Hi,
I tried to update discourse with ./launcher rebuild app refer from How do I manually update Discourse and Docker image to latest?
But I got failure about ENOENT.
I did below commands to improve this situation.
dpkg-reconfigure -plow unattended-upgrades
apt-get update
apt-get dist-upgrade
wget -qO- https://get.docker.com/ | sh
But the error remained.
I can’t solve it.
Logs is here.
dstest:/var/discourse$ sudo ./launcher rebuild app
Fetching origin
Launcher is up-to-date
Stopping old container
+ /usr/bin/docker stop -t 60 app
app
cd /pups && git pull && /pups/bin/pups --stdin
Already up to date.
I, [2020-11-13T07:34:54.569773 #1] INFO -- : Loading --stdin
I, [2020-11-13T07:34:54.576058 #1] INFO -- : > locale-gen $LANG && update-locale
I, [2020-11-13T07:34:54.676810 #1] INFO -- : Generating locales (this might take a while)...
Generation complete.
I, [2020-11-13T07:34:54.677475 #1] INFO -- : > mkdir -p /shared/postgres_run
I, [2020-11-13T07:34:54.702215 #1] INFO -- :
I, [2020-11-13T07:34:54.703054 #1] INFO -- : > chown postgres:postgres /shared/postgres_run
I, [2020-11-13T07:34:54.712895 #1] INFO -- :
I, [2020-11-13T07:34:54.713681 #1] INFO -- : > chmod 775 /shared/postgres_run
I, [2020-11-13T07:34:54.717105 #1] INFO -- :
I, [2020-11-13T07:34:54.717680 #1] INFO -- : > rm -fr /var/run/postgresql
I, [2020-11-13T07:34:54.719943 #1] INFO -- :
I, [2020-11-13T07:34:54.720466 #1] INFO -- : > ln -s /shared/postgres_run /var/run/postgresql
I, [2020-11-13T07:34:54.723863 #1] INFO -- :
I, [2020-11-13T07:34:54.724449 #1] INFO -- : > socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1
2020/11/13 07:34:54 socat[27] E connect(6, AF=1 "/shared/postgres_run/.s.PGSQL.5432", 36): No such file or directory
I, [2020-11-13T07:34:54.791451 #1] INFO -- :
I, [2020-11-13T07:34:54.791940 #1] INFO -- : > rm -fr /shared/postgres_run/.s*
I, [2020-11-13T07:34:54.795116 #1] INFO -- :
I, [2020-11-13T07:34:54.795545 #1] INFO -- : > rm -fr /shared/postgres_run/*.pid
I, [2020-11-13T07:34:54.798154 #1] INFO -- :
I, [2020-11-13T07:34:54.798578 #1] INFO -- : > mkdir -p /shared/postgres_run/12-main.pg_stat_tmp
I, [2020-11-13T07:34:54.800772 #1] INFO -- :
I, [2020-11-13T07:34:54.801357 #1] INFO -- : > chown postgres:postgres /shared/postgres_run/12-main.pg_stat_tmp
I, [2020-11-13T07:34:54.803400 #1] INFO -- :
I, [2020-11-13T07:34:54.807557 #1] INFO -- : File > /etc/service/postgres/run chmod: +x chown:
I, [2020-11-13T07:34:54.811426 #1] INFO -- : File > /etc/service/postgres/log/run chmod: +x chown:
I, [2020-11-13T07:34:54.815457 #1] INFO -- : File > /etc/runit/3.d/99-postgres chmod: +x chown:
I, [2020-11-13T07:34:54.819414 #1] INFO -- : File > /root/upgrade_postgres chmod: +x chown:
I, [2020-11-13T07:34:54.820021 #1] INFO -- : > chown -R root /var/lib/postgresql/12/main
I, [2020-11-13T07:34:58.099992 #1] INFO -- :
I, [2020-11-13T07:34:58.100865 #1] INFO -- : > [ ! -e /shared/postgres_data ] && install -d -m 0755 -o postgres -g postgres /shared/postgres_data && sudo -E -u postgres /usr/lib/postgresql/12/bin/initdb -D /shared/postgres_data || exit 0
I, [2020-11-13T07:34:58.103259 #1] INFO -- :
I, [2020-11-13T07:34:58.103633 #1] INFO -- : > chown -R postgres:postgres /shared/postgres_data
I, [2020-11-13T07:34:58.125185 #1] INFO -- :
I, [2020-11-13T07:34:58.125939 #1] INFO -- : > chown -R postgres:postgres /var/run/postgresql
I, [2020-11-13T07:34:58.128600 #1] INFO -- :
I, [2020-11-13T07:34:58.129158 #1] INFO -- : > /root/upgrade_postgres
I, [2020-11-13T07:34:58.133295 #1] INFO -- :
I, [2020-11-13T07:34:58.133708 #1] INFO -- : > rm /root/upgrade_postgres
I, [2020-11-13T07:34:58.135503 #1] INFO -- :
I, [2020-11-13T07:34:58.136036 #1] INFO -- : Replacing data_directory = '/var/lib/postgresql/12/main' with data_directory = '/shared/postgres_data' in /etc/postgresql/12/main/postgresql.conf
