版主正在破坏论坛
另外,她英语不流利,并且使用自动翻译工具与我们互动,这可能会导致误解、忽略我们建议中的细微差别,或者出现类似情况。我并不是说就是这种情况,但有时确实可能发生。
3 个赞
Just as an extra datapoint, I’m a member of another forum that has one main admin/moderator who works traditional business hours and a selection of TL4 community members who act as ‘mini-mods’ (so not even any category moderators), and as a TL4 on that site I find I have lots of powers to edit public post content when it’s inappropriate [1], close or unlist topics as necessary, set slow mode, etc. We don’t have Personal Messages or Chat, which makes things easier, but you can gate those features behind trust levels if they’re being misused on your site, as well as locking certain user’s trust levels below that threshold if they persistently misuse them.
FWIW, I find that there are some quite powerful tools available to trusted community members without needing to grant full moderation powers (whether TL4 or category moderators), and you can also revoke these if you find those community members are not as trusted as you thought.
I think in another topic you mentioned being reluctant to check the staff logs to review behaviour, but I would say that these can be excellent for keeping track of users with higher abilities - and you can quickly revoke any from users who aren’t in line with your forum’s ethos.
作为另一个论坛的成员,我发现该论坛有一位主要管理员/版主,他遵循传统的办公时间,还有一些TL4社区成员充当“迷你版主”(甚至没有分类版主)。在该网站上,作为TL4成员,我发现自己拥有许多在帖子内容不当时编辑公共帖子内容(结合没有公共编辑历史记录,这会非常有用)、根据需要关闭或取消列表主题、设置慢速模式等方面的权限。我们没有私人消息或聊天功能,这使得事情更容易,但如果您的网站上有人滥用这些功能,您可以将其设为仅限特定信任等级的用户使用,并且如果某些用户持续滥用这些功能,您可以将其信任等级锁定在该阈值以下。
供参考,我认为即使不授予完全的版主权限(无论是TL4还是分类版主),也有一些非常强大的工具可供受信任的社区成员使用,并且如果您发现这些社区成员的信任度不如您预期的那样,您也可以撤销这些权限。
我认为在另一个主题中,您提到不愿查看员工日志来审查行为,但我认为这些日志对于跟踪具有更高权限的用户来说非常有用——并且您可以快速撤销那些不符合您论坛精神的用户所拥有的任何权限。
  1. doubly useful in conjunction with having no public edit history ↩︎
6 个赞
即使你能阻止他们删除账户的能力,他们难道不能简单地删除那个人的每一篇帖子吗?或者继续篡改它们?特别是如果你已经不想检查日志了,他们可以随时进来并不断擦除尽可能多的旧帖子。
更不用说静默、匿名化、暂停、限制信任级别、合并和拆分主题,有无数种方法可以造成严重的混乱,你将要么 1. 在需要大量工作/重置才能修复(以牺牲进度为代价)之前一直不知道,要么 2. 你需要不断监控的东西。这两种情况听起来都不好。
逐一删除所有权限的选项会让你回到一开始就没有这些权限。如果你找不到可以信任的人,那么 IMO,你的第二选择是找到所需权限最少的东西,然后尝试添加他们需要能够做的任何具体事情,而不是给他们大量的权限并试图逐一阻止。如前所述,查看类别版主或信任级别 4 的选项。首先确定你需要他们做什么,而不是你不希望他们做什么。
3 个赞
很有趣,你想赋予哪些额外的权力。
3 个赞
如果您启用“高信任度标记自动隐藏帖子”的设置复选框,您可以让 TL3 和 TL4 用户标记帖子,以便在您有时间查看之前将其隐藏。还可以移除具有高 TL 的用户编辑其他用户内容的权限。
我只在我的论坛上授予人们 TL4 访问权限(而非版主),因为风险太高。我使用 webhook 在出现问题时通知我的 Slack。Webhook 会发布到 Firebase 云函数,由该函数决定是否发送 Slack 通知。
2 个赞
