Heutiger Fehler beim Upgrade von 2.5.1 auf 2.5.2, discourse-assign
Beim Versuch, das Testforum heute vor dem Update des Produktionsforums mit Version 2.5.1 stable zu aktualisieren, trat folgender Fehler auf:
I, [2020-10-07T06:39:44.735617 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
	88: from /usr/local/bin/bundle:23:in `<main>'
	87: from /usr/local/bin/bundle:23:in `load'
	86: from /usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/exe/bundle:34:in `<top (required)>'
	85: from /usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/friendly_errors.rb:123:in `with_friendly_errors'
	84: from /usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/exe/bundle:46:in `block in <top (required)>'
	83: from /usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/cli.rb:24:in `start'
	82: from /usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/vendor/thor/lib/thor/base.rb:476:in `start'
	81: from /usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/cli.rb:30:in `dispatch'
	80: from /usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/vendor/thor/lib/thor.rb:399:in `dispatch'
	79: from /usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
	78: from /usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
	77: from /usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/cli.rb:476:in `exec'
	76: from /usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/cli/exec.rb:28:in `run'
	75: from /usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/cli/exec.rb:63:in `kernel_load'
	74: from /usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/cli/exec.rb:63:in `load'
	73: from /var/www/discourse/vendor/bundle/ruby/2.6.0/bin/rake:23:in `<top (required)>'
	72: from /var/www/discourse/vendor/bundle/ruby/2.6.0/bin/rake:23:in `load'
	71: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/exe/rake:27:in `<top (required)>'
	70: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:80:in `run'
	69: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:186:in `standard_exception_handling'
	68: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:83:in `block in run'
	67: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:110:in `top_level'
	66: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:125:in `run_with_threads'
	65: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:116:in `block in top_level'
	64: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:116:in `each'
	63: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:116:in `block (2 levels) in top_level'
	62: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:160:in `invoke_task'
	61: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:188:in `invoke'
	60: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:199:in `invoke_with_call_chain'
	59: from /usr/local/lib/ruby/2.6.0/monitor.rb:235:in `mon_synchronize'
	58: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:218:in `block in invoke_with_call_chain'
	57: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:241:in `invoke_prerequisites'
	56: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:241:in `each'
	55: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:243:in `block in invoke_prerequisites'
	54: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:199:in `invoke_with_call_chain'
	53: from /usr/local/lib/ruby/2.6.0/monitor.rb:235:in `mon_synchronize'
	52: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:218:in `block in invoke_with_call_chain'
	51: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:241:in `invoke_prerequisites'
	50: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:241:in `each'
	49: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:243:in `block in invoke_prerequisites'
	48: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:199:in `invoke_with_call_chain'
	47: from /usr/local/lib/ruby/2.6.0/monitor.rb:235:in `mon_synchronize'
	46: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:219:in `block in invoke_with_call_chain'
	45: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:281:in `execute'
	44: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:281:in `each'
	43: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:281:in `block in execute'
	42: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3.1/lib/rails/application.rb:523:in `block in run_tasks_blocks'
	41: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3.1/lib/rails/application.rb:339:in `require_environment!'
	40: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3.1/lib/active_support/dependencies.rb:324:in `require'
	39: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3.1/lib/active_support/dependencies.rb:291:in `load_dependency'
	38: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3.1/lib/active_support/dependencies.rb:324:in `block in require'
	37: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/zeitwerk-2.3.0/lib/zeitwerk/kernel.rb:23:in `require'
	36: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.4.6/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:31:in `require'
	35: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.4.6/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:22:in `require_with_bootsnap_lfi'
	34: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.4.6/lib/bootsnap/load_path_cache/loaded_features_index.rb:92:in `register'
	33: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.4.6/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:23:in `block in require_with_bootsnap_lfi'
	32: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.4.6/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:23:in `require'
	31: from /var/www/discourse/config/environment.rb:7:in `<main>'
	30: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3.1/lib/rails/railtie.rb:190:in `method_missing'
	29: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3.1/lib/rails/railtie.rb:190:in `public_send'
	28: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3.1/lib/rails/application.rb:363:in `initialize!'