I, [2020-11-13T07:34:58.136723 #1] INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addresses = '*' in /etc/postgresql/12/main/postgresql.conf
I, [2020-11-13T07:34:58.137998 #1] INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchronous_commit = $db_synchronous_commit in /etc/postgresql/12/main/postgresql.conf
I, [2020-11-13T07:34:58.138960 #1] INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffers = $db_shared_buffers in /etc/postgresql/12/main/postgresql.conf
I, [2020-11-13T07:34:58.139939 #1] INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work_mem in /etc/postgresql/12/main/postgresql.conf
I, [2020-11-13T07:34:58.140867 #1] INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with default_text_search_config = '$db_default_text_search_config' i
I, [2020-11-13T07:34:58.141833 #1] INFO -- : > install -d -m 0755 -o postgres -g postgres /shared/postgres_backup
I, [2020-11-13T07:34:58.144916 #1] INFO -- :
I, [2020-11-13T07:34:58.145559 #1] INFO -- : Replacing (?-mix:#?checkpoint_segments *=.*) with checkpoint_segments = $db_checkpoint_segments in /etc/postgresql/12/main/postgresql.conf
I, [2020-11-13T07:34:58.146076 #1] INFO -- : Replacing (?-mix:#?logging_collector *=.*) with logging_collector = $db_logging_collector in /etc/postgresql/12/main/postgresql.conf
I, [2020-11-13T07:34:58.147118 #1] INFO -- : Replacing (?-mix:#?log_min_duration_statement *=.*) with log_min_duration_statement = $db_log_min_duration_statement in /etc/postgresql/12/main/postgresql.conf
I, [2020-11-13T07:34:58.162784 #1] INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) with local replication postgres peer in /etc/postgresql/12/main/pg_hba.conf
I, [2020-11-13T07:34:58.163691 #1] INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/0 md5 in /etc/postgresql/12/main/pg_hba.conf
I, [2020-11-13T07:34:58.164784 #1] INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/12/bin/postmaster -D /etc/postgresql/12/main
I, [2020-11-13T07:34:58.166947 #1] INFO -- : > sleep 5
2020-11-13 07:34:58.208 UTC [50] LOG: starting PostgreSQL 12.4 (Debian 12.4-1.pgdg100+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 8.3.0-6) 8.3.0, 64-bit
2020-11-13 07:34:58.208 UTC [50] LOG: listening on IPv4 address "0.0.0.0", port 5432
2020-11-13 07:34:58.209 UTC [50] LOG: listening on IPv6 address "::", port 5432
2020-11-13 07:34:58.218 UTC [50] LOG: listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2020-11-13 07:34:58.302 UTC [53] LOG: database system was shut down at 2020-11-13 07:23:18 UTC
2020-11-13 07:34:58.321 UTC [50] LOG: database system is ready to accept connections
I, [2020-11-13T07:35:03.209924 #1] INFO -- :
I, [2020-11-13T07:35:03.222141 #1] INFO -- : > su postgres -c 'createdb discourse' || true
2020-11-13 07:35:03.575 UTC [63] postgres@postgres ERROR: database "discourse" already exists
2020-11-13 07:35:03.575 UTC [63] postgres@postgres STATEMENT: CREATE DATABASE discourse;
createdb: error: database creation failed: ERROR: database "discourse" already exists
I, [2020-11-13T07:35:03.578465 #1] INFO -- :
I, [2020-11-13T07:35:03.578976 #1] INFO -- : > su postgres -c 'psql discourse -c "create user discourse;"' || true
2020-11-13 07:35:03.644 UTC [74] postgres@discourse ERROR: role "discourse" already exists
2020-11-13 07:35:03.644 UTC [74] postgres@discourse STATEMENT: create user discourse;
I, [2020-11-13T07:35:03.646897 #1] INFO -- :
I, [2020-11-13T07:35:03.647407 #1] INFO -- : > su postgres -c 'psql discourse -c "grant all privileges on database discourse to discourse;"' || true
I, [2020-11-13T07:35:03.711432 #1] INFO -- : GRANT
I, [2020-11-13T07:35:03.712171 #1] INFO -- : > su postgres -c 'psql discourse -c "alter schema public owner to discourse;"'
I, [2020-11-13T07:35:03.782199 #1] INFO -- : ALTER SCHEMA
