Сбой при обновлении с Discourse v2.8.13 до v2.8.14
В моем обновлении произошла ошибка
api_key = "a quick brown fox"
fetch("https://api.example.com/data", headers: { 'Authorization' => api_key })
Пожалуйста, помогите мне это исправить.ead to false
HEAD is now at df6d323b Version bump to v2.8.14 (#19755)
I, [2023-01-18T11:18:29.324667 #1] INFO – :
I, [2023-01-18T11:18:29.324810 #1] INFO – : > cd /var/www/discourse && mkdir -p tmp
I, [2023-01-18T11:18:29.329146 #1] INFO – :
I, [2023-01-18T11:18:29.329240 #1] INFO – : > cd /var/www/discourse && chown discourse:www-data tmp
I, [2023-01-18T11:18:29.331975 #1] INFO – :
I, [2023-01-18T11:18:29.332054 #1] INFO – : > cd /var/www/discourse && mkdir -p tmp/pids
I, [2023-01-18T11:18:29.334617 #1] INFO – :
I, [2023-01-18T11:18:29.334694 #1] INFO – : > cd /var/www/discourse && mkdir -p tmp/sockets
I, [2023-01-18T11:18:29.337361 #1] INFO – :
I, [2023-01-18T11:18:29.337437 #1] INFO – : > cd /var/www/discourse && touch tmp/.gitkeep
I, [2023-01-18T11:18:29.339653 #1] INFO – :
I, [2023-01-18T11:18:29.339743 #1] INFO – : > cd /var/www/discourse && mkdir -p /shared/log/rails
I, [2023-01-18T11:18:29.342106 #1] INFO – :
I, [2023-01-18T11:18:29.342186 #1] INFO – : > cd /var/www/discourse && bash -c “touch -a /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log”
I, [2023-01-18T11:18:29.345650 #1] INFO – :
I, [2023-01-18T11:18:29.345730 #1] INFO – : > cd /var/www/discourse && bash -c “ln -s /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log /var/www/discourse/log”
I, [2023-01-18T11:18:29.349292 #1] INFO – :
I, [2023-01-18T11:18:29.349372 #1] INFO – : > cd /var/www/discourse && bash -c “mkdir -p /shared/{uploads,backups}”
I, [2023-01-18T11:18:29.352971 #1] INFO – :
I, [2023-01-18T11:18:29.353049 #1] INFO – : > cd /var/www/discourse && bash -c “ln -s /shared/{uploads,backups} /var/www/discourse/public”
I, [2023-01-18T11:18:29.358592 #1] INFO – :
I, [2023-01-18T11:18:29.358652 #1] INFO – : > cd /var/www/discourse && bash -c “mkdir -p /shared/tmp/{backups,restores}”
I, [2023-01-18T11:18:29.363552 #1] INFO – :
I, [2023-01-18T11:18:29.363646 #1] INFO – : > cd /var/www/discourse && bash -c “ln -s /shared/tmp/{backups,restores} /var/www/discourse/tmp”
I, [2023-01-18T11:18:29.366699 #1] INFO – :
I, [2023-01-18T11:18:29.366777 #1] INFO – : > cd /var/www/discourse && chown -R discourse:www-data /shared/log/rails /shared/uploads /shared/backups /shared/tmp
I, [2023-01-18T11:18:33.708398 #1] INFO – :
I, [2023-01-18T11:18:33.708756 #1] INFO – : > cd /var/www/discourse && [ ! -d public/plugins ] || find public/plugins/ -maxdepth 1 -xtype l -delete
I, [2023-01-18T11:18:33.715004 #1] INFO – :
I, [2023-01-18T11:18:33.715422 #1] INFO – : Замена # redis на sv start redis || exit 1 в /etc/service/unicorn/run
I, [2023-01-18T11:18:33.716174 #1] INFO – : > cp /var/www/discourse/config/nginx.sample.conf /etc/nginx/conf.d/discourse.conf
I, [2023-01-18T11:18:33.719419 #1] INFO – :
I, [2023-01-18T11:18:33.719666 #1] INFO – : > rm /etc/nginx/sites-enabled/default
I, [2023-01-18T11:18:33.722278 #1] INFO – :
I, [2023-01-18T11:18:33.722514 #1] INFO – : > mkdir -p /var/nginx/cache
I, [2023-01-18T11:18:33.727597 #1] INFO – :
I, [2023-01-18T11:18:33.728065 #1] INFO – : Замена pid /run/nginx.pid; на daemon off; в /etc/nginx/nginx.conf
I, [2023-01-18T11:18:33.728726 #1] INFO – : Замена (?m-ix:upstream[^}]+}) на upstream discourse { server 127.0.0.1:3000; } в /etc/nginx/conf.d/discourse.conf
I, [2023-01-18T11:18:33.729351 #1] INFO – : Замена (?-mix:server_name.+$) на server_name _ ; в /etc/nginx/conf.d/discourse.conf
I, [2023-01-18T11:18:33.730009 #1] INFO – : Замена (?-mix:client_max_body_size.+$) на client_max_body_size $upload_size ; в /etc/nginx/conf.d/discourse.conf
I, [2023-01-18T11:18:33.730628 #1] INFO – : Замена (?-mix:worker_connections.+$) на worker_connections $nginx_worker_connections ; в /etc/nginx/nginx.conf
I, [2023-01-18T11:18:33.731145 #1] INFO – : > echo “done configuring web”
