So when you react to a flagged post, it causes the following to happen:
Canapin
(Coin-coin le Canapin)
3
Hey
Iām not sure I follow you. I tried to repro without success.
Can you describe the steps needed to make the issue appear and what exactly the issue is?
Canapin
6
Thanks
How flagged messages are displayed to other users has changed and donāt display āView ignored contentā anymore.
Related pull request:
The forum you take the video from may not have this update yet and need to be upgraded.
The issue could be gone then.
Maybe you can try asking the admin to upgrade the forum, and try again to see if the issue persists?
Hi, this is taken on my forum. I think you are correct; I havenāt upgraded in a while. Will do, thanks!
This is correct. It was taken on your forum
Canapin
9
Please report back if the issue persists or not, if possible. That would be great
I think itās fixed now after updating.
