I have a problem with sending a personal message when the user deletes a topic for the first time.
Two weeks ago, this worked very well (a bit too well, thanks for fixing that). But now, no message is sent even for a newly created user.
I didn’t edit the automation, so I don’t think it’s related to the settings. In case it matters, trust level is any, my admin user is the PM sender, and the delay is 0. Of course, the automation is enabled. The plugin in general also works; the “add to group based on a custom user field” automation just ran, but the solution one does not.
Is it possible that the post just marked as a solution is taken into account in the check whether the user has already solved a topic and therefore every user has already solved a topic when the check is running in the automation?
