Seguimiento: Asignar conflicto de plugin
Previously we ran into issues with upgrading to the latest version of Discourse, this turned out to be related to the Assign Plugin/ Production Data issue that @angus helped us identity and resolve by removing the plugin.
Moving forward we would like to reinstate the plugin but need to eliminate the chance of encountering the game breaking error we experienced previously. Below is details related to the log excerpts when everything was going on.
/var/www/discourse/plugins/discourse-assign/plugin.rb:284:in `block (2 levels) in activate!’
Backtrace:
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-mini-profiler-1.0.2/lib/patches/db/pg.rb:69:in `async_exec_params'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-mini-profiler-1.0.2/lib/patches/db/pg.rb:69:in `exec_params'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.3/lib/active_record/connection_adapters/postgresql_adapter.rb:611:in `block (2 levels) in exec_no_cache'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.3/lib/active_support/dependencies/interlock.rb:48:in `block in permit_concurrent_loads'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.3/lib/active_support/concurrency/share_lock.rb:187:in `yield_shares'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.3/lib/active_support/dependencies/interlock.rb:47:in `permit_concurrent_loads'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.3/lib/active_record/connection_adapters/postgresql_adapter.rb:610:in `block in exec_no_cache'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.3/lib/active_record/connection_adapters/abstract_adapter.rb:581:in `block (2 levels) in log'
> /usr/local/lib/ruby/2.6.0/monitor.rb:230:in `mon_synchronize'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.3/lib/active_record/connection_adapters/abstract_adapter.rb:580:in `block in log'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.3/lib/active_support/notifications/instrumenter.rb:23:in `instrument'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.3/lib/active_record/connection_adapters/abstract_adapter.rb:571:in `log'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.3/lib/active_record/connection_adapters/postgresql_adapter.rb:609:in `exec_no_cache'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.3/lib/active_record/connection_adapters/postgresql_adapter.rb:596:in `execute_and_clear'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.3/lib/active_record/connection_adapters/postgresql/database_statements.rb:81:in `exec_query'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.3/lib/active_record/connection_adapters/abstract/database_statements.rb:478:in `select'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.3/lib/active_record/connection_adapters/abstract/database_statements.rb:70:in `select_all'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.3/lib/active_record/connection_adapters/abstract/query_cache.rb:104:in `block in select_all'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.3/lib/active_record/connection_adapters/abstract/query_cache.rb:127:in `block in cache_sql'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.3/lib/active_record/connection_adapters/abstract/query_cache.rb:113:in `cache_sql'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.3/lib/active_record/connection_adapters/abstract/query_cache.rb:104:in `select_all'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.3/lib/active_record/connection_adapters/abstract/database_statements.rb:77:in `select_one'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.3/lib/active_record/relation/finder_methods.rb:322:in `block in exists?'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.3/lib/active_record/relation.rb:584:in `skip_query_cache_if_necessary'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.3/lib/active_record/relation/finder_methods.rb:322:in `exists?'
> /var/www/discourse/plugins/discourse-assign/plugin.rb:69:in `block (2 levels) in activate!'
> /var/www/discourse/lib/plugin/instance.rb:188:in `public_send'
> /var/www/discourse/lib/plugin/instance.rb:188:in `block (2 levels) in add_to_class'
> /var/www/discourse/plugins/discourse-assign/plugin.rb:284:in `block (2 levels) in activate!'
