The discussion revolves around a problem with a multisite instance where databases failed to migrate due to a PG::DuplicateColumn error. Initially, pfaffman suspected it was due to a column already existing, but later discovered that the issue was caused by SKIP_POST_DEPLOYMENT_MIGRATIONS being set, preventing previous migrations from running.
RGJ found a related GitHub commit that explains the problem, which is due to conflicting migrations trying to add the same columns. pfaffman confirmed that this explanation matches the issue he experienced.
Nick_Tomlinson is also experiencing the same issue and asks how to apply the fix from the GitHub commit to his Discourse instance.
Sorry for the false alarm. I so hate when I do this.
The issue was that I had SKIP_POST_DEPLOYMENT_MIGRATIONS: 1 set and then didn’t run multisite:migrate. After I did a `SKIP_POST_DEPLOYMENT_MIGRATIONS=- multisite:migrate’ I was then able to bootstrap.
I just need to fix my tooling for multisite to run the migration after cranking up the new semi-migrated container.
This commit is a redo of 2f1ddadff7dd47f824070c8a3f633f00a27aacde
which we reverted because it blew up an internal CI check. I looked
into it, and it happened because the old migration to add the bookmark
columns still existed, and those columns were dropped in a post migrate,
so the two migrations to add the columns were conflicting before
the post migrate was run.
