502 Bad Gateway após tentar reconstruir o branch test-passed
Tentei reconstruir o aplicativo depois de seguir as instruções sobre isso: Alterar branch de rastreamento para sua instância do Discourse, mas quando atualizo o app.yml e reconstruo o contêiner:
git pull
./launcher rebuild app
Recebi o erro fatal que mostra:
FAILED
Pups::ExecError: cd /var/www/discourse & git fetch --depth 1 origin tests-passed failed with return #<Process::Status: pid 140 exit 128>
Location of failure: /usr/local/lib/ruby/gems/2.7.0/gems/pups-1.1.1/lib/pups/exec_command.rb:117:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"code", "cmd"=>["git reset --hard", "git clean -f", "git remote set-branches --add origin main", "git remote set-branches origin $version", "git fetch --depth 1 origin $version", "git checkout $version", "mkdir -p tmp", "chown discourse:www-data tmp", "mkdir -p tmp/pids", "mkdir -p tmp/sockets", "touch tmp/.gitkeep", "mkdir -p                    /shared/log/rails", "bash -c \"touch -a           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log\"", "bash -c \"ln    -s           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log $home/log\"", "bash -c \"mkdir -p           /shared/{uploads,backups}\"", "bash -c \"ln    -s           /shared/{uploads,backups} $home/public\"", "bash -c \"mkdir -p           /shared/tmp/{backups,restores}\"", "bash -c \"ln    -s           /shared/tmp/{backups,restores} $home/tmp\"", "chown -R discourse:www-data /shared/log/rails /shared/uploads /shared/backups /shared/tmp\"", "find public/plugins/ -maxdepth 1 -xtype l -delete"]}}
bootstrap failed with exit code 128
14b470c4c6575f2bc366dff1fa8559f98bce37abe5703f63c070b939f67dab65
E o site mostra:
502 Bad Gateway
Como eu conserto isso?
Todo o log está aqui:
whole log.txt (18,3 KB)
Parece que a reconstrução falhou, e eu usei o ./discourse-doctor, que mostra:
==================== SERIOUS PROBLEM!!!! ====================
app not running!
Attempting to rebuild
Você está usando um proxy para tráfego de saída? Ele não parece estar funcionando corretamente.
fatal: unable to access 'https://github.com/discourse/discourse.git/':
  Received HTTP code 503 from proxy after CONNECT
Meu servidor está na China continental, tenho dúvidas se ele foi influenciado pelo GFW, fazendo com que a ação de reconstrução não consiga obter o branch no Github?
Sim, meu servidor está na China Continental e a atualização é sempre muito difícil, a ação padrão não consegue puxar o git do Github
Esse é o problema.
Muita informação aqui: Upgrade from within China fails due to git issues
Não sei como instalar um proxy no meu servidor。。。