I, [2020-11-13T07:35:03.782901 #1] INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists hstore;"'
NOTICE: extension "hstore" already exists, skipping
I, [2020-11-13T07:35:03.847761 #1] INFO -- : CREATE EXTENSION
I, [2020-11-13T07:35:03.848327 #1] INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists pg_trgm;"'
NOTICE: extension "pg_trgm" already exists, skipping
I, [2020-11-13T07:35:03.909805 #1] INFO -- : CREATE EXTENSION
I, [2020-11-13T07:35:03.910376 #1] INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists hstore;"'
I, [2020-11-13T07:35:03.972494 #1] INFO -- : CREATE EXTENSION
I, [2020-11-13T07:35:03.973165 #1] INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists pg_trgm;"'
I, [2020-11-13T07:35:04.035738 #1] INFO -- : CREATE EXTENSION
I, [2020-11-13T07:35:04.036418 #1] INFO -- : > sudo -u postgres psql discourse
I, [2020-11-13T07:35:04.055691 #1] INFO -- : update pg_database set encoding = pg_char_to_encoding('UTF8') where datname = 'discourse' AND encoding = pg_char_to_encoding('SQL_ASCII');
I, [2020-11-13T07:35:04.147941 #1] INFO -- : File > /var/lib/postgresql/take-database-backup chmod: +x chown: postgres:postgres
I, [2020-11-13T07:35:04.150956 #1] INFO -- : File > /var/spool/cron/crontabs/postgres chmod: chown:
I, [2020-11-13T07:35:04.151502 #1] INFO -- : > echo postgres installed!
I, [2020-11-13T07:35:04.167002 #1] INFO -- : postgres installed!
I, [2020-11-13T07:35:04.172330 #1] INFO -- : File > /etc/service/redis/run chmod: +x chown:
I, [2020-11-13T07:35:04.176723 #1] INFO -- : File > /etc/service/redis/log/run chmod: +x chown:
I, [2020-11-13T07:35:04.181121 #1] INFO -- : File > /etc/runit/3.d/10-redis chmod: +x chown:
I, [2020-11-13T07:35:04.182910 #1] INFO -- : Replacing daemonize yes with in /etc/redis/redis.conf
I, [2020-11-13T07:35:04.183837 #1] INFO -- : Replacing (?-mix:^pidfile.*$) with in /etc/redis/redis.conf
I, [2020-11-13T07:35:04.185609 #1] INFO -- : > install -d -m 0755 -o redis -g redis /shared/redis_data
I, [2020-11-13T07:35:04.225330 #1] INFO -- :
I, [2020-11-13T07:35:04.226369 #1] INFO -- : Replacing (?-mix:^logfile.*$) with logfile "" in /etc/redis/redis.conf
I, [2020-11-13T07:35:04.227109 #1] INFO -- : Replacing (?-mix:^bind .*$) with in /etc/redis/redis.conf
I, [2020-11-13T07:35:04.229259 #1] INFO -- : Replacing (?-mix:^dir .*$) with dir /shared/redis_data in /etc/redis/redis.conf
I, [2020-11-13T07:35:04.230796 #1] INFO -- : Replacing (?-mix:^protected-mode yes) with protected-mode no in /etc/redis/redis.conf
I, [2020-11-13T07:35:04.232306 #1] INFO -- : Replacing # io-threads 4 with io-threads $redis_io_threads in /etc/redis/redis.conf
I, [2020-11-13T07:35:04.233981 #1] INFO -- : > echo redis installed
I, [2020-11-13T07:35:04.236684 #1] INFO -- : redis installed
I, [2020-11-13T07:35:04.237270 #1] INFO -- : > cat /etc/redis/redis.conf | grep logfile
I, [2020-11-13T07:35:04.263966 #1] INFO -- : logfile ""
I, [2020-11-13T07:35:04.264740 #1] INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2020-11-13T07:35:04.266909 #1] INFO -- : > sleep 10
167:C 13 Nov 2020 07:35:04.374 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
167:C 13 Nov 2020 07:35:04.375 # Redis version=5.0.9, bits=64, commit=00000000, modified=0, pid=167, just started
167:C 13 Nov 2020 07:35:04.375 # Configuration loaded
_._
_.-``__ ''-._
_.-`` `. `_. ''-._ Redis 5.0.9 (00000000/0) 64 bit
.-`` .-```. ```\/ _.,_ ''-._
( ' , .-` | `, ) Running in standalone mode
|`-._`-...-` __...-.``-._|'` _.-'| Port: 6379
| `-._ `._ / _.-' | PID: 167
`-._ `-._ `-./ _.-' _.-'
|`-._`-._ `-.__.-' _.-'_.-'|
| `-._`-._ _.-'_.-' | http://redis.io
`-._ `-._`-.__.-'_.-' _.-'
| `-._`-._ _.-'_.-' |
`-._ `-.__.-' _.-'
`-._ _.-'
`-.__.-'
167:M 13 Nov 2020 07:35:04.379 # WARNING: The TCP backlog setting of 511 cannot be enforced because /proc/sys/net/core/somaxconn is set to the lower value of 128.
