常に `launcher rebuild app` に失敗します。GitHub を中国本土のミラーに置き換えるにはどうすればよいですか?
launcher rebuild app でアップデート中に、以下のようなエラーが常に発生します。
I, [2023-02-25T16:34:01.790521 #1]  INFO -- :
> cd /var/www/discourse && sudo -H -E -u discourse git clean -f
I, [2023-02-25T16:34:01.969445 #1]  INFO -- :
I, [2023-02-25T16:34:01.969665 #1]  INFO -- :
> cd /var/www/discourse && sudo -H -E -u discourse git remote set-branches --add origin main
I, [2023-02-25T16:34:01.980319 #1]  INFO -- :
I, [2023-02-25T16:34:01.980423 #1]  INFO -- :
> cd /var/www/discourse && sudo -H -E -u discourse git remote set-branches origin stable
I, [2023-02-25T16:34:01.991560 #1]  INFO -- :
I, [2023-02-25T16:34:01.991883 #1]  INFO -- :
> cd /var/www/discourse && sudo -H -E -u discourse git fetch --depth 1 origin stable
fatal: unable to access 'https://github.com/discourse/discourse.git/': GnuTLS recv error (-110): The TLS connection was non-properly terminated.
FAILED
Pups::ExecError: cd /var/www/discourse && sudo -H -E -u discourse git fetch --depth 1 origin stable failed with return #<Process::Status: pid 144 exit 128>
Location of failure: /usr/local/lib/ruby/gems/3.2.0/gems/pups-1.1.1/lib/pups/exec_command.rb:117:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"code", "cmd"=>["sudo -H -E -u discourse git reset --hard", "sudo -H -E -u discourse git clean -f", "sudo -H -E -u discourse git remote set-branches --add origin main", "sudo -H -E -u discourse git remote set-branches origin $version", "sudo -H -E -u discourse git fetch --depth 1 origin $version", "sudo -H -E -u discourse git checkout $version", "mkdir -p tmp", "chown discourse:www-data tmp", "mkdir -p tmp/pids", "mkdir -p tmp/sockets", "touch tmp/.gitkeep", "mkdir -p                    /shared/log/rails", "bash -c \"touch -a           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log\"", "bash -c \"ln    -s           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log $home/log\"", "bash -c \"mkdir -p           /shared/{uploads,backups}\"", "bash -c \"ln    -s           /shared/{uploads,backups} $home/public\"", "bash -c \"mkdir -p           /shared/tmp/{backups,restores}\"", "bash -c \"ln    -s           /shared/tmp/{backups,restores} $home/tmp\"", "chown -R discourse:www-data /shared/log/rails /shared/uploads /shared/backups /shared/tmp\"", "[ ! -d public/plugins ] || find public/plugins/ -maxdepth 1 -xtype l -delete"]}
bootstrap failed with exit code 128
751de54716a7a145e5dc813d9b25330322dbcd69ec1a047d38267c86a57a990c
GitHub が中国本土で禁止されたため、https://github.com を https://hub.fgit.gq のような CN ミラーに置き換える必要があると考えています。
可能でしょうか?また、どのようにすればよいですか?よろしくお願いします!
私も同じエラーが発生しました。問題は解決しましたか?
香港サーバーを使ってみてください
templates/web.china.template.yml に以下のコードを記述してください。
hooks:
  before_code:
    - exec:
        cmd:
          - su discourse -c 'git config --global url."https://githubfast.com/".insteadOf "https://github.com/"'
  before_web:
    - exec:
        cmd:
          - su discourse -c 'gem sources --add https://mirrors.tuna.tsinghua.edu.cn/rubygems/ --remove https://rubygems.org/'
          - su discourse -c 'bundle config mirror.https://rubygems.org https://mirrors.tuna.tsinghua.edu.cn/rubygems'
  before_yarn:
    - exec:
        cmd:
          - su discourse -c 'yarn config set registry https://mirrors.huaweicloud.com/repository/npm/'
          - su discourse -c 'pnpm config set registry https://mirrors.huaweicloud.com/repository/npm/'
  before_bundle_exec:
    - exec:
        cmd:
