Plugin per l'invio del modulo?
Sto cercando un plugin che trasformi i commenti di un determinato thread (o forse di una categoria specifica, se è meglio) in un modulo da compilare, in modo che gli utenti possano inviare contenuti solo tramite campi predefiniti. In pratica, un plugin simile a Google Moduli, dove invece di poter commentare liberamente in un thread, gli utenti devono compilare un breve modulo e il contenuto viene inserito nella thread con quella struttura. Esiste qualcosa del genere? Come si chiamerebbe, se esiste? Oppure, come si potrebbe realizzare questa funzionalità? Grazie!
1 Mi Piace
In my opinion, the Typeform onebox is the best way.
  1. Create a form in Typeform
  2. Paste the form link in your new topic
Example: the link to https://templates.typeform.com/to/zvlr4L becomes:
8 Mi Piace
Would this populate in a particular thread? Or would it go to backend only? Like an excel sheet or something
Results would be available only in the TypeForm admin area.
Trying to parse Discourse posts into structured data will always be tricky, since Discourse is free form text.
Gotcha. Yeah what I’m looking for is a way to force structure for certain threads, partially to make the threads easier to read through but mostly to make it easy for people to FOLLOW structure (as opposed to them having to copy/paste and then reformat a written out structure).
We do have category Topic Templates, but that’s far from a enforced way, only a suggestion. I can see it working only on very technical audiences.
1 Mi Piace
https://meta.discourse.org/t/topic-templates
This one? I’m not sure I get it exactly after reading through…
It’s available in the category edit modal:
2 Mi Piace
Oh interesting. So I could build a form style template and they’d have to manually select it to use it, otherwise it would just be a regular comment? Does that exist in the base Discourse toolbox?
Start a new post here, and select Marketplace. You’ll then see how it auto-populates the composer.
1 Mi Piace
Oh snap that’s perfect. How do I install/set that up, exactly? Just in basic discourse admin?
NVM, found it! Is there an option or plugin that allows this in particular threads, or just on a category level? And does it populate in each thread or just new unique posts? What I’m looking for is for that to show up in the comments on a thread versus a new thread itself.
Just the category level. There is the canned-replies plugin, but it works only for admins.
1 Mi Piace
So basically there is no existing plugin for thread-level auto-population?
1 Mi Piace
No such feature exists, no.
1 Mi Piace
That’s what I was looking for. Thanks!
Hi Falco, thanks for integrating Typeform onebox. It works, but doesn’t render the same way it renders for me. It renders as a square box that opens a new window instead of how your works as an embed.
What should I be doing right?
2 Mi Piace
Yes, typeform renders a bit differently now, it oneboxes. Not sure if we should have explicit support here, or if an <iframe> domain could be whitelisted, or what @falco
2 Mi Piace
Yeah unfortunately we had to give up on automatic typeform onebox :sad_but_relieved_face:
You can still allow the typeform URL in the iframe setting, and then paste the iframe code in a post.
4 Mi Piace
Ora lo abbiamo nativamente tramite Introducing Experimental Form Templates
4 Mi Piace