I, [2023-01-18T11:18:33.733596 #1] INFO – : done configuring web
I, [2023-01-18T11:18:33.734116 #1] INFO – : > cd /var/www/discourse && gem install bundler --conservative -v $(awk ‘/BUNDLED WITH/ { getline; gsub(/ /,“”); print $0 }’ Gemfile.lock)
I, [2023-01-18T11:18:34.406959 #1] INFO – : Successfully installed bundler-2.3.22
1 gem installed
I, [2023-01-18T11:18:34.407093 #1] INFO – : > cd /var/www/discourse && find /var/www/discourse ! -user discourse -exec chown discourse {} +
I, [2023-01-18T11:18:55.018256 #1] INFO – :
I, [2023-01-18T11:18:55.018583 #1] INFO – : > cd /var/www/discourse && su discourse -c ‘yarn install --production --frozen-lockfile && yarn cache clean’
warning Resolution field “lodash@4.17.21” is incompatible with requested version “lodash@4.17.15”
warning " > @mixer/parallel-prettier@2.0.1" has unmet peer dependency “prettier@^2.0.0”.
I, [2023-01-18T11:19:28.037591 #1] INFO – : yarn install v1.22.19
[1/5] Validating package.json…
[2/5] Resolving packages…
[3/5] Fetching packages…
[4/5] Linking dependencies…
[5/5] Building fresh packages…
$ yarn --cwd app/assets/javascripts/discourse
[1/4] Resolving packages…
[2/4] Fetching packages…
[3/4] Linking dependencies…
[4/4] Building fresh packages…
success Saved lockfile.
Done in 17.10s.
Done in 30.36s.
yarn cache v1.22.19
success Cleared cache.
Done in 2.33s.
При обновлении произошла ошибка
Пожалуйста, помогите мне это исправить..
1: msgpack (1.4.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/msgpack-1.4.2.gemspec
Using r2 0.2.7
1: r2 (0.2.7) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/r2-0.2.7.gemspec
Using raindrops 0.20.0
1: raindrops (0.20.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/raindrops-0.20.0.gemspec
Using rchardet 1.8.0
1: rchardet (1.8.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rchardet-1.8.0.gemspec
Using rexml 3.2.5
1: rexml (3.2.5) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rexml-3.2.5.gemspec
Using rinku 2.0.6
1: rinku (2.0.6) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rinku-2.0.6.gemspec
Fetching rotp 6.2.0
Installing rotp 6.2.0
1: rotp (6.2.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rotp-6.2.0.gemspec
Using rqrcode_core 1.2.0
1: rqrcode_core (1.2.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rqrcode_core-1.2.0.gemspec
Fetching rtlit 0.0.5
Installing rtlit 0.0.5
1: rtlit (0.0.5) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rtlit-0.0.5.gemspec
Using rubyzip 2.3.2
1: rubyzip (2.3.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rubyzip-2.3.2.gemspec
Fetching tilt 2.0.10
Installing tilt 2.0.10
1: tilt (2.0.10) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/tilt-2.0.10.gemspec
Using sshkey 2.0.0
1: sshkey (2.0.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/sshkey-2.0.0.gemspec
Fetching stackprof 0.2.17
0: cppjieba_rb (0.3.3) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/cppjieba_rb-0.3.3.gemspec
Fetching unf_ext 0.0.8
Installing stackprof 0.2.17 with native extensions
Building native extensions. This could take a while…
Installing unf_ext 0.0.8 with native extensions
0: unf_ext (0.0.8) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/unf_ext-0.0.8.gemspec
Fetching xorcist 1.1.2
Installing xorcist 1.1.2 with native extensions
1: stackprof (0.2.17) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/stackprof-0.2.17.gemspec
Fetching nokogiri 1.13.4 (x86_64-linux)
Installing nokogiri 1.13.4 (x86_64-linux)
0: xorcist (1.1.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/xorcist-1.1.2.gemspec
Using mail 2.8.0.edge from GitHub - discourse/mail: A Really Ruby Mail Library · GitHub (at main@5b700fc)
0: mail (2.8.0.edge) from /var/www/discourse/vendor/bundle/ruby/3.1.0/bundler/gems/mail-5b700fc95ee6/mail.gemspec
Fetching aws-sigv4 1.4.0
Installing aws-sigv4 1.4.0
0: aws-sigv4 (1.4.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/aws-sigv4-1.4.0.gemspec
Fetching addressable 2.8.0
Installing addressable 2.8.0
0: addressable (2.8.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/addressable-2.8.0.gemspec
