Hi!
I need to put the discourse forum under a URL like https://mydomain.com/forum.
I have installed NGinx in the server which hosts discourse (forum.mydomain.com) , and redirected it to the discourse instance, something similar to this: https://serversforhackers.com/video/installing-discourse-with-docker but without divide it in 3 containers.
In mydomain.com server I have the next configuration:
location /forum {
rewrite ^/forum/(.*) /$1 break;
proxy_pass https://forum.mydomain.com;
proxy_redirect off;
proxy_buffering off;
proxy_set_header Host $http_host;
proxy_set_header X-Forwarded-Host $http_host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
And the configuration of forum.mydomain.com is:
upstream discourse {
server 127.0.0.1:8080;
server {
listen 80 default_server;
server_name mydomain.com/forum;
return 301 https://mydomain.com/forum$request_uri;
server {
listen 443 default_server ssl;
client_body_buffer_size 32k;
client_header_buffer_size 8k;
large_client_header_buffers 8 64k;
root /var/www/discourse/public;
index index.html index.htm;
access_log /var/log/nginx/discourse.log;
error_log /var/log/nginx/discourse.log error;
merge_slashes on;
charset utf-8;
ssl_certificate /etc/letsencrypt/live/mydomain.com/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/mydomain.com/privkey.pem;
location ~ /.well-known {
allow all;
location / {
include proxy_params;
proxy_pass http://discourse;
proxy_redirect off;
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "upgrade";
When I access to https://mydomain.com/forum it redirects me to the forum, but fails loading CSS and shows the next error: Oops! That page doesn’t exist or is private.
There’s anyone in the room who has did this and succeed?
I’m open to any tutorial or simplest way to do this.
Thanks!
