RGJ
(Richard - Communiteq)
1
- Enable experimental form templates
- Create a template with a tag group selector
- Preview
- Tags are not populated
- Preview does not close
When actually using the template in topic creation, the tags are populated fine.
Errors:
TypeError: this.wrapperElement is undefined
Error: VM BUG: Target must be set before attempting to jump
tgxworld
(Alan Tan)
@Lhc_fl Can you have a look at this one next?
Lhc_fl
(Linca)
3
I investigated and found that the reason is that the process tag group step is not executed. These two PRs should solve this problem.