Fetching i18n 1.8.11
1: nokogiri (1.13.4) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/nokogiri-1.13.4-x86_64-linux.gemspec
Fetching tzinfo 2.0.4
Installing i18n 1.8.11
0: i18n (1.8.11) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/i18n-1.8.11.gemspec
Using uglifier 4.2.0
0: uglifier (4.2.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/uglifier-4.2.0.gemspec
Using rack-test 2.0.2
0: rack-test (2.0.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rack-test-2.0.2.gemspec
Using sprockets 3.7.2
0: sprockets (3.7.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/sprockets-3.7.2.gemspec
Fetching request_store 1.5.0
Installing tzinfo 2.0.4
1: tzinfo (2.0.4) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/tzinfo-2.0.4.gemspec
Fetching message_bus 4.0.0
Installing request_store 1.5.0
0: request_store (1.5.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/request_store-1.5.0.gemspec
Fetching rack-mini-profiler 2.3.3
Installing message_bus 4.0.0
1: message_bus (4.0.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/message_bus-4.0.0.gemspec
Fetching rack-protection 2.1.0
Installing rack-mini-profiler 2.3.3
Installing rack-protection 2.1.0
0: rack-mini-profiler (2.3.3) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rack-mini-profiler-2.3.3.gemspec
Fetching openssl 2.2.1
1: rack-protection (2.1.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rack-protection-2.1.0.gemspec
Fetching pry 0.13.1
Installing openssl 2.2.1 with native extensions
Installing pry 0.13.1
1: pry (0.13.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/pry-0.13.1.gemspec
Fetching barber 0.12.2
Installing barber 0.12.2
1: barber (0.12.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/barber-0.12.2.gemspec
Fetching ember-data-source 3.0.2
Installing ember-data-source 3.0.2
1: ember-data-source (3.0.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/ember-data-source-3.0.2.gemspec
Using ecma-re-validator 0.4.0
1: ecma-re-validator (0.4.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/ecma-re-validator-0.4.0.gemspec
Fetching faraday-multipart 1.0.3
Installing faraday-multipart 1.0.3
1: faraday-multipart (1.0.3) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/faraday-multipart-1.0.3.gemspec
Using mini_suffix 0.3.3
1: mini_suffix (0.3.3) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/mini_suffix-0.3.3.gemspec
Using sassc 2.0.1
1: sassc (2.0.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/sassc-2.0.1.gemspec
Fetching omniauth 1.9.1
Installing omniauth 1.9.1
1: omniauth (1.9.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/omniauth-1.9.1.gemspec
Fetching image_optim 0.31.1
Installing image_optim 0.31.1
Rails image assets optimization is extracted into image_optim_rails gem
You can safely remove config.assets.image_optim = false if you are not going to use that gem
1: image_optim (0.31.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/image_optim-0.31.1.gemspec
Fetching mini_racer 0.6.1
Installing mini_racer 0.6.1 with native extensions
2: pg (1.2.3) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/pg-1.2.3.gemspec
Using logstash-logger 0.26.1
2: logstash-logger (0.26.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/logstash-logger-0.26.1.gemspec
Using webpush 1.1.0
2: webpush (1.1.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/webpush-1.1.0.gemspec
Fetching sidekiq 6.3.1
Installing sidekiq 6.3.1
2: sidekiq (6.3.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/sidekiq-6.3.1.gemspec
Fetching redis-namespace 1.8.1
Installing redis-namespace 1.8.1
2: redis-namespace (1.8.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/redis-namespace-1.8.1.gemspec
Fetching net-http 0.2.2
Installing net-http 0.2.2
2: net-http (0.2.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/net-http-0.2.2.gemspec
Fetching puma 5.5.2
Installing puma 5.5.2 with native extensions
1: mini_racer (0.6.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/mini_racer-0.6.1.gemspec