	27: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3.1/lib/rails/initializable.rb:60:in `run_initializers'
	26: from /usr/local/lib/ruby/2.6.0/tsort.rb:205:in `tsort_each'
	25: from /usr/local/lib/ruby/2.6.0/tsort.rb:226:in `tsort_each'
	24: from /usr/local/lib/ruby/2.6.0/tsort.rb:347:in `each_strongly_connected_component'
	23: from /usr/local/lib/ruby/2.6.0/tsort.rb:347:in `call'
	22: from /usr/local/lib/ruby/2.6.0/tsort.rb:347:in `each'
	21: from /usr/local/lib/ruby/2.6.0/tsort.rb:349:in `block in each_strongly_connected_component'
	20: from /usr/local/lib/ruby/2.6.0/tsort.rb:431:in `each_strongly_connected_component_from'
	19: from /usr/local/lib/ruby/2.6.0/tsort.rb:350:in `block (2 levels) in each_strongly_connected_component'
	18: from /usr/local/lib/ruby/2.6.0/tsort.rb:228:in `block in tsort_each'
	17: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3.1/lib/rails/initializable.rb:61:in `block in run_initializers'
	16: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3.1/lib/rails/initializable.rb:32:in `run'
	15: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3.1/lib/rails/initializable.rb:32:in `instance_exec'
	14: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3.1/lib/rails/application/finisher.rb:129:in `block in <module:Finisher>'
	13: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3.1/lib/active_support/lazy_load_hooks.rb:51:in `run_load_hooks'
	12: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3.1/lib/active_support/lazy_load_hooks.rb:51:in `each'
	11: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3.1/lib/active_support/lazy_load_hooks.rb:52:in `block in run_load_hooks'
	10: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3.1/lib/active_support/lazy_load_hooks.rb:66:in `execute_hook'
	9: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3.1/lib/active_support/lazy_load_hooks.rb:61:in `with_execution_control'
	8: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3.1/lib/active_support/lazy_load_hooks.rb:68:in `block in execute_hook'
	7: from /var/www/discourse/config/application.rb:335:in `block in <class:Application>'
	6: from /var/www/discourse/lib/plugin_initialization_guard.rb:5:in `plugin_initialization_guard'
	5: from /var/www/discourse/config/application.rb:336:in `block (2 levels) in <class:Application>'
	4: from /var/www/discourse/config/application.rb:336:in `each'
	3: from /var/www/discourse/lib/plugin/instance.rb:363:in `notify_after_initialize'
	2: from /var/www/discourse/lib/plugin/instance.rb:363:in `each'
	1: from /var/www/discourse/lib/plugin/instance.rb:365:in `block in notify_after_initialize'
/var/www/discourse/plugins/discourse-assign/plugin.rb:495:in `block in activate!': undefined method `register_search_advanced_filter' for #<Plugin::Instance:0x00005560719c7648>
Did you mean?  register_seed_data (NoMethodError)
** INKOMPATIBELER PLUGIN **
Aufgrund von Fehlern im Plugin unter
kann Discourse nicht erstellt werden.
Was ist in diesem Fall zu tun?
Vielleicht möchten Sie die Systemsoftware ebenfalls vorher aktualisieren und sicherstellen, dass Sie die richtige PostgreSQL-Version verwenden.
apt-get update
apt-get upgrade
Stellen Sie dann sicher, dass Sie PostgreSQL 12 verwenden.
Ich habe einen PostgreSQL-Container auf einem anderen Server auf Version 12 aktualisiert:
└─# docker exec -it 5a6c70035b87 psql --version
psql (PostgreSQL) 12.4 (Debian 12.4-1.pgdg100+1)
Das hat aber nicht geholfen! Das Forum ließ sich weiterhin nicht mit dem discourse-assign-Plugin erstellen…
Ich habe die Systemsoftware auf dem Server aktualisiert, auf dem Discourse läuft:
root@cuba-test-forum-ru:/var/discourse# apt update
Hit:1 https://download.docker.com/linux/ubuntu bionic InRelease
Hit:2 http://archive.ubuntu.com/ubuntu bionic InRelease
Get:3 http://archive.ubuntu.com/ubuntu bionic-updates InRelease [88.7 kB]
Get:4 http://archive.ubuntu.com/ubuntu bionic-backports InRelease [74.6 kB]
Get:5 http://archive.ubuntu.com/ubuntu bionic-security InRelease [88.7 kB]
Fetched 252 kB in 1s (201 kB/s)
Reading package lists... Done
Building dependency tree
Reading state information... Done
All packages are up to date.
Und das hat geholfen! Das Forum wurde erfolgreich erstellt und mit dem discourse-assign-Plugin normal gestartet.
Nur aus Neugier – warum ist das so?
Die Funktion wurde vor 27 Tagen hinzugefügt:
Dies geschah, weil für Sie das Plugin und das Discourse-Kernsystem gleichzeitig aktualisiert werden mussten. Ein Neuaufbau über die Befehlszeile bewirkt genau das.
Ich habe den Befehl launcher rebuild app von Anfang an ausgeführt.
Aber erst nachdem ich die Systemsoftware auf dem Server aktualisiert hatte, trat beim Neuaufbau mit dem discourse-assign-Plugin ein Fehler auf.
Ich frage mich, warum das so ist. Zuvor war eine Aktualisierung der Systemsoftware nicht erforderlich.
