Échec de la mise à niveau vers v2.9.0beta3
Depuis la v2.9.0beta2 sur une configuration multisite et multi-conteneurs :
== 20220304162250 EnableUnaccentExtension : migration =========
-- enable_extension("unaccent")
Docker Manager : ÉCHEC DE LA MISE À NIVEAU
#<RuntimeError: RuntimeError>
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:203:in `run'
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:101:in `upgrade'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:19:in `block in <main>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.1/lib/active_support/fork_tracker.rb:10:in `block in fork'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.1/lib/active_support/fork_tracker.rb:8:in `fork'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.1/lib/active_support/fork_tracker.rb:27:in `fork'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:6:in `<main>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.10.3/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:48:in `load'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/commands/runner/runner_command.rb:42:in `perform'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/thor-1.2.1/lib/thor/command.rb:27:in `run'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/thor-1.2.1/lib/thor/invocation.rb:127:in `invoke_command'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/thor-1.2.1/lib/thor.rb:392:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/command/base.rb:69:in `perform'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/command.rb:48:in `invoke'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/railties-6.1.4.1/lib/rails/commands.rb:18:in `<main>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bootsnap-1.10.3/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:30:in `require'
bin/rails:18:in `<main>'
Quelle version de Postgres utilisez-vous ?
root@ps-data:/# psql --version
psql (PostgreSQL) 10.20 (Debian 10.20-1.pgdg110+1)
data reconstruit avec succès avec :
./launcher stop web_only; ./launcher stop data; ./launcher rebuild data; ./launcher rebuild data
Mais ensuite web_only échoue au démarrage avec une erreur OP.
Suivi des instructions pour la mise à niveau de PostgreSQL 13 update
les valeurs lc_collate pour la base de données « postgres » ne correspondent pas : ancienne « en_GB.UTF-8 », nouvelle « en_US.UTF-8 »
Échec, sortie
Selon PostgreSQL 13 update, notez la dernière ligne
Les valeurs de lc_collate pour la base de données « postgres » ne correspondent pas
Cette erreur se produit si vous utilisez des locales non par défaut pour votre base de données. Il a été signalé que vous aviez besoin de 3 variables pour que cela réussisse. Assurez-vous que la section env: de votre fichier app.yml contient les 3 lignes :
  LC_ALL: en_US.UTF-8
  LANG: en_US.UTF-8
  LANGUAGE: en_US.UTF-8
En remplaçant en_US.UTF-8 par votre locale.
