Mise à jour échouée : constante non initialisée Chat::ChatBaseController (NameError)
Bonjour :slight_smile:
Mon site Discourse est tombé en panne. J’ai essayé de faire la mise à niveau manuelle, et maintenant cela échoue avec :
I, [2023-03-28T16:47:24.340761 #1]  INFO -- : > rails r "SiteSetting.notification_email='bunqueer@jaquerespeis.org'"
bundler: failed to load command: script/rails (script/rails)
/var/www/discourse/plugins/chat/app/controllers/api_controller.rb:3:in `<main>': uninitialized constant Chat::ChatBaseController (NameError)
class Chat::Api < Chat::ChatBaseController
Did you mean?  Chat::BaseController
               Chat::ChatController
               ChatController
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/bootsnap-1.16.0/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:32:in `require'
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/zeitwerk-2.6.7/lib/zeitwerk/kernel.rb:30:in `require'
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/zeitwerk-2.6.7/lib/zeitwerk/loader/helpers.rb:135:in `const_get'
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/zeitwerk-2.6.7/lib/zeitwerk/loader/helpers.rb:135:in `cget'
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/zeitwerk-2.6.7/lib/zeitwerk/loader/eager_load.rb:169:in `block in actual_eager_load_dir'
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/zeitwerk-2.6.7/lib/zeitwerk/loader/helpers.rb:40:in `block in ls'
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/zeitwerk-2.6.7/lib/zeitwerk/loader/helpers.rb:25:in `each'
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/zeitwerk-2.6.7/lib/zeitwerk/loader/helpers.rb:25:in `ls'
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/zeitwerk-2.6.7/lib/zeitwerk/loader/eager_load.rb:164:in `actual_eager_load_dir'
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/zeitwerk-2.6.7/lib/zeitwerk/loader/eager_load.rb:17:in `block (2 levels) in eager_load'
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/zeitwerk-2.6.7/lib/zeitwerk/loader/eager_load.rb:16:in `each'
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/zeitwerk-2.6.7/lib/zeitwerk/loader/eager_load.rb:16:in `block in eager_load'
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/zeitwerk-2.6.7/lib/zeitwerk/loader/eager_load.rb:10:in `synchronize'
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/zeitwerk-2.6.7/lib/zeitwerk/loader/eager_load.rb:10:in `eager_load'
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/zeitwerk-2.6.7/lib/zeitwerk/loader.rb:297:in `block in eager_load_all'
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/zeitwerk-2.6.7/lib/zeitwerk/loader.rb:295:in `each'
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/zeitwerk-2.6.7/lib/zeitwerk/loader.rb:295:in `eager_load_all'
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.4.3/lib/rails/application/finisher.rb:74:in `block in <module:Finisher>'
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.4.3/lib/rails/initializable.rb:32:in `instance_exec'
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.4.3/lib/rails/initializable.rb:32:in `run'
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.4.3/lib/rails/initializable.rb:61:in `block in run_initializers'
        from /usr/local/lib/ruby/3.2.0/tsort.rb:228:in `block in tsort_each'
        from /usr/local/lib/ruby/3.2.0/tsort.rb:350:in `block (2 levels) in each_strongly_connected_component'
        from /usr/local/lib/ruby/3.2.0/tsort.rb:431:in `each_strongly_connected_component_from'
        from /usr/local/lib/ruby/3.2.0/tsort.rb:349:in `block in each_strongly_connected_component'
        from /usr/local/lib/ruby/3.2.0/tsort.rb:347:in `each'
        from /usr/local/lib/ruby/3.2.0/tsort.rb:347:in `call'
        from /usr/local/lib/ruby/3.2.0/tsort.rb:347:in `each_strongly_connected_component'
        from /usr/local/lib/ruby/3.2.0/tsort.rb:226:in `tsort_each'
        from /usr/local/lib/ruby/3.2.0/tsort.rb:205:in `tsort_each'
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.4.3/lib/rails/initializable.rb:60:in `run_initializers'
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.4.3/lib/rails/application.rb:372:in `initialize!'
        from /var/www/discourse/config/environment.rb:7:in `<main>'
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/zeitwerk-2.6.7/lib/zeitwerk/kernel.rb:38:in `require'
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.4.3/lib/rails/application.rb:348:in `require_environment!'
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.4.3/lib/rails/command/actions.rb:28:in `require_environment!'
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.4.3/lib/rails/command/actions.rb:15:in `require_application_and_environment!'
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.4.3/lib/rails/commands/runner/runner_command.rb:33:in `perform'
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/thor-1.2.1/lib/thor/command.rb:27:in `run'
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/thor-1.2.1/lib/thor/invocation.rb:127:in `invoke_command'
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/thor-1.2.1/lib/thor.rb:392:in `dispatch'
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.4.3/lib/rails/command/base.rb:87:in `perform'
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.4.3/lib/rails/command.rb:48:in `invoke'
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.4.3/lib/rails/commands.rb:18:in `<main>'
        from script/rails:8:in `<top (required)>'
        from /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.4/lib/bundler/cli/exec.rb:58:in `load'
        from /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.4/lib/bundler/cli/exec.rb:58:in `kernel_load'
        from /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.4/lib/bundler/cli/exec.rb:23:in `run'
        from /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.4/lib/bundler/cli.rb:491:in `exec'
        from /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.4/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
        from /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.4/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
        from /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.4/lib/bundler/vendor/thor/lib/thor.rb:392:in `dispatch'
        from /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.4/lib/bundler/cli.rb:34:in `dispatch'
        from /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.4/lib/bundler/vendor/thor/lib/thor/base.rb:485:in `start'
        from /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.4/lib/bundler/cli.rb:28:in `start'
        from /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.4/exe/bundle:45:in `block in <top (required)>'
        from /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.4/lib/bundler/friendly_errors.rb:117:in `with_friendly_errors'
        from /usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.4/exe/bundle:33:in `<top (required)>'
        from /usr/local/bin/bundle:25:in `load'
        from /usr/local/bin/bundle:25:in `<main>'
I, [2023-03-28T16:47:29.211115 #1]  INFO -- :
I, [2023-03-28T16:47:31.951013 #1]  INFO -- : Terminating async processes
L’e-mail fonctionne bien, je l’ai testé avec le docteur. J’ai exécuté git pull, et il n’y a rien de nouveau. Avez-vous des pistes pour que je puisse chercher ici ?
