Lettergroottes zijn verschillend in Firefox en Chrome
I noticed the fonts are of different size in Firefox and Chrome. Why they are rendered differently, it shouldn’t be like that. Is that the problem in theme?
Do you mean it’s bigger in Firefox?
If so, have you changed layout.css.devPixelsPerPx in the Firefox config?
I tested, and at first glance, I could see the difference too:
Then, after debugging, I found out that the pixel ratio was set to 1.09 for some reason.
I don’t remember modifying it; that’s odd. To reset it:
Now, it’s similar:
Is it your case as well?
I don’t remember changing it, but will soon check and report. Thank you.
OK so I checked and the value of layout.css.devPixelsPerPx is 1. Check https://forum.liberland.org, and please tell me if it’s the same in your Firefox and Chrome?
Yes, it’s the same:
So weird, I don’t know what to think. Zoom levels here are at same level…
Can you share a screenshot of what you see, like I did above?
Also, I’m not sure if it will be helpful, but you can try checking out this simple page (source): Browser font size diagnostics.
It gives basic information. You could compare the data between Chrome and Firefox. Feel free to take a screenshot and share it there.
It was the default font size setting in Firefox which was 18, and in Chrome it was 16. I don’t remember changing it in Firefox, but probably I did. Thank you!
