The discussion revolves around a disk space issue during Discourse installation on a VPS. AHI encounters a “less than 5GB free space” error while trying to start the Discourse app, prompting a prompt to clean up Docker images and containers. Despite attempting to skip the prerequisite check, AHI faces an image pull failure, indicating a lack of available disk space. codinghorror suggests upgrading to a larger disk, noting that even a $10/month DigitalOcean droplet offers more space. AHI questions the ease of installation on DigitalOcean compared to OVH. Mittineague shares a solution from a similar issue, while vincent confirms upgrading the VPS resolved the problem. NotAfk compares OVH and DigitalOcean, with vincent confirming he upgraded to a 7€/mo plan. mattburns_uk offers a tip to free space by removing old Linux kernel headers using purge-old-kernel.
> root@vps439337:/var/discourse# ./launcher start app --skip-prereqis
You have less than 5GB of free space on the disk. You will need more space to continue
Would you like to attempt to recover space by cleaning docker images and containers in the system?(y/N)y
WARNING! This will remove:
- all stopped containers
- all volumes not used by at least one container
- all networks not used by at least one container
- all dangling images
Are you sure you want to continue? [y/N]
If the cleanup was successful, you may try again now
root@vps439337:/var/discourse# df -k
Filesystem 1K-blocks Used Available Use% Mounted on
udev 990456 0 990456 0% /dev
tmpfs 199916 3180 196736 2% /run
/dev/vda1 10098468 5266100 4815984 53% /
tmpfs 999560 0 999560 0% /dev/shm
tmpfs 5120 0 5120 0% /run/lock
tmpfs 999560 0 999560 0% /sys/fs/cgroup
tmpfs 199916 0 199916 0% /run/user/0
I have a VPS from OVH(SSD 1), it’s seems like easier to install Discourse at DigitalOcean.
When i skip the error, i have this message, is it normal ? are they sure ton install correctly and fastly Discourse with DigitalOcean cloud server ?