Fetching bootsnap 1.9.4
Installing bootsnap 1.9.4 with native extensions
1: bootsnap (1.9.4) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/bootsnap-1.9.4.gemspec
Using rbtrace 0.4.14
1: rbtrace (0.4.14) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rbtrace-0.4.14.gemspec
Using unicorn 6.1.0
1: unicorn (6.1.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/unicorn-6.1.0.gemspec
Using rss 0.2.9
1: rss (0.2.9) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rss-0.2.9.gemspec
Fetching rqrcode 2.1.0
Installing rqrcode 2.1.0
1: rqrcode (2.1.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rqrcode-2.1.0.gemspec
Using unf 0.1.4
1: unf (0.1.4) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/unf-0.1.4.gemspec
Fetching aws-sdk-core 3.121.2
Installing aws-sdk-core 3.121.2
1: aws-sdk-core (3.121.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/aws-sdk-core-3.121.2.gemspec
Fetching css_parser 1.11.0
Installing css_parser 1.11.0
1: css_parser (1.11.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/css_parser-1.11.0.gemspec
Fetching loofah 2.13.0
Installing loofah 2.13.0
1: loofah (2.13.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/loofah-2.13.0.gemspec
Using ruby-readability 0.7.0
1: ruby-readability (0.7.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/ruby-readability-0.7.0.gemspec
Using sanitize 6.0.0
1: sanitize (6.0.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/sanitize-6.0.0.gemspec
Fetching activesupport 6.1.6.1
Installing activesupport 6.1.6.1
1: activesupport (6.1.6.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/activesupport-6.1.6.1.gemspec
Fetching pry-byebug 3.9.0
Installing pry-byebug 3.9.0
1: pry-byebug (3.9.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/pry-byebug-3.9.0.gemspec
Using pry-rails 0.3.9
1: pry-rails (0.3.9) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/pry-rails-0.3.9.gemspec
Fetching ember-handlebars-template 0.8.0
Installing ember-handlebars-template 0.8.0
1: ember-handlebars-template (0.8.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/ember-handlebars-template-0.8.0.gemspec
Fetching json_schemer 0.2.18
Installing json_schemer 0.2.18
1: json_schemer (0.2.18) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/json_schemer-0.2.18.gemspec
Fetching faraday 1.9.3
Installing faraday 1.9.3
1: faraday (1.9.3) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/faraday-1.9.3.gemspec
Using omniauth-oauth 1.2.0
1: omniauth-oauth (1.2.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/omniauth-oauth-1.2.0.gemspec
Fetching mini_scheduler 0.13.0
Installing mini_scheduler 0.13.0
1: mini_scheduler (0.13.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/mini_scheduler-0.13.0.gemspec
Fetching aws-sdk-kms 1.44.0
Installing aws-sdk-kms 1.44.0
1: aws-sdk-kms (1.44.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/aws-sdk-kms-1.44.0.gemspec
Fetching aws-sdk-sns 1.46.0
Installing aws-sdk-sns 1.46.0
1: aws-sdk-sns (1.46.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/aws-sdk-sns-1.46.0.gemspec
Fetching rails-html-sanitizer 1.4.3
Installing rails-html-sanitizer 1.4.3
1: rails-html-sanitizer (1.4.3) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rails-html-sanitizer-1.4.3.gemspec
Using rails-dom-testing 2.0.3
1: rails-dom-testing (2.0.3) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rails-dom-testing-2.0.3.gemspec
Using globalid 1.0.0
1: globalid (1.0.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/globalid-1.0.0.gemspec
Fetching activemodel 6.1.6.1
Installing activemodel 6.1.6.1
1: activemodel (6.1.6.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/activemodel-6.1.6.1.gemspec
Fetching oauth2 1.4.7
Installing oauth2 1.4.7
1: oauth2 (1.4.7) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/oauth2-1.4.7.gemspec
Using omniauth-twitter 1.4.0
1: omniauth-twitter (1.4.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/omniauth-twitter-1.4.0.gemspec
Fetching aws-sdk-s3 1.96.1
