Favicon not loading in FireFox
A user, hellekin, reported that the favicon is not loading in Firefox, instead showing a white square. sam suspected that a recent change might have caused the issue. After some investigation, sam discovered that the problem occurs because the message bus starts listening too early, causing Firefox to spin indefinitely. A patch was applied to fix this issue (sam). However, even after upgrading to the latest Discourse version, hellekin still experiences the white square favicon issue. Further debugging revealed that the problem only occurs when logged in and is likely related to the Tor Browser Bundle’s anti-tracking code. The issue is now being investigated on the Tor side (hellekin).
I don’t think it’s related but the latest upgrade seems to have wiped out the favicon: it appears as a white square to me both here on meta and on talk.devuan.org.
EDIT: seems to have come back to normal here on meta.
I merged in a change by @tgxworld for following redirects in favicon downloads, perhaps it broke this
3개의 좋아요
Still broken here (the favicon turned into a white square).
Is there a way to disable these favicon tricks and keep it static?
[Edited:] I had the preference set to use the notification with the favicon. I turned it off, but the favicon remains a white square.
I tested your site on Chrome and FireFox. Both browsers work for me. Has this been resolved for you? Are there any errors in your logs?
1개의 좋아요
Hey, thank you @tgxworld for having a look. I’m upgrading the instance, but so far I’ve had a white square icon. Hopefully after the upgrade it will be fixed. Response in a few minutes…
Updated to the latest, still having the same issue the favicon is loading, but
Takes a lot of time to loading finished.
Looks like message bus POSTs are timing out on your sites:
Notice the URL at upper right: /message-bus/ those requests are taking 25+ seconds
2개의 좋아요
That is by design :slight_smile: its long polling, also happens here
OK, I see why this is happening, we are start listening to the message bus a bit too early, before the whole page rendered. Firefox gets confused here and just keeps spinning.
Will have a look at how to avoid this …
4개의 좋아요
Should be fixed per:
https://github.com/discourse/discourse/commit/6c1d5b8cd356baa24fc1457cc544224e55902783
4개의 좋아요
After upgrading to the latest Discourse, including @sam’s patch to the spinning issue, I still get a white square as a favicon.
The normal favicon images is set as: /user_avatar/talk.devuan.org/system/16/20.png
Which is:
I have another image for the favicon in the assets topic pointing to /uploads/default/original/1X/850b3654d4b4d94dbf6a98b27de7146d69aa723b.png (i.e.,
Setting one or the other brings a white square.
How can I debug this?
[edit: thanks @zogstrip]
update: the favicon appears normally when logged out.
All right, I figured out that it’s not a Firefox issue but a Tor Browser Bundle issue.
It’s unclear yet what exactly affects this, but I suspect anti-tracking code. There are a number of related bugs in the Tor Trac but nothing reporting this white square misbehavior.
To be investigated on Tor side.
2개의 좋아요