> (eval):49:in `_fast_attributes'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/active_model_serializers-0.8.4/lib/active_model/serializer.rb:456:in `attributes'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/active_model_serializers-0.8.4/lib/active_model/serializer.rb:480:in `_serializable_hash'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/active_model_serializers-0.8.4/lib/active_model/serializer.rb:359:in `serializable_hash'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/active_model_serializers-0.8.4/lib/active_model/serializer.rb:347:in `as_json'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.3/lib/active_support/json/encoding.rb:22:in `encode'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.3/lib/active_support/core_ext/object/json.rb:41:in `to_json'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/active_model_serializers-0.8.4/lib/active_model/serializer.rb:331:in `to_json'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/multi_json-1.13.1/lib/multi_json/adapters/oj.rb:40:in `dump'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/multi_json-1.13.1/lib/multi_json/adapter.rb:25:in `dump'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/multi_json-1.13.1/lib/multi_json.rb:139:in `dump'
> /var/www/discourse/app/controllers/application_controller.rb:535:in `preload_current_user_data'
> /var/www/discourse/app/controllers/application_controller.rb:354:in `preload_json'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.3/lib/active_support/callbacks.rb:426:in `block in make_lambda'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.3/lib/active_support/callbacks.rb:198:in `block (2 levels) in halting'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/abstract_controller/callbacks.rb:34:in `block (2 levels) in <module:Callbacks>'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.3/lib/active_support/callbacks.rb:199:in `block in halting'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.3/lib/active_support/callbacks.rb:513:in `block in invoke_before'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.3/lib/active_support/callbacks.rb:513:in `each'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.3/lib/active_support/callbacks.rb:513:in `invoke_before'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.3/lib/active_support/callbacks.rb:131:in `run_callbacks'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/abstract_controller/callbacks.rb:41:in `process_action'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_controller/metal/rescue.rb:22:in `process_action'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_controller/metal/instrumentation.rb:34:in `block in process_action'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.3/lib/active_support/notifications.rb:168:in `block in instrument'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.3/lib/active_support/notifications.rb:168:in `instrument'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_controller/metal/instrumentation.rb:32:in `process_action'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_controller/metal/params_wrapper.rb:256:in `process_action'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.3/lib/active_record/railties/controller_runtime.rb:24:in `process_action'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/abstract_controller/base.rb:134:in `process'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionview-5.2.3/lib/action_view/rendering.rb:32:in `process'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-mini-profiler-1.0.2/lib/mini_profiler/profiling_methods.rb:78:in `block in profile_method'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_controller/metal.rb:191:in `dispatch'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_controller/metal.rb:252:in `dispatch'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_dispatch/routing/route_set.rb:52:in `dispatch'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_dispatch/routing/route_set.rb:34:in `serve'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_dispatch/journey/router.rb:52:in `block in serve'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_dispatch/journey/router.rb:35:in `each'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_dispatch/journey/router.rb:35:in `serve'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_dispatch/routing/route_set.rb:840:in `call'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-protection-2.0.5/lib/rack/protection/frame_options.rb:31:in `call'
> /var/www/discourse/lib/middleware/omniauth_bypass_middleware.rb:68:in `call'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/tempfile_reaper.rb:15:in `call'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/conditional_get.rb:25:in `call'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/head.rb:12:in `call'
> /var/www/discourse/lib/content_security_policy/middleware.rb:12:in `call'
> /var/www/discourse/lib/middleware/anonymous_cache.rb:220:in `call'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/session/abstract/id.rb:232:in `context'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/session/abstract/id.rb:226:in `call'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_dispatch/middleware/cookies.rb:670:in `call'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_dispatch/middleware/callbacks.rb:28:in `block in call'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.3/lib/active_support/callbacks.rb:98:in `run_callbacks'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_dispatch/middleware/callbacks.rb:26:in `call'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_dispatch/middleware/debug_exceptions.rb:61:in `call'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_dispatch/middleware/show_exceptions.rb:33:in `call'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/logster-2.3.0/lib/logster/middleware/reporter.rb:30:in `call'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-5.2.3/lib/rails/rack/logger.rb:38:in `call_app'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-5.2.3/lib/rails/rack/logger.rb:28:in `call'
> /var/www/discourse/config/initializers/100-quiet_logger.rb:18:in `call'
> /var/www/discourse/config/initializers/100-silence_logger.rb:31:in `call'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_dispatch/middleware/remote_ip.rb:81:in `call'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_dispatch/middleware/request_id.rb:27:in `call'
> /var/www/discourse/lib/middleware/enforce_hostname.rb:17:in `call'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/method_override.rb:22:in `call'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-5.2.3/lib/action_dispatch/middleware/executor.rb:14:in `call'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/sendfile.rb:111:in `call'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-mini-profiler-1.0.2/lib/mini_profiler/profiler.rb:171:in `call'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/message_bus-2.2.2/lib/message_bus/rack/middleware.rb:57:in `call'
> /var/www/discourse/lib/middleware/request_tracker.rb:169:in `call'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-5.2.3/lib/rails/engine.rb:524:in `call'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-5.2.3/lib/rails/railtie.rb:190:in `public_send'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-5.2.3/lib/rails/railtie.rb:190:in `method_missing'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/urlmap.rb:68:in `block in call'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/urlmap.rb:53:in `each'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/urlmap.rb:53:in `call'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/unicorn-5.5.1/lib/unicorn/http_server.rb:605:in `process_client'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/unicorn-5.5.1/lib/unicorn/http_server.rb:700:in `worker_loop'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/unicorn-5.5.1/lib/unicorn/http_server.rb:548:in `spawn_missing_workers'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/unicorn-5.5.1/lib/unicorn/http_server.rb:144:in `start'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/unicorn-5.5.1/bin/unicorn:128:in `<top (required)>'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/bin/unicorn:23:in `load'
> /var/www/discourse/vendor/bundle/ruby/2.6.0/bin/unicorn:23:in `<main>'
Info:
> ActiveRecord::StatementInvalid (PG::InvalidTextRepresentation: ERROR: invalid input syntax for integer: “admins”
> LINE 1: …p_users".“user_id” = 15040 AND (groups.id in (‘3’,‘admins’,’…
> : SELECT 1 AS one FROM “groups” INNER JOIN “group_users” ON “groups”.“id” = “group_users”.“group_id” WHERE “group_users”.“user_id” = 15040 AND (groups.id in (‘3’,‘admins’,‘RDSE’)) LIMIT 1)
> /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-mini-profiler-1.0.2/lib/patches/db/pg.rb:69:in `async_exec_params’
Please let me know if there is anything else you need to help us move forward. Thank you.
