What would you like done?
we are looking for a custom plugin/component development service for our discourse site
Below is the requirement.
- A Ui component where user can upload files into s3 bucket .
- Then Every file should have downloadable and shareable link which user should get.
- Those links also should be listed down in one ui component.
When do you need it done?
ASAP
What is your budget, in $ USD that you can offer for this task?
Negotiable
merefield
(Robert)
#2
FYI there is already native support to put uploads in S3 storage, you just need to enable:
So the current Post UI already supports this.
Perhaps you can leverage that if you need further modifications and should simplify your project significantly.
See: Using Object Storage for Uploads (S3 & Clones)
pfaffman
(Jay Pfaffman)
#3
Where would that be? The topic in which they uploaded it?
You want a single page that has a list of every upload? If not, how would one specify those uploads?
Sure, but do you want something like $50, $500, $1000, $2500?
Hi Hemant,
I am interested to take this up, sending you a PM
system
(system)
closed
#5
