Fresh Discourse/Docker install wont send mails
A user named funktionierbar is setting up a fresh Discourse installation via Docker and encounters an issue where emails fail to send during the initial setup, preventing completion. The setup uses Apache2 as a reverse proxy and a local mailcow Docker mail server on port 587 with STARTTLS. Despite correct DNS resolution and working SMTP tests from outside the container, the container fails to connect, returning “Cannot assign requested address” and “Connection timed out” errors during OpenSSL tests. pfaffman suggests checking email configuration and suspects a Docker network issue. funktionierbar confirms no logs appear on the mail server and verifies the issue persists even after aligning email addresses. Eventually, funktionierbar resolves the issue by enabling IPv6 support in the Docker network, following a tutorial, which immediately fixed the connection problem. The root cause was IPv6 being disabled in Docker’s default network configuration, blocking outbound IPv6 connections to the mail server.
Hi people,
I want to switch a long standing forum from phpBB3 to Discourse. I managed to setup the Docker, and am able to access the Initial Setup. Unfortunately there is no mail being sent, so i can’t finish the init.
I did some debugging and cant find the reason, so I am turning to you for help.
My setup is like this, I have setup apache2 as a reverseproxy to the docker, which works. My mailserver is a mailcow docker on the same machine. The mailserver is tested thoroughly and works fine on a daily basis through SMTP with STARTTLS on Port 587 and webmail.
the config in my app.yml looks like this:
  DISCOURSE_SMTP_ADDRESS: mail.example.com
  DISCOURSE_SMTP_PORT: 587
  DISCOURSE_SMTP_USER_NAME: discourse@example.com
  DISCOURSE_SMTP_PASSWORD: "password"
  #DISCOURSE_SMTP_ENABLE_START_TLS: true           # (optional, default true)
  #DISCOURSE_SMTP_DOMAIN: mail.example.com
  DISCOURSE_NOTIFICATION_EMAIL: discourse@example.com
when i run ./discourse-doctor i get:
==================== MAIL TEST ====================
For a robust test, get an address from http://www.mail-tester.com/
Or just send a test message to yourself.
Email address for mail test? ('n' to skip) [admin@example.com]:
Sending mail to admin@example.com. . .
Testing sending to admin@example.com using mail.example.com:587, username:discourse@example.com with plain auth.
ERROR
                                   UNEXPECTED ERROR
Cannot assign requested address - connect(2) for [correct ipv6]:587
SOLUTION
This is not a common error. No recommended solution exists!
Please report the exact error message above to https://meta.discourse.org/
(And a solution, if you find one!)
Being unable to find people with similar error messages on the web, I turned to this thread
I was easily able to connect to the mailserver with telnet from outside the container.
What I tried inside the container:
getent hosts mail.example.com
provided the correct IPv6 Adress
But then the errors started turning up:
openssl s_client -connect mail.example.com:587 -starttls smtp
140124593714496:error:0200206E:system library:connect:Connection timed out:../crypto/bio/b_sock2.c:110:
140124593714496:error:2008A067:BIO routines:BIO_connect:connect error:../crypto/bio/b_sock2.c:111:
connect:errno=110
openssl s_client -6 -connect "[correct IPv6]:587" -starttls smtp
139918557709632:error:02002063:system library:connect:Cannot assign requested address:../crypto/bio/b_sock2.c:110:
139918557709632:error:2008A067:BIO routines:BIO_connect:connect error:../crypto/bio/b_sock2.c:111:
connect:errno=99
 openssl s_client -connect smtp.gmail.com:587 -starttls smtp
works just fine
When I try the
from outside the container, It works also fine.
My mailcow/postfix logs show nothing…
I am stumped. Can you help me where to look next?
See Troubleshoot email on a new Discourse install.
The issue is probably that your notification email address is not one that you have configured your mark server to send from.
But that doesn’t explain the “connection timed out” errors. That sounds like some docker network issue.
thank you for your reply. I tried using the same adress in both fields, no change, same error.
Following the Troubleshooting thread:
What do the Discourse logs say?
`Job exception: Cannot assign requested address - connect(2) for [correct IPv6]:587
What do your email provider logs say?
No log entries show up relating to mails sent from discourse.
I then tried this Method https://www.saotn.org/test-smtp-authentication-starttls/ to see if I would be able to authenticate through openssl, and it works fine from the server, but not from inside the container, it produces the error I described in the first post.
How can I find out what is blocking the connection here?
omfg it was so easy.
I just had to activate IPv6 in my Docker network, just the first three steps in this tutorial and it worked.