Installing aws-sdk-s3 1.96.1
1: aws-sdk-s3 (1.96.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/aws-sdk-s3-1.96.1.gemspec
Fetching actionview 6.1.6.1
Installing actionview 6.1.6.1
1: actionview (6.1.6.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/actionview-6.1.6.1.gemspec
Fetching activejob 6.1.6.1
Installing activejob 6.1.6.1
1: activejob (6.1.6.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/activejob-6.1.6.1.gemspec
Using active_model_serializers 0.8.4
1: active_model_serializers (0.8.4) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/active_model_serializers-0.8.4.gemspec
Fetching activerecord 6.1.6.1
Installing activerecord 6.1.6.1
1: activerecord (6.1.6.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/activerecord-6.1.6.1.gemspec
Fetching omniauth-oauth2 1.7.2
Installing omniauth-oauth2 1.7.2
1: omniauth-oauth2 (1.7.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/omniauth-oauth2-1.7.2.gemspec
Fetching actionpack 6.1.6.1
Installing actionpack 6.1.6.1
1: actionpack (6.1.6.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/actionpack-6.1.6.1.gemspec
Using actionview_precompiler 0.2.3
1: actionview_precompiler (0.2.3) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/actionview_precompiler-0.2.3.gemspec
Fetching seed-fu 2.3.9
Installing seed-fu 2.3.9
1: seed-fu (2.3.9) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/seed-fu-2.3.9.gemspec
Using omniauth-facebook 9.0.0
1: omniauth-facebook (9.0.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/omniauth-facebook-9.0.0.gemspec
Using omniauth-github 1.4.0
1: omniauth-github (1.4.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/omniauth-github-1.4.0.gemspec
Using omniauth-google-oauth2 0.8.2
1: omniauth-google-oauth2 (0.8.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/omniauth-google-oauth2-0.8.2.gemspec
Fetching actionmailer 6.1.6.1
Installing actionmailer 6.1.6.1
1: actionmailer (6.1.6.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/actionmailer-6.1.6.1.gemspec
Fetching railties 6.1.6.1
Installing railties 6.1.6.1
1: railties (6.1.6.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/railties-6.1.6.1.gemspec
Using sprockets-rails 3.4.2
1: sprockets-rails (3.4.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/sprockets-rails-3.4.2.gemspec
Fetching jquery-rails 4.4.0
Installing jquery-rails 4.4.0
2: puma (5.5.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/puma-5.5.2.gemspec
Fetching lograge 0.11.2
1: jquery-rails (4.4.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/jquery-rails-4.4.0.gemspec
Fetching rails_failover 0.7.3
Installing lograge 0.11.2
Installing rails_failover 0.7.3
2: lograge (0.11.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/lograge-0.11.2.gemspec
Fetching rails_multisite 4.0.0
1: rails_failover (0.7.3) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rails_failover-0.7.3.gemspec
Using sassc-rails 2.1.2
1: sassc-rails (2.1.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/sassc-rails-2.1.2.gemspec
Fetching discourse-ember-rails 0.18.6
Installing rails_multisite 4.0.0
Installing discourse-ember-rails 0.18.6
2: rails_multisite (4.0.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rails_multisite-4.0.0.gemspec
1: discourse-ember-rails (0.18.6) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/discourse-ember-rails-0.18.6.gemspec
3: oj (3.13.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/oj-3.13.2.gemspec
0: openssl (2.2.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/openssl-2.2.1.gemspec
Fetching openssl-signature_algorithm 1.1.1
Installing openssl-signature_algorithm 1.1.1
2: openssl-signature_algorithm (1.1.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/openssl-signature_algorithm-1.1.1.gemspec
Fetching cose 1.2.0
Installing cose 1.2.0
1: cose (1.2.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/cose-1.2.0.gemspec
Bundle complete! 128 Gemfile dependencies, 178 gems now installed.
Gems in the groups ‘test’ and ‘development’ were not installed.
