Impossibile ripristinare dal backup perché il file di backup è stato rinominato
Getting the below error when I try to restore data from backup. Pls help.
 Copying archive to tmp directory...
    Unzipping archive, this may take a while...
    tar: meta.json: Not found in archive
    tar: Exiting with failure status due to previous errors
    No metadata file to extract.
    EXCEPTION: Migration version is missing from the filename.
    /var/www/discourse/lib/backup_restore/restorer.rb:226:in `extract_metadata'
    /var/www/discourse/lib/backup_restore/restorer.rb:54:in `run'
    script/discourse:136:in `restore'
    /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/thor-0.19.4/lib/thor/command.rb:27:in `run'
    /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/thor-0.19.4/lib/thor/invocation.rb:126:in `invoke_command'
    /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/thor-0.19.4/lib/thor.rb:369:in `dispatch'
    /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/thor-0.19.4/lib/thor/base.rb:444:in `start'
    script/discourse:277:in `<top (required)>'
    /usr/local/lib/ruby/gems/2.5.0/gems/bundler-1.17.1/lib/bundler/cli/exec.rb:74:in `load'
    /usr/local/lib/ruby/gems/2.5.0/gems/bundler-1.17.1/lib/bundler/cli/exec.rb:74:in `kernel_load'
    /usr/local/lib/ruby/gems/2.5.0/gems/bundler-1.17.1/lib/bundler/cli/exec.rb:28:in `run'
    /usr/local/lib/ruby/gems/2.5.0/gems/bundler-1.17.1/lib/bundler/cli.rb:463:in `exec'
    /usr/local/lib/ruby/gems/2.5.0/gems/bundler-1.17.1/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
    /usr/local/lib/ruby/gems/2.5.0/gems/bundler-1.17.1/lib/bundler/vendor/thor/lib/thor/invocation.rb:126:in `invoke_command'
    /usr/local/lib/ruby/gems/2.5.0/gems/bundler-1.17.1/lib/bundler/vendor/thor/lib/thor.rb:387:in `dispatch'
    /usr/local/lib/ruby/gems/2.5.0/gems/bundler-1.17.1/lib/bundler/cli.rb:27:in `dispatch'
    /usr/local/lib/ruby/gems/2.5.0/gems/bundler-1.17.1/lib/bundler/vendor/thor/lib/thor/base.rb:466:in `start'
    /usr/local/lib/ruby/gems/2.5.0/gems/bundler-1.17.1/lib/bundler/cli.rb:18:in `start'
    /usr/local/lib/ruby/gems/2.5.0/gems/bundler-1.17.1/exe/bundle:30:in `block in <top (required)>'
    /usr/local/lib/ruby/gems/2.5.0/gems/bundler-1.17.1/lib/bundler/friendly_errors.rb:124:in `with_friendly_errors'
    /usr/local/lib/ruby/gems/2.5.0/gems/bundler-1.17.1/exe/bundle:22:in `<top (required)>'
    /usr/local/bin/bundle:23:in `load'
    /usr/local/bin/bundle:23:in `<main>'
    Trying to rollback...
    There was no need to rollback
    Cleaning stuff up...
    Removing tmp '/var/www/discourse/tmp/restores/default/2018-12-07-125822' directory...
    Unpausing sidekiq...
    Marking restore as finished...
    Notifying 'system' of the end of the restore...
    Finished!
    [FAILED]
    Restore done.
Did you rename the backup file?
5 Mi Piace
I’m not sure about renaming. Maybe. Does it affects?
Yes, it stops the restore from working. That’s why you’re seeing the following error message.
Can you rename it back to the original filename?
6 Mi Piace
I don’t know the original filename. Also, I don’t have access to old server. I’ve the .gz backup file only.
Any way to find the filename or any other way resolve this??
Thank you.
1 Mi Piace
Open the backup file and extract the dump.sql file from the dump.sql.gz. Open the dump.sql file and look for a block of numbers that gets inserted into the schema_migrations table.
COPY public.schema_migrations (version) FROM stdin;
20000225050318
20120311163914
20120311164326
20181031165343
20181112013117
20181120140552
Take the highest number and append it to your backup file. Make sure to prefix the number with -v. For example, it might look like this: mybackup-v20181120140552.tar.gz
10 Mi Piace
Thanks a ton man. :pray: :pray: :pray: :pray:
4 Mi Piace