1 me gusta
Sorry, I am not following? Conflict with what?
1 me gusta
Are you sure “group id 3 admins” is correct?
@Mittineague I confirmed this morning that the group id for admins is indeed the default group ID.
05%20AM
The log information I included was during our down time and we have temporarily removed the Assign plugin which immediately resolved the issue and allowed us to successfully leverage discourse again.
The value of the assign_allowed_on_groups site setting is in a bad state. We migrated from using group names to group IDs.
admins should be replaced with the group ID to fix the issue.
2 Me gusta
How do I go about modifying that?
From your Discourse folder, you should:
  • Enter the container running ./launcher enter app
  • Open a Rails console running rails c
Once inside the console, you can run this script to fix the issue:
allowed_groups = SiteSetting.assign_allowed_on_groups.split('|')
allowed_groups.map! do |ag|
  ag.to_i.to_s == ag ? ag : Group.select(:id).find_by(name: ag).id
SiteSetting.assign_allowed_on_groups = allowed_groups.join('|')
4 Me gusta
After doing the above suggested, I was not able to successfully run the script. Below is the output of the attempt. Any direction is highly appreciated :pray:
app:/var/www/discourse# rails c
[1] pry(main)> allowed_groups = SiteSetting.assign_allowed_on_groups.split('|')
NoMethodError: undefined method `assign_allowed_on_groups' for #<Class:0x0000563ec4670260>
from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.3/lib/active_record/dynamic_matchers.rb:22:in `method_missing'
[2] pry(main)> allowed_groups.map! do |ag|
[2] pry(main)* ag.to_i.to_s == ag ? ag : Group.select(:id).find_by(name: ag).id
[2] pry(main)* end
NoMethodError: undefined method `map!' for nil:NilClass
from (pry):2:in `__pry__'
[3] pry(main)> SiteSetting.assign_allowed_on_groups = allowed_groups.join('|')
NoMethodError: undefined method `join' for nil:NilClass
from (pry):5:in `__pry__'
Looks to me like you have an old version of Discourse assign installed … are you on tests-passed with latest discourse assign?
1 me gusta
Let me look into this @sam and I will let you know what I find :+1:
With the Assign Plugin currently removed @sam, you feel reinstalling the plugin with the latest version might be the best course of action?
@sam @angus I went to reinstall the Assign plugin again tonight and experience complete failure again after sign in. I captured logs of the failure but wouldn’t prefer not to post them publicly but willing to do so via DM.
Any suggestion on how to move forward?
Are you on the stable branch? Are there other plugins you have installed that might be causing a conflict?
I believe so as I pulled from Master.
Just the following, nothing that would stick out to me.
You’d need to have done some work to be on the (less desirable) stable branch. Do you see something like
version: stable
in your app.yml? If you’re on stable then things might be more complicated.
You might try ./discourse-doctor. And/or make sure that you do a git pull before rebuilding.
57%20PM
This is what I see in my App.yml
1 me gusta
Any additional ideas here to help us move forward with the Assign plugin? @angus?
Hey @Jim.Morrison ,
Can you run this inside a console and show me the output:
DB.query_single(<<~SQL SELECT site_settings.value FROM site_settings WHERE site_settings.name = 'assign_allowed_on_groups' SQL ).first.to_s.split('|')
I believe that my script didn’t work because the plugin was disabled.
1 me gusta
Direct messaged you the details from the console. Thanks @Roman!
After going back and forth with @Roman on this, we were able to finally get this resolved!
After running the query that Roman wrote to eliminate a data conflict, adding the Assign plugin and then rebuilding the app, I was met with success!
Roman has been a huge asset through this whole ordeal and I couldn’t give him enough praise for this! Thank you so much for working with me on this @Roman!
3 Me gusta