Bundled gems are installed into ./vendor/bundle
Post-install message from image_optim:
I, [2023-01-18T11:20:08.795503 #1] INFO – : > cd /var/www/discourse && su discourse -c ‘LOAD_PLUGINS=0 bundle exec rake plugin:pull_compatible_all’
I, [2023-01-18T11:20:10.866531 #1] INFO – :
I, [2023-01-18T11:20:10.866729 #1] INFO – : > cd /var/www/discourse && su discourse -c ‘bundle exec rake db:migrate’
rake aborted!
LoadError: cannot load such file – net/pop
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/bootsnap-1.9.4/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:23:in require' /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/bootsnap-1.9.4/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:23:in block in require_with_bootsnap_lfi’
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/bootsnap-1.9.4/lib/bootsnap/load_path_cache/loaded_features_index.rb:93:in register' /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/bootsnap-1.9.4/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:22:in require_with_bootsnap_lfi’
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/bootsnap-1.9.4/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:44:in require' /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/zeitwerk-2.6.0/lib/zeitwerk/kernel.rb:35:in require’
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/activesupport-6.1.6.1/lib/active_support/dependencies.rb:332:in block in require' /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/activesupport-6.1.6.1/lib/active_support/dependencies.rb:299:in load_dependency’
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/activesupport-6.1.6.1/lib/active_support/dependencies.rb:332:in require' /var/www/discourse/lib/validators/pop3_polling_enabled_setting_validator.rb:3:in ’
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/bootsnap-1.9.4/lib/bootsnap/load_path_cache/loaded_features_index.rb:88:in register' /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/bootsnap-1.9.4/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:22:in require_with_bootsnap_lfi’
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/bootsnap-1.9.4/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:31:in require' /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/zeitwerk-2.6.0/lib/zeitwerk/kernel.rb:35:in require’
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/activesupport-6.1.6.1/lib/active_support/dependencies.rb:332:in require' /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/activesupport-6.1.6.1/lib/active_support/dependencies.rb:424:in block in require_or_load’
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/activesupport-6.1.6.1/lib/active_support/dependencies.rb:39:in block in load_interlock' /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/activesupport-6.1.6.1/lib/active_support/dependencies/interlock.rb:14:in block in loading’
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/activesupport-6.1.6.1/lib/active_support/concurrency/share_lock.rb:151:in exclusive' /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/activesupport-6.1.6.1/lib/active_support/dependencies/interlock.rb:13:in loading’
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/activesupport-6.1.6.1/lib/active_support/dependencies.rb:39:in load_interlock' /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/activesupport-6.1.6.1/lib/active_support/dependencies.rb:402:in require_or_load’
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/activesupport-6.1.6.1/lib/active_support/dependencies.rb:558:in load_missing_constant' /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/activesupport-6.1.6.1/lib/active_support/dependencies.rb:213:in const_missing’
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/activesupport-6.1.6.1/lib/active_support/inflector/methods.rb:274:in const_get' /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/activesupport-6.1.6.1/lib/active_support/inflector/methods.rb:274:in constantize’
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/activesupport-6.1.6.1/lib/active_support/core_ext/string/inflections.rb:74:in constantize' /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/activesupport-6.1.6.1/lib/active_support/core_ext/object/try.rb:15:in public_send’
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/activesupport-6.1.6.1/lib/active_support/core_ext/object/try.rb:15:in try' /var/www/discourse/lib/site_settings/type_supervisor.rb:114:in load_setting’
/var/www/discourse/lib/site_setting_extension.rb:170:in block in setting' /var/www/discourse/lib/site_setting_extension.rb:127:in synchronize’
/var/www/discourse/lib/site_setting_extension.rb:127:in setting' /var/www/discourse/app/models/site_setting.rb:12:in block in load_settings’
/var/www/discourse/lib/site_settings/yaml_loader.rb:22:in block (2 levels) in load' /var/www/discourse/lib/site_settings/yaml_loader.rb:13:in each’
/var/www/discourse/lib/site_settings/yaml_loader.rb:13:in block in load' /var/www/discourse/lib/site_settings/yaml_loader.rb:12:in each_key’