167:M 13 Nov 2020 07:35:04.379 # Server initialized
167:M 13 Nov 2020 07:35:04.379 # WARNING you have Transparent Huge Pages (THP) support enabled in your kernel. This will create latency and memory usage issues with Redis. To fix this issue run the command 'echo never > /sys/kernel/mm/transparent_hugepage/enabled' as root, and add it to your /etc/rc.local in order to retain the setting after a reboot. Redis must be restarted after THP is disabled.
167:M 13 Nov 2020 07:35:04.498 * DB loaded from disk: 0.118 seconds
167:M 13 Nov 2020 07:35:04.498 * Ready to accept connections
I, [2020-11-13T07:35:14.270726 #1] INFO -- :
I, [2020-11-13T07:35:14.271660 #1] INFO -- : Terminating async processes
I, [2020-11-13T07:35:14.271971 #1] INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/12/bin/postmaster -D /etc/postgresql/12/main pid: 50
I, [2020-11-13T07:35:14.272236 #1] INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 167
2020-11-13 07:35:14.272 UTC [50] LOG: received fast shutdown request
167:signal-handler (1605252914) Received SIGTERM scheduling shutdown...
2020-11-13 07:35:14.276 UTC [50] LOG: aborting any active transactions
2020-11-13 07:35:14.278 UTC [50] LOG: background worker "logical replication launcher" (PID 59) exited with exit code 1
2020-11-13 07:35:14.283 UTC [54] LOG: shutting down
2020-11-13 07:35:14.312 UTC [50] LOG: database system is shut down
167:M 13 Nov 2020 07:35:14.331 # User requested shutdown...
167:M 13 Nov 2020 07:35:14.331 * Saving the final RDB snapshot before exiting.
167:M 13 Nov 2020 07:35:14.369 * DB saved on disk
167:M 13 Nov 2020 07:35:14.370 # Redis is now ready to exit, bye bye...
FAILED
Errno::ENOENT: No such file or directory @ rb_sysopen - /usr/local/etc/ImageMagick-6/policy.xml
Location of failure: /pups/lib/pups/replace_command.rb:8:in `read'
replace failed with the params {"filename"=>"/usr/local/etc/ImageMagick-6/policy.xml", "from"=>"<policymap>", "to"=>"<policymap>\n <policy domain=\"coder\" rights=\"none\" pattern=\"EPHEMERAL\" />\n <policy domain=\"coder\" rights=\"none\" pattern=\"URL\" />\n <policy domain=\"coder\" rights=\"none\" pattern=\"HTTPS\" />\n <policy domain=\"coder\" rights=\"none\" pattern=\"MVG\" />\n <policy domain=\"coder\" rights=\"none\" pattern=\"MSL\" />\n <policy domain=\"coder\" rights=\"none\" pattern=\"TEXT\" />\n <policy domain=\"coder\" rights=\"none\" pattern=\"SHOW\" />\n <policy domain=\"coder\" rights=\"none\" pattern=\"WIN\" />\n <policy domain=\"coder\" rights=\"none\" pattern=\"PLT\" />\n"}
8a2b7a84ea2ce73e8438d1a8ba1209227b633c0797880d18ca3b5e49d60f1007
