Front nginx https reverse proxy to discourse http
danchik encountered mixed content warnings on their Discourse instance, where HTTP links were being served over HTTPS via an Nginx reverse proxy. Despite configuring Nginx to forward traffic securely, some resources like images and OpenSearch XML were still loaded via HTTP. The issue was resolved by enabling the force_https setting in the Discourse admin console, as suggested by Falco.
Hello
I have nginx runnig on 443 accepting traffic on https://discourse.example.com and sending it to discourse on that is running on port 8080…
When I connect to https://discourse.example.com the discourse serves welcome page and issues a warning: “Your connection to this site is not fully secured” (and it claims that some links and images on page are mixed) …
I can see all traffic being served via https, and the few http requests that appear get redirected and re-requested on https…
looking at the page source of the served discourse welcome page, I found a few http: // references (where I would expect https: //)
for example: <link rel="apple-touch-icon" type="image/png" href="http://discourse.example.com/images/default-apple-touch-icon.png"...
or: href="http://discourse.example.com/opensearch.xml"…
How does one change so that that it provides everything via https??
this is what my nginx has for 443 port:
location / {
            proxy_pass http://localhost:8080;
            proxy_set_header Host $http_host;
            proxy_http_version 1.1;
            proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
            proxy_set_header X-Forwarded-Proto https;
            proxy_set_header X-Forwarded-Host $host:443;  # added this no help
            proxy_set_header X-Forwarded-Port 443;  # added this no help
            add_header Front-End-Https on;  # added this no help
            proxy_set_header X-Real-IP $remote_addr;  # added this no help
exact error (except with different domain name) is :
SEC7137: [Mixed-Content] The origin 'https://discorurse.example.com' was loaded in a secure context and loaded an optionally blockable insecure image resource at 'http://discourse.example.com/uploads/default/original/1X/a49b3195c893e60f12b7829dd86f40b1790269fb.png'.
Thank you
Check the force_https site setting in the admin console.
Thank you, that looks to have worked.
