Installation fraîche sur Ubuntu. Espace disque manquant
My VPS have 10gb. It’s a fresh 16.04 Ubuntu install. I followed this tutorial : discourse/docs/INSTALL-cloud.md at main · discourse/discourse · GitHub
I got this message after doing the ./discourse-setup command.
You have less than 5GB of free space on the disk where /var/lib/docker is located. You will need more space to continue
Filesystem Size Used Avail Use% Mounted on
/dev/sda1 9.7G 5.1G 4.6G 54% /
I tried the command for cleaning docker images. But I still goot this message. I assume I could upgrade my VPS space. But wow. 10gb is not enough really? .. Is there any other way to solve this?
You also need swap, unless your machine has 4GB or more RAM, and that is typically 2GB of space. You will have a bad time if all you have is 10GB of drive to work with. Even the $5/month Digital Ocean plans offer 25GB of disk space.
Ok then i’ll upgrade!
I am having a similar issue…i am installing Discourse in my local computer with CentOS7 and this is what i am seeing…
Status: Downloaded newer image for discourse/base:2.0.20171231
/dev/sda8 9.1G 6.3G 2.4G 73% /
I do have SWAP partition which was 6GB when i was installing the OS just a few days ago.
Can someone help me with a solution to this. I have not installed anything in this OS and have dedicated 80 GB of my hard disk partition to this OS.
Docker, by default, will store images at /var/lib/docker. Your / partition only have 9GB with only 2.4GB available. This can lead to problems, so we warn you before they happen.
You can:
  • Add more space to the / partition, or
  • Move docker image folder to another partition with more free space.
I am reading online about increasing the size of the partition but it seems risky especially with CentOS. Something to do with the need to comment a partition else the OS will go to emergency mode. I am not that good with commands to know what commenting a partition is so i don’t want to risk damaging the OS…
I ran into this problem with my localhost when setting up a DEV environment in Ubuntu 16.04.
I had to use a fixed drive instead of dynamic, ended up using a 50GB VDI
Update on Missing Space on Disk: Since my hard drive partitions were not LVM, I opted to use GpartedLive on a USB Stick, resized my hard drive after making the stick bootable and rebooted my computer. I only landed on a simple error which needed me to add a colon : in my app.yml file…line 89 which i did and resumed the battle to install this amazing software. All went well for me as it successfully installed. :slight_smile:
