 확인하고 싶었습니다.