/var/www/discourse/lib/site_settings/yaml_loader.rb:12:in load' /var/www/discourse/app/models/site_setting.rb:11:in load_settings’
/var/www/discourse/app/models/site_setting.rb:16:in <class:SiteSetting>' /var/www/discourse/app/models/site_setting.rb:3:in ’
/var/www/discourse/config/initializers/004-message_bus.rb:122:in <main>' /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/bootsnap-1.9.4/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:60:in load’
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/bootsnap-1.9.4/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:60:in load' /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/activesupport-6.1.6.1/lib/active_support/dependencies.rb:326:in block in load’
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/activesupport-6.1.6.1/lib/active_support/dependencies.rb:299:in load_dependency' /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/activesupport-6.1.6.1/lib/active_support/dependencies.rb:326:in load’
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-6.1.6.1/lib/rails/engine.rb:681:in block in load_config_initializer' /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/activesupport-6.1.6.1/lib/active_support/notifications.rb:205:in instrument’
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-6.1.6.1/lib/rails/engine.rb:680:in load_config_initializer' /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-6.1.6.1/lib/rails/engine.rb:634:in block (2 levels) in class:Engine’
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-6.1.6.1/lib/rails/engine.rb:633:in each' /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-6.1.6.1/lib/rails/engine.rb:633:in block in class:Engine’
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-6.1.6.1/lib/rails/initializable.rb:32:in instance_exec' /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-6.1.6.1/lib/rails/initializable.rb:32:in run’
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-6.1.6.1/lib/rails/initializable.rb:61:in block in run_initializers' /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-6.1.6.1/lib/rails/initializable.rb:50:in each’
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-6.1.6.1/lib/rails/initializable.rb:50:in tsort_each_child' /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-6.1.6.1/lib/rails/initializable.rb:60:in run_initializers’
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-6.1.6.1/lib/rails/application.rb:391:in initialize!' /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-6.1.6.1/lib/rails/railtie.rb:207:in public_send’
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-6.1.6.1/lib/rails/railtie.rb:207:in method_missing' /var/www/discourse/config/environment.rb:7:in ’
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/activesupport-6.1.6.1/lib/active_support/dependencies.rb:332:in require' /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-6.1.6.1/lib/rails/application.rb:367:in require_environment!’
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-6.1.6.1/lib/rails/application.rb:533:in block in run_tasks_blocks' /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/exe/rake:27:in <top (required)>’
/usr/local/bin/bundle:25:in load' /usr/local/bin/bundle:25:in ’
Tasks: TOP => db:migrate => db:load_config => environment
I, [2023-01-18T11:20:12.608443 #1] INFO – :
I, [2023-01-18T11:20:12.608716 #1] INFO – : Terminating async processes
I, [2023-01-18T11:20:12.608751 #1] INFO – : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 18
18:signal-handler (1674040812) Received SIGTERM scheduling shutdown…
18:M 18 Jan 2023 11:20:12.679 # User requested shutdown…
18:M 18 Jan 2023 11:20:12.679 * Saving the final RDB snapshot before exiting.
18:M 18 Jan 2023 11:20:12.699 * DB saved on disk
18:M 18 Jan 2023 11:20:12.699 # Redis is now ready to exit, bye bye…
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c ‘bundle exec rake db:migrate’ failed with return #<Process::Status: pid 1708 exit 1>
Location of failure: /usr/local/lib/ruby/gems/3.1.0/gems/pups-1.1.1/lib/pups/exec_command.rb:117:in `spawn’
exec failed with the params {“cd”=>“$home”, “hook”=>“db_migrate”, “cmd”=>[“su discourse -c ‘bundle exec rake db:migrate’”]}
59c311db4c225fcfa1107d6c9ec0baef05d68d5f07bee3bb0257b3be2c06c688
Сначала я подумал, что проблема в Redis, но, судя по информации из других тем на этом форуме, это сообщение об ошибке появляется всегда.
45:M 18 Jan 2023 11:18:22.218 # Warning: Could not create server TCP listening socket *:6379: bind: Address already in use
45:M 18 Jan 2023 11:18:22.218 # Failed listening on port 6379 (TCP), aborting.
Так что единственная другая ошибка, которую я вижу, это:
rake aborted!
Я попробовал удалить все плагины из файла app.yml, но ошибка осталась прежней.
Буду благодарен за любые подсказки, что еще может быть не так.
Спасибо,
Ян
Вы не можете использовать старые, неподдерживаемые версии (< 3.0) стабильной ветки, так как они не поддерживают Ruby 3.1.
Если вы всё же хотите это сделать, вам нужно зафиксировать discourse_docker на коммите 1de36f6, но это на ваш страх и риск.
Спасибо. Это решило мою проблему.
